Passat B8 early 2015, Retrofitting A5 front camera + DLA + Lane assist- Finished
   #81
sam1754
France
C?ID=324989
After erasing all DCTS, I managed to put right wheels edge body heights. But it didn't allow me to do it for camera height. It was at 1338 and I wanted to put it at 1318 but it said "request out of range"??? Why? Perhaps it's an automatic value which is calculated by controller as it run basic setting???
   #82
downtime
Finland
C?ID=280813
Ahaa, sorry for not noticing that. Only error you can have at the camera is "no or incorrect basic setting", otherwise the calibration routine will not go.
I thought you had read about that already.
I think camera height is automatic based on the car model. At least that was not measured in the official calibration procedure.
Found instructions on the other forum on how to do the calibration with VCDS :
"I did it with VCDS: Clear fault, Login 20103, Distance to board 1500 mm, height front left, front Right, rear right, rear left, basic settings, clear fault twice"
   #83
sam1754
France
C?ID=324989
As I changed the windscreen, fault came back. I didn't notice it at that time but I knew the need to clear fault codes.
So, as you and some other users let me ear it's probably sure VCDS won't work, I was really not optimistic:o
Where did you find this, please?
downtime
Finland
C?ID=280813
It still isn't 100% it will work :)
VCP forum. You need to own the tool to be able to register. Closed forum.
   #85
NEtech
Denmark
C?ID=56995
Here is some information for one of the calibration procedures (Fast) for [A5-Frt Sens. Drv. Assist]
Part No SW: 3Q0 980 654
ASAM Dataset: EV_MFKBoschMQBB
Information:
  1. Calibration setup VAS 6430 is installed together with Wheel alignment tool, as described in erwin!
  2. Distance from front wheel center to calibration board is 1500 mm ±25 mm
  3. Height for calibration board I don't know, it is shown for the car in Wheel alignment tool!
  4. Charger connected > Doors must be closed > Maybe hood closed (not mentioned in erwin)
  5. No persons in the car > Min. 50% fuel in the tank > No light reflections in the room
  6. Move front wheels to straight-ahead position.
  7. Select calibration run for front camera for driver assist systems (R242) on wheel alignment computer.
  8. Mount quick-release clamps on all four wheels.
  9. Mount wheel alignment sensors on wheels.
  10. Carry out wheel run-out compensation at rear wheels.
  11. Bounce springs.
  12. Measure standing height from floor to wheel house edge, on all four wheels and note it.
Copy this file to:
C:\Ross-Tech\VCDS\Labels\User
Use latest VCDS 19.6.2
2) (Maybe not necessary for it to succeed)
Ignition ON > Start/Stop deactivated
Go to VCDS start screen
[Applications]
[Controller Channel Map]
Single Controller Address: A5
Login or security access code: S11111
Function: "Measuring values"
Please post data from map logfile here.
[Select]
Access [A5-Frt Sens. Drv. Assist]
[Fault Codes - 02]
3)
[Select]
[Fault Codes - 02]
[Clear Codes - 05]
[Security Access - 16] > Enter shown code (20103)
[Adaptation - 10]
 IDE09376-IDE02001 Body height wheel house edge-Body height left front  wheel house edge  > Enter value written down > [Do It!]
IDE09376-IDE02002 Body height wheel house edge-Body height right front wheel house edge > Enter value written down > [Do It!]
IDE09376-IDE02003 Body height wheel house edge-Body height left rear  wheel house edge   > Enter value written down > [Do It!]
IDE09376-IDE02004 Body height wheel house edge-Body height right rear wheel house edge  > Enter value written down > [Do It!]
IDE07358-Distance to calibration field > Enter 1500 > [Do It!]
4)
[Basic Settings - 04]
IDE03343-ENG114972-Static calibration (customer service)
[Show Measuring Data]
Search and mark: IDE10403 / IDE10924 (if available)
[Go!]
Value is showing: "Running"
Wait for: "Not Running"
[Stop]
[Done, Go Back]
[Applications]
[Erase All DTCs]
   #86
sam1754
France
C?ID=324989
So, All physical adjustements are OK, controlled many, many times with me and my son. All is correct. Target is really accurate 0.1mm right!
All is done with laser leveler and I verified with VW rear and front emblems, camera, fm antenna alignement and all is ok...
When I ran "search target" without target, it said "running" and right after "unknown".
Now, with target on the wall, it says first "running" and after a second "not running"... and nothing else. The only thing I can do is clicking "STOP".
:banghead:
I did all you wrote above and as I click IDE03343-Camera calibration [x], it says "ERROR: Request Sequence Error ???
Here is the Channel map from A5 controller:
;SW:3Q0-980-654   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist --- SA: S00048
;Component:MQB_B_MFK     H04 0010, Coding:000408020000040100061344C050A10094000E200020
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
;Wednesday,09,October,2019,10:47:37:16465
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 74B121E99E3F2AB7DDF-8020
Group,Description,Actual
IDE00018,Voltage terminal 15,11.2, V
IDE00102,Control Module temperature,27, °C
IDE00323,Security Access: Number of invalid keys,3,
IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
IDE00326,Steering wheel angle,3.9, °
IDE00767,No. of unscheduled ECU resets,4,
IDE00925-MAS02471,Yaw rate-Sign,Positive,
IDE00925,Yaw rate,0.00, °/s
IDE00973,Outside air temperature,14.5, °C
IDE01968,Dynamic calibration: yaw angle offset,0.000, °
IDE01969,Dynamic calibration: pitch angle offset,0.000, °
IDE01970,Dynamic calibration: roll angle offset,0.000, °
IDE01971,Lowest recorded control module temperature,-9, °C
IDE01972,Highest recorded control module temperature,70, °C
IDE02057,Dynamic calibration: status,Passive: no values stored,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,not activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Clear view,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,Calibration not yet performed,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,0, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,255,
IDE04125,Visibility,Not Used,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09433-MAS01632,Perception module for light assistant-Status,ERROR,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,unknown Object_1_distance,
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,unknown Object_2_distance,
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,unknown Object_1_horizontal_angle,
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,unknown Object_2_horizontal_angle,
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,unknown Object_1_vertical_angle,
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,unknown Object_2_vertical_angle,
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,unknown Object_1_horizontal_expansion,
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,unknown Object_2_horizontal_expansion,
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,Not available,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,Not available,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,unknown Object_1_horizontal_quality_left,
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,unknown Object_2_horizontal_quality_left,
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,unknown Object_1_horizontal_quality_right,
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,unknown Object_2_horizontal_quality_right,
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,unknown Object_1_vertical_quality,
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,unknown Object_2_vertical_quality,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Restricted view,
IDE09436,Recognized street illumination,Not available,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration not OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,-0.069, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.533, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.320, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1336, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,ERROR,
IDE10664-MAS00106,Current initial calibration: details-Year,2019,
IDE10664-MAS00107,Current initial calibration: details-Month,10,
IDE10664-MAS00108,Current initial calibration: details-Day,9,
IDE10664-MAS00109,Current initial calibration: details-Hours,10,
IDE10664-MAS00110,Current initial calibration: details-Minutes,36,
IDE10664-MAS00111,Current initial calibration: details-Seconds,36,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,43955,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,-----------------,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1386,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,644,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,353,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE11956,Boot manager version,31 12 30 01,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,9,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,48,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,21,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,119,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,43955, km
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,Yes,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,System malfunction,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,ERROR,
Elapsed Time: 01:16
   #87
NEtech
Denmark
C?ID=56995
Where do you see this in my information #85 ?
