Resolved Passat B8 early 2015, Retrofitting A5 front camera + DLA + Lane assist- Finished
Resolved
   #41
sam1754
France
C?ID=324989
Maybe I'm mistaking but the back line where sc 32 to sc37 fuses are plugged is a terminal 15 feeding... why shouldn't put a single connector on this line???
+12V come from back line and go to the camera (for example) through the upper connector you have to plug behind... which I couldn't place. I think it's a simple way to do it, no?
[/url][/IMG]
I think I can just adapt a fuse with a cable into "green arrow" to take the +12v and feeding camera via a fuse holder... is there a matter doing this???
   #42
sam1754
France
C?ID=324989
What do you mean by "fighting the can gateway"???
If it's soldering cables on module, job is done, no problem with that.
   #43
downtime
C?ID=280813
Yes yes, single connector works just fine. I thought you were going to use piggyback fuse :)
And I disagree on the can module �� Maybe I’m getting old but unplugging and dismantling the connector, soldering wires to the existing wires and all this laying on your back in inhuman position, soldering in a very tight and dark place �� No thank you anymore. Done that enough ��
Anyway, we are maybe diverting from the topic a bit.
   #44
sam1754
France
C?ID=324989
My shoulders say "YOU'RE RIGHT!!!" Please, stop the torture:D
   #45
sam1754
France
C?ID=324989
So, I just have to plug ACC sensor. I made a fuse connector to test it now.
Here is the scan after enabling A5 in Can gateway 19.
[Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654     HW: 3Q0 980 654
  Component and/or Version: MQB_B_MFK     H04 0010
           Software Coding: 0004080204000401002200448050A10084000E200040
            Work Shop Code: WSC 00015 115 08193
              ASAM Dataset: EV_MFKBoschMQBB 001001 (VW48)
                      VCID: 74B121E99E3F2AB7DE9-8020
0768 - No Basic Setting
          B2010 00 [009] - -
          [Calibration_VIN_mismatch]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:15
                    Control Module temperature: 31 °C
                    Outside air temperature: 28.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 2.7 s
                    Voltage terminal 15: 11.7 V
                    mid: 00 51
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:15
                    mid: 00 28
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
1122675 - Databus
          [TIMEOUT_LWR_AFS_02]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:14
                    System run time: 1.1 s
                    Voltage terminal 15: 11.2 V
                    mid: 01 E7
                    Status of camera: Initializing
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
1122597 - Local Data Bus
          U1169 00 [009] - Missing Message
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:14
                    mid: 01 41
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:16
                    System run time: 3.3 s
                    mid: 02 A0
                    Status of camera: System malfunction
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
downtime
C?ID=280813
Looks good. Now just coding and adaption and calibration.
   #47
sam1754
France
C?ID=324989
I don't have to wait for calibration before adaptation and coding job?
   #48
siLc
Tallinn, Estonia
C?ID=330192
It would be wise to finish installation and coding before attempting calibration. Also the camera software is really old - if you can, have it updated to at least revision F (3Q0 980 654F) or later.
   #49
sam1754
France
C?ID=324989
I'm a little alone here and VW dealers have a real lack of knowledge, even using car's functions is sometimes hard for them. So I do all I can myself...
What can the update provide?
PS: it's a manual gearbox and steady led lights car.
   #50
sam1754
France
C?ID=324989
Here is a new scan with ACC-cam wires installed. Thanks to who talked about the coupling point, it's really easier this way. I'll post photos as soon as my back'll be ok... ouch!
I noticed there's no longer any communication error between ACC sensor and camera, so the connection is ok:D
Saturday,14,September,2019,19:44:44:16465
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZGE******  License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 6C 6D A5
          BB BC CA
VIN: WVWZZZ3CZGE*****   Mileage: 43747km-27183miles
BC-Door Rear Pass -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BT    HW: 04E 907 309 AB
   Component: R4 1.4l TFS   H22 9177
   Revision: R6H22---
   Coding: 01190032234405083000
   ASAM Dataset: EV_ECM14TFS01104E906027BT 001011
   ROD: EV_ECM14TFS01104E906027BT.rod
   VCID: 77AB16E58F4941AFFBB-8022
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 61295000003003
   Coding: 0FEC6A8F34202B75077E060141CA49F0562CD4E0608292F13420F078C002
   Shop #: WSC 16560 003 1048576
   VCID: 7EA503C1A07370E7B8D-802A
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0709
   Revision: 00036000    Serial number: 0369268362
   Coding: 0F00000603
   Shop #: WSC 05311 115 00242
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   VCID: 3A2DCFD1FCDB9CC7C45-806E
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8015769
   Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020024200100011015504000101802
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 6D87348DFD15FB7F117-8038
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580405150120
   Coding: 00950A46C2C102FF53C440040014570C188A000000000000000000000000
   Shop #: WSC 131071 102 209715
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03537235CB911D0FD73-8056
   Component: WWS    150510  042 0607
   Serial number:         150516230219
   Component: RLHS  037 0059
   Serial number: S5Y15M06D02H04M23S23
   Coding: 00A8DD
   Light switch:
   Serial number: 27 03 2015  00000105
   Sun Roof:
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: ÿÿÿ305183615132
   Coding: 0271161841
   Shop #: WSC 05311 115 00066
