Retrofit xenon/led in a Caddy 2018
Dtslopik
NL
C?ID=129023
Hello guys,
We have retrofitted xenon headlights in a 2018 Volkswagen Caddy.
We have a problem to activate the drl lights.
The headlights highbeam and low beam work perfect (with shutter) the direction indicator works also fine.
We checked the wiring diagrams from halogeen headlights to xenon headlights and it's all a 10 polig connection and all the positions are the same.
So we think it's a coding problem.
Could someone assist us please?
Dtslopik
NL
C?ID=129023
Friday,07,December,2018,11:14:32:05994
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Dealer/Shop Name: Dtslopik
Workshop Code: 998 00005 034111
VIN: WV1ZZZ2KZKX039030   License Plate:
Mileage: 20km-12mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
VIN: WV1ZZZ2KZKX039030   Mileage: 20km-12miles
Address 01: Engine (J623-DFSF)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 MQ    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4100
   Revision: 8AH20---
   Coding: 01110012040409090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI01104L906016MQ 001001
   ROD: EV_ECM20TDI01104L906016MP.rod
   VCID: 04507AB5CE9A6987BAD-8050
   Revision: 00000000    Serial number: 62768000000664
   Coding: 1079409B9365A48708750279C98225E3780000
   VCID: 3FDAB559E7FCCA5FA7F-806A
   Part No SW: 1K8 907 426 AM    HW: 1K8 907 426 AM
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004003
   VCID: 7EA4085DA0760357EC9-802A
   Part No SW: 5K0 937 085 AG    HW: 5K0 937 085 AG
   Component: BCM PQ35 B+   122 0193
   Revision: BB122001
   Coding: 611A583A8025086D080000029040080403040008424F8160648487000041
   Shop #: WSC 00005 998 34111
   VCID: 78A81E4582D23D67A65-802C
   Subsystem 1 - Part No: 2K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 05101  61  0715
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 1
                    Mileage: 27 km
                    Date: 2018.12.07
                    Time: 16:36:45
                    Voltage: 12.35 V
                    Reset counter: 1
                    Mileage: 27 km
                    Date: 2018.12.07
                    Time: 16:36:45
                    Voltage: 12.35 V
   Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
   Component: VW10Airbag00H 010 0018
   Revision: --------    Serial number: 003EL003X9NK
   Coding: 000000000000000000000000000000003048
   VCID: 3D26CF51EDF0D84FB53-8068
   Serial number: 3497ARB40695KDHCO94M
   Serial number: 3507ARB40695KDHC5P6D
   Part No SW: 5K0 953 521 FT    HW: 5K0 953 569 BE
   Revision: FF010042    Serial number: 20181009200051
   Coding: 5080060000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 035279A9CB946EBF837-8056
   Part No SW: 2K5 920 866 E    HW: 2K5 920 866 E
   Component: KOMBI         H02 2030
   Coding: 110A000200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 3634D07DC8C60B17749-8062
   Part No SW: 7N0 907 530 BN    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1691
   Revision:   H58       Serial number: 121018F1000636
   Coding: 357400
   VCID: 7DA60F51ADF0184FF53-8028
                    Reset counter: 1
                    Mileage: 27 km
                    Date: 2018.12.07
                    Time: 16:32:35
   Component: IMMO          H02 2030
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C340DCCFE9FF7201-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2143
   Coding: 0132144
   Shop #: WSC 35110 377 00144
   VCID: 71BE2361EDA86C2F61B-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 317    3501
   Revision: 00H22000
   VCID: 392EDB41F558E46F99B-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0132144
   VCID: 72BC2C6DE8AE5737981-8026
   Part No SW: 7F0 035 153     HW: 7F0 035 153
   Component: Radio         022 0133
   Revision: --------    Serial number: VWZGZ1V3793863
   Coding: 00000220000000
   VCID: 5EE468DD0036E357CC9-800A
00856 - Radio Antenna
                    Fault Status: 00101011
                    Mileage: 8 km
                    Date: 2018.12.03
                    Time: 13:54:34
   Component: Batt.regelung H58 1691
   Coding: 030F7873
   VCID: 71BE2361E1A86C2F61B-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75885801001809290C77
End----------(Elapsed Time: 00:47, VBatt start/end: 12.6V/12.5V)-----------
m87a
Bosnia and Herzegovina
C?ID=156900
you need to change byte 18, when you change it you might need to experiment before everything will work ok, but be warned once you change it you can't go back, since 00 is just a mask for a hidden value
Dtslopik
NL
C?ID=129023
We did manage to chanteren byte 18 but not the result we wanted, we’ve testing the complete saturday and we never get the drl working.
Are there any other options you suggest?
m87a
C?ID=156900
what did you try for byte 18? do you try to bridge pins 4 & 10?
iichel
Netherlands, eastern part
C?ID=284912
Are you sure the current BCM can support LED DRL via PWM?
Dtslopik
NL
C?ID=129023
Yes i’m sure the bcm can do a pwm output to pin 10 and 4.
