Resolved Passat B8 early 2015, Retrofitting A5 front camera + DLA + Lane assist- Finished
Resolved
downtime
Finland
C?ID=280813
Why they don’t want to calibrate? Official workshop have all the means and training to do it. Just tell them that the camera just lost it’s calibration, don’t tell them it’s retrofitted. They think it’s jinxed after you tell them :)
It should be possible to do by yourself by having a print shop print you the board in right size. Then position it correctly and run calibration.
Doing it with VCDS, maybe not. Using ODIS, yes deflnitely.
   #62
rhinopower
C?ID=58979
I'd love to!!! I'll search for a B'nB and I come soon:p
I hope it's just a question of time to put this board at the right place... and run VCDS A5 basic setting.
Because it is from a different car, the vin in the camera wont match the car. It is done with ODIS and GFF. Car has to be in the correct position in relation to the calibration screen. Measurements are entered for each wheel arch to the floor, and input as you go along. Once ODIS is happy you have calibrated correctly the VIN is updated and everything fixed
   #63
Gentlemen, I really can't condone discussion of cloned/pirated products here, not even ODIS.
sam1754
France
C?ID=324989
I understand but I don't know ODIS, I thought VCDS could provide full access to VAG car. As ODIS seems to be unbuyable, I'm really asking how I'll manage to calibrate the camera???:banghead:
Yoda said "No clone here!" young Padawan... so how will the force be with me to calibrate the camera?:rolleyes:
sam1754
France
C?ID=324989
   #66
Livefour2day
C?ID=32736
If you can get to the UK I highly recommend rhinopower who can sort all of your calibration out he did mine it works perfectly.
sam1754
France
C?ID=324989
If I could, sure I will!!! Now it's no longer a question of money. A society can do it for 550€ (both ACC and camera) with a complete support, not the vehicule on the ground. But it's about four hours driving to get there... hmmmm
   #68
siLc
Tallinn, Estonia
C?ID=330192
550€? That is a realllly steep price...and with a long drive? Where in France are you, if I may ask?
   #69
downtime
Finland
C?ID=280813
It’s expensive. In Finland (and we are very expensive country) it’s 300€ for camera and acc both and they do full wheel alignment.
sam1754
France
C?ID=324989
Oh it's not a secret:D! I live near Luxemburg. The society who can do calibration is in Auxerre. I agree with you, it's expensive.
   #71
symb
Finland
C?ID=354278
I have now wires coming from the windscreen through the roof and dash board. T17 9 and 11 pin's and ground are connected. I'll connect t20 pin's to can gateway this weekend. I would lije to connect + to the sc36 or 37 fuse but I don't manage to reach the hole behind the fuse board. How did you do it?
And please Symb, how did you pull out this evil's double clip on A column? I do as you said and it came, no problem... but now I want to replace the column...
Many thanks for the answers.
PS: I'll post some good photos to complete this great tutorial;)
I dismantled the clip and assembled it back to the trim piece so I could just plug it back in.
Yes yes, single connector works just fine. I thought you were going to use piggyback fuse :)
And I disagree on the can module �� Maybe I’m getting old but unplugging and dismantling the connector, soldering wires to the existing wires and all this laying on your back in inhuman position, soldering in a very tight and dark place �� No thank you anymore. Done that enough ��
Anyway, we are maybe diverting from the topic a bit.
Aww, come on now, it wasn't THAT bad. :cool:
So, I just have to plug ACC sensor. I made a fuse connector to test it now.
Here is the scan after enabling A5 in Can gateway 19.
[Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654     HW: 3Q0 980 654
  Component and/or Version: MQB_B_MFK     H04 0010
           Software Coding: 0004080204000401002200448050A10084000E200040
            Work Shop Code: WSC 00015 115 08193
              ASAM Dataset: EV_MFKBoschMQBB 001001 (VW48)
                      VCID: 74B121E99E3F2AB7DE9-8020
0768 - No Basic Setting
          B2010 00 [009] - -
          [Calibration_VIN_mismatch]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:15
                    Control Module temperature: 31 °C
                    Outside air temperature: 28.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 2.7 s
                    Voltage terminal 15: 11.7 V
                    mid: 00 51
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:15
                    mid: 00 28
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
1122675 - Databus
          [TIMEOUT_LWR_AFS_02]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:14
                    System run time: 1.1 s
                    Voltage terminal 15: 11.2 V
                    mid: 01 E7
                    Status of camera: Initializing
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
1122597 - Local Data Bus
          U1169 00 [009] - Missing Message
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:14
                    mid: 01 41
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:16
                    System run time: 3.3 s
                    mid: 02 A0
                    Status of camera: System malfunction
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
Remember that when calibrating:
B2010 00 [009] - -
This is the only allowed active fault at the A5 module.
   #72
symb
Finland
C?ID=354278
Any luck with your calibration? Did you change the windscreen or do you have some DIY solution for the camera?
I partially understand the dealer's POV if latter.
   #73
sam1754
France
C?ID=324989
The new windscreen is ordered and the local bodybuilder will do the job.
For calibration, I'll do it in my garage... it'll take a long long time with many head scratchings!:rolleyes: VW Luxemburg also didn't want to calibrate camera... "What a wonderful world":facepalm:
   #74
sam1754
France
C?ID=324989
The target is printed on Tivek to be re-usable. A friend made a target with solidworks at 1:1 scale to avoid any precision trouble. It cost 90€ but it's a real professionnal work.
   #75
sam1754
France
C?ID=324989
Anybody can tell me how to do with VCDS? I looked at "basic settings" for A5 module and saw "searching target", I think it's the first thing to do but after that???
   #76
downtime
Finland
C?ID=280813
I’m pretty much 100% sure you can’t :(
   #77
sam1754
France
C?ID=324989
All over the net I found this on every systems (VCDS, ODIS, OBD11...)
A5 controller
security access 20103
Basic settings
1. search target
2. initial online calibration
3. static calibration (customer service)
4. static calibration ( end of assembly line mode)
I'll try this when I'll have time but as NTech said "No idea, but if that should be an problem for VCDS, I guess it would also be a problem for odis. "
   #78
NEtech
Denmark
C?ID=56995
Post your current Autoscan and Controller Channel map here.
Have you been online on erwin, for procedure ?
downtime
Finland
C?ID=280813
VCDS and ODIS work a bit differently here. For ODIS this is no problem with GFF (guided fault finding). VCDS does not have this kind of automated functionality which means you need to know the exact procedure and in exact order to have it done. And even that is not 100% sure it will be successful.
Remember that ODIS is a dealer workshop tool, VCDS is for us hobbyists.
sam1754
France
C?ID=324989
Hello NETech, my current autoscan is on page 6.
A5 controller channel map:
;SW:3Q0-980-654   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H04 0010, Coding:000408020000040100061344C050A10094000E200020
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
;Monday,07,October,2019,17:58:06:16465
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 74B121E99E3F2AB7DDF-8020
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
IDE04733-Road sign detection fusion mode,Road sign fusion ,1
IDE07358-Distance to calibration field,1500 mm,2
IDE07596-Personalization of lane dept. warning Cl. 15 on,Last setting ,1
IDE09375-IDE05717-Axle offset-Front axle transverse position,2.80001 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,0.400006 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,719 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,719 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,719 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,719 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2400 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,745 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1530 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2400 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-745 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1530 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2400 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,745 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,870 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2400 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-745 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,870 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Early ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10871-System mode: lane depart. warn:,Steering wheel vibration not active ,1
IDE10872-Warning intensity: lane depart. warning,Medium ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.320 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,-0.069 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.533 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,1336 mm,8
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
ENG120319-Mask_error_reactions_for_development,not activated ,1
ENG107577-Masked_fault_classes-,255 ,4
ENG130777-standstill_mode,not activated ,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
ENG130779-Xcp_interface,not activated ,1
Elapsed Time: 00:08
Even with security access code, it returns an error message when I try to enter real values for body heights...
What do you mean about Erwin? Procedure has been done by an other French guy ( same procedure) with OBD11 and it wasn't so hard to do!!! What's wrong with VCDS? For Hobbyists ok but it's not the cheapest tool!!! I hope and I think it can work!
