Hi Guys
I have This Vw transporter 2013 bi-turbo 180 tdi with a Sensor reference fault, it also displays in the instrument cluster change air filter which ive never seen before.
Can anyone help as I'm not sure what sensor/sensors to check or replace??
Thanks in advance,
Thanks in advance,
Friday,06,December,2019,08:55:57:52053
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Dealer/Shop Name: Wagenworx LTD
VIN: WV1ZZZ7HZDH105713 License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 0B
VIN: WV1ZZZ7HZDH105713 Mileage: 121690km-75614miles
56-Radio -- Status: Malfunction 1110
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GN HW: 03L 907 309 L
Component: R4 2,0L EDC H38 6326
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012233400080000
Shop #: WSC 00168 210 93958
ASAM Dataset: EV_ECM20BTD01103L906019GN 003005
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: FDB2A4F36C3ABBA74C-80A8
4123 - Sensor Reference Voltage A
P0641 00 [175] - Open Circuit
Mileage: 121137 km
Date: 2019.11.09
Time: 11:10:54
Engine speed: 1994.00 /min
Vehicle speed: 104 km/h
Coolant temperature: 91 °C
Intake air temperature: 19 °C
Voltage terminal 30: 14.180 V
Exh.gas temp.sen 1: 280.1 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: 325.6 °C
Exh.gas temp.sen 4: 308.1 °C
Shut-off timer: last engine shut-off time: 206 s
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 108764AD09A4089A26A99072AA6110
Shop #: WSC 02756 790 49152
VCID: BA386FEF35944C9F29-80EE
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 104
Mileage: 120735 km
Date: 2014.03.16
Time: 08:27:55
Count: 23808
Count: 1
Count: 8241
Count: 764
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BF HW: 7E5 907 047 BF
Component: Climatic-T5 H20 0506
Revision: 00001010
Coding: 0000000002
Shop #: WSC 02756 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: F4A481D75F70FAEF33-80A0
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 K HW: 7H0 937 087
Component: BCM T5GP H+4 H32 0407
Revision: BO032001 Serial number: 0533 054130723
Coding: A0B0793A0A612413922048106C2B8CD40080410F60844000320000000000
Shop #: WSC 93958 288 02691
VCID: BC3469F73FA072AF3B-80E8
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
Subsystem 3 - Part No: 7E1 951 172
Subsystem 5 - Part No: 7E1 951 172
03789 - Terminal 75 Limp Mode Active
Reset counter: 132
Mileage: 120872 km
Date: 2014.03.16
Time: 16:49:47
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261301500002
Coding: 118001
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: BB366AEB32AE759732-80EE
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00GBJEF
Shop #: WSC 02754 790 50316
VCID: B5227CD3148AA3E7C4-80E0
Part No SW: 7E0 920 970 G HW: 7E0 920 970 G
Component: KOMBI H06 0605
Coding: 160A01
VCID: AE1053BFF1DC903F85-80FA
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H32 0407
Revision: BO032001
Coding: 042300
VCID: F0AC8DC72368C6CFD7-80A4
01304 - Radio
Reset counter: 137
Mileage: 112806 km
Date: 2013.05.02
Time: 13:00:37
Component: IMMO H06 0605
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: EA989FAF0DB43C1F99-80BE
Address 56: Radio
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00000192852466
Coding: 410D000101000000
Shop #: WSC 02756 790 00000
VCID: B12A48C3E8E28FC798-80E4
End----------(Elapsed Time: 01:55, VBatt start/end: 14.3V/14.2V)-----------
