Sticky How to post an Auto-Scan
Sticky
Using the classic, Windows-based VCDS:
Also, please wrap your Auto-Scan data in CODE tags, like this:
[CODE]Chassis Type: 4G0
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 72 82 84 85 8B 8E 8F 90
VIN: WAUBGAFC5CN015352
82-Heads Up Display -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: OK 0000[/CODE]
What that does is put your data into a frame that people can scroll independently, or scroll right past if they don't want to look at the whole thing, like this:
Chassis Type: 4G0
Obscuring your VIN: Personally, I think it's silly to do this. Your VIN is in full view at the base of the windshield to anyone that walks by your car, so I don't have a problem posting VINs of cars we own on the 'net. However, some people don't wish to do that, and if you're one of them, please keep in mind that it's the last few digits that uniquely identify your car, while the first 12 or so tell us what kind of car it is, where it was made, etc. So if you feel it's necessary to obscure your VIN, please do it like this: WAUBGAFC5CN0xxxxx
EDIT/PS: Please post the WHOLE scan, not just the Gateway Installation List portion as shown above.
EDIT/PPS: Please use the ENGLISH version of VCDS to post data in this forum. If you're using a version translated into another language, you can download the English version from this page and it will happily coexist on your PC with whatever translated version you normally use.
And, how to do an Auto-Scan with VCDS-Mobile:
Yes, I know the "Click Here" part of that video doesn't work yet.. ;)
Boki Ar
Arandjelovac, Serbia
C?ID=57300
One more time about [CODE][/CODE] tags.
In the forum's edit box, click this button:
Then a pop-up will appear. Paste your scan data into the pop-up, and click [Continue].
Presto, your data is in CODE tags. ;)
Bilko
Cheshire, England.
C?ID=389547
Here goes...........
Tuesday,25,March,2025,12:32:51:04073
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: WVWZZZ3CZFE803432   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 36 37 42 44 46 4C 4F
          52 53 55 56 61 62 6C 72 77
VIN: WVWZZZ3CZFE803432   Mileage: 52330km-32516miles
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 06J 906 027 DE    HW: 06J 907 309 B
   Component: MED17.5.2        05 5359
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404000C24070160
   Shop #: WSC 05311 000 00001
   VCID: 71BFD2070DA9E412709-8024
   VINID: 9E69EAAAA0D3A965480031030806792C95
012424 - Starter Relay
               P3088 - 000 - Electrical Malfunction - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 6.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 6.096 V
000602 - Fuel Pump Control Module
               P025A - 000 - Electrical Fault - Intermittent
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:33:54
                    Temperature: 7.0°C
                    Temperature: 10.0°C
                    Voltage: 6.096 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:34:01
                    Temperature: 7.0°C
                    Temperature: 10.0°C
                    Voltage: 6.985 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 1.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 10.033 V
   Part No SW: 0AM 300 064     HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5201
   Revision: 00043014    Serial number: CU501405045511
   VCID: 6B83C06F2F850EC24A5-803E
   Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
   Component: J104   C2 450M VD18 0040
   Revision: --H07---    Serial number: 00000008228127
   Coding: 0001914
   VCID: 79AFEA2755D9AC52C89-802C
   Part No SW: 3AA 907 044 BQ    HW: 3AA 907 044 BQ
   Component: Climatronic   H05 0607
   Revision: 00001K02
   Coding: 071401A048
   Shop #: WSC 00015 115 00001
   VCID: 005987C33A83FD9A8F7-8054
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0475
   Revision: BD422001
   Coding: 0008000000000000008C0280B40009642355040865200D20E484462400C1
   VCID: 49CF5AE749B9FCD2189-801C
   Subsystem 1 - Part No SW: 3C8 955 119 J    HW: 3C8 955 119 J
   Component: WWS464 070514  024 0644
   Serial number: 14050507028710
   Coding: 044D9D
   Component: RLFS  024 0042
   Serial number: Y14M06D12H05M24S36S7
   Coding: 0228DD
                    Reset counter: 30
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:33:60
                    Voltage: 6.40 V
                    Reset counter: 30
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:34:57
                        Term 15 Off
                    Voltage: 7.60 V
                    Fault Status: 00101010
                    Reset counter: 29
                    Mileage: 51944 km
                    Date: 2018.12.28.
