Current Versions
   #301
Spacewalker
Poland
C?ID=159607
Another question
checking VCDS app on android
this is Autoscan from gateway made on the bench with HexNet
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 140814F1000386
Coding: 358032
Shop #: WSC 21862 418 42054
VCID: 7BB61242FA4C0F9EDF-802E
and Advanced ID
Sunday,17,September,2017,21:19:45:43375
VCDS Version: Release 17.8.0
Control Module Part Number: 7N0 907 530 BL
Component and/or Version: J533 Gateway H56 1682
Software Coding: 358032
Work Shop Code: WSC 21862
Advanced Identification
Identification: SJ8-FST
Revision: H56
Date: 14.08.14
Manufacturer number: 00F1
Test stand number: 0386
Flash Status
Programming Attempts(application): 10
Successful Attempts(application): 10
Programming Attempts(data): 17
Successful Attempts(data): 9
Programming Status: 00000000
Flash Date: 2049.14.02
Flash Tool Code: 42054 418 21862
Flash Tool Code(data): 12345 123 12345
Misc.
Hardware number: 7N0 907 530 AN
Workshop System Name: J533
Equipment/PR Code: 0004B0906D716372
Dataset Number: 7N0067v____
Dataset Version: 0065
End of Line Equipment Level: --------------------
VCDS Info:
Labels: 7N0-907-530-V2.clb
VCDS app show this
   #302
Looks to me like something in VCDS-Mobile didn't get cleared from the last module you looked at?
Spacewalker
Poland
C?ID=159607
for me it show completly different device .
HW 8K0 959 655 is Aribag module
also s.n
I only connect GW on the bench , no other module
   #304
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Known bug. FS#553
   #305
Spacewalker
Poland
C?ID=159607
here is scan of cluster I was talked last time, scan did via HexCan
Adres 17: Zest.wskaźników (J285)       Plik etykiet: 5K0-920-xxx-17.clb
   Oznaczenie elementu SW: 7N0 920 880 L    HW: 7N5 920 880 A
   Komponent: KOMBI         H04 1104
   Numer seryjny: 00000000000000
   Kodowanie: 111F010000
   Kod serwisu: WSC 85046 004 02308
   Zbiór danych ASAM: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 3C77D538B7A5D5A1F5-8068
also screen from AKP version
   #306
Shaun
Bump for CB V0.4407
* Updated UDS address list
* Fix for certain rare comms issues
* Support for release channel switching
   #307
badgerden
C?ID=248910
Well pardon me for having a Mac, but I need help with the Hex Net Config Utility. Mac is Sierra version 10.12.6 (16G1036). Java is Version 8 update 151. I've tried getting the zip files from this thread (2.014 and 1.963). Both HexNetConfigV*'s here uncompress to V1.959. I've searched everywhere in my user directory and deleted everything that says HexNetConfig, even in something called a Saved Application State directory. So I think I've made sure its not user error.
When I run the utility, I see current data: CB = 0.4407, FW = 0.254, CFB = 0.10, BL = 0.28, and DS = 10000048.
The utility announces an update to DS = 0000050. It gets to a point that says "Getting Block 4". After a couple of minutes, it bails with "Error Code -11".
My dealership erased my changes and I want them back, but I wanted to update the plug in box before doing that. I assume you can get my device serial number?
I have the pid error log, it says the error was outside Java in native code if you want it.
Any ideas?
Thanks,
GB
Shaun
To update the dataset, the utility will mount the HEX-NET as a usb mass storage drive. Error code -11 is an error with this process. You need to be sure that your HEX-NET is able to be mounted as a drive, you might have a window for example asking you what to do with a new drive you need to click, or you might have some other program that is trying to grab it. Make sure it's not trying to open with iphoto, for example. If you are running in a virtual machine or similar type setup, you might need to make sure the interface is configured to reattach to the right machine. Do you have any anti-virus software running?
badgerden
C?ID=248910
So that explains why i get the "disk not ejected properly" error when JarRscrLoader cores out. i finally got the update completed earlier today by just closing the dialogue box about allowing writes to the hex net instead of clicking "ok". thank you for looking at it for me. While I have your attention, I need to ask about the equipment number field displayed in vcds mobile. I tried to recover the changes my dealer took away but vcds mobile reports the number is out of range (by an order of magnitude). I found a thread on this that says to just type in a "legal" value. Does that work and if it does, why is it error-checked? Is the new value actually written to the MMI?
Thank you,
GB
   #310
Any random 5 digit number will work for "Equipment Number" if/when that's required.
badgerden
C?ID=248910
Thank you Benevolent Dictator
   #312
Shaun
Bump for CB V0.4409
* Fix for data loading/rod redirect issues
* Fix for UDS mv drops with grouped requests + turbo mode
* Fix for Immo3 extra info parsing
hans j
Utah
C?ID=60436
Mine keeps telling my I'm not up to date, but the updating software says I am up to date. I've been having to use older versions to make it work.
VCDS 17.12 says I'm at:
CB 0.4409.4
FW 0.254
WiFi 310C
and says firmware update required.
Firmware software says:
CB 0.4409
FW 0.254
CFB 0.10
BL 0.28
DS 00000050
   #314
You'll need to flip your interface onto the Beta update channel using VCIConfig, as described on the Beta Page in the Release Notes section:
If you are using a HEX-NET or HEX-V2 interface, you must set the update channel for your interface to "Beta" and update it before you can use this version of VCDS.
Shaun
You need to switch your interface to the beta channel to get the latest testing firmware that goes with the beta version of VCDS.
In VCIConfig, go to [Advanced] -> Update channel [Beta] -> [Change Channel]
Then check for updates again.
EDIT: As Uwe showed above, with the picture.
   #317
Shaun
Bump for CB V0.4411
* Support for configurable CharInt from VCDS
* Test fix for comms with certain CAN modules
   #318
Gary
C?ID=30906
Channel set
Bump for CB V0.4411
I have your Beta version of VCDS on my desktop and also the release, should I set the channel for the HexNet to beta in the beta version only, or do I also set the beta channel in the release version?
   #319
It doesn't matter which one you use. That setting tells the server which channel you're on; it's not a local setting.
BTW, since we now have a Release 18.1.0, Beta 17.12 is deprecated. :thanks:
romad
Prescott, AZ
C?ID=208765
I just updated my Hex-Net but all I see on the "About" is this:
CodeBlock V0.4411
FW version: 0.254
Dataset: 00000050
No CFB or BL
No 10000050 dataset
But I'm told that my Hex-Net is up to date. Where do I find the CFB & BL info?
I'm viewing this via my Firefox 52ESR web browser on my iMac
