- Aug 19, 2021
- 59
- 29
- Seattle, WA, USA
- C?ID=42996
My new-to-me 2012 Audi TT Quattro 2.0T is headed in for its first service visit in a couple weeks. I have a several stored codes that I need to ensure stay logged in the ECU, for warranty purposes. I use a HEX+CAN interface that I purchased lonnnnng ago. I am planning to use the [Controller Channels Map] function found in the Applications Screen to make a backup of my control modules and adaptation channels, prior to my visit. At the very least, I want a backup of my ABS Control Module. (See the Auto-Scan Log.)
//COMPLETE AUTO-SCAN LOG
- Does anyone know if performing a "snapshot" with the above mentioned process will clear stored codes from the ECU?
Thursday,19,August,2021,09:23:27:36494
VCDS Version: 21.3.0.0 (x64)
VIN: TRUBFAFK5C100XXXX License Plate: I<3TACOS
Mileage: 180280km-112020mi Repair Order:
Chassis Type: FK-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 37 42 44 46 47 4C 52 55
56 61 77
VIN: TRUBFAFK5C100XXXX Mileage: 180280km-112020miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CET) Labels:. 06J-907-115-CES.clb
Part No SW: 8J0 907 115 BD HW: 8J0 907 115 AJ
Component: 2.0l R4/4V AVS 01 0010
Revision: EIH06--- Serial number: AUX7Z0K6FNI0C0
Coding: 0113010A1C0F0160
Shop #: WSC 01236 785 00200
VCID: 6FED13307E1382F32A-803A
P0299 - 000 - Control Range Not Reached - Intermittent
Mileage: 180061 km
Date: 2021.08.14
Time: 15:33:03
RPM: 3279 /min
Load: 87.0 %
Speed: 69.0 km/h
Temperature: 98.0°C
Temperature: 46.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
Part No SW: 02E 300 013 T HW: 02E 927 770 AT
Component: GSG DSG AG6 541 2743
Revision: 06454104 Serial number: 00001911250131
Shop #: WSC 04940 001 00001
VCID: 224B2A04FD417F9BF5-8076
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 E HW: 8J0 614 517 E
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0610195
Shop #: WSC 59024 001 1048576
VCID: 2F6DD330BE93C2F36A-807A
Fault Status: 00101101
Reset counter: 43
Mileage: 179548 km
Date: 2021.08.05
Time: 12:05:36
Count: 25600
Count: 8193
Count: 8193
Count: 52480
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 BC HW: 8J0 820 043 BC
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001191742
Coding: 1572900
VCID: 68DF782C5BFD55CB6B-803C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 S HW: 8P0 907 063 S
Component: BCM PQ35 H 110 0653
Revision: 00110 AD
Coding: 6E000B0FA81336242074C9E001100D4D50FE77AA1020D928DC000A440041
Shop #: WSC 01236 758 00200
VCID: 44878C9CC71551ABA7-8010
Subsystem 1 - Part No SW: 8J1 955 119 A HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00FD10
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02492C
01503 - Bulb for 3rd Brake Light (M25)
Fault Status: 00101010
Fault Frequency: 32
Reset counter: 29
Mileage: 178244 km
Date: 2021.06.01
Time: 09:17:46
Voltage: 14.65 V
Term 50 Off
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7L0602074
Coding: 0000100
VCID: 3663E65441C9F33B29-8062
Reset counter: 196
Mileage: 178575 km
Date: 2021.06.22
Time: 12:42:52
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: 20 Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K005EBT2
Coding: 0012848
VCID: 79F92D683057DC4384-802C
Subsystem 1 - Part No: 8J0 910 339 A
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 05MGW
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB40DC85416Wÿ†63
Subsystem 5 - Serial number: 85416Wÿ†6342DRB40DC3C70D1ÿ†63
Subsystem 6 - Serial number: 3C70D1ÿ†63747RB4064290CBRÿ†63
Subsystem 7 - Serial number: 290CBRÿ†63847RB406429062Dÿ
Subsystem 8 - Serial number: 29062Dÿ
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014141
VCID: 46839694312963BBB9-8012
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 990 Q HW: 8J0 920 990 Q
Component: KOMBIINSTR. VDO H02 0650
Revision: D0H02002 Serial number: 2246K002000596
Coding: 0273288
VCID: 408F808C130D4D8B83-8014
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 160711F2000779
Coding: 354100
VCID: 377DEB5086C30A3332-8062
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 458191980C2F68A3B0-8010
Revision: D0H02002 Serial number: AUX7Z0K6FNI0C0
Shop #: WSC 26105 444 100708
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 F HW: 8J0 035 193 F
Component: RNS-E PU US H06 0260
Revision: 0000013S Serial number: AUZBZ7LD801062
Coding: 0610677
VCID: 2D51C938B49FB0E358-8078
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 J HW: 8J8 959 801 J
Component: Tuer-SG 004 0102
Coding: 0001077
VCID: 44878C9C071551ABA7-8010
Part No: 8J0 909 144 M
Component: EPS_ZFLS Kl. 236 3201
Revision: 00H20000
VCID: 3A7BF26475D1175BCD-806E
Address 47: Sound System (J525) Labels:* 8J0-035-223.lbl
Part No SW: 8J0 035 223 F HW: 8J0 035 223 F
Component: Audi TT Amp5K H05 0170
Revision: -------- Serial number: BP208319867335
Coding: 060101060002
ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
ROD: EV_AudioAmpli5ChannBNO1_003.rod
VCID: 275D3B105E639AB3A2-8072
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 C HW: 4F0 907 274
Component: J793 RKA+ H04 0190
Revision: 00000518 Serial number: 00005180075860
Coding: 0614600
VCID: 326BDA44ADA1EF1B05-8066
Reset counter: 42
Mileage: 179548 km
Date: 2021.08.05
Time: 12:05:40
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.50 V
Temperature: 27.0°C
(no units): 102.0
Part No SW: 8J8 959 802 J HW: 8J8 959 802 J
Coding: 0001076
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H01 0010
Coding: 0000010
VCID: 3C77F47C7FE5296BDF-8068
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0610677
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: F320115A
VCID: 71E91548A82794033C-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650940404
Part No SW: 8P1 862 336 A HW: 8P1 862 336
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005156011
Coding: 0011477
End-------------------------(Elapsed Time: 02:32)--------------------------
