- May 20, 2021
- 22
- 18
- Reading, UK
- C?ID=438310
Hi there
any advice would be much appreciated!
Wednesday,28,July,2021,11:31:54:20013
VCDS Version: 21.3.0.0 (x64) HEX-NET2 CB: 0.4543.4
VIN: WV1ZZZ7HZHH119698 License Plate: LJ17WKH
Mileage: 118420km-73582mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZHH119698 Mileage: 118420km-73582miles
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 3802
Revision: 23002001
Coding: 00194014433401090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 0154EFD9518DE8D380D-8054
9 Faults Found:
25792 - Mass Air Flow Sensor (G70)
P0101 00 [032] - Implausible Signal
Mileage: 118429 km
Date: 2050.01.21
Time: 00:00:20
Engine RPM: 0.00 /min
Coolant temperature: 24 °C
Intake air temperature: -29 °C
Voltage terminal 30: 11.585 V
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.30 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.000 bar
Absolute intake pressure: 99 kPa abs
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 4
Index of next requested engine mode: 4
Index of engine target mode: 4
13174 - Mass Air Flow Sensor (G70)
P0103 00 [032] - Signal too High
Mileage: 118429 km
Date: 2050.01.21
Time: 00:00:20
Voltage terminal 30: 11.554 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.17 %
25577 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Date: 2000.01.00
Time: 00:00:00
Engine RPM: 87.75 /min
Coolant temperature: 29 °C
Intake air temperature: 0 °C
Voltage terminal 30: 4.914 V
Immobilizer Snapshot 001 Byte 1: 14
Immobilizer Snapshot 001 Byte 2: 00
Immobilizer Snapshot 001 Byte 3: 0A
Immobilizer Snapshot 001 Byte 4: 49
Immobilizer Snapshot 001 Byte 5: 30
Immobilizer Snapshot 001 Byte 6: 00
Immobilizer Snapshot 002 Byte 1: 00
Immobilizer Snapshot 002 Byte 2: 00
Immobilizer Snapshot 002 Byte 3: 00
Immobilizer Snapshot 002 Byte 4: 00
Immobilizer Snapshot 002 Byte 5: 00
Immobilizer Snapshot 002 Byte 6: 00
Immobilizer Snapshot 004 Byte 1: 00
Immobilizer Snapshot 004 Byte 2: 00
Immobilizer Snapshot 004 Byte 3: 00
25796 - Body Control Module (Central Electric)
U0140 00 [047] - No Communications
Fault Frequency: 19
Mileage: 118429 km
Date: 2049.01.23
Time: 10:01:12
Engine RPM: 827.75 /min
Normed load value: 32.5 %
Coolant temperature: 32 °C
Intake air temperature: 14 °C
Voltage terminal 30: 14.140 V
Accelerator pedal travel: raw value: 0.00 %
CAN status - engine control module: 0
Cruise Control System (CCS): status: passive
selected gear: Shifting process active
32111 - Voltage Supply for Particulate Sensor
P24D0 00 [032] - Short to GND
Mileage: 118429 km
Date: 2050.01.21
Time: 00:13:25
Coolant temperature: 30 °C
Intake air temperature: 17 °C
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.44 %
Charge air pressure: specified value: 0.004 bar
Absolute intake pressure: 100 kPa abs
Index of current engine mode: 0
Index of next requested engine mode: 0
Index of engine target mode: 0
30250 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [032] - Implausible Signal
Mileage: 118429 km
Date: 2050.01.21
Time: 00:00:20
Voltage terminal 30: 11.539 V
Air filter outlet: pressure sensor 1 bank 1: raw value: 946 mbar
Turbocharg.2 compress.outlet: press.sensor 1 bank 1: raw value: 0 mbar
Ambient air pressure sensor 1 bank 1: raw value: 0.996 bar
Engine status: Stop
Outside temperature sensor 1: B1: raw value: 23.0 °C
Filtered value of IN_Dpf_dp_raw-CDPF Delta Pressure in hPa: 0.500 hPa
Particle filter: air pressure sensor 1 bank 1: raw value: 0.6 mbar
31391 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0105 00 [032] - Malfunction
Mileage: 118429 km
27202 - Sensor Reference Voltage A
P0641 00 [032] - Open Circuit
Date: 2000.01.00
Time: 00:00:00
Engine RPM: 535.25 /min
Voltage terminal 30: 4.882 V
Engine status: Engine start
Engine running time-Pressure BIN10 bar: 0 s
Control Module temperature: 26.7 °C
ESM_Battery_voltage-Voltage: 4.94 V
Low battery mode active-Bool type: No
ESM_Vext_raw-ESM_sensor_voltage: 3.2891 V
Starter control: terminal 50 feedback-Terminal 50 on CAN: not active
Starter control: terminal 50 feedback-Terminal 50 CAN valid: active
Starter control: terminal 50 feedback-Terminal 50 via cable: not active
Starter control: terminal 50 feedback-Starter relay: not active
Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: not active
Starter control: terminal 50 feedback: 8
Starter control: shut-off conditions 1-Immobilizer: not active
Starter control: shut-off conditions 1-Starter shift malfunction: not active
