Friday,07,December,2018,11:14:32:05994
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Dealer/Shop Name: Dtslopik
Workshop Code: 998 00005 034111
VIN: WV1ZZZ2KZKX039030 License Plate:
Mileage: 20km-12mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
VIN: WV1ZZZ2KZKX039030 Mileage: 20km-12miles
Address 01: Engine (J623-DFSF) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 MQ HW: 04L 907 309 K
Component: R4 2.0l TDI H20 4100
Revision: 8AH20---
Coding: 01110012040409090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016MQ 001001
ROD: EV_ECM20TDI01104L906016MP.rod
VCID: 04507AB5CE9A6987BAD-8050
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 62768000000664
Coding: 1079409B9365A48708750279C98225E3780000
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDAB559E7FCCA5FA7F-806A
Part No SW: 1K8 907 426 AM HW: 1K8 907 426 AM
Component: AC Manuell H21 0909
Revision: 00001002
Coding: 0010004003
VCID: 7EA4085DA0760357EC9-802A
Part No SW: 5K0 937 085 AG HW: 5K0 937 085 AG
Component: BCM PQ35 B+ 122 0193
Revision: BB122001
Coding: 611A583A8025086D080000029040080403040008424F8160648487000041
Shop #: WSC 00005 998 34111
VCID: 78A81E4582D23D67A65-802C
Subsystem 1 - Part No: 2K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 05101 61 0715
Coding: 009795
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 1
Mileage: 27 km
Date: 2018.12.07
Time: 16:36:45
Voltage: 12.35 V
Reset counter: 1
Mileage: 27 km
Date: 2018.12.07
Time: 16:36:45
Voltage: 12.35 V
Part No SW: 2K5 959 655 D HW: 2K5 959 655 D
Component: VW10Airbag00H 010 0018
Revision: -------- Serial number: 003EL003X9NK
Coding: 000000000000000000000000000000003048
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
VCID: 3D26CF51EDF0D84FB53-8068
Serial number: 3497ARB40695KDHCO94M
Serial number: 3507ARB40695KDHC5P6D
Part No SW: 5K0 953 521 FT HW: 5K0 953 569 BE
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20181009200051
Coding: 5080060000
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 035279A9CB946EBF837-8056
Part No SW: 2K5 920 866 E HW: 2K5 920 866 E
Component: KOMBI H02 2030
Coding: 110A000200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
VCID: 3634D07DC8C60B17749-8062
Part No SW: 7N0 907 530 BN HW: 7N0 907 530 AL
Component: J533 Gateway H58 1691
Revision: H58 Serial number: 121018F1000636
Coding: 357400
VCID: 7DA60F51ADF0184FF53-8028
01771 - Control Module for Headlight Range (J431)
Reset counter: 1
Mileage: 27 km
Date: 2018.12.07
Time: 16:32:35
Component: IMMO H02 2030
Coding: 000002
VCID: 6A8C340DCCFE9FF7201-803E
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2143
Coding: 0132144
Shop #: WSC 35110 377 00144
VCID: 71BE2361EDA86C2F61B-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 317 3501
Revision: 00H22000
VCID: 392EDB41F558E46F99B-806C
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0132144
VCID: 72BC2C6DE8AE5737981-8026
Part No SW: 7F0 035 153 HW: 7F0 035 153
Component: Radio 022 0133
Revision: -------- Serial number: VWZGZ1V3793863
Coding: 00000220000000
VCID: 5EE468DD0036E357CC9-800A
00856 - Radio Antenna
Fault Status: 00101011
Reset counter: 40
Mileage: 8 km
Date: 2018.12.03
Time: 13:54:34
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1691
Coding: 030F7873
VCID: 71BE2361E1A86C2F61B-8024
Subsystem 1 - Part No SW: 2K0 915 181 HW: 2K0 915 181
Component: J367-BDMConti H03 1050
Serial number: 75885801001809290C77
End----------(Elapsed Time: 00:47, VBatt start/end: 12.6V/12.5V)-----------
