Saturday,14,September,2019,19:44:44:16465
-- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
Version: 19.6.0.2 (x64) HEX-V2 : 0.4508.4
VIN: WVWZZZ3CZGE****** License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 6C 6D A5
BB BC CA
VIN: WVWZZZ3CZGE***** Mileage: 43747km-27183miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CZEA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BT HW: 04E 907 309 AB
Component: R4 1.4l TFS H22 9177
Revision: R6H22---
Coding: 01190032234405083000
Shop #: 00000 000 00000
Dataset: EV_ECM14TFS01104E906027BT 001011
ROD: EV_ECM14TFS01104E906027BT.rod
VCID: 77AB16E58F4941AFFBB-8022
CAN Converter 01:
Readiness: 1110 0001
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 61295000003003
Coding: 0FEC6A8F34202B75077E060141CA49F0562CD4E0608292F13420F078C002
Shop #: 16560 003 1048576
Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7EA503C1A07370E7B8D-802A
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0709
Revision: 00036000 Serial number: 0369268362
Coding: 0F00000603
Shop #: 05311 115 00242
Dataset: EV_KessyHellaMQBAB 004032
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 3A2DCFD1FCDB9CC7C45-806E
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8015769
Part No SW: 5G0 907 044 BG HW: 5G0 907 044 BG
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020024200100011015504000101802
Shop #: 00015 115 08193
Dataset: EV_ACClimaBHBVW37X 005137
VCID: 6D87348DFD15FB7F117-8038
Air quality sensor:
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: PQ37BOSCH 028 0162
Revision: -------- Serial number: 86580405150120
Coding: 00950A46C2C102FF53C440040014570C188A000000000000000000000000
Shop #: 131071 102 209715
Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 03537235CB911D0FD73-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150510 042 0607
Serial number: 150516230219
Component: 037 0059
Serial number: S5Y15M06D02H04M23S23
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - H01 0032
Serial number: 27 03 2015 00000105
Sun Roof:
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: ÿÿÿ305183615132
Coding: 0271161841
Shop #: 05311 115 00066
Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000.rod
VCID: 0D47540D9DD55B7FB17-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: BOSCH H04 0192
Coding: 2A00600351FFC428949C804D
Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3431E1E9DEBF6AB71E9-8060
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Fault Frequency: 104
Reset counter: 147
Mileage: 43747 km
Date: 2019.09.14
Time: 18:12:00
Control Module temperature: 29 °C
Voltage terminal 15: 11.3 V
Part No SW: 3Q0 959 655 AF HW: 3Q0 959 655 AF
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R2PA9V0V9
Coding: 88CCC000000000005C5400CC000800000065
Shop #: 05314 000 00001
Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 025D7731D48B1407DC5-8056
Subsystem 1 - Part No SW: ----------- HW: 454 001 505 15
Serial number: 3576U0000007982C541D
Subsystem 2 - Part No SW: ----------- HW: 454 001 505 15
Serial number: 3586U000000B6D90A41K
Subsystem 3 - Part No SW: ----------- HW: 454 801 805 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RBDEAC706000000T
Subsystem 4 - Part No SW: ----------- HW: 454 801 805 15
Component: SideSensor_Pr 111 0148
Serial number: 3526RBF89EA06000000U
Subsystem 5 - Part No SW: ----------- HW: 454 801 705 15
Component: FrontSensor_D 114 0149
Serial number: 3556V6EA15706000000D
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150530400166
Coding: 0400
Shop #: 00015 115 00001
Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D27C4CDEDF5ABFFE17-8068
Part No SW: 3G0 920 750 A HW: 3G0 920 750 A
Component: KOMBI 301 6430
Coding: 07A50B102F800008038A6B011001000000000000
Shop #: 04240 995 00000
Dataset: EV_DashBoardVDDMQBAB 009046
VCID: 221D17B1744BF407FC5-8076
U1014 00 [009] - -
Reset counter: 108
Mileage: 43747 km
Date: 2019.09.14
Time: 16:18:13
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW High 212 2227
Revision: -------- Serial number: 22051510802856
Coding: 0B0300047F085700FB000258080F00010001070000000000000000000000
Shop #: 131071 1023 2097151
Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 75B71CED954533BFE97-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001106270095217
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 0636226603