                    Time: 16:11:42
                    Voltage: 14.55 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28201415602031
   Coding: 308104
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3FDB443F07FD4262B6D-806A
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 23051404850002
   Coding: 010180
   Shop #: WSC 05314 000 00001
   VCID: 270BFC5FFFEDEAA2EED-8072
   Component: J234__70J VW10 HI   2518
   Revision: 28020000    Serial number: 003L7PC2N6V1
   Coding: 0012362
   VCID: 7CA1F3335AEB997AD3F-8028
   Subsystem 1 - Serial number: 6332MTS603431404
   Subsystem 2 - Serial number: 6342MTS602501404
   Subsystem 3 - Serial number: 6351HTS6C7AFVCKR
   Subsystem 4 - Serial number: 6361HTS6K4CBUCKR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 CN    HW: 5K0 953 569 AS
   Revision: FF010042    Serial number: 20140610200290
   Coding: 099A270001
   VCID: 73B3D80F7B35D602825-8026
   Component: E221__MFL-TK6  H07 0022
   Coding: E30000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
                    Reset counter: 30
136194 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Reset counter: 30
617742 - Selector Lever Park Position Lock Switch
          B1162 07 [00001000] - Mechanical Failure
                    Reset counter: 28
                    Mileage: 51989 km
                    Date: 2024.08.21.
                    Time: 14:04:21
   Part No SW: 3C8 920 971 FX    HW: 3C8 920 971 FX
   Component: KOMBI         H04 0905
   Coding: 140F01
   Shop #: WSC 00000 000 99999
   VCID: 08499FE312B3C5DAC77-805C
13635840 - Supply voltage
          [Supply voltage too low]
                    Reset counter: 30
   Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1653
   Revision:   H56       Serial number: 040614F1001437
   Coding: 469007
   VCID: 015F82C73109F492809-8054
                    Reset counter: 29
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:34:59
   Part No SW: 3AA 959 799 E    HW: 3AA 959 799 E
   Component:    IMMO         090 0409
   Revision: 00090000    Serial number: VWZCZ000000000
   VCID: 4ACD65EB40BFF7CA113-801E
01176 - Key
                    Reset counter: 63
                    Mileage: 51946 km
                    Date: 2018.12.31.
                    Time: 09:28:53
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 30
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:33:42
Address 2E: Media Player 3
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3101
   Revision: 00H05000
   Coding: 000039
   Shop #: WSC 40022 666 40022
   VCID: 372B2C1F2F4D7A227ED-8062
   Part No SW: 1T0 035 680 T    HW: 1T0 035 680 T
   Component: RNS-MID       H23 6270
   Revision: AB001001    Serial number: VWZ6Z7P9158023
   Coding: 04000402040000A0000F
   VCID: 3FDB443F077D4262B6D-806A
   Component: EU West V13  8316
                    Reset counter: 29
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:33:36
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0556
   Revision: 12110009    Serial number: 0008687586
   Coding: 0013FF
   Shop #: WSC 05311 115 00001
   VCID: 6D87CE771D1100F2541-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  005 0501
   Serial number: 00000004003095
   Coding: 010098
          B11EC 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 33
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 31
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 207    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F2A2715596C52889-806C
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 09 KESSY PQ47   090 0375
   Coding: 01910A0001C60E76360494157200DFCE10580003042498
   Component: Neigungssensor  004 0611
   Subsystem 4 - Component:       ViP n.mounted
                    Reset counter: 30
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1653
   Coding: 01030108
   VCID: 6FBBD47F179DF2E266D-803A
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 419500022640
   Coding: 000006
   Subsystem 2 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0556
   Revision: 14110009    Serial number: 0008691305
   Coding: 0013FE
   VCID: 6E85C97B1017FBEA6DB-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  005 0501
   Serial number: 00000004016151
   Coding: 010098
                    Reset counter: 30
                    Reset counter: 32
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000082184
   Coding: 0022157
   VCID: 38292F232E53755A777-806C
   Component: AFS-ECU       H04 0111
   Coding: 073600000B000200
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 372B2C1F2FCD7A227ED-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
9574144 - Bulb for Low Beam Headlamp Left
          B1217 00 [00001000] - -
                    Fault Frequency: 21
                    Reset counter: 29
                    Mileage: 51944 km
                    Date: 2024.08.06.
                    Time: 16:11:42
                    Reset counter: 29
                    Mileage: 51992 km
                    Date: 2019.05.23.
                    Time: 15:33:36
   Component: Batt.regelung H56 1653
   Coding: 03260859
   VCID: 71BFD20701A9E412709-8024
   Component: J367-BDM  H07 0180
   Serial number: 41156G12571491292368
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H13000    Serial number: 525PA8-J452000
   Coding: 0020008
   VCID: 678BBC5F336D2AA22ED-8032
                    Reset counter: 30
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Part No SW: 5N0 035 729     HW: 5N0 035 729
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666278482 Dataset Number: 5N0035729   0001
   Coding: 0A01000080010101
   ROD: EV_UHVUMI.rod
End----(Elapsed Time: 02:14, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
------------------------------23 Faults Found-----------