Please test as I wrote.
All over the net I found this on every systems (VCDS, ODIS, OBD11...)
A5 controller
security access 20103
Basic settings
1. search target
2. initial online calibration
3. static calibration (customer service)
4. static calibration ( end of assembly line mode)
Please show the link for this.
SA: S00048
It does not look like you wrote the SA, as I wrote S11111 ..
Have you copied the CLB file to ...\User ?
   #88
sam1754
France
C?ID=324989
Ok, I went further...
I copied the CLB file saw your message when choosing camera calibration but IDE 10403 don't show any new information, just static calibration not done...
For S11111, it said "S11111 is invalid, key must be 5 numeric digits 00000-99999"???
For procedure, you're probably right, it should be done like you said for cameras already mounted on the car or for all??? I don't know, I saw this procedure on an non official russian ODIS forum, so I won't put the link here but as I said, here is a video made by a french guy on OBD11, 100% legal:https://www.youtube.com/watch?v=jPdpQWVCZN4&t=728s
And now, after doing the right procedure described in your post, it almost worked .
When I chose calibration, it runs then say "unknown" and "not running"...
And here is a copy of fault codes after that (I think there's a trouble with physical installation or parameters???):
 Address A5: Frt Sens. Drv. Assist       Labels: User\3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654     HW: 3Q0 980 654
  Component and/or Version: MQB_B_MFK     H04 0010
           Software Coding: 000408020000040100061344C050A10094000E200020
            Work Shop Code: WSC 00015 115 08193
              ASAM Dataset: EV_MFKBoschMQBB 001001 (VW48)
0663 - Control Module For Camera
          C110A 76 [008] - Wrong mounting position
          [Initial_calibration_out_of_range]
                    Reset counter: 119
                    Mileage: 43955 km
                    Date: 2019.10.09
                    Time: 13:17:07
                    Control Module temperature: 30 °C
                    Outside air temperature: 16.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 735.6 s
                    Voltage terminal 15: 11.2 V
                    mid: 00 1C
                    Status of camera: Calibration
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0660 - No Basic Setting
          B2010 00 [009] - -
          [Initial_calibration_missing]
                    Reset counter: 119
                    Mileage: 43955 km
                    Date: 2019.10.09
                    Time: 13:16:19
                    Control Module temperature: 29 °C
                    System run time: 688.1 s
                    mid: 00 1E
                    Status of camera: System malfunction
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
Address A5: DTCs cleared
And after that, I came back to adaptation:
At first installation, I saw camera height 1338 mm under adaptation menu, I put the target at this height... but it was for the original alltrack passat on which the camera was mounted.
After changing wheel housing heigts, camera height has been updated to 1317 mm. I have to move target and retry.... HOPE HOPE HOPE!!!
Many thanks for helping me!
sam1754
France
C?ID=324989
Target moved but I have the "ERROR: Request Sequence Error" message again. And when I go to adaptation menu, the procedure is rejected!!!
My confidence in VCDS becomes of pluis in smaller. It was THE great on board system when I started in the early 2000's but now, it seems to be as windows 98!
I hope I'll manage to calibrate the camera with VCDS but I'll order an OBD11 to test it even I think it's not as rich as VCDS.
NEtech
Denmark
C?ID=56995
Sorry I forgot something in the CLB file, please download and copy the same (it is updated).
I have difficulty to understand what and when you are doing something, it would be better if you made screenshots and posted.
I have not seen every second of the video, but i don't think there is anything shown about partnumber or ASAM data.
And that is another procedure/calibration he is showing.
   #91
sam1754
France
C?ID=324989
I waited a long long time after enterting s11111 but it still not accept security access...
And some times it works, some times not???
And screen calibration is as good as it should be at VW dealer.
"Error 37 Time Delay not expired"
Put a charger on this car and leave the ignition on. Then wait until:
IDE00323 -- Security Access: Number of invalid keys
goes to zero.
sam1754
France
C?ID=324989
I did what you said ( error 37 time delay expired) and retryed calibration process and it always return the same fault code: C110A 76 [008] - Wrong mounting position [Initial_calibration_out_of_range]
I don't understand what's wrong??? It doesn't seem to be a procedure trouble???
   #94
NEtech
Denmark
C?ID=56995
I think you have to write every step you do.
I have doubts this is going to work.
You have copied the new clb file to users?
Don't use S11111 direct in [A5], it is only used in step 2)
   #95
sam1754
France
C?ID=324989
1)
Copy this file to:
I did it with the new file but I don't know what it's for? Can you explain it to me please?
[Applications]
[Select]
[Fault Codes - 02]
DONE and it worked as it was supposed to do this time.
