ABS coding 2013 audi a3 8v
mrqcars
C?ID=307137
car has had ,new engine, engine ecu ,speedo and ,central electronics module( no 9)and key from same car,all these parts came from the same car which was a breaker,also has had svm performed, but has not helped abs which has 0000ect for coding and won't take any codes,i don't have original code, any help available
I have a picture of pr code from car this lot is fitted in ,the abs module is original to the car not the ecu set, and no I didnt keep abs ecu from breaker, doh!
Friday,07,September,2018,15:21:19:34356
VCDS Version: 18.2.1.2  HEX-V2 CB: 0.4411.4
VIN: WAUZZZ8VXFA071465   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8VXFA071465   Mileage: 33402km-20755miles
Address 01: Engine (J623-CYVB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 CJ    HW: 04E 907 309 AF
   Component: 1.2l R4 TSI   H21 7798
   Revision: R5H21---
   Coding: 02190012230401082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM12TFS01104E906027CJ 001005
   ROD: EV_ECM12TFS01104E906027CJ.rod
   VCID: 6E86C718D01F663793B-803A
4716 - No Communications with Parking Brake Control Module
          U0128 00 [039] - -
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 14:14:04
                    Engine speed: 699.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 13.334 V
                    selected gear-Bits 0-7: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 S    HW: 5Q0 907 379 G
   Component: ESC           H31 0456
   Revision: 00000000    Serial number: 61973000000620
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 4CC26D9086437427DDF-8018
10 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 185
                    Date: 2018.09.07
                    Time: 14:13:36
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Date: 2018.09.07
                    Time: 14:13:36
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Date: 2018.09.07
                    Time: 14:13:36
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Date: 2018.09.07
                    Time: 14:13:36
0398 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Vehicle equipped with vacuum sensor but no vacuum sensor coded]
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 14:13:38
8278 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                    Reset counter: 185
                    Date: 2018.09.07
                    Time: 14:13:36
8290 - Coding Not Possible
          U10BC 00 [137] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 14:13:40
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 14:13:40
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 185
                    Date: 2018.09.07
                    Time: 14:13:36
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 185
                    Date: 2018.09.07
                    Time: 14:13:36
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 B    HW: 8V0 820 047 B
   Component: AC Manuell el H11 0031
   Revision: 20019000    Serial number: 00000000023158
   Coding: 00100004000000001000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008016
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 35342874F5C915EF921-8060
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 12:22:52
                    Outside air temperature: 33 °C
                    Temperature after evaporator: 40.0 °C
                    Refrigerant pressure: 1.0 bar
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0134
   Serial number: 01011427302781
   Coding: 07040840C20102FD03044004B31407080000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DA4F0548D790DAF1A1-8028
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130705  041 0580
   Serial number:         130712062925
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0002
   Serial number: 20118716
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 18 05 2013  00000351
   Serial number: 000000000ZY131751BJL
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [009] - -
          [Sirene-DWA->kein Signal/Kommunikation]
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 12:47:05
267032 - Alarm Horn / Siren for Anti-Theft System
          B131D 29 [009] - Signal Implausible
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 12:47:05
939524 - No Communications with Humidity Sensor
          U10F5 00 [009] - -
          [Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 12:47:05
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER0168WL
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 49CC54848931610FE69-801C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 207 13
   Serial number: 357670000005A0DCFC09
   Subsystem 2 - Part No SW: -----------    HW: 480 001 207 13
   Serial number: 358670000005C0DCFC0C
   Subsystem 3 - Part No SW: -----------    HW: 480 401 307 13
   Serial number: 3516502BD1142C758369
   Subsystem 4 - Part No SW: -----------    HW: 480 401 307 13
   Serial number: 3526502C3107DB50E1EI
   Subsystem 5 - Part No SW: -----------    HW: 480 402 208 14
   Serial number: 3556502A316C6CE272DS
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 909 14
