VW TRANSPORTER 2017. ALTERNATOR NOT CHARGING. TRIED NEW ALTERNATOR, STILL NOT CHARGING.
ABE MW
Reading, UK
C?ID=438310
Hi there
any advice would be much appreciated!
Wednesday,28,July,2021,11:31:54:20013
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4543.4
VIN: WV1ZZZ7HZHH119698   License Plate: LJ17WKH
Mileage: 118420km-73582mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZHH119698   Mileage: 118420km-73582miles
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KL    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 3802
   Revision: 23002001
   Coding: 00194014433401090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 0154EFD9518DE8D380D-8054
9 Faults Found:
25792 - Mass Air Flow Sensor (G70)
          P0101 00 [032] - Implausible Signal
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:00:20
                    Engine RPM: 0.00 /min
                    Coolant temperature: 24 °C
                    Intake air temperature: -29 °C
                    Voltage terminal 30: 11.585 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.30 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.000 bar
                    Absolute intake pressure: 99 kPa abs
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 4
                    Index of next requested engine mode: 4
                    Index of engine target mode: 4
13174 - Mass Air Flow Sensor (G70)
          P0103 00 [032] - Signal too High
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:00:20
                    Voltage terminal 30: 11.554 V
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.17 %
25577 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
                    Date: 2000.01.00
                    Engine RPM: 87.75 /min
                    Coolant temperature: 29 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 4.914 V
                    Immobilizer Snapshot 001 Byte 1: 14
                    Immobilizer Snapshot 001 Byte 2: 00
                    Immobilizer Snapshot 001 Byte 3: 0A
                    Immobilizer Snapshot 001 Byte 4: 49
                    Immobilizer Snapshot 001 Byte 5: 30
                    Immobilizer Snapshot 001 Byte 6: 00
                    Immobilizer Snapshot 002 Byte 1: 00
                    Immobilizer Snapshot 002 Byte 2: 00
                    Immobilizer Snapshot 002 Byte 3: 00
                    Immobilizer Snapshot 002 Byte 4: 00
                    Immobilizer Snapshot 002 Byte 5: 00
                    Immobilizer Snapshot 002 Byte 6: 00
                    Immobilizer Snapshot 004 Byte 1: 00
                    Immobilizer Snapshot 004 Byte 2: 00
                    Immobilizer Snapshot 004 Byte 3: 00
25796 - Body Control Module (Central Electric)
          U0140 00 [047] - No Communications
                    Fault Frequency: 19
                    Mileage: 118429 km
                    Date: 2049.01.23
                    Time: 10:01:12
                    Engine RPM: 827.75 /min
                    Normed load value: 32.5 %
                    Coolant temperature: 32 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 14.140 V
                    Accelerator pedal travel: raw value: 0.00 %
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: passive
                    selected gear: Shifting process active
32111 - Voltage Supply for Particulate Sensor
          P24D0 00 [032] - Short to GND
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:13:25
                    Coolant temperature: 30 °C
                    Intake air temperature: 17 °C
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.44 %
                    Charge air pressure: specified value: 0.004 bar
                    Absolute intake pressure: 100 kPa abs
                    Index of current engine mode: 0
                    Index of next requested engine mode: 0
                    Index of engine target mode: 0
30250 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [032] - Implausible Signal
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:00:20
                    Voltage terminal 30: 11.539 V
                    Air filter outlet: pressure sensor 1 bank 1: raw value: 946 mbar
                    Turbocharg.2 compress.outlet: press.sensor 1 bank 1: raw value: 0 mbar
                    Ambient air pressure sensor 1 bank 1: raw value: 0.996 bar
                    Engine status: Stop
                    Outside temperature sensor 1: B1: raw value: 23.0 °C
                    Filtered value of IN_Dpf_dp_raw-CDPF Delta Pressure in hPa: 0.500 hPa
                    Particle filter: air pressure sensor 1 bank 1: raw value: 0.6 mbar
31391 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [032] - Malfunction
                    Mileage: 118429 km
27202 - Sensor Reference Voltage A
          P0641 00 [032] - Open Circuit
                    Date: 2000.01.00
                    Engine RPM: 535.25 /min
                    Voltage terminal 30: 4.882 V
                    Engine status: Engine start
                    Engine running time-Pressure BIN10 bar: 0 s
                    Control Module temperature: 26.7 °C
                    ESM_Battery_voltage-Voltage: 4.94 V
                    Low battery mode active-Bool type: No
                    ESM_Vext_raw-ESM_sensor_voltage: 3.2891 V
                    Starter control: terminal 50 feedback-Terminal 50 on CAN: not active
                    Starter control: terminal 50 feedback-Terminal 50 CAN valid: active
                    Starter control: terminal 50 feedback-Terminal 50 via cable: not active