;SW:3Q0-980-654   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist --- SA: S11111
;Wednesday,09,October,2019,18:06:36:16465
IDE00018,Voltage terminal 15,12.8, V
IDE00326-MAS02471,Steering wheel angle-Sign,Positive,
IDE00326,Steering wheel angle,8.2, °
IDE00925-MAS02471,Yaw rate-Sign,Negative,
IDE00925,Yaw rate,0.03, °/s
IDE00973,Outside air temperature,17.0, °C
IDE04312-MAS00084,System run time-Terminal 15 on,247.7, s
IDE09441,Traffic sign 1,0,
IDE09442,Traffic sign 2,0,
IDE09443,Traffic sign 3,0,
IDE09444,Traffic sign 4,0,
IDE09445,Traffic sign 5,0,
IDE09446,Additional signs 1,0,
IDE09447,Additional signs 2,0,
IDE09448,Additional signs 3,0,
IDE09449,Additional signs 4,0,
IDE09450,Additional signs 5,0,
IDE10396-ENG130851,Vehicle moving on its own-Pitch_rate,0.01, °/s
IDE10396-ENG130850,Vehicle moving on its own-Roll_rate,0.00, °/s
IDE10396-ENG119266,Vehicle moving on its own-Yaw_rate,0.00, °/s
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,-0.515, °
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,-3.481, °
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.591, °
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1317, mm
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,Installation position incorrect,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,Installation position incorrect,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Installation position incorrect,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Installation position incorrect,
IDE10664-MAS00109,Current initial calibration: details-Hours,17,
IDE10664-MAS00110,Current initial calibration: details-Minutes,26,
IDE10664-MAS00111,Current initial calibration: details-Seconds,10,
IDE10664-MAS01632,Current initial calibration: details-Status,Installation position incorrect,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,7,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,18,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,121,
ENG130806-ENG130856,Blindness_Matrix-Blindness_Matrix_1_1,7,
ENG130806-ENG130857,Blindness_Matrix-Blindness_Matrix_1_2,7,
ENG130806-ENG130858,Blindness_Matrix-Blindness_Matrix_1_3,7,
ENG130806-ENG130859,Blindness_Matrix-Blindness_Matrix_1_4,7,
ENG130806-ENG130860,Blindness_Matrix-Blindness_Matrix_1_5,7,
ENG130806-ENG130861,Blindness_Matrix-Blindness_Matrix_2_1,7,
ENG130806-ENG130862,Blindness_Matrix-Blindness_Matrix_2_2,7,
ENG130806-ENG130863,Blindness_Matrix-Blindness_Matrix_2_3,7,
ENG130806-ENG130864,Blindness_Matrix-Blindness_Matrix_2_4,7,
ENG130806-ENG130865,Blindness_Matrix-Blindness_Matrix_2_5,7,
ENG130806-ENG130866,Blindness_Matrix-Blindness_Matrix_3_1,7,
ENG130806-ENG130867,Blindness_Matrix-Blindness_Matrix_3_2,7,
ENG130806-ENG130868,Blindness_Matrix-Blindness_Matrix_3_3,7,
ENG130806-ENG130869,Blindness_Matrix-Blindness_Matrix_3_4,7,
ENG130806-ENG130870,Blindness_Matrix-Blindness_Matrix_3_5,7,
ENG130806-ENG130871,Blindness_Matrix-Blindness_Matrix_4_1,7,
ENG130806-ENG130872,Blindness_Matrix-Blindness_Matrix_4_2,7,
ENG130806-ENG130873,Blindness_Matrix-Blindness_Matrix_4_3,7,
ENG130806-ENG130874,Blindness_Matrix-Blindness_Matrix_4_4,7,
ENG130806-ENG130875,Blindness_Matrix-Blindness_Matrix_4_5,7,
ENG130806-ENG130876,Blindness_Matrix-Blindness_Matrix_5_1,7,
ENG130806-ENG130877,Blindness_Matrix-Blindness_Matrix_5_2,7,
ENG130806-ENG130878,Blindness_Matrix-Blindness_Matrix_5_3,7,
ENG130806-ENG130879,Blindness_Matrix-Blindness_Matrix_5_4,7,
ENG130806-ENG130880,Blindness_Matrix-Blindness_Matrix_5_5,7,
ENG120402-ENG120253,Camera_information-par_camera_control_average,409,
ENG120402-ENG120255,Camera_information-par_frame_counter,8911,
ENG130822-ENG130854,camera_state_details-camera_debug_requests,00000001 ,
ENG130822-ENG130853,camera_state_details-camera_hot_restart_counter,0,
ENG130822-ENG130852,camera_state_details-camera_system_state_details,31,
ENG130822-ENG130855,camera_state_details-Kamera Debug Information,00000000 00000000 00000000 00000010 ,
ENG130795,Count_street_lighting,0,
ENG120438,EH_Sys_Country_Code,0,
ENG130820-ENG130848,Ehr-Ehr_mem_usage_attributes,46, %
ENG130820-ENG130847,Ehr-Ehr_mem_usage_segments,100, %
ENG130820-ENG130849,Ehr-Ehr_mem_usage_speedlimits,47, %
ENG130820-ENG130846,Ehr-EHR_SW_Version,01 00 01,
ENG130816-ENG131033,hca_Parameter_App_001_App_050-hca_Parameter_par_App_001,4223557550,
ENG130816-ENG131034,hca_Parameter_App_001_App_050-hca_Parameter_par_App_002,3800488123,
ENG130816-ENG131035,hca_Parameter_App_001_App_050-hca_Parameter_par_App_003,3216172011,
ENG130816-ENG131036,hca_Parameter_App_001_App_050-hca_Parameter_par_App_004,4294967294,
ENG130816-ENG131037,hca_Parameter_App_001_App_050-hca_Parameter_par_App_005,4160749567,
ENG130816-ENG131038,hca_Parameter_App_001_App_050-hca_Parameter_par_App_006,4294967295,
ENG130816-ENG131039,hca_Parameter_App_001_App_050-hca_Parameter_par_App_007,1067030938,