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502C5175A8D2C33K
   Subsystem 7 - Part No SW: -----------    HW: 480 400 909 14
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029D176A6C5D15S
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 809 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C3176A6C43073
          B13BC F2 [137] - No function
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 12:22:52
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 225
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 12:22:52
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 12071304401185
   Coding: 8418
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 77A8E27CAF4527FF40D-8022
   Part No SW: 8V0 920 971 C    HW: 8V0 920 971 C
   Component: KOMBI         H02 4291
   Coding: 27840200228046000100A8001000000000000000
   VCID: 3D243054CDF9CDAF5A1-8068
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 13:06:27
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1144
   Revision: --------    Serial number: 0000805725
   Coding: 030100042B0864005B000248000B00000001000000000000000000000000
   ROD: EV_GatewLear_009_VW37.rod
   VCID: 3A2E3B48DCD7FA977F3-806E
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 18 07 2013  B1195410
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051760393
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 05071306070244
   Coding: 00100E204001040100001002
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DC4CA4B101A94F3E9-8014
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 185
                    Mileage: 33402 km
                    Date: 2018.09.07
                    Time: 12:49:21
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.25 V
                    Temperature: 40.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 14.55 V
                    uAdSensI_SwitchedKl30_xdu16: 14.56 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 24061303110499
   Coding: 001006204001040100001002
   VCID: 3C223D50D6E3C4A76DF-8068
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    041 0420
   Serial number: A7F00310141983
   Coding: 01730001FF00000021111101000A00002F0001460100010006
   Shop #: WSC 19279 003 1048576
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 3B203E4CD3EDC39F645-806E
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DG601KZC
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000027061300020642
End----------(Elapsed Time: 01:12, VBatt start/end: 12.5V/12.5V)-----------
iichel
Netherlands, eastern part
C?ID=284912
I don't think anyone here has taken the effort to reverse-engineer the MQB ESC coding since there are a lot of variables to take into account like ACC, front assist, you name it. All the MQB sweetness you can imagine. It will probably take a good few (full) days to get the hang of it. And even then you don't have any guarantees of success. I'm managing MK60EC1 codes and ESP9.0i/8.2i codes nicely nowadays but it hasn't been a smooth trip... :D
I guess your best chance is SVM but somehow that got rejected? Not sure why. Perhaps it's worth having a look to see if all the VINs stored in the car (cluster, engine, gearbox) match. Maybe the gateway and some other modules in the MQB system also keep track of the VIN and they need changing as well.
Your second best chance is to somehow find that ABS module that came with the car.
Your third best chance is to hope someone found an algorithm to generate ESC long coding (or is willing to learn how to do so).
mrqcars
C?ID=307137
yes same car ,it has not moved since last post in 2017,really sick off looking at it, but yes what about those code tags !
downtime
Finland
C?ID=280813
I have quite good understanding of MQB IPB pumps. I can try and generate the code for you but takes some time as I’m travelling at the moment.
mrqcars
C?ID=307137
thank you !!
downtime
Finland
C?ID=280813
Ok, first try. This has your VIN number injected and is for 1.2 liter gasoline engine :
13FF6A9234280A6E0177030381CC29C8562C5080C08194B4004100588208
I modified the code so that this does not have ACC enabled anymore.
Edit :
The VIN in ABS code is now the same as you have on the autoscan WAUZZZ8VXFA071465. Is that correct or the one in the PR sticker you have the picture taken from? Because if it's the sticker that is correct, then you need to have the instrument cluster and engine ECU recoded so that they have the correct VIN number for your car.
mrqcars
C?ID=307137
Hi many thanks for the help so far ,when trying change code I get “coding rejected error 31:request out of range” I have tried 40168 as security code and 20103 ,are either of these correct ?,thanks in advance,Michael
mrqcars
C?ID=307137
Now tried all these access codes,most were accepted but some error 31 message
25004
11966
15081
18573
20103
24435
25004
28183
31857
37202
40168
44595
10505
mrqcars
C?ID=307137
Sorry should have read same error 31
downtime
Finland
C?ID=280813
Ok, the code is not correct for the car. That's why it's not accepting it. No need to input security code when coding ABS, it should accept.
