Okay, Ross-Tech Audi brain trust, here you go – your insight is appreciated.
The transmission went into limp mode – directly into 5th gear upon shifting into drive.
PRND432 dash display is in relief, that is, surrounded by red, instead of being red lettering.
I can watch the measuring block trans. gear go to 1 and then immediately to 5. With brake on, engine RPM is 608, input RPM is 0.
Other contributing factors: The bottom of car was oil and antifreeze soaked after I made the sad mistake of letting a trusted shop replace my timing belt. Many leaks resulted, which I have now cleaned up. Wires were left out of mounting looms as well, that is, left loose. The car is my winter driver on salted secondary Iowa roads.
Prior to this time, the cruise control would drop out intermittently.
Trans filter and fluid changed some years back at 190,000 miles. Yes, I understand it is an old car.
It was suddenly slow to shift.
Vag-Com reads that the trans is in first, then goes directly to 5th. Car drives in 5th. Reverse works.
No leakage visible from trans
Pre-existing ABS brake error as well (Internal Control Module Memory Error) Wiring problem or death knell for module.
Battery was low - this scan is before DTC's were cleared.
Predominant error codes, which clear until the car is moved:
17117 - Gear 3 P0733 - 35-00 - Incorrect Ratio
17114 - Gear Ratio Monitoring P0730 - 35-00 - Incorrect Gear Ratio
18032 - MIL Request Signal Active (Check TCM for errors too!) P1624 - 35-00 –
17087 - Brake Switch (F) P0703 - 35-00 - Electrical Malfunction (My note: This is a pre-set malfunction which is erased if the brake switch is activated).
My pre-existing ABS error: 65535 - Internal Control Module Memory Error 35-10 - - - Intermittent
Full scan below.
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 35: DTCs cleared
Address 45: DTCs cleared
Address 55: DTCs cleared
Address 02: DTCs cleared
My plan so far: Check the F125 switch wiring and connector. Thoughts? Condolences? Here is a reference to the F125 switch: http://www.audipages.com/Tech_Articles/auto_transmission/f125switchreplace.html
And, hoping this obituary is premature:
This car, nicknamed Audrey by my wife, has had sooo many hail marys. The transmission that stopped shifting smoothly years ago, but came back after a fluid change and filter (yes, the magnet had 1 CC of metal dust). The cracked block that I watched drip antifreeze from inside the block, under a piston, into the oil pan when coolant was pressurized – the antifreeze boiled off in the summer, but collected in the winter; the oil never reached antifreeze, but the antifreeze dripped into oil! (Water glass fixed that many years ago – it held!) The ABS module replacement. The plugged body drains carrying a gallon of water inside the AC center duct, sloshing mysteriously. The oil cooler plastic pipe replacement. The air conditioning condenser replacement after the shop boogered it. And the problem that it came with originally – a leaky rear transaxle seal fixed without removing the transaxle. All four CV boots. Several brake calipers. Many pads. New tires and polished wheels, all paint removed, buffed to look like chrome, pristine. This light aluminum rocket could pass anything with a tap of the pedal, hug any curve (given the new upper and lower aluminum control arms) and claw through the Iowa snow and ice to get me home. It carried small cousins, sleeping soundly, on long trips. My then-toddler daughter scratched her initials in the door grips. But best of all, this car drove me to purchase Ross-tech Vag-com. My fellow mechanical engineers and controls gurus saw the parallels to the engineering work we do. It’s just a big, fun puzzle.
Full scan below.
Wednesday,30,November,2022,11:36:05:29481
VCDS Version: 22.3.0.1 (x64)
Data version: 20220225 DS336.1
Mileage: 311060km-193283mi Repair Order: A8 11-30-2022 POST ASSY PRE CLEAR
Chassis Type: 4D - Audi A8 D2 (1994 > 2003)
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
02
Mileage: 311060km-193283miles
Part No: 4D0 907 557 M
Component: 4.2L V8/4V MOTR AT D02
Coding: 01273
Shop #: WSC 02324
VCID: 366300C11234543F28-4AE8
P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D31
Shop #: BB 24302
VCID: 285FDEB9C88032CFAA-5122
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4D0 820 043 K
Component: D2-KLIMAVOLLAUTOMAT D05
Coding: 00180
Shop #: WSC 02324
VCID: 2447CA89B4A8D6AF86-2574
00801 - A/C Refrigerant High Pressure Switch (F118)
Address 15: Airbags Labels: 4D0-959-655-AI7.lbl
Part No: 4D0 959 655 H
Component: Airbag 7 Audi 050C
Coding: 00225
Shop #: WSC 02324
VCID: 377D0DC5153EAD3733-5122
Address 17: Instruments Labels: 4D0-919-033-MYW.lbl
Part No: 4D0 919 035 P
Component: D2-KOMBIINSTRUMENT D53
Coding: 00283
Shop #: WSC 02324
VCID: 336539D5014641170F-5074
Address 35: Centr. Locks Labels:. 8D0-862-257.clb
Part No: 8L0 862 257 N
Component: CV-Pump D06
Coding: 16140
Shop #: WSC 02324
VCID: 408F661940F0EA8F82-4ECE
35-00 - -
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 8L0 951 173
Component: Innenraumueberw. D04
Coding: 00001
VCID: 6ED3E8A12AE42CFF20-4B4C
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00008
Shop #: WSC 02324
VCID: 65C1978DFF12EFA751-5140
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4D0 035 186 B
Component: Radio D03
VCID: 2149C39DABBAC387ED-4B00
No Faults Found
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 BH
Component: AG5 01L 4.2l4V USA 1313
Coding: 00002
VCID: 70EFF6D930D03A0F32-5122
17117 - Gear 3
End-------------------------(Elapsed Time: 04:58)--------------------------
02
Coding: 01273
Shop #: WSC 02324
VCID: 366300C11234543F28-4B00
Readiness: N/A
Shop #: BB 24302
Coding: 00180
Shop #: WSC 02324
VCID: 2447CA89B4A8D6AF86-256C
Coding: 00225
Shop #: WSC 02324
VCID: 377D0DC5153EAD3733-515E
Coding: 00283
Shop #: WSC 02324
VCID: 336539D5014641170F-5058
Coding: 16140
Shop #: WSC 02324
VCID: 408F661940F0EA8F82-4EEA
Coding: 00001
VCID: 6ED3E8A12AE42CFF20-4B32
Coding: 00008
Shop #: WSC 02324
VCID: 65C1978DFF12EFA751-515E
VCID: 55A1A74DAC727F27C1-4B00
Note: Excessive Comm Errors
Coding: 00002
End-------------------------(Elapsed Time: 05:13)--------------------------
02
Coding: 01273
Shop #: WSC 02324
Readiness: N/A
Shop #: BB 24302
Coding: 00180
Shop #: WSC 02324
30-00 - Open or Short to Plus
Coding: 00225
Shop #: WSC 02324
VCID: 377D0DC5153EAD3733-5140
Coding: 00283
Shop #: WSC 02324
Coding: 16140
Shop #: WSC 02324
Coding: 00001
Coding: 00008
Shop #: WSC 02324
Coding: 00117
Shop #: WSC 00001
No Faults Found
Coding: 00002
VCID: 70EFF6D930D03A0F32-515E
End-------------------------(Elapsed Time: 04:46)--------------------------