ENG130816-ENG131040,hca_Parameter_App_001_App_050-hca_Parameter_par_App_008,1092616192,
ENG130816-ENG131041,hca_Parameter_App_001_App_050-hca_Parameter_par_App_009,1070386381,
ENG130816-ENG131042,hca_Parameter_App_001_App_050-hca_Parameter_par_App_010,1057803469,
ENG130816-ENG131043,hca_Parameter_App_001_App_050-hca_Parameter_par_App_011,1048576000,
ENG130816-ENG131044,hca_Parameter_App_001_App_050-hca_Parameter_par_App_012,1048576000,
ENG130816-ENG131045,hca_Parameter_App_001_App_050-hca_Parameter_par_App_013,1036831949,
ENG130816-ENG131046,hca_Parameter_App_001_App_050-hca_Parameter_par_App_014,1050253722,
ENG130816-ENG131047,hca_Parameter_App_001_App_050-hca_Parameter_par_App_015,0,
ENG130816-ENG131048,hca_Parameter_App_001_App_050-hca_Parameter_par_App_016,0,
ENG130816-ENG131049,hca_Parameter_App_001_App_050-hca_Parameter_par_App_017,1071225242,
ENG130816-ENG131050,hca_Parameter_App_001_App_050-hca_Parameter_par_App_018,1120403456,
ENG130816-ENG131051,hca_Parameter_App_001_App_050-hca_Parameter_par_App_019,3,
ENG130816-ENG131052,hca_Parameter_App_001_App_050-hca_Parameter_par_App_020,1045220557,
ENG130816-ENG131053,hca_Parameter_App_001_App_050-hca_Parameter_par_App_021,1133576192,
ENG130816-ENG131054,hca_Parameter_App_001_App_050-hca_Parameter_par_App_022,1065353216,
ENG130816-ENG131055,hca_Parameter_App_001_App_050-hca_Parameter_par_App_023,750,
ENG130816-ENG131056,hca_Parameter_App_001_App_050-hca_Parameter_par_App_024,3,
ENG130816-ENG131057,hca_Parameter_App_001_App_050-hca_Parameter_par_App_025,2,
ENG130816-ENG131058,hca_Parameter_App_001_App_050-hca_Parameter_par_App_026,1092301619,
ENG130816-ENG131059,hca_Parameter_App_001_App_050-hca_Parameter_par_App_027,20,
ENG130816-ENG131060,hca_Parameter_App_001_App_050-hca_Parameter_par_App_028,1060320051,
ENG130816-ENG131061,hca_Parameter_App_001_App_050-hca_Parameter_par_App_029,1045220557,
ENG130816-ENG131062,hca_Parameter_App_001_App_050-hca_Parameter_par_App_030,1058642330,
ENG130816-ENG131063,hca_Parameter_App_001_App_050-hca_Parameter_par_App_031,5,
ENG130816-ENG131064,hca_Parameter_App_001_App_050-hca_Parameter_par_App_032,1055286886,
ENG130816-ENG131065,hca_Parameter_App_001_App_050-hca_Parameter_par_App_033,1028443341,
ENG130816-ENG131066,hca_Parameter_App_001_App_050-hca_Parameter_par_App_034,1200,
ENG130816-ENG131067,hca_Parameter_App_001_App_050-hca_Parameter_par_App_035,1133903872,
ENG130816-ENG131068,hca_Parameter_App_001_App_050-hca_Parameter_par_App_036,1079320248,
ENG130816-ENG131069,hca_Parameter_App_001_App_050-hca_Parameter_par_App_037,1069547520,
ENG130816-ENG131070,hca_Parameter_App_001_App_050-hca_Parameter_par_App_038,50,
ENG130816-ENG131071,hca_Parameter_App_001_App_050-hca_Parameter_par_App_039,1045220557,
ENG130816-ENG00000,hca_Parameter_App_001_App_050-hca_Parameter_par_App_040,100,
ENG130816-ENG00001,hca_Parameter_App_001_App_050-hca_Parameter_par_App_041,1065353216,
ENG130816-ENG00002,hca_Parameter_App_001_App_050-hca_Parameter_par_App_042,5,
ENG130816-ENG00003,hca_Parameter_App_001_App_050-hca_Parameter_par_App_043,1028443341,
ENG130816-ENG00004,hca_Parameter_App_001_App_050-hca_Parameter_par_App_044,1079320248,
ENG130816-ENG00005,hca_Parameter_App_001_App_050-hca_Parameter_par_App_045,1050253722,
ENG130816-ENG00006,hca_Parameter_App_001_App_050-hca_Parameter_par_App_046,1053609165,
ENG130816-ENG00007,hca_Parameter_App_001_App_050-hca_Parameter_par_App_047,1036831949,
ENG130816-ENG00008,hca_Parameter_App_001_App_050-hca_Parameter_par_App_048,1000593162,
ENG130816-ENG00009,hca_Parameter_App_001_App_050-hca_Parameter_par_App_049,995640528,
ENG130816-ENG00010,hca_Parameter_App_001_App_050-hca_Parameter_par_App_050,1050253722,
ENG130799-ENG00011,hca_Parameter_App_051_App_100-hca_Parameter_par_App_051,1093781265,
ENG130799-ENG00012,hca_Parameter_App_051_App_100-hca_Parameter_par_App_052,1099257191,
ENG130799-ENG00013,hca_Parameter_App_051_App_100-hca_Parameter_par_App_053,1065353216,
ENG130799-ENG00014,hca_Parameter_App_051_App_100-hca_Parameter_par_App_054,1065353216,
ENG130799-ENG00015,hca_Parameter_App_051_App_100-hca_Parameter_par_App_055,1065353216,
ENG130799-ENG00016,hca_Parameter_App_051_App_100-hca_Parameter_par_App_056,1099258921,
ENG130799-ENG00017,hca_Parameter_App_051_App_100-hca_Parameter_par_App_057,1115815936,
ENG130799-ENG00018,hca_Parameter_App_051_App_100-hca_Parameter_par_App_058,1133576192,
ENG130799-ENG00019,hca_Parameter_App_051_App_100-hca_Parameter_par_App_059,1118218879,
ENG130799-ENG00020,hca_Parameter_App_051_App_100-hca_Parameter_par_App_060,1036831949,
ENG130799-ENG00021,hca_Parameter_App_051_App_100-hca_Parameter_par_App_061,1101004800,
ENG130799-ENG00022,hca_Parameter_App_051_App_100-hca_Parameter_par_App_062,1000593162,
ENG130799-ENG00023,hca_Parameter_App_051_App_100-hca_Parameter_par_App_063,1063675494,
ENG130799-ENG00024,hca_Parameter_App_051_App_100-hca_Parameter_par_App_064,1110558481,
