Hi folks,
Got a few errors I need help with sorting before I can start the fun stuff.
Background:
Van was parked up for a few weeks, on driving after, coil light comes on then engine management light, then limp mode, combined with some strange engine off, ignition on behavior - twitching rev gauge, rough flashing battery light and what I think is top of engine relay clicking and possible ABS pump switching on and off.
VW garage have had the vehicle and swapped out the engine speed sensor after this fault first appeared - they had the vehicle and the fault condition never actually re-appeared for them... hence why I'm now here.
As I was doing an Autoscan started off ok, then the faults started happening so I took a number of scans as things "deteriorated".
This is all a little new to me, I'm used to less tech approach of Land Rover Defenders, but keen to learn.
Started vehicle - started scan, then coil light came on.
So then re-ran the code after stopping the engine and re starting the engine.
Then took a scan with the engine off - this is with the speedo going nuts and battery light flashing - note the engine speed read-outs
So I then cleared the DTC and took one final scan
Apologies for the massive dump of information - I've also got a short video of the dash behavior and a what's make a noise in the engine bay.
Background:
Thursday,24,September,2020,18:33:37:50500
VCDS Version: 20.4.2.0 (x64) HEX-NET2 CB: 0.4527.4
VIN: WV1ZZZ7HZEH126568 License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 77 0B
VIN: WV1ZZZ7HZEH126568 Mileage: 102820km-63889miles
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GN HW: 03L 907 309 L
Component: R4 2,0L EDC H38 6326
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012233400080000
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_ECM20BTD01103L906019GN 003005
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7DAC924E5D7D3AA3395-8028
4124 - Sensor Reference Voltage B
P0651 00 [040] - Open Circuit
Fault Frequency: 7
Mileage: 102576 km
Date: 2020.08.06
Time: 09:05:21
Engine speed: 2004.50 /min
Normed load value: 45.1 %
Vehicle speed: 82 km/h
Coolant temperature: 92 °C
Intake air temperature: 91 °C
Voltage terminal 30: 14.140 V
Exh.gas temp.sen 1: 392.6 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: 274.7 °C
Exh.gas temp.sen 4: 239.8 °C
Shut-off timer: last engine shut-off time: 405 s
4087 - Engine Speed Sensor (G28)
P0322 00 [032] - No Signal
Mileage: 102584 km
Date: 2020.08.06
Time: 09:18:49
Engine speed: 1615.50 /min
Normed load value: 44.7 %
Vehicle speed: 34 km/h
Coolant temperature: 89 °C
Intake air temperature: 96 °C
Voltage terminal 30: 13.880 V
Engine start: start synchronization: EPM_MODE_BACKUP_CRS
Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 60
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508764AD89A60A9B26A79177A96610
Shop #: WSC 02736 790 49152
VCID: 3A2659520C53CD9B5C7-806E
Fault Status: 00101101
Reset counter: 195
Mileage: 102576 km
Date: 2014.12.28
Time: 09:05:22
Count: 21504
Count: 1
Count: 8241
Count: 766
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 07041404650361
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EAE9542507B21BB20F-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 7CAA9F4A466733AB0EB-8028
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 M HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0413
Revision: BO034001 Serial number: 0573 099140657
Coding: A0A0303A0A612433922848106C2B8C540080432F60844000320000000000
Shop #: WSC 02736 790 00000
VCID: 3E2E5542107BE1BB60F-806A
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU011041441011726
Coding: 1000B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU010041441003602
Coding: 0000A0
Subsystem 3 - Part No: 7E1 951 172
Subsystem 5 - Part No: 7E1 951 172
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32901409302221
Coding: 118001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 3A2659520CD3CD9B5C7-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00P6590
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 353C4A6E25CD22E3B15-8060
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 460A01
VCID: 31347E7ED1A50EC3EDD-8064
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0413
Revision: BO034001
Coding: 042300
VCID: 70B2BB7A1AAF47CBA23-8024
Component: IMMO H04 0710
VCID: 6A86A9123CF3BD1BEC7-803E
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 044 0082
Revision: 01000001 Serial number: VWZ1Z2P0166463
Coding: 05000200020014
Shop #: WSC 02734 790 00000
VCID: 333874762B393CD39F1-8066
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00008200266045
Coding: 410D000101000000
VCID: 31347E7ED1250EC3EDD-8064
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H15 4217
Revision: 1B001001 Serial number: 00007666086783
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C2A5F4A06E7F3AB4EB-8068
End----------(Elapsed Time: 01:29, VBatt start/end: 14.1V/14.3V)-----------
Thursday,24,September,2020,18:48:33:50500
P0651 00 [175] - Open Circuit
Mileage: 102826 km
Date: 2020.09.24
Time: 18:38:59
Engine speed: 937.00 /min
Normed load value: 23.1 %
Coolant temperature: 59 °C
Intake air temperature: 65 °C
Voltage terminal 30: 14.180 V
Exh.gas temp.sen 1: 113.4 °C
Exh.gas temp.sen 3: 102.3 °C
Exh.gas temp.sen 4: 85.6 °C
Shut-off timer: last engine shut-off time: 2747 s
Readiness: 1 1 0 0 1
Revision: 00H43001
Fault Status: 01101101
Reset counter: 156
Mileage: 102576 km
Date: 2014.12.28
Time: 09:05:22
Count: 21504
Count: 1
Count: 8241
Count: 766
Coding: 01
Revision: 00001012
Coding: 0000000002
Coding: 1000B0
Coding: 0000A0
Coding: 118001
Coding: 460A01
Revision: BO034001
Coding: 042300
End----------(Elapsed Time: 02:02, VBatt start/end: 14.3V/14.2V)-----------
Thursday,24,September,2020,19:03:23:50500
Mileage: 102826 km
Date: 2020.09.24
Time: 18:38:59
5170 - Manifold Pressure / Boost Sensor (G31)
P0237 00 [167] - Signal too Low
Mileage: 102826 km
Time: 00:00:00
Coolant temperature: 70 °C
Intake air temperature: 66 °C
Voltage terminal 30: 13.000 V
Charge air pressure: actual value: 500.0 hPa
Intake air pressure sensor after air cleaner: raw value: 981 hPa
Sensor for charge pressure between turbochargers: raw value: 985.2 hPa
Engine status: COENG_READY
Revision: 00H43001
Reset counter: 156
Mileage: 102576 km
Date: 2014.12.28
Time: 09:05:22
Count: 21504
Count: 1
Count: 8241
Count: 766
Coding: 01
Revision: 00001012
Coding: 0000000002
Coding: 1000B0
Coding: 0000A0
Coding: 118001
Coding: 460A01
Revision: BO034001
Coding: 042300
End----(Elapsed Time: 02:04, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
Thursday,24,September,2020,19:14:47:50500
P0651 00 [167] - Open Circuit
Mileage: 102826 km
Date: 2020.09.24
Time: 19:09:55
Coolant temperature: 66 °C
Intake air temperature: 61 °C
Voltage terminal 30: 12.380 V
Exh.gas temp.sen 1: 115.7 °C
Exh.gas temp.sen 3: 115.7 °C
Exh.gas temp.sen 4: 100.1 °C
Shut-off timer: last engine shut-off time: 37 s
Revision: 00H43001
Reset counter: 156
Mileage: 102576 km
Date: 2014.12.28
Time: 09:05:22
Count: 21504
Count: 1
Count: 8241
Count: 766
Coding: 01
Revision: 00001012
Coding: 0000000002
Coding: 1000B0
Coding: 0000A0
Coding: 460A01
Revision: BO034001
Coding: 042300
End----(Elapsed Time: 03:16, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
