car has had ,new engine, engine ecu ,speedo and ,central electronics module( no 9)and key from same car,all these parts came from the same car which was a breaker,also has had svm performed, but has not helped abs which has 0000ect for coding and won't take any codes,i don't have original code, any help available
I have a picture of pr code from car this lot is fitted in ,the abs module is original to the car not the ecu set, and no I didnt keep abs ecu from breaker, doh!
Friday,07,September,2018,15:21:19:34356
VCDS Version: 18.2.1.2 HEX-V2 CB: 0.4411.4
VIN: WAUZZZ8VXFA071465 License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8VXFA071465 Mileage: 33402km-20755miles
Address 01: Engine (J623-CYVB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 CJ HW: 04E 907 309 AF
Component: 1.2l R4 TSI H21 7798
Revision: R5H21---
Coding: 02190012230401082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM12TFS01104E906027CJ 001005
ROD: EV_ECM12TFS01104E906027CJ.rod
VCID: 6E86C718D01F663793B-803A
4716 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 33402 km
Date: 2018.09.07
Time: 14:14:04
Engine speed: 699.00 /min
Normed load value: 18.8 %
Coolant temperature: 96 °C
Intake air temperature: 66 °C
Voltage terminal 30: 13.334 V
selected gear-Bits 0-7: 0
Readiness: 1110 0001
Part No SW: 5Q0 907 379 S HW: 5Q0 907 379 G
Component: ESC H31 0456
Revision: 00000000 Serial number: 61973000000620
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 4CC26D9086437427DDF-8018
10 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Reset counter: 185
Date: 2018.09.07
Time: 14:13:36
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 185
Date: 2018.09.07
Time: 14:13:36
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 185
Date: 2018.09.07
Time: 14:13:36
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 185
Date: 2018.09.07
Time: 14:13:36
0398 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Vehicle equipped with vacuum sensor but no vacuum sensor coded]
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 14:13:38
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
[FCAN: Mismatch between bytecoding and Lenkerposition signal]
Reset counter: 185
Date: 2018.09.07
Time: 14:13:36
8290 - Coding Not Possible
U10BC 00 [137] - -
[FCAN: Unplausible VIN number]
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 14:13:40
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 14:13:40
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
Reset counter: 185
Date: 2018.09.07
Time: 14:13:36
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 185
Date: 2018.09.07
Time: 14:13:36
Address 08: Auto HVAC (E87) Labels:| 8V0-820-047.clb
Part No SW: 8V0 820 047 B HW: 8V0 820 047 B
Component: AC Manuell el H11 0031
Revision: 20019000 Serial number: 00000000023158
Coding: 00100004000000001000000000000000
ASAM Dataset: EV_AirCondiFrontManAU37X 008016
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 35342874F5C915EF921-8060
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 12:22:52
Outside air temperature: 33 °C
Temperature after evaporator: 40.0 °C
Refrigerant pressure: 1.0 bar
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0134
Serial number: 01011427302781
Coding: 07040840C20102FD03044004B31407080000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7DA4F0548D790DAF1A1-8028
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130705 041 0580
Serial number: 130712062925
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0002
Serial number: 20118716
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 Q HW: 8V0 941 531 Q
Serial number: 18 05 2013 00000351
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY131751BJL
267012 - No Communications with Anti-Theft Siren / Alarm Horn
U10F3 00 [009] - -
[Sirene-DWA->kein Signal/Kommunikation]
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 12:47:05
267032 - Alarm Horn / Siren for Anti-Theft System
B131D 29 [009] - Signal Implausible
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 12:47:05
939524 - No Communications with Humidity Sensor
U10F5 00 [009] - -
[Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 12:47:05
Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
Component: AirbagVW20 009 0349
Serial number: 003GER0168WL
VCID: 49CC54848931610FE69-801C
Subsystem 1 - Part No SW: ----------- HW: 480 001 207 13
Serial number: 357670000005A0DCFC09
Subsystem 2 - Part No SW: ----------- HW: 480 001 207 13
Serial number: 358670000005C0DCFC0C
Subsystem 3 - Part No SW: ----------- HW: 480 401 307 13
Serial number: 3516502BD1142C758369
Subsystem 4 - Part No SW: ----------- HW: 480 401 307 13
Serial number: 3526502C3107DB50E1EI
Subsystem 5 - Part No SW: ----------- HW: 480 402 208 14
Serial number: 3556502A316C6CE272DS
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 909 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502C5175A8D2C33K
Subsystem 7 - Part No SW: ----------- HW: 480 400 909 14
Component: PedP_Sensor_P 001 6149
Serial number: 22965029D176A6C5D15S
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 809 14
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C3176A6C43073
B13BC F2 [137] - No function
Mileage: 33402 km
Date: 2018.09.07
Time: 12:22:52
1050117 - Databus
Reset counter: 225
Mileage: 33402 km
Date: 2018.09.07
Time: 12:22:52
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Revision: -------- Serial number: 12071304401185
Coding: 8418
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 77A8E27CAF4527FF40D-8022
Part No SW: 8V0 920 971 C HW: 8V0 920 971 C
Component: KOMBI H02 4291
Coding: 27840200228046000100A8001000000000000000
VCID: 3D243054CDF9CDAF5A1-8068
16776967 - Databus
[EPB_02 keine Kommunikation]
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 13:06:27
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1144
Revision: -------- Serial number: 0000805725
Coding: 030100042B0864005B000248000B00000001000000000000000000000000
ROD: EV_GatewLear_009_VW37.rod
VCID: 3A2E3B48DCD7FA977F3-806E
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Serial number: 18 07 2013 B1195410
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051760393
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
Component: TSG FS 012 0006
Serial number: 05071306070244
Coding: 00100E204001040100001002
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DC4CA4B101A94F3E9-8014
19204 - Databus
[ESP_02 Botschaft - SNA_Check]
Reset counter: 185
Mileage: 33402 km
Date: 2018.09.07
Time: 12:49:21
Motor status: 01
System status: Driving mode
Supply voltage: 14.25 V
Temperature: 40.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 7F
uioUdNotFilt_xdu16: 14.55 V
uAdSensI_SwitchedKl30_xdu16: 14.56 V
Part No SW: 5Q0 959 392 A HW: 5Q0 959 392
Component: TSG BFS 012 0006
Serial number: 24061303110499
Coding: 001006204001040100001002
VCID: 3C223D50D6E3C4A76DF-8068
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 041 0420
Serial number: A7F00310141983
Coding: 01730001FF00000021111101000A00002F0001460100010006
Shop #: WSC 19279 003 1048576
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 3B203E4CD3EDC39F645-806E
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H48 0013
Serial number: AUZ8Z9DG601KZC
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000027061300020642
End----------(Elapsed Time: 01:12, VBatt start/end: 12.5V/12.5V)-----------