ENG130799-ENG00025,hca_Parameter_App_051_App_100-hca_Parameter_par_App_065,1109102140,
ENG130799-ENG00026,hca_Parameter_App_051_App_100-hca_Parameter_par_App_066,1090865070,
ENG130799-ENG00027,hca_Parameter_App_051_App_100-hca_Parameter_par_App_067,1073741824,
ENG130799-ENG00028,hca_Parameter_App_051_App_100-hca_Parameter_par_App_068,1069547520,
ENG130799-ENG00029,hca_Parameter_App_051_App_100-hca_Parameter_par_App_069,50,
ENG130799-ENG00030,hca_Parameter_App_051_App_100-hca_Parameter_par_App_070,1041865114,
ENG130799-ENG00031,hca_Parameter_App_051_App_100-hca_Parameter_par_App_071,500,
ENG130799-ENG00032,hca_Parameter_App_051_App_100-hca_Parameter_par_App_072,1050253722,
ENG130799-ENG00033,hca_Parameter_App_051_App_100-hca_Parameter_par_App_073,200,
ENG130799-ENG00034,hca_Parameter_App_051_App_100-hca_Parameter_par_App_074,1039516303,
ENG130799-ENG00035,hca_Parameter_App_051_App_100-hca_Parameter_par_App_075,155,
ENG130799-ENG00036,hca_Parameter_App_051_App_100-hca_Parameter_par_App_076,1050253722,
ENG130799-ENG00037,hca_Parameter_App_051_App_100-hca_Parameter_par_App_077,1056964608,
ENG130799-ENG00038,hca_Parameter_App_051_App_100-hca_Parameter_par_App_078,1039516303,
ENG130799-ENG00039,hca_Parameter_App_051_App_100-hca_Parameter_par_App_079,1069547520,
ENG130799-ENG00040,hca_Parameter_App_051_App_100-hca_Parameter_par_App_080,2,
ENG130799-ENG00041,hca_Parameter_App_051_App_100-hca_Parameter_par_App_081,1056964608,
ENG130799-ENG00042,hca_Parameter_App_051_App_100-hca_Parameter_par_App_082,1120403456,
ENG130799-ENG00043,hca_Parameter_App_051_App_100-hca_Parameter_par_App_083,1073741824,
ENG130799-ENG00044,hca_Parameter_App_051_App_100-hca_Parameter_par_App_084,1075838976,
ENG130799-ENG00045,hca_Parameter_App_051_App_100-hca_Parameter_par_App_085,150,
ENG130799-ENG00046,hca_Parameter_App_051_App_100-hca_Parameter_par_App_086,3,
ENG130799-ENG00047,hca_Parameter_App_051_App_100-hca_Parameter_par_App_087,1,
ENG130799-ENG00048,hca_Parameter_App_051_App_100-hca_Parameter_par_App_088,3212836864,
ENG130799-ENG00049,hca_Parameter_App_051_App_100-hca_Parameter_par_App_089,17950,
ENG130799-ENG00050,hca_Parameter_App_051_App_100-hca_Parameter_par_App_090,1053609165,
ENG130799-ENG00051,hca_Parameter_App_051_App_100-hca_Parameter_par_App_091,1090865070,
ENG130799-ENG00052,hca_Parameter_App_051_App_100-hca_Parameter_par_App_092,10,
ENG130799-ENG00053,hca_Parameter_App_051_App_100-hca_Parameter_par_App_093,100,
ENG130799-ENG00054,hca_Parameter_App_051_App_100-hca_Parameter_par_App_094,1112014848,
ENG130799-ENG00055,hca_Parameter_App_051_App_100-hca_Parameter_par_App_095,3192704205,
ENG130799-ENG00056,hca_Parameter_App_051_App_100-hca_Parameter_par_App_096,100,
ENG130799-ENG00057,hca_Parameter_App_051_App_100-hca_Parameter_par_App_097,3137540719,
ENG130799-ENG00058,hca_Parameter_App_051_App_100-hca_Parameter_par_App_098,1017370378,
ENG130799-ENG00059,hca_Parameter_App_051_App_100-hca_Parameter_par_App_099,25,
ENG130799-ENG00060,hca_Parameter_App_051_App_100-hca_Parameter_par_App_100,1068615546,
ENG130817-ENG130933,hca_Parameter_App_101_App_150-hca_Parameter_par_App_101,17000,
ENG130817-ENG130934,hca_Parameter_App_101_App_150-hca_Parameter_par_App_102,1045220557,
ENG130817-ENG130935,hca_Parameter_App_101_App_150-hca_Parameter_par_App_103,3221225472,
ENG130817-ENG130936,hca_Parameter_App_101_App_150-hca_Parameter_par_App_104,150,
ENG130817-ENG130937,hca_Parameter_App_101_App_150-hca_Parameter_par_App_105,1119215065,
ENG130817-ENG130938,hca_Parameter_App_101_App_150-hca_Parameter_par_App_106,1120403456,
ENG130817-ENG130939,hca_Parameter_App_101_App_150-hca_Parameter_par_App_107,32699,
ENG130817-ENG130940,hca_Parameter_App_101_App_150-hca_Parameter_par_App_108,1039516303,
ENG130817-ENG130941,hca_Parameter_App_101_App_150-hca_Parameter_par_App_109,1099956224,
ENG130817-ENG130942,hca_Parameter_App_101_App_150-hca_Parameter_par_App_110,1133903872,
ENG130817-ENG130943,hca_Parameter_App_101_App_150-hca_Parameter_par_App_111,1135542272,
ENG130817-ENG130944,hca_Parameter_App_101_App_150-hca_Parameter_par_App_112,500,
ENG130817-ENG130945,hca_Parameter_App_101_App_150-hca_Parameter_par_App_113,1073741824,
ENG130817-ENG130946,hca_Parameter_App_101_App_150-hca_Parameter_par_App_114,50,
ENG130817-ENG130947,hca_Parameter_App_101_App_150-hca_Parameter_par_App_115,12073,
ENG130817-ENG130948,hca_Parameter_App_101_App_150-hca_Parameter_par_App_116,1041865114,
ENG130817-ENG130949,hca_Parameter_App_101_App_150-hca_Parameter_par_App_117,1056964608,
ENG130817-ENG130950,hca_Parameter_App_101_App_150-hca_Parameter_par_App_118,8946808,
ENG130817-ENG130951,hca_Parameter_App_101_App_150-hca_Parameter_par_App_119,1073741824,
ENG130817-ENG130952,hca_Parameter_App_101_App_150-hca_Parameter_par_App_120,1112014848,
ENG130817-ENG130953,hca_Parameter_App_101_App_150-hca_Parameter_par_App_121,1041865114,
