Sticky Current Versions
Sticky
   #401
rs38
C?ID=519578
Hi Uwe,
I saw a few blockmaps in the forum done by that beta version since a months or so...
Do you have a particular need that isn't addressed by the current Release?
I am evaluating an unsupported car which is very(!) similar to the Audi E-Tron GT 😎
VCDS has obviously implemented many feature to satisfy the customer even if the car is not 100% defined or supported.
I guess it was since 22.3.1 many ECUs now work very nicely for diagnostic value readings.
if there is no ASAM mapping, bad luck of course,
but for some ECU e.g. $5F there is a "I know what I do"-pop up and I can choose similar definition files
and any of the suggested .rod files are working like a charm!
My question or suggestion to your support was already:
Why isn’t it possible to choose for similar .rod files for all ECUs may be limited to read-only functions?
e.g. Gateway $19, great source of diagnostic data.
My car has ASAM def: EV_Gatew31xPO513
VCDS has:
EV_Gatew31xAU65x_AU49.rod, EV_Gatew31xAU65x_AU58.rod
EV_Gatew31xAU65x_BY63.rod ,EV_Gatew31xAU65x_LB63.rod
EV_Gatew31xAU65x_VW53.rod
May be I want to try one of these like in $5F? The chances are very high that most of the measurement values work fine.
I am pretty sure, I do not understand all your mapping logic and safety concerns, but long story short: I am hoping for some chances to see some closer definitions/mappings in a beta.
   #402
Please be patient. I expect there will be a 22.5 or newer version available fairly soon.
However, I make no promises of better support for your "unsupported car". ;)
Right, and adding to that you could try the Chassis override Auto-Scan procedure that pre-dated Pick-a-ROD. Open MyAutoScan.txt and add experimental ** lines such as:
; This file has the same format as the main AutoScan.txt file,
; but it's intended to contain custom entries for your own car(s)
; that will be displayed before the standard models in the selection
; box on the Auto-Scan screen.
; Chassis Code (max 3 characters),
; Description  (max 15 characters),
; Comma-separated list of addresses (max 125 addresses)
; Maximum 250 chassis types (total of both files)
; Example:
01,My BENCH,01,02,08,17,19,25,45
**,VW37,00
**,VW41,00
**,VW46,00
**,AU37,00
**,AU72,00
; Remove the semi-colon from the above line to see how it works.
; ... or add your own using that format
Those exact choices aren't ideal for you but that's a file on my PC. I would try using AU58 (and/or AU65 if you want to get real creative) based on a 2022 Audi e-tron GT scan I'm looking at that used:
Chassis Type: FW-AU58 (4KL)​
Address 17: Instruments (J285) Labels:* None-SRI2​
Part No SW: 4J3 920 795 HW: 4J3 920 795​
Component: FHybRDW------ H25 0087​
ASAM Dataset: EV_DashBoardAU65X 002025​
ROD: EV_DashBoardAU65X_002_AU58.rod
VCID: 71B4BE8E815B61A3606-8124​
Address 19: CAN Gateway (J533) Labels:* None​
Part No SW: 4KL 907 468 D HW: 4K1 907 468 C​
Component: Gateway H07 0603​
ASAM Dataset: EV_Gatew31xAU65x 003220​
ROD: EV_Gatew31xAU65x_AU58.rod
Selecting your new chassis type from the drop-down prior to the next Auto-Scan followed by double clicking into each module from the finished scan results may result in additional RODs loading but consider that experimental at best!
   #404
rs38
C?ID=519578
thanks for your suggestion, but it did not help.
   #405
Shaun
Bump for new beta versions:
CB V0.4622
* Fix for comms with certain CAN gateways
* Improvements for golf8 comms
HN2- FW V1.71
* DoIP support for golf8 platform
   #406
Liteace1
Spain
C?ID=90243
CB V0.4622
HN2- FW V1.71
whats the doip situation ?
   #407
WebCF
C?ID=166818
If I remeber right: The current HW generation is capable of this but DoIP is not yet required
Yes, the current HEX-NET generation supports DoIP. That means HEX-NETs with serial numbers starting with 'HN2-', which are also visually obvious because the shells are blue rather than black.
HEX-V2 interfaces do not support DoIP.
Correct. No VAG car currently in production requires DoIP for diagnostics.
Shaun
Bump for new versions on release channel:
CB V0.4623
* Comms improvements with certain newer platforms
HN2 FW V1.71
HN1 FW V0.257
* Fix for max data length
   #410
romad
Prescott, AZ
C?ID=208765
Have you stopped sending out notices when new versions are released? I just realized I haven't seen any emails from you for weeks if not months so I came here to check. I see there was an update released 10 days ago but I still haven't received an email.
   #411
We've never done that.
Well, way back in the early days, there was a Yahoo e-mail list/group called "VAG-COM Announce" where new versions were posted that one could subscribe to, but those Yahoo e-mail groups were deprecated by Yahoo itself many moons ago.
Besides, VCDS itself will tell you when there's a new version available -- assuming of course that it has internet access when you start it.
romad
Prescott, AZ
C?ID=208765
Hmmm, then I wonder where I remember seeing such notices. I thought it was via the email notifications of new posts to this thread that I have set in my preferences. Oh, well but thanks for the reply.
   #413
Hi @romad, I remember having a similar question to Uwe in the past:
make sure on the VCDS page click Options > "user interface and identification" (tab on top right) click >
then "check for free updates" heading and select from pull down menu "Releases and Batas"
then save and restart VCDS.
Also...... if , like myself, you place your PC in "hibernate" or "sleep" mode , you won't get VCDS update (small vcds pop up window asking if you wish to update now) notices when the PC starts back up ; you have to Restart your PC occasionally and then I have observed the VCDS notice to Update! Just some observations.......
romad
Prescott, AZ
C?ID=208765
Thank you, Stefan. However, I don't have VCDS rather I have a Hex-Net. Since I use MacOS, and Ross-Tech never made a Mac version of VCDS, I'm dependent on this thread for update info. If it wasn't for the exorbitant price for Windows 7, I'd put it on my MacBook Air under Boot Camp then get a copy of VCDS to use on it without having WiFi available.
   #415
romad
Prescott, AZ
C?ID=208765
Doesn't the current version of Parallels come with a Windows license?
I don't know. However, I've been told you don't support using VCDS in a virtual machine so I haven't looked at Parallels. The question then is if I buy a copy of it, could I legally use the possible license to install Windows under Boot Camp on my MacBook Air. If so, then the MBA would be a PC with no virtualization problems. It is something to look at, though.
Edit. OK, I just checked it out. Parallels will automatically download and install a copy of Windows 11, BUT you still have to go to the Microsoft Store and buy the full license. However, because my MBA is a mid-2011, it doesn't meet the Win 11 minimum system requirements as far as I can tell.
Edit 2. I'm told that the versions that will work under Boot Camp on my MBA are either Windows 7 or Windows 8.1.
Shaun
Bump for release CB V0.4630
* Fix for certain measuring values
* Comms fixes for certain platforms
* Support for additional feature codes
   #419
JMR
Romania
C?ID=432218
mine too
Shaun
Bump for CB V0.4631
* Fixes for feature code handling with certain interfaces
* Improvements for comms with wifi and with certain newer platforms