I was affraid to bridge 10 and 4 because the voltage is switching from 10 to 4 and the opposite, thought i would destroy the bcm if i bridge them.
You guys think i can set my bcm on byte 18 to a pwm signaal and then bridge 4 to 10 it will work??
rovafe56
Mexico
C?ID=191104
Do you have any succes activating the DRLs? I’m in the same situation, same BCM as yours
vastechnics
C?ID=143747
Byte 18 must be 74. Same like old caddy model. Try and reply hehe.
Regards
rovafe56
Mexico
C?ID=191104
Tried byte 18 bit 74, DRLs ON but bulb warning for rear Fog Light
rovafe56
Mexico
C?ID=191104
Can You please post autoscan?
To my knowledge, Byte18 has to be C2.
Again, tried byte 18 bit C2 now gave me both rear fogs error
Heres my autoscan with bit 74
Chassis Type: SE-VN35 (7N0)
VIN: WV1CAZSE2HX001747   Mileage: 19220km-11942miles
Address 01: Engine (J623-CWVA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 057 CB    HW: 04E 907 309 AL
   Component: R4 1.6l MPI   H23 2728
   Revision: 32H23000
   Coding: 00110052042400000000
   ASAM Dataset: EV_ECM16MPI01104E906057CB 001004
   ROD: EV_ECM16MPI_VN35.rod
   VCID: 69F75B3C880641026C-803C
   Revision: 00000000    Serial number: 43016000000427
   Coding: 109A42959362A47F087C427AC98925E32800F0
   VCID: 3FA3A564A6021FB2E2-806A
   Part No SW: 1K8 907 426 AT    HW: 1K8 907 426 AT
   Revision: 00001002
   Coding: 0010002002
   VCID: 052F778C845E8562E8-8050
   Part No SW: 5K0 937 085 AE    HW: 5K0 937 085 AE
   Component: BCM PQ35 B+   122 0184
   Revision: BH122001
   Coding: 6F1A5A3A8037202D08C800829000086403E5740852028860E48406040040
   Shop #: WSC 35110 377 00145
   VCID: 76CD0040C1B89EFAF1-8022
   Subsystem 1 - Part No: 2K1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 24101  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K0 951 605 F
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 235
                    Mileage: 19219 km
                    Date: 2019.01.11
                    Time: 15:26:28
                    Voltage: 11.90 V
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag00J H08 0018
   Revision: --------    Serial number: 003V3002LWCI
   Coding: 00000000000000000000000000000000304A
   VCID: 3A55D470BD203A9AD5-806E
   Part No SW: 1K5 953 521 CF    HW: 5K0 953 569 BB
   Revision: FF010042    Serial number: 20161031101223
   Coding: 4080160000
   VCID: 73CB3954DACA8BD2D6-8026
   Part No SW: 2K5 920 866 B    HW: 2K5 920 866 B
   Coding: 110A000300
   VCID: 334BF9549A4ACBD216-8066
   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1682
   Revision:   H58       Serial number: 021116F1000523
   Coding: 357400
   VCID: 79D70B7CF0A6F1829C-802C
   Component: IMMO          H03 1104
   VCID: 6AF524308D004A1A65-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 04 0173
   Coding: 0000000
   VCID: 76CD004001B89EFAF1-8022
   Component: EPS_ZFLS Kl. 309    3501
   Revision: 00H22000
   VCID: 3957CB7C70263182DC-806C
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75CF074C1CBE95E2F8-8020
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4R6221361
   Coding: 16000240020005
   Shop #: WSC 00078 790 00208
   VCID: 46ADB080F1D84E7AA1-8012
   Component: Batt.regelung H58 1682
   Coding: 01240864
   VCID: 71C7335CA8D6B9C224-8024
End-------------------------(Elapsed Time: 01:38)--------------------------
Here with bit C2
   Revision: 32H23000
   Revision: 00001002
   Coding: 0010002002
   Revision: BH122001
   Coding: 6F1A5A3A8037202D08C800829000086403E5C20852028860E48406040040
   Coding: 009795
01830 - Bulbs for Fog-Lamps; Rear
                    Reset counter: 238
                    Mileage: 19228 km
                    Date: 2019.01.12
                    Time: 12:19:56
                    Voltage: 12.30 V
   Coding: 4080160000
   Coding: 110A000300
   Coding: 357400
   Coding: 0000000
   Revision: 00H22000
   Coding: 0000000
   Coding: 01240864
siLc
Tallinn, Estonia
C?ID=330192
Is this RHD?
RHD telltale signs are missing from the autoscan. These usually are the wiper motor and steering rack part numbers, which RHD cars have a number 2 as the third letter instead of 0 or 1. Also speedo in km/h.
Given the location (Mexico), RHD strikes me as unlikely.
vastechnics
C?ID=143747
Then i don’t get the VIN ***CAZ.
rovafe56
Mexico
C?ID=191104
I’m in Mexico so is LHD
Best bit for me was C4, no errors, but now the rear parking lights and stop lights are on when the switch is on Parking and ON, they are dimmed, and when I press the stop pedal the stop lights gets brighter
