Current Versions
   #421
romad
Prescott, AZ
C?ID=208765
Bump for CB V0.4631
* Fixes for feature code handling with certain interfaces
* Improvements for comms with wifi and with certain newer platforms
Not sure if it is updated or not.
Launched VCDS-Mobile in Safari 13.1.2 on my iMac and selected check for updates. It found V0.4631 and started the download going through 3 steps:
1. Download
2. Verify
3. Extract files
All 3 ran successfully it appears.
However the next screen that came up in the window, was this one
And it has stayed that way for the last hour. On the Hex-Net LED1 is dark, LED2 is solid green, and LED3 is flashing green.
Edit. OK, I canceled out and started again. This time I'm told ETA: ~2 hours so I'll let it run and see what is what in 2 - 3 hours.
Edit 2. Well it ran through the 3 steps (apparently successfully) in only 35 minutes instead of the predicted 2 hours. It has gone into the ASAM Update screen again so we'll see what happens.
Edit 3. OK it is 3 hours later and I still have the same screen as above. Why is it not updating?
rs38
C?ID=519578
where can I find a change log for the new v23.3 ?
   #423
romad
Prescott, AZ
C?ID=208765
1. Download
2. Verify
3. Extract files
Bueller? Bueller? Bueller?
   #425
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Many changes are DoIP related, some are more broader as to compatibility with certain modules and of course updated ASAM/ODX data as well as label files etc. - @Uwe is in charge of the public changelog.
   #428
Shaun
Bump for beta CB V0.4639
* Improvements for VIN handling on certain platforms
* Comms and formatting fixes for certain platforms
* Support for ROD files with very long names
and beta DS's
DS 00000064
* Improvements for gw list
DS 20000063
* New rod data (DS337)
* Support for init options in mobile (bypass DoIP, bypass CAN etc.)
DS 20000062
* New rod data (DS325)
* Improvements to in-file timestamping
DS 20000061
   #429
Shaun
Bump for beta CB V0.4643
* Fix for select list on certain platforms
* Fix for VIN forgotten after ASAM update check
* Fixes for comm status results on certain platforms
   #430
Spacewalker
Poland
C?ID=159607
anyone can look why I can not download ASAM update ?
5 min awaing time and still nothing, reset mobile data, reset phone, use differente mobile data, re-connect Hex Next.
while connect to ECU, I see pop up message with warning "no asam data found localy" and checking update
then I see - update available , click download and waiting .....5 min later show 0kb
network test PING is 150-180ms
   #431
Shaun
Have you tried using VCIConfig?
   #433
Dana
Western PA, USA
Is that function exist in APP ? because right now I can only use APP in there ,
Good morning,
VCIConfig is the Windows based app that launches from VCDS after clicking Program Options > Config. It needs to be used via USB (no car required) and the Update tab should download RODs.
If that isn't working properly I can email you instructions so we can try to do a full reset of the internal SD card.
Shaun
Bump for CB V0.4643 now on release.
CB V0.4643
* Fixes for comms with certain platforms
* Fixes for VIN handling with certain platforms
   #435
rs38
C?ID=519578
is there a changelog from current release 23.11 compared to last release (afaik) 23.3.1 ?
   #436
would take your team 10 minutes to make it up2date.
As I've explained before, we're tired of having every clone-seller in the world copy & paste from there verbatim.
