VW Transporter (T5.1) 180 Bi-turbo, 2014 - Intermittent engine fault
Maverik
C?ID=418950
Hi folks,
Got a few errors I need help with sorting before I can start the fun stuff.
Background:
Van was parked up for a few weeks, on driving after, coil light comes on then engine management light, then limp mode, combined with some strange engine off, ignition on behavior - twitching rev gauge, rough flashing battery light and what I think is top of engine relay clicking and possible ABS pump switching on and off.
VW garage have had the vehicle and swapped out the engine speed sensor after this fault first appeared - they had the vehicle and the fault condition never actually re-appeared for them... hence why I'm now here.
As I was doing an Autoscan started off ok, then the faults started happening so I took a number of scans as things "deteriorated".
This is all a little new to me, I'm used to less tech approach of Land Rover Defenders, but keen to learn.
Started vehicle - started scan, then coil light came on.
Thursday,24,September,2020,18:33:37:50500
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: WV1ZZZ7HZEH126568   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 77 0B
VIN: WV1ZZZ7HZEH126568   Mileage: 102820km-63889miles
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 GN    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6326
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 01194012233400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019GN 003005
   ROD: EV_ECM20BTD01103L906019GK_003.rod
   VCID: 7DAC924E5D7D3AA3395-8028
4124 - Sensor Reference Voltage B
          P0651 00 [040] - Open Circuit
                    Mileage: 102576 km
                    Date: 2020.08.06
                    Time: 09:05:21
                    Engine speed: 2004.50 /min
                    Normed load value: 45.1 %
                    Vehicle speed: 82 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 91 °C
                    Voltage terminal 30: 14.140 V
                    Exh.gas temp.sen 1: 392.6 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 274.7 °C
                    Exh.gas temp.sen 4: 239.8 °C
                    Shut-off timer: last engine shut-off time: 405 s
4087 - Engine Speed Sensor (G28)
          P0322 00 [032] - No Signal
                    Mileage: 102584 km
                    Date: 2020.08.06
                    Time: 09:18:49
                    Engine speed: 1615.50 /min
                    Normed load value: 44.7 %
                    Vehicle speed: 34 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 96 °C
                    Voltage terminal 30: 13.880 V
                    Engine start: start synchronization: EPM_MODE_BACKUP_CRS
                    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 60
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508764AD89A60A9B26A79177A96610
   Shop #: WSC 02736 790 49152
   VCID: 3A2659520C53CD9B5C7-806E
                    Fault Status: 00101101
                    Reset counter: 195
                    Mileage: 102576 km
                    Date: 2014.12.28
                    Time: 09:05:22
                    Count: 21504
                    Count: 1
                    Count: 8241
                    Count: 766
   Serial number: 07041404650361
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EAE9542507B21BB20F-802A
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0506
   Revision: 00001012
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7CAA9F4A466733AB0EB-8028
   Part No SW: 7H0 937 087 M    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0413
   Revision: BO034001    Serial number: 0573 099140657
   Coding: A0A0303A0A612433922848106C2B8C540080432F60844000320000000000
   Shop #: WSC 02736 790 00000
   VCID: 3E2E5542107BE1BB60F-806A
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU011041441011726
   Coding: 1000B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU010041441003602
   Coding: 0000A0
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 7E1 951 172
   Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0106
   Revision: --------    Serial number: 32901409302221
   Coding: 118001
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K_001_VN75.rod
   VCID: 3A2659520CD3CD9B5C7-806E
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00P6590
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 353C4A6E25CD22E3B15-8060
   Part No SW: 7E0 920 970 J    HW: 7E0 920 970 J
   Component: KOMBI         H04 0710
   Coding: 460A01
   VCID: 31347E7ED1A50EC3EDD-8064
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0413
   Revision: BO034001
   Coding: 042300
   VCID: 70B2BB7A1AAF47CBA23-8024
   Component: IMMO          H04 0710
   VCID: 6A86A9123CF3BD1BEC7-803E
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  044 0082
   Revision: 01000001    Serial number: VWZ1Z2P0166463
   Coding: 05000200020014
   Shop #: WSC 02734 790 00000
   VCID: 333874762B393CD39F1-8066
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00008200266045
   Coding: 410D000101000000
   VCID: 31347E7ED1250EC3EDD-8064
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007666086783
   Coding: 0A01010000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C2A5F4A06E7F3AB4EB-8068
End----------(Elapsed Time: 01:29, VBatt start/end: 14.1V/14.3V)-----------
So then re-ran the code after stopping the engine and re starting the engine.
