RANDOM NO START
DPATE
Mason City, IA, USA
C?ID=529025
I have a 2003 Passat V-6 with about 110,000. It runs great but randomly it won't start. It cranks and turns over fine but don't seem to be firing. If I try over and over enough times it starts. I replaced the coil pack with an aftermarket one. It ran better than ever and started every time for about two weeks then went back to random no start. . I was asked if I had a VCDS to scan it. I didn't so I ordered one. It gives me these codes...
19537 Engine temperature too low
P3081-35-00
17801 Ignition Coil Power Output 1
P1393-35-00 Electrical Malfunction
17802 Ignition Coil Power Output 2
P1394-35-00 Electrical Malfunction
17803 Ignition Coil Power Output 3
P1395-35-00 Electrical Malfunction
Where do I start? Temp sender? Another coil pack??
Where do I start?
Greetings and Welcome and thanks for the information, but......, You need to post a complete and unedited Auto-Scan. Please see the Blue tool bar at the top of this page "How-To" , click on it and a pull down menu will display, choose How to post a Auto-Scan. That way, all the VW members can see what they are dealing with and then they will advise accordingly.
DPATE
Mason City, IA, USA
C?ID=529025
It sounds very complicated and I am not sure I follow it all but I will attempt to.
Just click on the </> icon and a new box will open for you to paste the text of the Auto-Scan :thumbs:
Sounds good, and don't worry about a couple of attempts if it doesn't display well ; Admin. "will clean it up" (per your request) if it gets a bit messy! :D
DPATE
Mason City, IA, USA
C?ID=529025
I did it!
Saturday,24,September,2022,12:48:24:11174
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: WVWYH63B63E016688   License Plate:
VIN: WVWYH63B63E016688   Mileage: 193650km-120328miles
Address 01: Engine        Labels: 078-907-551-ATQ.lbl
   Part No: 3B0 907 551 CR
   Component: 2.8L V6/5V      G   0002
   Coding: 07251
   Shop #: WSC 05311
   VCID: 75B7EDC0FCD38CC3C45-5160
   WVWYH63B63E016688     VWZ7Z0B5367981
17530 - Oxygen (Lambda) Sensor Heating; B2 S2
            P1122 - 35-00 - Open Circuit
17548 - Oxygen (Lambda) Sensor; B2 S2
            P1140 - 35-00 - Internal Resistance too High
19537 - Engine Temperature too Low
            P3081 - 35-00 -
17801 - Ignition Coil Power Output 1
            P1393 - 35-00 - Electrical Malfunction
17802 - Ignition Coil Power Output 2
            P1394 - 35-00 - Electrical Malfunction
17803 - Ignition Coil Power Output 3
            P1395 - 35-00 - Electrical Malfunction
   Part No: 3B0 927 156 AK
   Component: AG5 01V 2.8l5V  USA 3940
   Coding: 00102
   Shop #: WSC 05311
   VCID: 6FBBDFA89E8FB6130E9-5160
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Shop #: BB 24334
   VCID: 1C61D8643FB97D8B1BB-51CE
   Part No: 3B1 907 044 J
   Component: CLIMATRONIC B5GP    0005
   Coding: 17200
   Shop #: WSC 05311
   VCID: 2809F4B47BE1A12B8F3-5184
00603 - Footwell/defroster Flap Positioning Motor (V85)
            37-00 - Faulty
01271 - Positioning Motor for Temperature Flap (V68)
            37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
            37-00 - Faulty
            37-00 - Faulty
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0001
   Coding: 12345
   Shop #: WSC 05311
   VCID: 2411E08407C9454BA3B-513C
00532 - Supply Voltage B+
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0004
   Coding: 00118
   Shop #: WSC 05314
   VCID: 2F3B1FA85E0FF6134E9-523C
   Part No: 3B0 920 927 B
   Component: KOMBI+WEGFAHRSP VDO V08
   Coding: 07235
01039 - Coolant Temperature Sensor (G2)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.clb
   Part No: 6N0 909 901
   Coding: 00004
   Shop #: WSC 05314
   VCID: 70B9DCD483B1A9EB173-513C
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: Sitzverstellung     0301
   VCID: 2F3B1FA85B0FF6134E9-513C
01008 - Note; Emergency OFF Switch is Active!