Can you check what VIN number you have in motor ECU and in instruments? It should be in advanced info by going into the module and clicking on advanced info button. Let me know this and I'll generate a new code with proper VIN. That is most likely the reason the code is rejected. Other bytes should be fine.
mrqcars
C?ID=307137
Monday,10,September,2018,13:24:02:34356
VCDS Version: Release 18.2.1
Control Module Part Number: 5Q0 907 379 S
Component and/or Version: ESC H31 0456
Software Coding: 000000000000000000000000000000000000000000000000000000000000
Work Shop Code: WSC 06314
Advanced Identification/FAZIT
Identification: TT1-06P
Revision: 00000000
Date: 16.07.13
Manufacturer number: 0103
Test stand number: 0620
Flash Status
Programming Attempts(application): 0/0
Successful Attempts(application): 0/0
Flash Date: 00.00.00
Misc.
Hardware number: 5Q0 907 379 G
Workshop System Name: J104
Equipment/PR Code: FFFFFFFFFFFFFFFF
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset Revision: 033001
VCDS Info:
Labels: 5Q0-907-379-IPB-V1.clb
mrqcars
C?ID=307137
Monday,10,September,2018,13:23:02:34356
Address 17: Instruments
Control Module Part Number: 8V0 920 971 C
Component and/or Version: KOMBI H02 4291
Software Coding: 27840200228046000100A8001000000000000000
Identification: VDD-024
Date: 07.10.14
Manufacturer number: 5501
Test stand number: 0170
Flash Status
Programming Attempts(application): 0/0/0
Programming Attempts(data): 0/0/0
Successful Attempts(data): 0/0/0
Flash Tool Code(data): 00000 000 00000
Misc.
Hardware number: 8V0 920 971 C
Workshop System Name: J285
Equipment/PR Code: 0000000000000000
ASAM Dataset Revision: 009040
Car Info
Chassis Number: WAUZZZ8VXFA071465
VCDS Info:
Labels: 5G0-920-XXX-17.clb-SRI3
mrqcars
C?ID=307137
Engine Ecu
Monday,10,September,2018,13:28:05:34356
Address 01: Engine
Control Module Part Number: 04E 906 027 CJ
Component and/or Version: 1.2l R4 TSI H21 7798
Software Coding: 02190012230401082000
Identification: BPG-810
Revision: R5H21---
Date: 02.10.14
Manufacturer number: 1225
Test stand number: 0897
Flash Status
Programming Attempts(application): 1/1/1
Successful Attempts(application): 1/1/1
Flash Date: 14.10.13
Misc.
Hardware number: 04E 907 309 AF
Workshop System Name: J623
ASAM Dataset Revision: 001005
Car Info
Engine code: CYVB
VCDS Info:
Labels: 04E-907-309-V1.clb
Readiness: No script available
andyhud
C?ID=32695
Have you plumbed in a WSC, Importer and Tester code into VCDS under Options first? ABS modules really like this stuff to accept coding I've noticed.
mrqcars
C?ID=307137
Yes all those boxes have numbers on them but don’t look to be changeable
andyhud
C?ID=32695
if they are populated then it should be all good. Its just if they are empty (aka VCDS Stealth Mode) sometimes it doesnt work
RT can change them if you had to, but you need to message them direct I believe...
downtime
Finland
C?ID=280813
Ok, I've used the same VIN for the ABS coding. Let me double check the coding. Just to be sure, I will also generate an ABS coding with the VIN number in the PR sticker.
downtime
Finland
C?ID=280813
Second try :
13FF6A9234270A6D017B030681C829C8562C5080C08194B4004100780208
I actually messed up with the previous coding, I put the VIN numbers to wrong bytes :) Sorry about that. Try now does it accept the coding.
Edit : Fixed byte 06, was wrong.
Edit 2 :
Another one. Based on A3 1.2 TSI manual with your VIN injected :
10F16AA224270A6D0177060641C82508562450806082A4B2002100080608
Still more tinkering :) Now both codings should be ok
mrqcars
C?ID=307137
Hi massive thanks for your help but the car doesn’t like either code,any tips greatly appreciated!!