Starter control: shut-off conditions 1-Speed: not active
Starter control: shut-off conditions 1-Drivetrain: not active
Starter control: shut-off conditions 1-RPM aborted starts: active
Starter control: shut-off conditions 1-Engag. duration: not active
Starter control: shut-off conditions 1-Engag. duration aborted starts: not active
Starter control: shut-off conditions 1-Engag. duration panic start: not active
Starter control: shut-off conditions 1-new errors: not active
Starter control: shut-off conditions 1-manual start/error: not active
Starter control: shut-off conditions 1-ignition: not active
Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction: not active
Starter control: shut-off conditions 1-Direct start function: not active
Starter control: shut-off conditions 1-Engag. duration defrost.: not active
Starter control: shut-off conditions 1: 514
27200 - Sensor Reference Voltage B
P0651 00 [032] - Open Circuit
Date: 2000.01.00
Time: 00:00:00
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 40287000001034
Coding: 557E409825638487AA7B027FA48A21E6790000
Shop #: WSC 02739 790 50316
VCID: 3FD0292167F95E23B69-806A
0128 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[undervoltage]
Reset counter: 191
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:24
8208 - Databus
[ACAN: MO1_Sta_Pedal signal failure value]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
8216 - Databus
[ACAN: MO3_FPGradient signal failure value]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
8217 - Databus
[ACAN: MO3_Pedalwert signal failure value]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
8338 - Databus
[ACAN: MO1_Pedalwert]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 14011713471449
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EAE94252073972BFDF-802A
136194 - Supply voltage
U1011 00 [009] - Voltage too Low
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:46
Voltage terminal 15: 0.00 V
Voltage terminal 30: 6.35 V
Terminal 15 status: OFF
Entprellzeit: 90000 ms
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ROD: EV_ClimaT5Basis.rod
VCID: 73B8B5111B31CA43821-8026
13635840 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 231
Date: 2021.07.28
Time: 00:20:19
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 018171093
Coding: A0A4303A0A61343193284F746CEB8E740F84708F60CC6D60320400220840
Shop #: WSC 02737 022 68400
VCID: 2A0668758CFBCB8BF17-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 230117 04 42 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P
Component: J386__TSG_FT 003 0653
Serial number: KU0KU018011770184639
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 003 0653
Serial number: KU0KU018011770186324
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29160003520660067031
Coding: B0FFFF
03301 - Response Closing Status of Drivers Door
Reset counter: 230
Mileage: 118429 km
Date: 2021.07.07
Time: 11:54:28
03442 - Return Message Closing Status of Rear Lid
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.09
Time: 19:12:12
00532 - Supply Voltage B+
Reset counter: 231
Fault Frequency: 16
Reset counter: 231
Date: 2021.07.27
Time: 10:16:16
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32931634901616
Coding: 11800A
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 43D825D10B113AC3D21-8016
[Versorgungsspannung - zu niedrig]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:23
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:23
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V3003KRGH
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750_VN75.rod
VCID: 3A2658357CDB7B0B817-806E
[Powersupply lower threshold fall short of]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:51
B13BC F2 [008] - No function
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1104
Coding: 450B010300
[Supply voltage too low]
Reset counter: 40
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:22
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 6882D27D5277399B273-803C
Component: IMMO H03 1104
VCID: 6A86A8754CFB0B8B317-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 055 7085
Serial number: 15121600012431
Coding: 065700003C00000041111101008000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E0E6465B093A7AB2DF-807A
1537 - Supply voltage
[Supply voltage - lower limit value not reached]
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:23
Voltage terminal 30: 11.1 V