Thursday,24,September,2020,18:48:33:50500
          P0651 00 [175] - Open Circuit
                    Mileage: 102826 km
                    Date: 2020.09.24
                    Time: 18:38:59
                    Engine speed: 937.00 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 59 °C
                    Intake air temperature: 65 °C
                    Voltage terminal 30: 14.180 V
                    Exh.gas temp.sen 1: 113.4 °C
                    Exh.gas temp.sen 3: 102.3 °C
                    Exh.gas temp.sen 4: 85.6 °C
                    Shut-off timer: last engine shut-off time: 2747 s
Readiness: 1 1 0 0 1
   Revision: 00H43001
                    Fault Status: 01101101
                    Reset counter: 156
                    Mileage: 102576 km
                    Date: 2014.12.28
                    Time: 09:05:22
                    Count: 21504
                    Count: 1
                    Count: 8241
                    Count: 766
   Coding: 01
   Revision: 00001012
   Coding: 0000000002
   Coding: 1000B0
   Coding: 0000A0
   Coding: 118001
   Coding: 460A01
   Revision: BO034001
   Coding: 042300
End----------(Elapsed Time: 02:02, VBatt start/end: 14.3V/14.2V)-----------
Then took a scan with the engine off - this is with the speedo going nuts and battery light flashing - note the engine speed read-outs
Thursday,24,September,2020,19:03:23:50500
                    Mileage: 102826 km
                    Date: 2020.09.24
                    Time: 18:38:59
5170 - Manifold Pressure / Boost Sensor (G31)
          P0237 00 [167] - Signal too Low
                    Mileage: 102826 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 70 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 13.000 V
                    Charge air pressure: actual value: 500.0 hPa
                    Intake air pressure sensor after air cleaner: raw value: 981 hPa
                    Sensor for charge pressure between turbochargers: raw value: 985.2 hPa
                    Engine status: COENG_READY
   Revision: 00H43001
                    Reset counter: 156
                    Mileage: 102576 km
                    Date: 2014.12.28
                    Time: 09:05:22
                    Count: 21504
                    Count: 1
                    Count: 8241
                    Count: 766
   Coding: 01
   Revision: 00001012
   Coding: 0000000002
   Coding: 1000B0
   Coding: 0000A0
   Coding: 118001
   Coding: 460A01
   Revision: BO034001
   Coding: 042300
End----(Elapsed Time: 02:04, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
So I then cleared the DTC and took one final scan
Thursday,24,September,2020,19:14:47:50500
          P0651 00 [167] - Open Circuit
                    Mileage: 102826 km
                    Date: 2020.09.24
                    Time: 19:09:55
                    Coolant temperature: 66 °C
                    Intake air temperature: 61 °C
                    Voltage terminal 30: 12.380 V
                    Exh.gas temp.sen 1: 115.7 °C
                    Exh.gas temp.sen 3: 115.7 °C
                    Exh.gas temp.sen 4: 100.1 °C
                    Shut-off timer: last engine shut-off time: 37 s
   Revision: 00H43001
                    Reset counter: 156
                    Mileage: 102576 km
                    Date: 2014.12.28
                    Time: 09:05:22
                    Count: 21504
                    Count: 1
                    Count: 8241
                    Count: 766
   Coding: 01
   Revision: 00001012
   Coding: 0000000002
   Coding: 1000B0
   Coding: 0000A0
   Coding: 460A01
   Revision: BO034001
   Coding: 042300
End----(Elapsed Time: 03:16, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
Apologies for the massive dump of information - I've also got a short video of the dash behavior and a what's make a noise in the engine bay.
Maverik
C?ID=418950
A small update:
I contacted the owner of this thread: - as it holds some similar fault codes to me.
And they got back in touch to say that the fault they found and fixed was a broken Boost pressure sensor , which does tie in with the 3rd Autoscan down.
HMC
C?ID=28246
This behavior is typical of low electrical energy to control modules, have you checked this>
Regards HMC
Maverik
C?ID=418950
Due to the fault the van hasn't been used much lately, I'll get the battery put on a maintenance charge.
At the point of recording the scan i had stopped and restarted the vehicle a few times.
Regards HMC
I'm skeptical that those voltages are low enough to cause the Reference Voltage faults in @Maverik 's scans. Sensor Reference Voltage is generally 5V....
MartinsX
Riga, Latvia
C?ID=268515
I think HMC's comment was more addressed to text description in OP's first post (flickering dash warning lights etc.), not to 4124/P0651 DTC.
