Current Versions
   #361
guys, is there any way why my Hexnet today strat give continuously beep .. and red indicators start blinking 1 by 1
it happen when I connect it to OBD
all is ok as far as I know, diagnostic, ...but noise from :facepalm:
19.4 version
I believe continuous beeping and red blinking when connected to OBD is supposed to mean a shorted K-Line at the OBD-II connector. What do you get when you do [Options] -> [Test] in VCDS?
Spacewalker
Poland
C?ID=159607
I use on omy bench test loom, when is no Kline wire
CAN testting
K1 ok
K2 ok
Vbat 12V
Vign 10.5v
Now is only one LED bliking ,
when 2 was bliking (2 narrow) I let device connected for some time
after I back - was silent ;)
   #363
Shaun
Bump for beta CB V0.4507
* More CAN broadcast filtering
   #365
Shaun
Bump for CB V0.4513 on beta channel
* Updated chassis info
* Fixes for ASAM functions
   #367
Shaun
Bump for beta CB V0.4543
* Comms improvements for ID.3 platform
* Fixes for 29bit OBDII addresses
* New addresses
   #369
Shaun
Bump for CB V0.4544 now on release
* Fix for TP1.6 1281 comms
   #370
Thank you, "update successful" ; test / save also OK.
   #371
Shaun
Bump for beta CB V0.4548
* Fixes for LT3 comms
* Support for ID.4 fallback address ranges
* Fix for a timer wrap when logging
* Fix for unit being included with the value in some mv logs
   #374
Shaun
Bump for beta CB V0.4555
* Fix for registration issue
   #375
Jacek
Poland
C?ID=360566
Hello, after updating to CB V0.4555, the automatic scan does not open in the "gateway instalation list" in ver.21.3.0, in beta 21.8.2 it is ok.
   #376
Eric
HC800000
The new codeblock is going to have issues with older VCDS versions over WiFi. Until we have a new release on Sept 1st, please use either the Beta Wifi/USB or the Release over USB only.
Jacek
Poland
C?ID=360566
Ok
   #378
Shaun
Bump for CB V0.4555 now on release. Cumulative changelog since last release:
* Fixes for measuring value logging
* OBDII fixes
* Fix for Clear all DTCS
HN2- FW V1.64 now on release
* Updated wifi fw and routines
* Fix for DoIP init
   #379
Jacek
Poland
C?ID=360566
Ver.21.9 works ok, they work on the Polish version 21.3, it still does not work with wifi only with a usb cable.
And this is probably not what HEX-NET is about.
   #380
This is a known backwards compatibility issue; CB 0.4555 may not work properly with 21.3 and older versions when used with a HEX-NET on WiFi. There are two possible work-arounds until a translated 21.9 is available:
1) Use the translated version with the HEX-NET via USB
2) Use the English version 21.9