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 0D47540D9DD55B7FB17-8058
   Component: ACC BOSCH MQB H04 0192
   Coding: 2A00600351FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3431E1E9DEBF6AB71E9-8060
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 104
                    Reset counter: 147
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 18:12:00
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 11.3 V
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2PA9V0V9
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 025D7731D48B1407DC5-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 001 505 15
   Serial number: 3576U0000007982C541D
   Subsystem 2 - Part No SW: -----------    HW: 454 001 505 15
   Serial number: 3586U000000B6D90A41K
   Subsystem 3 - Part No SW: -----------    HW: 454 801 805 15
   Serial number: 3516RBDEAC706000000T
   Subsystem 4 - Part No SW: -----------    HW: 454 801 805 15
   Serial number: 3526RBF89EA06000000U
   Subsystem 5 - Part No SW: -----------    HW: 454 801 705 15
   Serial number: 3556V6EA15706000000D
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150530400166
   Coding: 0400
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D27C4CDEDF5ABFFE17-8068
   Part No SW: 3G0 920 750 A    HW: 3G0 920 750 A
   Component: KOMBI         301 6430
   Coding: 07A50B102F800008038A6B011001000000000000
   Shop #: WSC 04240 995 00000
   VCID: 221D17B1744BF407FC5-8076
          U1014 00 [009] - -
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:13
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 22051510802856
   Coding: 0B0300047F085700FB000258080F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B71CED954533BFE97-8020
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001106270095217
   Coding: 2CFFFF
   Serial number: 0636226603
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H54 0033
   Serial number: 0092220
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
131663 - No Communications with Front Sensor Package for Driver Assist. Systems
          U10E0 00 [008] - -
          [Timeout Knoten 0x4F / A5 - Frontsensorik für Fahrerassistenzsysteme]
                    Reset counter: 148
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 18:12:03
                    Terminal 15: On
66304 - Databus
          U1124 00 [008] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 147
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:18:14
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
   Serial number: 15000089803009
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF28FDE12D1F9F35F-8024
   Serial number: 190515BEJ06598
   Coding: 00371B20D000020000001000
   VCID: 43D3B2358B11DD0F973-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000250312
   Coding: 01010010005000
   Shop #: WSC 00015 115 00242
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3B23CAD5F3E1A5CFDF3-806E
   Serial number: 200515BEJ14957
   Coding: 00371120DC00020000001000
   VCID: 42DDB731940BD4079C5-8016
   Coding: 03DA000009000000
   Shop #: WSC 05311 000 08193
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0629
   Coding: 02840201FF00000051110001000808001F01008401200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6E853381F013006728D-803A
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R1541807
   Subsystem 2 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184020142002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
   Part No SW: 5Q0 959 107 E    HW: 5Q0 959 107 E
   Component: HDSG-Modul    H12 0233
   Revision: --------    Serial number: 30029362500000
   Coding: 0208
   ASAM Dataset: EV_DeckLidCONTIAU736 001009
   Part No SW: 3Q0 980 654     HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0010
   Serial number: 17021511P10178
   Coding: 0004080200000401000620448050A10094000E230020
          B2010 00 [009] - -
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 19:28:37
                    Control Module temperature: 28 °C
                    Outside air temperature: 21.5 °C
                    System run time: 51.8 s
                    Voltage terminal 15: 11.8 V
                    mid: 00 51
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
          U1014 00 [009] - -
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 19:28:37
                    mid: 00 28
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 19:28:37
                    System run time: 52.2 s
                    mid: 01 41
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0659 - Steering
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 19:28:37
                    System run time: 52.4 s
                    mid: 02 A0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
   Serial number: 190115BA706289
   Coding: 000611200100020000001000
   Shop #: WSC 99999 999 28888
   VCID: 45D7AC2D8525E33FB97-8010
   Serial number: 190115BA706398
   Coding: 000E10200100020000001000
          B122D 29 [009] - Signal Implausible
                    Reset counter: 107
                    Mileage: 43747 km
                    Date: 2019.09.14
                    Time: 16:38:53
   Part No SW: 4M0 907 594 B    HW: 4M0 907 594
   Component: SAD_STG_1     009 0002
   Coding: 008040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 3537DCEDD5C573BF297-8060
End----(Elapsed Time: 02:28, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
   #51
sam1754
France
C?ID=324989
Here the hole to pass the wire to the ACC sensor as shown by Symb.
And here the hole on the bonnet side. I easily put the wires through the way under the battery, unscrewing the 13mm screw of battery maintain clip , pulling the battery to the front.
Here is a coupling point for ACC sensor. I think you must be under the car to do this comfortably (jack bridge or a hole on the floor like me).
I had to pull backa pinkplastic clip and insert a metal stick to push out white caps and insert 2 can pins. Wires are already here from coupling point to sensor as Symb noticed.
