[Controller Channels Map] Snapshot
Ryan.Carver
Seattle, WA, USA
C?ID=42996
My new-to-me 2012 Audi TT Quattro 2.0T is headed in for its first service visit in a couple weeks. I have a several stored codes that I need to ensure stay logged in the ECU, for warranty purposes. I use a HEX+CAN interface that I purchased lonnnnng ago. I am planning to use the [Controller Channels Map] function found in the Applications Screen to make a backup of my control modules and adaptation channels, prior to my visit. At the very least, I want a backup of my ABS Control Module. (See the Auto-Scan Log.)
  • Does anyone know if performing a "snapshot" with the above mentioned process will clear stored codes from the ECU?
//COMPLETE AUTO-SCAN LOG
Thursday,19,August,2021,09:23:27:36494
VCDS Version: 21.3.0.0 (x64)
VIN: TRUBFAFK5C100XXXX   License Plate: I<3TACOS
Mileage: 180280km-112020mi   Repair Order:
Chassis Type: FK-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 37 42 44 46 47 4C 52 55
          56 61 77
VIN: TRUBFAFK5C100XXXX   Mileage: 180280km-112020miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CET)       Labels:. 06J-907-115-CES.clb
   Part No SW: 8J0 907 115 BD    HW: 8J0 907 115 AJ
   Component: 2.0l R4/4V AVS   01 0010
   Revision: EIH06---    Serial number: AUX7Z0K6FNI0C0
   Coding: 0113010A1C0F0160
   Shop #: WSC 01236 785 00200
   VCID: 6FED13307E1382F32A-803A
000665 - Boost Pressure Regulation
               P0299 - 000 - Control Range Not Reached - Intermittent
                    Mileage: 180061 km
                    Date: 2021.08.14
                    Time: 15:33:03
                    RPM: 3279 /min
                    Load: 87.0 %
                    Speed: 69.0 km/h
                    Temperature: 98.0°C
                    Temperature: 46.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
   Part No SW: 02E 300 013 T    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 2743
   Revision: 06454104    Serial number: 00001911250131
   Shop #: WSC 04940 001 00001
   VCID: 224B2A04FD417F9BF5-8076
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 E    HW: 8J0 614 517 E
   Component: ESP MK60E1          0010
   Revision: 00H60001
   Coding: 0610195
   Shop #: WSC 59024 001 1048576
   VCID: 2F6DD330BE93C2F36A-807A
                    Fault Status: 00101101
                    Reset counter: 43
                    Mileage: 179548 km
                    Date: 2021.08.05
                    Time: 12:05:36
                    Count: 25600
                    Count: 8193
                    Count: 8193
                    Count: 52480
   Part No SW: 8J0 820 043 BC    HW: 8J0 820 043 BC
   Component: J255  Klima 1 Zone  0110
   Revision: 00H09006    Serial number: 00000001191742
   Coding: 1572900
   VCID: 68DF782C5BFD55CB6B-803C
   Part No SW: 8P0 907 063 S    HW: 8P0 907 063 S
   Component: BCM PQ35  H   110 0653
   Revision: 00110 AD
   Coding: 6E000B0FA81336242074C9E001100D4D50FE77AA1020D928DC000A440041
   Shop #: WSC 01236 758 00200
   VCID: 44878C9CC71551ABA7-8010
   Subsystem 1 - Part No SW: 8J1 955 119 A    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H08 0070
   Coding: 00FD10
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 02492C
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101010
                    Fault Frequency: 32
                    Reset counter: 29
                    Mileage: 178244 km
                    Date: 2021.06.01
                    Time: 09:17:46
                        Term 15 On
                    Voltage: 14.65 V
                        Term 50 Off
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0602074
   Coding: 0000100
   VCID: 3663E65441C9F33B29-8062
                    Reset counter: 196
                    Mileage: 178575 km
                    Date: 2021.06.22
                    Time: 12:42:52
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: 20 Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K005EBT2
   Coding: 0012848
   VCID: 79F92D683057DC4384-802C
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 05MGW
