Monday,07,November,2022,13:35:14:17718
VCDS Version: 22.9.0.0 (x64) HEX-NET CB: 0.4623.4
VIN: TMBKB7NS8L8512424 License Plate:
Mileage: 15728km-9772mi Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 42 44 4B 52 5F 6D 75 BB
BC D6 D7
VIN: TMBKB7NS8L8512424 Mileage: 15728km-9772miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
4B-Multifunc. Module -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DPCA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 BC HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9597
Revision: 8AH20000 CVN: 5586D059
Coding: 0125003223241D0830000000000000000000000000000000
ASAM Dataset: EV_ECM15TFS01105E906018BC 003003
ROD: EV_ECM15TFS01105E906018BC_003_SK37.rod
VCID: 679E9C5F9E28E2B5E2-8032
VINID: 91D49B4877A321C205042102108F8D0149
Readiness: 1110 0001
Part No SW: 0GC 300 046 A HW: 0GC 927 711 H
Component: GSG DQ381 H06 2403
Revision: 00H06V09 CVN: 6C8BCC85
ASAM Dataset: EV_TCMDQ381061 001001
ROD: EV_TCMDQ381061.rod
VCID: 281CDF6353B62DCD2B-807C
No subsystems:
Part No SW: 5Q0 614 517 DK HW: 5Q0 614 517 BN
Component: ESC H35 0113
Revision: 00000000 Serial number: 60020000000207
Coding: 6007929F4021236E477B060262C749064902C4E26046927130215078D2024A0B00002E64121A03102F35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW37.rod
VCID: 7DB2DE37ECB4586528-8028
8196 - Databus
[FCAN : ACC_10 message is not received]
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:38
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0537152297
Coding: 032C0C0723
Shop #: WSC 00033 790 00145
ROD: EV_KessyHellaMQBAB.rod
VCID: 45C276D7C4E4D0A530-8010
Part No SW: 565 907 044 CF HW: 565 907 044 CF
Component: Climatronic H04 2202
Revision: 00001K00
Coding: 16110004000110011005000800101026
ASAM Dataset: EV_ACClimaBHBVW37X 006150
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 618A8247700C9C852C-8034
Air quality sensor:
Subsystem 3 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H31 0120
Serial number: 84040159
Part No SW: 5Q0 937 086 CE HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: J53F09121900N0
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 7F4E243FE6B84A753A-802A
Wiper motor control module:
Subsystem 1 - Part No SW: 567 955 119 HW: 567 955 119
Component: WWS326 191024 051 0910
Serial number: 887253F0401929700129
Coding: 164DDD
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SBY19M12D16H19M50S44
Coding: 00885D
Serial number: 000000000ZY193252AC6
Subsystem 4 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000799756
Humidity sensor: interior:
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 521 P HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100121220190C301867
Part No SW: 3Q0 919 294 E HW: 3Q0 919 294
Component: PDC 8 Kanal H08 0046
Serial number: 000211199448081
Coding: 0071051011
ASAM Dataset: EV_EPHBO18VW3260000 007021
ROD: EV_EPHBO18VW3260000_SK37.rod
VCID: 3B36102FB220965556-806E
Address 13: Auto Dist. Reg
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PQ0GCE4
Coding: 98CCC0C0000000005C5400CF008840000065
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0B5680EFA20066D526-805E
Subsystem 1 - Part No SW: ----------- HW: 454 001 511 19
Serial number: 3570000000041998134B
Subsystem 2 - Part No SW: ----------- HW: 454 001 811 19
Serial number: 35800000000EC99C8240
Subsystem 3 - Part No SW: ----------- HW: 454 800 311 19
Serial number: 351000584641A0000004
Subsystem 4 - Part No SW: ----------- HW: 454 800 811 19
Serial number: 35200766B661A000000K
Subsystem 5 - Part No SW: ----------- HW: 454 802 610 19
Serial number: 3550045C23A1A000000H
Part No SW: 565 920 950 C HW: 565 920 950 C
Component: KOMBI 303 6700
Coding: 27A4011C2B80A60001886A011001000880000000
VCID: 1C74F3B317EEF16DBF-8048
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_AWV_0x1B keine Kommunikation]
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:40
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 17121910802399
Coding: 030100047F085700AB10024A180F00010001070000000000000000000000
Shop #: WSC 00033 790 00172
GVL: 01463C0008000600400C80008000C80000000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 70ACF703ABE6250DB3-8024
Generator:
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E