To test the camera, I made a fuse holder totally insulated and covered with car textile tape, waiting for the one I ordered... but I think this can stay here finally. I used 1.5mm2 cable to run to the fuse, so it's more reliable than low cost fuse holders... my opinion
THE EVIL CLIP!!!:D To pull it out, you have to press the back part with pliers.
sam1754
France
C?ID=324989
So, except the roof, all is in his place. As I havn't recieved the new clips yet, I managed to remount the evil clip delicatly and replace it correctly.:o
I erased fault codes and started a scan.
I don't know how to code A5 correctly to stop error message. I understood local data bus error is for anti fog not connected, steering wheel not coded, ok, calibrate, ok but coding??? I changed some things like alltrack to variant and DSG to manual...:confused:
Sunday,15,September,2019,11:50:38:16465
VIN: WVWZZZ3CZGE++++++  License Plate:
          BB BC CA
VIN: WVWZZZ3CZGE+++++   Mileage: 43747km-27183miles
   Revision: R6H22---
   CAN Converter 01:
   Coding: 0F00000603
   Revision: 00001K10
   Coding: 00A8DD
   Light switch:
   Sun Roof:
   Coding: 0271161841
   Coding: 0400
          U1014 00 [009] - -
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.15
                    Time: 11:47:50
   Coding: 2CFFFF
   Analog clock:
   Coding: 0208
          B2010 00 [009] - -
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.15
                    Time: 11:47:50
                    Control Module temperature: 57 °C
                    Outside air temperature: 27.5 °C
                    System run time: 579.6 s
                    Voltage terminal 15: 11.4 V
                    mid: 00 51
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
          U1014 00 [009] - -
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.15
                    Time: 11:47:50
                    mid: 00 28
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.15
                    Time: 11:47:50
                    System run time: 580.0 s
                    mid: 01 41
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0659 - Steering
                    Reset counter: 108
                    Mileage: 43747 km
                    Date: 2019.09.15
                    Time: 11:47:51
                    System run time: 580.2 s
                    mid: 02 A0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
End----(Elapsed Time: 02:26, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
   #53
m87a
Bosnia and Herzegovina
C?ID=156900
17
byte 4, bit 6
byte 11 bit 1
A5
byte 0 bit 0 or
byte 16 bit 7
10
byte 3 bit 3 or bit 5 (Lane assist)
44
login 19249
byte 0 bit 4 or
byte 3 bit 0 or
byte 4 bit 0
also 5F adaptations
   #54
siLc
Tallinn, Estonia
C?ID=330192
A5 coding should be 000408020000040100061344C050A10094000E200020
Since this vehicle has 5F navi and PLA 3.0, PSD (Byte 10), VZE (Byte 16, Bit 4) and PLA can also be coded in A5.
   #55
sam1754
France
C?ID=324989
:popcorn: Reading you is really pleasent and I'm really asking how you can find this coding? VIN number?:rolleyes:
I'll try this as quick as possible...
I couldn't wait anymore, I tested it!
Here is the new scan... with no fault code apart camera's calibration:
Sunday,15,September,2019,16:25:38:16465
VIN: WVWZZZ3CZGE+++++   License Plate:
          BB BC CA
   Revision: R6H22---
   CAN Converter 01:
   Coding: 0F00000603
   Revision: 00001K10
   Coding: 00950946C2C102FF53C440040014570C188A000000000000000000000000
   Coding: 00A8DD
   Light switch:
   Sun Roof:
   Coding: 0271163841
   Coding: 2A00604351FFC428949C804D
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 109
                    Mileage: 43747 km
                    Date: 2019.09.15
                    Time: 16:23:07
                    Control Module temperature: 46 °C
                    Voltage terminal 15: 11.6 V
   Coding: 0400
   Coding: 07A50B106F840008038A6B031001000000000000
   Coding: 2CFFFF
   Analog clock:
   Coding: 01010011005000
   Coding: 0208
   Coding: 000408020000040100061344C050A10094000E200020
          B2010 00 [009] - -
                    Reset counter: 109
                    Mileage: 43747 km
                    Date: 2019.09.15
                    Time: 16:23:07
                    Control Module temperature: 43 °C
                    Outside air temperature: 28.5 °C
                    System run time: 278.8 s
                    mid: 00 51
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
End----(Elapsed Time: 02:12, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
siLc
Tallinn, Estonia
C?ID=330192
By posting your autoscan, you made it possible for us to see whats installed in the car, and with hadez16's CodingCompare tool and a custom label file for the A5 front camera, come up with a coding string which should suit your car.
   #57
sam1754
France
C?ID=324989
And I say a BIG BIG BIG MERCI!!! to Symb Silc Downtime and all VCDS users!
sam1754
France
C?ID=324989
Snif!
No official VW's dealer and no car glass shop wants to calibrate the A5 module... even if I bought the windscreen by them.
I don't know if it's really possible with VCDS and the pattern???
   #59
rhinopower
C?ID=58979
Come to the UK and i will calibrate it for you :)
sam1754
France
C?ID=324989
I'd love to!!! I'll search for a B'nB and I come soon:p
I hope it's just a question of time to put this board at the right place... and run VCDS A5 basic setting.