OP really need WD and check all 5V supply circuits in engine wiring loom step by step.
BTW who knows the definition of P0651-00 open circuit/prerequisites for setting it? I have tested a lot of ECU's on table with just power and data connected (all sensor and actuator inputs/outputs open) and never seen such DTC set. Internal fault of 5V converter inside ECU maybe?
Maverik
C?ID=418950
Thanks for the input so far, feeling my way a little, working on getting some documentation. Also had a good play around with VCDS today. Also got a little more info. So when the rev meter does its thing with the flashing battery light, the motor I can hear is the front left headlight beam adjuster motor. I went and cancelled all the DTC's from previous and went for a drive, all normal, until I arrived back home when I got this pop up, strangely this was by its self no sign of the previous P0651 DTC - I've got some breakout leads on the way so I can do some voltage checking - also ordered a new pressure sender, get that ruled out.
Not knowing much about the wiring in this thing, my gut is telling me not to rule out a coincidental mutually exclusive double fault.
Sunday,27,September,2020,12:45:07:50500
VIN: WV1ZZZ7HZEH126568   Mileage: 102830km-63895miles
11901 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [167] - Implausible Signal
                    Mileage: 102833 km
                    Date: 2020.09.27
                    Time: 12:39:01
                    Coolant temperature: 88 °C
                    Intake air temperature: 103 °C
                    Voltage terminal 30: 13.060 V
                    Charge air pressure: actual value: 622.6 hPa
                    Intake air pressure sensor after air cleaner: raw value: 1003 hPa
                    Sensor for charge pressure between turbochargers: raw value: 1009.6 hPa
                    Engine status: COENG_FINISH
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
   Revision: 00H43001
   Coding: 01
   Revision: 00001012
   Coding: 0000000002
   Coding: 1000B0
   Coding: 0000A0
   Coding: 118001
   Coding: 460A01
   Revision: BO034001
   Coding: 042300
End----------(Elapsed Time: 01:27, VBatt start/end: 13.8V/13.8V)-----------
MartinsX
Riga, Latvia
C?ID=268515
It's MAP/IAT sensor or wiring to it.
                    Mileage: 102833 km
                    Date: 2020.09.27
                    Time: 12:39:01
Maverik
C?ID=418950
Can I swap this like for like or do I need to go in and, (sorry I don't know what the correct terminology is) update anything in the engine controller?
MartinsX
Riga, Latvia
C?ID=268515
MAP/IAT is the same G31, also called Boost pressure sensor, it has a built-in IAT (Intake Air Temperature) sensor, too.
If You are not familiar with reading WD and using DVOM, probably easiest way is to replace it. If problem persists, You have to learn things above or ask some car electrician for help.
Maverik
C?ID=418950
So I've replaced G31, took some pin voltages with the new and old sender as per below - the only thing that stood out on the old sender was a voltage drop on Pin 2 with ignition off compared to the new sender.
Terminal testing old sender (Engine on, Engine off) 0 281 006 060 140324T005316C
Pin 1 = 0v, 0v
Pin 2 = 2.4v, 1.5v
Pin 3 = 5v, 5v
Pin 4 = 1.1v, 1.1v
Terminal testing New sender (Engine on, Engine off) Bosch 0 281 006 059 200810T085632C
Pin 1 = 0v, 0v
Pin 2 = 2.7v, 2.6v
Pin 3 = 5v, 5v
Pin 4 = 1.1v, 1.1v
Can anyone advise where I need to look to know what to expect with the pin outs? I've got a copy of Elsawin,but not been able to find anything in there.
dnoermann
C?ID=358118
Maverik
C?ID=418950
So I swapped out G31 sender, I also removed the battery and had a good inspect of the main fuse boxes and pulled the ECU out - other than a rather odd metallic smell that I got when I first opened up the main box everything looked as it should I've been using the van and she's not thrown any more codes at me.
Not entirely convinced thats solved the problem as I can't understand how that would cause the headlight level motor to flick on and off with the battery light and speedo.
I've been reading up on overheating issues of the ECU as well as I believe this generation of van's had a fair few wiring chafing problems. Just waiting and seeing now for any faults to re-appear.
Maverik
C?ID=418950
So just to close this out a little. I've been using the van regularly since last October and done a good few miles, its not missed a beat.
One thing a did after the last post was to unplug the front right headlight (as you look from the front) and give the plug a a good clean with contact cleaner I've not had any repeats of the intermittent fault of the motor running with getting strange gauge activity.