ENG130817-ENG130954,hca_Parameter_App_101_App_150-hca_Parameter_par_App_122,1092616192,
ENG130817-ENG130955,hca_Parameter_App_101_App_150-hca_Parameter_par_App_123,1065353216,
ENG130817-ENG130956,hca_Parameter_App_101_App_150-hca_Parameter_par_App_124,1099956224,
ENG130817-ENG130957,hca_Parameter_App_101_App_150-hca_Parameter_par_App_125,1085392762,
ENG130817-ENG130958,hca_Parameter_App_101_App_150-hca_Parameter_par_App_126,3,
ENG130817-ENG130959,hca_Parameter_App_101_App_150-hca_Parameter_par_App_127,150,
ENG130817-ENG130960,hca_Parameter_App_101_App_150-hca_Parameter_par_App_128,1067030938,
ENG130817-ENG130961,hca_Parameter_App_101_App_150-hca_Parameter_par_App_129,1056964608,
ENG130817-ENG130962,hca_Parameter_App_101_App_150-hca_Parameter_par_App_130,1090833613,
ENG130817-ENG130963,hca_Parameter_App_101_App_150-hca_Parameter_par_App_131,1090868530,
ENG130817-ENG130964,hca_Parameter_App_101_App_150-hca_Parameter_par_App_132,1085276160,
ENG130817-ENG130965,hca_Parameter_App_101_App_150-hca_Parameter_par_App_133,1000593162,
ENG130817-ENG130966,hca_Parameter_App_101_App_150-hca_Parameter_par_App_134,1020054733,
ENG130817-ENG130967,hca_Parameter_App_101_App_150-hca_Parameter_par_App_135,1008981770,
ENG130817-ENG130968,hca_Parameter_App_101_App_150-hca_Parameter_par_App_136,1025758986,
ENG130817-ENG130969,hca_Parameter_App_101_App_150-hca_Parameter_par_App_137,1058642330,
ENG130817-ENG130970,hca_Parameter_App_101_App_150-hca_Parameter_par_App_138,1063675494,
ENG130817-ENG130971,hca_Parameter_App_101_App_150-hca_Parameter_par_App_139,1061997773,
ENG130817-ENG130972,hca_Parameter_App_101_App_150-hca_Parameter_par_App_140,1065353216,
ENG130817-ENG130973,hca_Parameter_App_101_App_150-hca_Parameter_par_App_141,1050253722,
ENG130817-ENG130974,hca_Parameter_App_101_App_150-hca_Parameter_par_App_142,1060320051,
ENG130817-ENG130975,hca_Parameter_App_101_App_150-hca_Parameter_par_App_143,1050253722,
ENG130817-ENG130976,hca_Parameter_App_101_App_150-hca_Parameter_par_App_144,1061997773,
ENG130817-ENG130977,hca_Parameter_App_101_App_150-hca_Parameter_par_App_145,0,
ENG130817-ENG130978,hca_Parameter_App_101_App_150-hca_Parameter_par_App_146,1060320051,
ENG130817-ENG130979,hca_Parameter_App_101_App_150-hca_Parameter_par_App_147,1056964608,
ENG130817-ENG130980,hca_Parameter_App_101_App_150-hca_Parameter_par_App_148,1082130432,
ENG130817-ENG130981,hca_Parameter_App_101_App_150-hca_Parameter_par_App_149,1065353216,
ENG130817-ENG130982,hca_Parameter_App_101_App_150-hca_Parameter_par_App_150,1074580685,
ENG130810-ENG130983,hca_Parameter_App_151_App_200-hca_Parameter_par_App_151,1071225242,
ENG130810-ENG130984,hca_Parameter_App_151_App_200-hca_Parameter_par_App_152,1060320051,
ENG130810-ENG130985,hca_Parameter_App_151_App_200-hca_Parameter_par_App_153,1076363264,
ENG130810-ENG130986,hca_Parameter_App_151_App_200-hca_Parameter_par_App_154,1099257138,
ENG130810-ENG130987,hca_Parameter_App_151_App_200-hca_Parameter_par_App_155,1056964608,
ENG130810-ENG130988,hca_Parameter_App_151_App_200-hca_Parameter_par_App_156,0,
ENG130810-ENG130989,hca_Parameter_App_151_App_200-hca_Parameter_par_App_157,1060320051,
ENG130810-ENG130990,hca_Parameter_App_151_App_200-hca_Parameter_par_App_158,0,
ENG130810-ENG130991,hca_Parameter_App_151_App_200-hca_Parameter_par_App_159,1056964608,
ENG130810-ENG130992,hca_Parameter_App_151_App_200-hca_Parameter_par_App_160,1056964608,
ENG130810-ENG130993,hca_Parameter_App_151_App_200-hca_Parameter_par_App_161,1120403456,
ENG130810-ENG130994,hca_Parameter_App_151_App_200-hca_Parameter_par_App_162,1092324898,
ENG130810-ENG130995,hca_Parameter_App_151_App_200-hca_Parameter_par_App_163,1036831949,
ENG130810-ENG130996,hca_Parameter_App_151_App_200-hca_Parameter_par_App_164,1073741824,
ENG130810-ENG130997,hca_Parameter_App_151_App_200-hca_Parameter_par_App_165,1067869798,
ENG130810-ENG130998,hca_Parameter_App_151_App_200-hca_Parameter_par_App_166,1066192077,
ENG130810-ENG130999,hca_Parameter_App_151_App_200-hca_Parameter_par_App_167,1077936128,
ENG130810-ENG131000,hca_Parameter_App_151_App_200-hca_Parameter_par_App_168,1020054733,
ENG130810-ENG131001,hca_Parameter_App_151_App_200-hca_Parameter_par_App_169,1036831949,
ENG130810-ENG131002,hca_Parameter_App_151_App_200-hca_Parameter_par_App_170,1034147594,
ENG130810-ENG131003,hca_Parameter_App_151_App_200-hca_Parameter_par_App_171,1036831949,
ENG130810-ENG131004,hca_Parameter_App_151_App_200-hca_Parameter_par_App_172,1036831949,
ENG130810-ENG131005,hca_Parameter_App_151_App_200-hca_Parameter_par_App_173,1036831949,
ENG130810-ENG131006,hca_Parameter_App_151_App_200-hca_Parameter_par_App_174,1028443341,
ENG130810-ENG131007,hca_Parameter_App_151_App_200-hca_Parameter_par_App_175,100,
ENG130810-ENG131008,hca_Parameter_App_151_App_200-hca_Parameter_par_App_176,150,
ENG130810-ENG131009,hca_Parameter_App_151_App_200-hca_Parameter_par_App_177,250,