                    Starter control: terminal 50 feedback-Starter relay: not active
                    Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: not active
                    Starter control: terminal 50 feedback: 8
                    Starter control: shut-off conditions 1-Immobilizer: not active
                    Starter control: shut-off conditions 1-Starter shift malfunction: not active
                    Starter control: shut-off conditions 1-Speed: not active
                    Starter control: shut-off conditions 1-Drivetrain: not active
                    Starter control: shut-off conditions 1-RPM aborted starts: active
                    Starter control: shut-off conditions 1-Engag. duration: not active
                    Starter control: shut-off conditions 1-Engag. duration aborted starts: not active
                    Starter control: shut-off conditions 1-Engag. duration panic start: not active
                    Starter control: shut-off conditions 1-new errors: not active
                    Starter control: shut-off conditions 1-manual start/error: not active
                    Starter control: shut-off conditions 1-ignition: not active
                    Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction: not active
                    Starter control: shut-off conditions 1-Direct start function: not active
                    Starter control: shut-off conditions 1-Engag. duration defrost.: not active
                    Starter control: shut-off conditions 1: 514
27200 - Sensor Reference Voltage B
          P0651 00 [032] - Open Circuit
                    Date: 2000.01.00
Readiness: N/A
   Revision: 00000000    Serial number: 40287000001034
   Coding: 557E409825638487AA7B027FA48A21E6790000
   Shop #: WSC 02739 790 50316
   VCID: 3FD0292167F95E23B69-806A
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [undervoltage]
                    Reset counter: 191
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:24
8208 - Databus
          [ACAN: MO1_Sta_Pedal signal failure value]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
8216 - Databus
          [ACAN: MO3_FPGradient signal failure value]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
8217 - Databus
          [ACAN: MO3_Pedalwert signal failure value]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
8338 - Databus
          [ACAN: MO1_Pedalwert]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
   Serial number: 14011713471449
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EAE94252073972BFDF-802A
136194 - Supply voltage
          U1011 00 [009] - Voltage too Low
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:46
                    Voltage terminal 15: 0.00 V
                    Voltage terminal 30: 6.35 V
                    Terminal 15 status: OFF
                    Entprellzeit: 90000 ms
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73B8B5111B31CA43821-8026
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 231
                    Date: 2021.07.28
                    Time: 00:20:19
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 018171093
   Coding: A0A4303A0A61343193284F746CEB8E740F84708F60CC6D60320400220840
   Shop #: WSC 02737 022 68400
   VCID: 2A0668758CFBCB8BF17-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 230117 04  42  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU018011770184639
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU018011770186324
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160003520660067031
   Coding: B0FFFF
03301 - Response Closing Status of Drivers Door
                    Reset counter: 230
                    Mileage: 118429 km
                    Date: 2021.07.07
                    Time: 11:54:28
03442 - Return Message Closing Status of Rear Lid
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.09
                    Time: 19:12:12
                    Reset counter: 231
                    Fault Frequency: 16
                    Reset counter: 231
                    Date: 2021.07.27
                    Time: 10:16:16
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32931634901616
   Coding: 11800A
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 43D825D10B113AC3D21-8016
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:23
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:23
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3003KRGH
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 3A2658357CDB7B0B817-806E
          [Powersupply lower threshold fall short of]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:51
          B13BC F2 [008] - No function
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Coding: 450B010300
          [Supply voltage too low]
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:22
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 6882D27D5277399B273-803C
   Component: IMMO          H03 1104
   VCID: 6A86A8754CFB0B8B317-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     055 7085
   Serial number: 15121600012431
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E0E6465B093A7AB2DF-807A
1537 - Supply voltage
          [Supply voltage - lower limit value not reached]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:23
                    Voltage terminal 30: 11.1 V
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:25
                    Voltage terminal 30: 7.2 V
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 330B7A73
   Shop #: WSC 61351 001 1048576
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75410903921701201094