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H54 0033
Serial number: 0092220
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
131663 - No Communications with Front Sensor Package for Driver Assist. Systems
U10E0 00 [008] - -
[Timeout Knoten 0x4F / A5 - Frontsensorik für Fahrerassistenzsysteme]
Reset counter: 148
Mileage: 43747 km
Date: 2019.09.14
Time: 18:12:03
Supply voltage: Terminal 30: 11.9 V
Terminal 15: On
66304 - Databus
U1124 00 [008] - Additional Installations Detected
[Mehrverbau CAN]
Reset counter: 147
Mileage: 43747 km
Date: 2019.09.14
Time: 16:18:14
Supply voltage: Terminal 30: 11.8 V
Terminal 15: On
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000089803009
Coding: 0000000000000000
Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71BF28FDE12D1F9F35F-8024
Component: FS 020 0041
Serial number: 190515BEJ06598
Coding: 00371B20D000020000001000
Shop #: 12345 123 12345
Dataset: EV_DCUDriveSideEWMAXKLO 006003
VCID: 43D3B2358B11DD0F973-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000250312
Coding: 01010010005000
Shop #: 00015 115 00242
Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
VCID: 3B23CAD5F3E1A5CFDF3-806E
Component: BFS 020 0041
Serial number: 200515BEJ14957
Coding: 00371120DC00020000001000
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 42DDB731940BD4079C5-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR- 005 0080
Coding: 03DA000009000000
Shop #: 05311 000 08193
Dataset: EV_HeadlRegulVWLWRMQB 001110
Address 5F: Information Electr. (J794) Labels:| 5G0-035--STD2.clb
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0629
Coding: 02840201FF00000051110001000808001F01008401200100CF
Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 6E853381F013006728D-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R1541807
Subsystem 2 - Part No SW: 5NA 919 866 R HW: -----------
Component: ECE AS 19/20 --- 1115
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 0184020142002017000040
Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
Part No SW: 5Q0 959 107 E HW: 5Q0 959 107 E
Component: HDSG-Modul H12 0233
Revision: -------- Serial number: 30029362500000
Coding: 0208
Dataset: EV_DeckLidCONTIAU736 001009
Part No SW: 3Q0 980 654 HW: 3Q0 980 654
Component: MQB_B_MFK H04 0010
Serial number: 17021511P10178
Coding: 0004080200000401000620448050A10094000E230020
Dataset: EV_MFKBoschMQBB 001001
VCID: 74B121E99E3F2AB7DE9-8020
0768 - No Basic Setting
B2010 00 [009] - -
[Calibration_VIN_mismatch]
Reset counter: 108
Mileage: 43747 km
Date: 2019.09.14
Time: 19:28:37
Control Module temperature: 28 °C
Outside air temperature: 21.5 °C
Vehicle speed: 0.00 km/h
System run time: 51.8 s
Voltage terminal 15: 11.8 V
mid: 00 51
Status of camera: System malfunction
Engine_Running_Info: 0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 0
Software_Info_1: 0
0646 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Variant_coding_failure]
Reset counter: 108
Mileage: 43747 km
Date: 2019.09.14
Time: 19:28:37
mid: 00 28
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 0
Software_Info_1: 0
1122597 - Local Data Bus
U1169 00 [009] - Missing Message
Reset counter: 108
Mileage: 43747 km
Date: 2019.09.14
Time: 19:28:37
System run time: 52.2 s
mid: 01 41
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 0
Software_Info_1: 0
0659 - Steering
C10AC F2 [009] - Lane-Holding Assistance Not Coded
[HC_interface_at_the_steering_not_activated]
Reset counter: 108
Mileage: 43747 km
Date: 2019.09.14
Time: 19:28:37
System run time: 52.4 s
mid: 02 A0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 0
Software_Info_1: 0
Component: HFS 020 0041
Serial number: 190115BA706289
Coding: 000611200100020000001000
Shop #: 99999 999 28888
Dataset: EV_DCURearDriveMAXKLO 006003
VCID: 45D7AC2D8525E33FB97-8010
Component: HBFS 020 0041
Serial number: 190115BA706398
Coding: 000E10200100020000001000
Dataset: EV_DCURearPasseMAXKLO 006003
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Reset counter: 107
Mileage: 43747 km
Date: 2019.09.14
Time: 16:38:53
Part No SW: 4M0 907 594 B HW: 4M0 907 594
Component: SAD_STG_1 009 0002
Coding: 008040748202
Dataset: EV_SunRoofCONTIAU736 004008
VCID: 3537DCEDD5C573BF297-8060
End----(Elapsed Time: 02:28, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