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40DC85416Wÿ†63
   Subsystem 5 - Serial number: 85416Wÿ†6342DRB40DC3C70D1ÿ†63
   Subsystem 6 - Serial number: 3C70D1ÿ†63747RB4064290CBRÿ†63
   Subsystem 7 - Serial number: 290CBRÿ†63847RB406429062Dÿ
   Subsystem 8 - Serial number: 29062Dÿ
   Component: J0527           H37 0070
   Coding: 0014141
   VCID: 46839694312963BBB9-8012
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 990 Q    HW: 8J0 920 990 Q
   Component: KOMBIINSTR. VDO H02 0650
   Revision: D0H02002    Serial number: 2246K002000596
   Coding: 0273288
   Shop #: WSC 12345 123 12345
   VCID: 408F808C130D4D8B83-8014
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 160711F2000779
   Coding: 354100
   VCID: 377DEB5086C30A3332-8062
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 458191980C2F68A3B0-8010
   Revision: D0H02002    Serial number: AUX7Z0K6FNI0C0
   Shop #: WSC 26105 444 100708
   Part No SW: 8J0 035 193 F    HW: 8J0 035 193 F
   Component: RNS-E PU US     H06 0260
   Revision: 0000013S    Serial number: AUZBZ7LD801062
   Coding: 0610677
   VCID: 2D51C938B49FB0E358-8078
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8J8 959 801 J    HW: 8J8 959 801 J
   Component: Tuer-SG         004 0102
   Coding: 0001077
   VCID: 44878C9C071551ABA7-8010
   Part No: 8J0 909 144 M
   Component: EPS_ZFLS Kl. 236    3201
   Revision: 00H20000
   VCID: 3A7BF26475D1175BCD-806E
Address 47: Sound System (J525)       Labels:* 8J0-035-223.lbl
   Part No SW: 8J0 035 223 F    HW: 8J0 035 223 F
   Component: Audi TT Amp5K H05 0170
   Revision: --------    Serial number: BP208319867335
   Coding: 060101060002
   ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
   ROD: EV_AudioAmpli5ChannBNO1_003.rod
   VCID: 275D3B105E639AB3A2-8072
Address 4C: Tire Pressure II        Labels: 8J0-907-274.lbl
   Part No SW: 8J0 907 274 C    HW: 4F0 907 274
   Component: J793  RKA+      H04 0190
   Revision: 00000518    Serial number: 00005180075860
   Coding: 0614600
   VCID: 326BDA44ADA1EF1B05-8066
01316 - ABS Control Module
                    Reset counter: 42
                    Mileage: 179548 km
                    Date: 2021.08.05
                    Time: 12:05:40
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.50 V
                    Temperature: 27.0°C
                    (no units): 102.0
   Part No SW: 8J8 959 802 J    HW: 8J8 959 802 J
   Coding: 0001076
   Part No: 8P3 907 357 B
   Coding: 0000010
   VCID: 3C77F47C7FE5296BDF-8068
   Coding: 0610677
   Component: Batt.regelung H43 1620
   Coding: F320115A
   VCID: 71E91548A82794033C-8024
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650940404
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005156011
   Coding: 0011477
End-------------------------(Elapsed Time: 02:32)--------------------------
Making a controller channel map should not have any effect on fault codes.
Ryan.Carver
Seattle, WA, USA
C?ID=42996
Gracias, Uwe! Will report back any difficulties. Otherwise, assume all is good. ;)
Ryan.Carver
Seattle, WA, USA
C?ID=42996
So, I did have a little hiccup making a backup. Stored codes were retained (whew!) and I saved my output as a .CSV-File. But, I could not output as "Raw Hex". I searched around and came across THIS THREAD before posting a reply. I have a HEX+CAN interface, but it gives me the following nastygram, "Only current generation interfaces support this feature. Please upgrade to a current Ross-Tech Interface." I thought the "HEX" in the naming convention of HEX+CAN implied that I could backup and restore .HEX-Files? Please advise.
Bruce
Near Philadelphia, PA, USA
The HEX in the name of the products have to do with our partner in design. Their company name includes the word "HEX".
The name has nothing to do with what VCDS is capable of doing.
You need a current generation HEX interface to perform a raw hexadecimal file output. (HEX-V2 or HEX-NET)
ColinT
Scotland
C?ID=43234
I had a hex can a few years ago, bought a hex v2 earlier this year. It does indeed allow you to save data in hex format so that it can be restored.