02252 - Generator
                    Reset counter: 190
                    Mileage: 118429 km
                    Date: 2021.06.28
                    Time: 09:59:19
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 231
                    Date: 2021.07.10
                    Time: 01:16:22
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000427860570
   Coding: 410D000103000000
   Shop #: WSC 02739 790 00000
   VCID: 32367015A42B834B497-8066
                    Reset counter: 231
                    Date: 2021.07.28
End----------(Elapsed Time: 01:51, VBatt start/end: 14.5V/14.4V)-----------
   Revision: 23002001
9 Faults Found:
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:00:20
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:00:20
          P1570 00 [032] - -
                    Date: 2000.01.00
                    Fault Frequency: 19
                    Mileage: 118429 km
                    Date: 2049.01.23
                    Time: 10:01:12
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:13:25
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:00:20
                    Engine status: Stop
                    Mileage: 118429 km
                    Date: 2000.01.00
                    Date: 2000.01.00
Readiness: N/A
          U1400 00 [008] - -
          [undervoltage]
                    Reset counter: 191
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:24
8208 - Databus
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
8216 - Databus
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
8217 - Databus
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
8338 - Databus
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:01
   Coding: 01
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:46
   Revision: 00001002
   Coding: 0000000003
                    Reset counter: 231
                    Date: 2021.07.28
                    Time: 00:20:19
   Coding: 0228EE
   Coding: 1400B0
   Coding: 0400A0
   Coding: B0FFFF
                    Reset counter: 230
                    Mileage: 118429 km
                    Date: 2021.07.07
                    Time: 11:54:28
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.09
                    Time: 19:12:12
                    Reset counter: 231
                    Fault Frequency: 16
                    Reset counter: 231
                    Date: 2021.07.27
                    Time: 10:16:16
   Coding: 11800A
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:23
          U1400 00 [008] - -
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:23
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:51
   Coding: 450B010300
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:22
   Revision: B9081001
   Coding: 042305
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:19:23
          U1400 00 [008] - -
                    Reset counter: 231
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:25
   Coding: 330B7A73
02252 - Generator
                    Reset counter: 190
                    Mileage: 118429 km
                    Date: 2021.06.28
                    Time: 09:59:19
                    Reset counter: 231
                    Date: 2021.07.10
                    Time: 01:16:22
                    Reset counter: 231
                    Date: 2021.07.28
End----------(Elapsed Time: 01:53, VBatt start/end: 14.5V/14.2V)-----------
Address 09: DTCs cleared
   Revision: 23002001
          U0140 00 [035] - No Communications
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:27:06
                    Coolant temperature: 27 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.242 V
                    Cruise Control System (CCS): status: main switch off
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:27:26
                    Voltage terminal 30: 3.757 V
                    Control Module temperature: 30.7 °C
                    ESM_Battery_voltage-Voltage: 3.76 V
                    Starter control: terminal 50 feedback-Terminal 50 on CAN: active
                    Starter control: terminal 50 feedback-Terminal 50 via cable: active
                    Starter control: terminal 50 feedback-Starter relay: active
                    Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: active
                    Starter control: terminal 50 feedback: 62
                    Starter control: shut-off conditions 1-RPM aborted starts: not active
                    Starter control: shut-off conditions 1: 0
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:27:26
27198 - Sensor Reference Voltage C
          P0697 00 [032] - Open Circuit
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:27:26
                    Voltage terminal 30: 3.726 V
                    ESM_Battery_voltage-Voltage: 3.73 V
27196 - Sensor Reference Voltage "D"
          P06A3 00 [032] - Open Circuit
                    Mileage: 118429 km
                    Date: 2050.01.21
                    Time: 00:27:26
Readiness: N/A
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: 0228EE
   Coding: 1400B0
   Coding: 0400A0
   Coding: B0FFFF
   Coding: 11800A
   Coding: 450B010300
   Revision: B9081001
   Coding: 042305
   Coding: 330B7A73
02252 - Generator
                    Reset counter: 191
                    Mileage: 118429 km
                    Date: 2021.07.28
                    Time: 00:00:59
End----------(Elapsed Time: 01:54, VBatt start/end: 14.5V/14.3V)-----------
ABE MW
Reading, UK
C?ID=438310
Can anyone source the wiring diagram for 25796 - Body Control Module (Central Electric)?
