- Apr 19, 2022
- 4
- 0
- Hampshire, UK
- C?ID=508854
Hi Uwe,
Detail up dated and Hex V2 registered
Two points:Haven't used my account for a while and now my account seems to be "under review". Can this be changed to allow forum use once again please?
Interesting, I thought I had the cable registered. Anyway, the form has been filled in, thanks.Two points:
1) The fact that you made this post indicates that you can use the forum despite that message.
2) It's been five years since you joined and you still haven't done what's described in the first post of this thread to Get Verified. Maybe you should so now?
Form filled, sent etc.. hope there was everything.As far as I can tell, you have not. There is no match for the e-mail address you used to join the forum in our customer records and you have not supplied a VCDS serial number.
Thanks for that I didn't realise I had to register, I thoughts that the serial number did it automatically, anyway, followed the process, should be all good. RegardsIf your status is something other than a "Verified" user, that means we could not find you in our customer records when you joined the forum. This could be due to one of following:
1) You didn't give us enough information. Perhaps you didn't provide a serial number, or maybe you're using a different e-mail address than when you bought your system. If you bought your system directly from Ross-Tech, you should be in our records. In that case, please e-mail us (Sales@Ross-Tech.com) and we'll look into it.
2) You bought your VCDS system from one of our resellers and you haven't registered the product with Ross-Tech yet. In that case you are not in our customer records, and can't get verified until after you do register.
3) You bought a second-hand system and aren't eligible for support. You can still post in the New User section of the forum, but you won't get posting access to most of the rest of the forum unless/until you elect to transfer ownership of that system into your name. You can do that here at a cost of $99.
- If you have one of our older interfaces (anything other than a HEX-NET or HEX-V2) then please fill out this form -- it's free! Also, please put "Please check my forum status" in the 'Notes or Special Instructions' field of the form.
- If you have a HEX-NET, please register it as described in the video in this post.
- If you have a HEX-V2, please register it as described in the video in this post.
4) You bought an illegally pirated VCDS system. In that case, you're not really welcome here unless/until you decide to buy a real one.
Where, specifically?I still cannot post in some forum areas,
cannot create one in How To's and Tips,
Correct. Only Staff Members and above can create a new thread in that section. Occasionally we'll move a thread from another section to that section. If someone wishes to post something in that section, find another appropriate section to make the post, and then ask us to move it.I'd say that the "How to's & Tips" section isn't the place for asking questions. It's a reference section where "How to's & Tips" are detailed.
Although it won't be finished processing until working hours, I can see that it's in our system, so...:have now transferred ownership so hopefully will be done in working hours,