ENG130810-ENG131010,hca_Parameter_App_151_App_200-hca_Parameter_par_App_178,500,
ENG130810-ENG131011,hca_Parameter_App_151_App_200-hca_Parameter_par_App_179,200,
ENG130810-ENG131012,hca_Parameter_App_151_App_200-hca_Parameter_par_App_180,1,
ENG130810-ENG131013,hca_Parameter_App_151_App_200-hca_Parameter_par_App_181,200,
ENG130810-ENG131014,hca_Parameter_App_151_App_200-hca_Parameter_par_App_182,150,
ENG130810-ENG131015,hca_Parameter_App_151_App_200-hca_Parameter_par_App_183,5,
ENG130810-ENG131016,hca_Parameter_App_151_App_200-hca_Parameter_par_App_184,1041865114,
ENG130810-ENG131017,hca_Parameter_App_151_App_200-hca_Parameter_par_App_185,2,
ENG130810-ENG131018,hca_Parameter_App_151_App_200-hca_Parameter_par_App_186,150,
ENG130810-ENG131019,hca_Parameter_App_151_App_200-hca_Parameter_par_App_187,150,
ENG130810-ENG131020,hca_Parameter_App_151_App_200-hca_Parameter_par_App_188,0,
ENG130810-ENG131021,hca_Parameter_App_151_App_200-hca_Parameter_par_App_189,100,
ENG130810-ENG131022,hca_Parameter_App_151_App_200-hca_Parameter_par_App_190,250,
ENG130810-ENG131023,hca_Parameter_App_151_App_200-hca_Parameter_par_App_191,6,
ENG130810-ENG131024,hca_Parameter_App_151_App_200-hca_Parameter_par_App_192,1080033280,
ENG130810-ENG131025,hca_Parameter_App_151_App_200-hca_Parameter_par_App_193,0,
ENG130810-ENG131026,hca_Parameter_App_151_App_200-hca_Parameter_par_App_194,0,
ENG130810-ENG131027,hca_Parameter_App_151_App_200-hca_Parameter_par_App_195,1099257191,
ENG130810-ENG131028,hca_Parameter_App_151_App_200-hca_Parameter_par_App_196,0,
ENG130810-ENG131029,hca_Parameter_App_151_App_200-hca_Parameter_par_App_197,4294967295,
ENG130810-ENG131030,hca_Parameter_App_151_App_200-hca_Parameter_par_App_198,1613874181,
ENG130810-ENG131031,hca_Parameter_App_151_App_200-hca_Parameter_par_App_199,3393735333,
ENG130810-ENG131032,hca_Parameter_App_151_App_200-hca_Parameter_par_App_200,0,
ENG120389-ENG120177,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Breite,1.8437500, m
ENG120389-ENG120180,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Lenkuebers,15.0000000,
ENG120389-ENG120178,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Radstand,2.7890625, m
ENG120389-ENG120179,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Vchar,32.50, m/s
ENG120417-ENG120274,Person_hca_Key_0-hmi_Hca_An,OFF,
ENG120417-ENG120277,Person_hca_Key_0-hmi_System_Mode,vibration_off,
ENG120417-ENG120276,Person_hca_Key_0-hmi_Warning_Intensity,Medium,
ENG120417-ENG120275,Person_hca_Key_0-hmi_Warning_Time,Early,
ENG120418-ENG120274,Person_hca_Key_1-hmi_Hca_An,On,
ENG120418-ENG120277,Person_hca_Key_1-hmi_System_Mode,vibration_off,
ENG120418-ENG120276,Person_hca_Key_1-hmi_Warning_Intensity,Medium,
ENG120418-ENG120275,Person_hca_Key_1-hmi_Warning_Time,Late,
ENG120419-ENG120274,Person_hca_Key_2-hmi_Hca_An,OFF,
ENG120419-ENG120277,Person_hca_Key_2-hmi_System_Mode,vibration_off,
ENG120419-ENG120276,Person_hca_Key_2-hmi_Warning_Intensity,Medium,
ENG120419-ENG120275,Person_hca_Key_2-hmi_Warning_Time,Late,
ENG120420-ENG120274,Person_hca_Key_3-hmi_Hca_An,OFF,
ENG120420-ENG120277,Person_hca_Key_3-hmi_System_Mode,vibration_off,
ENG120420-ENG120276,Person_hca_Key_3-hmi_Warning_Intensity,Medium,
ENG120420-ENG120275,Person_hca_Key_3-hmi_Warning_Time,Early,
ENG130791-ENG00068,Rsr_objects_01-Rsr_objects_01_add1_attribute,0,
ENG130791-ENG00067,Rsr_objects_01-Rsr_objects_01_add1_class,no_Information,
ENG130791-ENG00066,Rsr_objects_01-Rsr_objects_01_attribute,0,
ENG130791-ENG00065,Rsr_objects_01-Rsr_objects_01_class,no_Information,
ENG130791-ENG00064,Rsr_objects_01-Rsr_objects_01_objectid,0,
ENG130811-ENG00073,Rsr_objects_02-Rsr_objects_02_add1_attribute,0,
ENG130811-ENG00072,Rsr_objects_02-Rsr_objects_02_add1_class,no_Information,
ENG130811-ENG00071,Rsr_objects_02-Rsr_objects_02_attribute,0,
ENG130811-ENG00070,Rsr_objects_02-Rsr_objects_02_class,no_Information,
ENG130811-ENG00069,Rsr_objects_02-Rsr_objects_02_objectid,0,
ENG130804-ENG00078,Rsr_objects_03-Rsr_objects_03_add1_attribute,0,
ENG130804-ENG00077,Rsr_objects_03-Rsr_objects_03_add1_class,no_Information,
ENG130804-ENG00076,Rsr_objects_03-Rsr_objects_03_attribute,0,
ENG130804-ENG00075,Rsr_objects_03-Rsr_objects_03_class,no_Information,
ENG130804-ENG00074,Rsr_objects_03-Rsr_objects_03_objectid,0,
ENG130792-ENG00083,Rsr_objects_04-Rsr_objects_04_add1_attribute,0,
ENG130792-ENG00082,Rsr_objects_04-Rsr_objects_04_add1_class,no_Information,
ENG130792-ENG00081,Rsr_objects_04-Rsr_objects_04_attribute,0,
ENG130792-ENG00080,Rsr_objects_04-Rsr_objects_04_class,no_Information,
ENG130792-ENG00079,Rsr_objects_04-Rsr_objects_04_objectid,0,
ENG130809-ENG00088,Rsr_objects_05-Rsr_objects_05_add1_attribute,0,
ENG130809-ENG00087,Rsr_objects_05-Rsr_objects_05_add1_class,no_Information,
ENG130809-ENG00086,Rsr_objects_05-Rsr_objects_05_attribute,0,
ENG130809-ENG00085,Rsr_objects_05-Rsr_objects_05_class,no_Information,