I believe the fault is due to this error, I need to test wiring but can not find diagrams anywhere!
Zenerdiode
Newcastle, England
C?ID=24330
I have downloaded the wiring diagrams off Erwin but it wont show me pin outs for the plugs :(
It shows the pin allocation numbers though. Then the pin/socket chambers in the plug-couplers are labelled. Admittedly, the older I get, the stronger reading glasses and brighter light are required.
Also, wiring core colours are shown on erWin to help you chase the wires.
ABE MW
Reading, UK
C?ID=438310
Just realised i have been looking at the diagrams for T6.1. Erwin will not give the option for diagrams for this model, only ''fitting instructions''
any ideas? strange how it will not give diagrams for a older model. or am i being stupid?
iichel
Netherlands, eastern part
C?ID=284912
Perhaps you're being stupid, perhaps not. I prefer to believe you're not.
So let's have a look at your diagram. The alternator should have a yellow/green LIN wire, in common with the BDM sensor, going to BCM T73b (=white connector) pin 37. Given that your BDM is connected, I suspect that either the wire is damaged somewhere near the alternator in the engine bay, or the connector has some corrosion or is simply not connected.
ABE MW
Reading, UK
C?ID=438310
Hi
Thanks for your response.
I can not figure out how to upload a picture of my diagram, however I am 100% certain the diagram I have is for the T6.1 and its wired differently to the model in question. Still is a yellow and green wire, but it goes to the J533 T20a pin 3.
I will check continuity from the BCM T73b (=white connector) pin 37 to Alternator. hopefully this is the pin I needed, just could not find the diagram.
No corrosion on plug, it is 100% connected as I have had it off and on.
Thank you for the information :)
Please see:
iichel
C?ID=284912
This is the diagram I took:
I'm not very into T6 T6.2 T6.2 etc, but it is the 7E0 platform.
iichel
C?ID=284912
Coming to look at it, have a look at T10i (dark brown 10pin connector in e-box). This way, you don't have to look at the BCM directly, but take the LIN port on the BDM (negative battery terminal). We know that line between the BCM and the BDM is working fine. Saves you a couple of metres of wire and the hassle of disconnecting the BCM.
I believe to have deduced that your problem is within the orange square:
ABE MW
Reading, UK
C?ID=438310
FIXED. I HAVE NOW HAD 3-4 OF THE SAME VEHICLES WITH THE SAME FAULT NOW. SEEMS TO BE A VERY COMMON FAULT.
THE BRAKE IN THE LIN WIRE FROM ALTERNATOR IS ALWAYS IN THE SAME PLACE. FOLLOW THE WIRE FROM ALTERNAOTR INTO THE LOOM AND JUST BEFORE WERE THE LOOM STARTS TO GO UP THE ENGINE BAY IS WHERE IT BRAKES. OPEN PLASTIC CASING AROUND LOOM AND PULL ON YELLOW AND GREEN WIRE, IT WILL SNAP EASY.
SEEMS TO BE WHERE WATER SITS INISDE/THE LOWEST POINT OF THE LOOM AND CORODES THE WIRING.
