Current Versions
   #341
No, I'm fine with the release channel. My only concern was with the BL version discrepancy between what I was told I had and what was shown here
My bad. I've fixed it.
Shaun
Bump for DS 60000055
* New rod and label data
* Support for rod clear function
Also, beta dataset has been updated to DS 60000057
equivalent to VCDS dataset 20180927
   #343
Shaun
Bump for beta CB V0.4438
* Support for new MUX and measuring value types
Shaun
Bump for beta CB V0.4441
* Improvements for aiding with server load balancing
* Tweaks to 'talking to cloud' flag
* Tweaks to VCDS comms
   #345
romad
Prescott, AZ
C?ID=208765
Are the versions listed in Uwe's Post 1 for the general release channel or the Beta channel?
Reason I ask was when I saw that CodeBlock 0.4441 was out I went to update but I was updated to 0.4436, not 0.4441
   #346
Shaun
Check the full changelog below that post, it shows which are beta and release versions.
You can flip your interface onto the Beta channel if you want using VCIConfig, under the Adavanced tab.
romad
Prescott, AZ
C?ID=208765
Ah, OK. Ignore what is in Post 1, and go by what is in Post 3.
Well, after the download started, it was going to take a couple hours so I went to lunch. When I came back it was stalled after only 10% had been downloaded, so I restarted it. Now it is stalled after only 52KB were downloaded. I'm going to give up and try again in a few days.
   #349
Spacewalker
C?ID=159607
Guys
is there anyway to add EOL diagnostic support ??
   #350
Spacewalker
C?ID=159607
for changing coding what can be change
whole coding inc VIN number ,
But when you login EOL you can only display coding for retrofiting / update equipment
   #352
TBAx
C?ID=287144
Diagnostics mode change is already available via the use of makros in labels.
   #355
Shaun
Bump for beta codeblock CB V0.4444
* Support for new UDS addresses
* Improved CAN broadcast support
* Support for additional subgvl
* Fixes for live data hud
Shaun
Bump for beta codeblock CB V0.4451
* Fix for 'Clear all DTCs'
* Fixes for freeze frame data
* Fixes for UDS init and timing with certain modules
   #357
Shaun
Bump for beta codeblock CB V0.4502
* Tweaks for CAN broadcast for MQB/MLBevo
* Fix for some encrypted label redirects
* Fix for version number display
And beta firmware FW V0.256
* Tweaks to event queue processing and TCP comms
New VCIConfig for testing: http://vcds-cloud.com/VCIConfig-2.247.zip
Fix for version display, transferring typo and "checking rods" message that doesn't clear after update is complete
Shaun
Bump for Beta CB V0.4504
* Fix for data logging
* Add more models to diagnostic firewall check
   #359
Shaun
Bump for CB V0.4505 now on release
Cumulative changes since last release:
* Numerous comms improvements and fixes
* Fix for encrypted label redir
   #360
Spacewalker
C?ID=159607
guys, is there any way why my Hexnet today strat give continuously beep .. and red indicators start blinking 1 by 1
it happen when I connect it to OBD
all is ok as far as I know, diagnostic, ...but noise from :facepalm:
19.4 version