1539 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to insufficient voltage - lower limit value not reached]
Fault Frequency: 7
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:25
Voltage terminal 30: 7.2 V
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 330B7A73
Shop #: WSC 61351 001 1048576
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Serial number: 75410903921701201094
02252 - Generator
Reset counter: 190
Mileage: 118429 km
Date: 2021.06.28
Time: 09:59:19
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 231
Date: 2021.07.10
Time: 01:16:22
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000427860570
Coding: 410D000103000000
Shop #: WSC 02739 790 00000
VCID: 32367015A42B834B497-8066
Reset counter: 231
Date: 2021.07.28
Time: 00:00:00
End----------(Elapsed Time: 01:51, VBatt start/end: 14.5V/14.4V)-----------
Revision: 23002001
9 Faults Found:
Mileage: 118429 km
Date: 2050.01.21
Time: 00:00:20
Mileage: 118429 km
Date: 2050.01.21
Time: 00:00:20
P1570 00 [032] - -
Date: 2000.01.00
Time: 00:00:00
Fault Frequency: 19
Mileage: 118429 km
Date: 2049.01.23
Time: 10:01:12
Mileage: 118429 km
Date: 2050.01.21
Time: 00:13:25
Mileage: 118429 km
Date: 2050.01.21
Time: 00:00:20
Engine status: Stop
Mileage: 118429 km
Date: 2000.01.00
Time: 00:00:00
Date: 2000.01.00
Time: 00:00:00
Readiness: N/A
U1400 00 [008] - -
[undervoltage]
Reset counter: 191
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:24
8208 - Databus
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
8216 - Databus
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
8217 - Databus
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
8338 - Databus
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:01
Coding: 01
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:46
Revision: 00001002
Coding: 0000000003
Reset counter: 231
Date: 2021.07.28
Time: 00:20:19
Coding: 0228EE
Coding: 1400B0
Coding: 0400A0
Coding: B0FFFF
Reset counter: 230
Mileage: 118429 km
Date: 2021.07.07
Time: 11:54:28
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.09
Time: 19:12:12
Reset counter: 231
Fault Frequency: 16
Reset counter: 231
Date: 2021.07.27
Time: 10:16:16
Coding: 11800A
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:23
U1400 00 [008] - -
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:23
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:51
Coding: 450B010300
Reset counter: 40
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:22
Revision: B9081001
Coding: 042305
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:19:23
U1400 00 [008] - -
Fault Frequency: 7
Reset counter: 231
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:25
Coding: 330B7A73
02252 - Generator
Reset counter: 190
Mileage: 118429 km
Date: 2021.06.28
Time: 09:59:19
Reset counter: 231
Date: 2021.07.10
Time: 01:16:22
Reset counter: 231
Date: 2021.07.28
Time: 00:00:00
End----------(Elapsed Time: 01:53, VBatt start/end: 14.5V/14.2V)-----------
Address 09: DTCs cleared
Revision: 23002001
U0140 00 [035] - No Communications
Mileage: 118429 km
Date: 2050.01.21
Time: 00:27:06
Coolant temperature: 27 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.242 V
Cruise Control System (CCS): status: main switch off
Mileage: 118429 km
Date: 2050.01.21
Time: 00:27:26
Voltage terminal 30: 3.757 V
Control Module temperature: 30.7 °C
ESM_Battery_voltage-Voltage: 3.76 V
Starter control: terminal 50 feedback-Terminal 50 on CAN: active
Starter control: terminal 50 feedback-Terminal 50 via cable: active
Starter control: terminal 50 feedback-Starter relay: active
Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: active
Starter control: terminal 50 feedback: 62
Starter control: shut-off conditions 1-RPM aborted starts: not active
Starter control: shut-off conditions 1: 0
Mileage: 118429 km
Date: 2050.01.21
Time: 00:27:26
27198 - Sensor Reference Voltage C
P0697 00 [032] - Open Circuit
Mileage: 118429 km
Date: 2050.01.21
Time: 00:27:26
Voltage terminal 30: 3.726 V
ESM_Battery_voltage-Voltage: 3.73 V
27196 - Sensor Reference Voltage "D"
P06A3 00 [032] - Open Circuit
Mileage: 118429 km
Date: 2050.01.21
Time: 00:27:26
Readiness: N/A
Coding: 01
Revision: 00001002
Coding: 0000000003
Coding: 0228EE
Coding: 1400B0
Coding: 0400A0
Coding: B0FFFF
Coding: 11800A
Coding: 450B010300
Revision: B9081001
Coding: 042305
Coding: 330B7A73
02252 - Generator
Reset counter: 191
Mileage: 118429 km
Date: 2021.07.28
Time: 00:00:59
End----------(Elapsed Time: 01:54, VBatt start/end: 14.5V/14.3V)-----------