01010 - Sensor for Driver's Seat Recline (G219)
00998 - Motor for Driver's Seat Recline (V45)
   Part No: 1C0 959 799 C
   Component: 81 Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 05311
   VCID: 372B27C8A65F3ED3169-4B1E
   Subsystem 1 - Part No: 1C0959801
   Component: 81 Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C0959802A
   Component: 81 Tõrsteuer.BF KLO 0006
   Subsystem 3 - Part No: 1C0959811
   Component: 81 Tõrsteuer.HL KLO 0004
   Subsystem 4 - Part No: 1C0959812
   Component: 81 Tõrsteuer.HR KLO 0004
            27-00 - Implausible Signal
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180
   Component:    Radio NP2        0055
   Coding: 04031
   Shop #: WSC 05311
   VCID: 5DE7956064233483AC5-513C
End----(Elapsed Time: 04:10, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
DPATE
Mason City, IA, USA
C?ID=529025
I'm attempting to replace the temp sensor now. Afterward should I clear the codes and drive it?
I would. But I suspect there's also an issue with the ignition circuitry for bank 1 of your engine that will need to be addressed.
JMR
Romania
C?ID=432218
i would suspect a bad grounding point ? I'm not sure if on this engine the grounding point is connected to all six packs...perhaps there is 1 ground point for a bank and another for bank 2 ?
You also need to check your number 2 lambda sensor ..either is burned or have bad wiring/connector problem.
TFSI
Maryland, USA
C?ID=66650
If you think the engine temp sender is the bad boy, you can unplug it and try to start if u see any change.
DPATE
Mason City, IA, USA
C?ID=529025
I have been struggling trying to install the new temp sensor since Sunday. I don't know what I'm doing wrong....I cannot get it down far enough for the clip to grab it. I haven't had a car for days now.
DPATE
Mason City, IA, USA
C?ID=529025
Tuesday,04,October,2022,19:00:07:11174
VIN: WVWYH63B63E016688   Mileage: 193670km-120340miles
   Coding: 07251
   Shop #: WSC 05311
9 Faults Found:
            P0300 - 35-00 -
16686 - Cylinder 2
            P0302 - 35-00 - Misfire Detected
17831 - Secondary Air Injection System; Bank 1
            P1423 - 35-00 - Insufficient Flow
17819 - Secondary Air Injection System; Bank 2
            P1411 - 35-00 - Insufficient Flow
Readiness: 0110 1101
   Coding: 00102
   Shop #: WSC 05311
   Shop #: BB 24334
   Coding: 17200
   Shop #: WSC 05311
            37-00 - Faulty
            37-00 - Faulty
   Coding: 12345
   Shop #: WSC 05311
   Coding: 00118
   Shop #: WSC 05314
   Coding: 07235
   Coding: 00004
   Shop #: WSC 05314
   Coding: 00258
   Shop #: WSC 05311
   Coding: 04031
   Shop #: WSC 05311
End----------(Elapsed Time: 04:07, VBatt start/end: 12.3V/12.3V)-----------
DPATE
Mason City, IA, USA
C?ID=529025
This is after I put the temp sensor in and it was driven a few miles.
EuroX
Northern NJ USA
C?ID=208579
I suspect shit quality coil or loose ground for coil. Were the wires checked going to the plugs?? IIRC this engine does not have COP unless I am mistaken. I would be checking wires to plugs, ground for coil and of course suspect very low quality coil being the issue.
DPATE
Mason City, IA, USA
C?ID=529025
I will double check all connections. So should I put a Volkswagon coil pack in?
EuroX
Northern NJ USA
C?ID=208579
Check the basic's first doesn't have to be a vw coil but I would get one from a reputable vendor not from amazon.
DPATE
Mason City, IA, USA
C?ID=529025
This is what I installed, it has a 5 year guarantee. There are more expensive ones listed on Rockauto. I have had good luck with other parts I have purchased from them.
DPATE
Mason City, IA, USA
C?ID=529025
Tuesday,18,October,2022,17:52:32:11174
VIN: WVWYH63B63E016688   Mileage: 194500km-120856miles
   Coding: 07251
   Shop #: WSC 05311
            P1423 - 35-10 - Insufficient Flow - Intermittent
16825 - EVAP Emission Control Sys
            P0441 - 35-00 - Incorrect Flow
Readiness: 0010 1001
   Coding: 00102
   Shop #: WSC 05311
   Shop #: BB 24334
   Coding: 17200
   Shop #: WSC 05311
            37-00 - Faulty
            37-00 - Faulty
            37-00 - Faulty
            37-00 - Faulty
   Coding: 12345
   Shop #: WSC 05311
   Coding: 00118
   Shop #: WSC 05314
   Coding: 07235
   Coding: 00004
   Shop #: WSC 05314
   Coding: 00258
   Shop #: WSC 05311
   Coding: 04031
   Shop #: WSC 05311
End----------(Elapsed Time: 04:02, VBatt start/end: 12.2V/12.2V)-----------