Component: E221__MFL-PR6 H03 0180
Serial number: 000000000E2435201219
Subsystem 3 - Part No SW: 5QA 915 181 C HW: 5QA 915 181 C
Component: J367-BDMConti H03 1051
Serial number: 7588610300191227069B
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:38
Terminal 30 power supply: 12.3 V
Terminal 15: On
8526363 - Crash Shut-Down
B189C F0 [009] - Active
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:38
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000331170001
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 3326380F9A705E158E-8066
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000400684067
Coding: 00100820D001020000001100
ROD: EV_DCU2DriveSideMAXHCONT_SK37.rod
VCID: 4DD24EF71C9428E5F8-8018
Subsystem 1 - Part No SW: 5Q0 959 408 A HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000036778298
Coding: 1D0200
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74A4FB13DFFE192D57-8020
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 12121911601261
Coding: 000000070900036E00003D01190000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 373E0C1F8E08B235B2-8062
66881 - Databus
[LED_L_falsch_codiert received error value]
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000400138391
Coding: 00100020D001020000001100
ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
VCID: 4CD443F3E78E21EDEF-8018
Subsystem 1 - Part No SW: 5Q0 959 407 A HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000036560832
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
Part No SW: 565 035 021 E HW: 565 035 021
Component: MU-H-LND-EU H55 1440
Serial number: A853L0KP023190
Coding: 03231601FF0000004111120100880A102F0100C601200500DE
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 106C9783CB26450DD3-8044
Subsystem 1 - Part No SW: 565 919 606 D HW: 565 919 606 D
Component: ABT_High-2 H53 9130
Serial number: SKZ6ZHX0051657
Data carrier:
Subsystem 2 - Part No SW: V03 959 803 TF HW: -----------
Component: ECE 2019/2020 --- 0177
Compact disc data bank:
Component: Gracenote2 --- 1017
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:42
Voltage terminal 30: 12.5 V
BAP-BAP_Function_ID: 02
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C737-6291-8
Coding: 1B08
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 48DC7FE3F3F6CDCDCB-801C
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0827
Revision: --------
Coding: 03231601EA421A0D3F1C9E000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_AU21.rod
VCID: 3D321E37AC34986568-8068
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Component: LED1L H07 0011
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 0444ABD38F5E29AD67-8050
0019 - Headlamp Type
C119F 00 [175] - Implausible
Reset counter: 0
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0011
End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.1V)-----------
Monday,07,November,2022,13:45:18:17718
BC D6 D7
No subsystems:
8196 - Databus
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:38
Coding: 032C0C0723
Revision: 00001K00
Air quality sensor:
Coding: 164DDD
Coding: 00885D
Coding: 0071051011
U1110 00 [009] - -
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:40
16776960 - Databus
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
16776961 - Databus
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
Generator:
U0235 00 [009] - -
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:38
Terminal 15: On
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:38
Terminal 15: On
Coding: 1D0200
Coding: 81170000
66881 - Databus
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
Coding: 050200
Data carrier:
U1111 00 [009] - -
Reset counter: 45
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:42
Coding: 1B08
Revision: --------
Reset counter: 0
Mileage: 15728 km
Date: 2022.09.26
Time: 23:06:37
End----(Elapsed Time: 01:50, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
I have a 2020 Tiguan after accident. The left front LED headlight was broken and the controller missing. I changed the controller with a used one from ebay with the same part no. but the light not working in the same way. Probably need coding. Could anybody help? Thank you.
