- Feb 10, 2014
- 207
- 80
- Prescott, AZ
- C?ID=208765
Not sure if it is updated or not.Bump for CB V0.4631
* Fixes for feature code handling with certain interfaces
* Improvements for comms with wifi and with certain newer platforms
Launched VCDS-Mobile in Safari 13.1.2 on my iMac and selected check for updates. It found V0.4631 and started the download going through 3 steps:
1. Download
2. Verify
3. Extract files
All 3 ran successfully it appears.
However the next screen that came up in the window, was this one
And it has stayed that way for the last hour. On the Hex-Net LED1 is dark, LED2 is solid green, and LED3 is flashing green.
Edit. OK, I canceled out and started again. This time I'm told ETA: ~2 hours so I'll let it run and see what is what in 2 - 3 hours.
Edit 2. Well it ran through the 3 steps (apparently successfully) in only 35 minutes instead of the predicted 2 hours. It has gone into the ASAM Update screen again so we'll see what happens.
Edit 3. OK it is 3 hours later and I still have the same screen as above. Why is it not updating?