ENG130809-ENG00084,Rsr_objects_05-Rsr_objects_05_objectid,0,
ENG130805-ENG00093,Rsr_objects_06-Rsr_objects_06_add1_attribute,0,
ENG130805-ENG00092,Rsr_objects_06-Rsr_objects_06_add1_class,no_Information,
ENG130805-ENG00091,Rsr_objects_06-Rsr_objects_06_attribute,0,
ENG130805-ENG00090,Rsr_objects_06-Rsr_objects_06_class,no_Information,
ENG130805-ENG00089,Rsr_objects_06-Rsr_objects_06_objectid,0,
ENG130797-ENG00098,Rsr_objects_07-Rsr_objects_07_add1_attribute,0,
ENG130797-ENG00097,Rsr_objects_07-Rsr_objects_07_add1_class,no_Information,
ENG130797-ENG00096,Rsr_objects_07-Rsr_objects_07_attribute,0,
ENG130797-ENG00095,Rsr_objects_07-Rsr_objects_07_class,no_Information,
ENG130797-ENG00094,Rsr_objects_07-Rsr_objects_07_objectid,0,
ENG130819-ENG00103,Rsr_objects_08-Rsr_objects_08_add1_attribute,0,
ENG130819-ENG00102,Rsr_objects_08-Rsr_objects_08_add1_class,no_Information,
ENG130819-ENG00101,Rsr_objects_08-Rsr_objects_08_attribute,0,
ENG130819-ENG00100,Rsr_objects_08-Rsr_objects_08_class,no_Information,
ENG130819-ENG00099,Rsr_objects_08-Rsr_objects_08_objectid,0,
ENG130790-ENG00108,Rsr_objects_09-Rsr_objects_09_add1_attribute,0,
ENG130790-ENG00107,Rsr_objects_09-Rsr_objects_09_add1_class,no_Information,
ENG130790-ENG00106,Rsr_objects_09-Rsr_objects_09_attribute,0,
ENG130790-ENG00105,Rsr_objects_09-Rsr_objects_09_class,no_Information,
ENG130790-ENG00104,Rsr_objects_09-Rsr_objects_09_objectid,0,
ENG130814-ENG130845,VZE_message_text-Par_vze_message_text,1,
ENG130789,VZF_Warning_Traffic_Sig_1,not activated,
ENG130801,VZF_Warning_Traffic_Sig_2,not activated,
ENG130800,VZF_Warning_Traffic_Sig_3,not activated,
ENG130802,VZF_Warning_Traffic_Sig_4,not activated,
ENG130803,VZF_Warning_Traffic_Sig_5,not activated,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,No,
Elapsed Time: 02:07
3)
[Select]
[Fault Codes - 02]
[Clear Codes - 05]
DONE
[Security Access - 16] > Enter shown code (20103) DONE
[Adaptation - 10]
IDE09376-IDE02001 Body height wheel house edge-Body height left front wheel house edge > Enter value written down > [Do It!] DONE
IDE09376-IDE02002 Body height wheel house edge-Body height right front wheel house edge > Enter value written down > [Do It!] DONE
IDE09376-IDE02003 Body height wheel house edge-Body height left rear wheel house edge > Enter value written down > [Do It!] DONE
IDE09376-IDE02004 Body height wheel house edge-Body height right rear wheel house edge > Enter value written down > [Do It!] DONE
IDE07358-Distance to calibration field > Enter 1500 > [Do It!] DONE
4)
IDE03343-ENG114972-Static calibration (customer service) DONE
Search and mark: IDE10403 / IDE10924 (if available) but nothing change, it just say "calibration not correct or something like that"
[Go!]
Value is showing: "Running" then "Unknown
[Stop]
[Done, Go Back]
And I have this: 0663 - Control Module For Camera
[Applications]
[Erase All DTCs]
I should try again but I don't understand what's wrong???
   #96
sam1754
France
C?ID=324989
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,-----------------, so it doesn't recognize vehicle?
IDE10664-MAS03010,Current initial calibration: details-Focal length,1386, What is this measurement? Distance to the target???
   #97
sam1754
France
C?ID=324989
I found this on RT forum:
Camera Lane assist problem MKVII
Hello
I have a problem with the camera lane assist.
Address A5: Frt Sens. Drv. Assist Labels: 5Q0-980-653.CLB
Control Module Part Number: 5Q0 980 653 E HW: 5Q0 980 653
Component and/or Version: MQB_MFK H05 0051
Software Coding: 0100010001020300000300000000000100
Work Shop Code: WSC 01349 123 104857
ASAM Dataset: EV_MFKBoschAU370 001001 (VW37)
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3A71C8ABBD69E7EE65-806E
C110A 76 [009] - Wrong mounting position
Reset counter: 44
Mileage: 70419 km
Date: 2015.12.21
Time: 20:35:52
Have you more information to fix it ?
Best regards
Sebastian
And said
i answer to myself , it s due of invalid position of calibration board during calibration process.
Only odis with specific condition can erase this !
   #98
NEtech
Denmark
C?ID=56995
1)
Copy this file to:
Compare the 2 controller map files, then you see it.
Maybe this:
And this
IDE10664-MAS01632,Current initial calibration: details-Status, Installation position incorrect
Some other items, first map:
I wrote use charger, but apparently not.
Next map:
If charger connected, not so useful.
Straight?
Interesting.
   #99
NEtech
Denmark
C?ID=56995
Are you sure coding for [A5] is correct, Byte 9 and Byte 21
   #100
sam1754
France
C?ID=324989
I'll take time to see it.
Next map:
Yes, it's a soft charger so it takes time to reach 12v but after that it's ok
Straight?
I made it 0°, moving the steering wheel during calibration.
Interesting.
What should it mean? May I have to run online calibration first to allow static calibration as described on videos???
