Mk7 Golf Gti multiple errors. Throttle body, reference voltages, engine sensors.
Jim Beagley
C?ID=349735
Morning all. I have a 2014 MK7 Golf GTI in the workshop causing some headaches (and heartache!:cry:).
We had the car in for an 80,000 mile service (including plugs). The radiator was also replaced as it was leaking and spraying coolant over the front of the engine when the fan kicked in. After the job was completed, the coolant residue was rinsed off with a pressure washer. An auto scan at the time showed no faults, and the SRI was reset. The customer then did about 15 trouble free miles before the dash lit up like a Christmas tree and the throttle stopped responding. We recovered the car. It runs, but badly, and the throttle does not respond - see autoscan. I have checked all connectors for water ingress, and dried everything out. I have also checked fuses etc.
There are so many faults, it’s hard to know where to start! Clearing the engine faults leaves three persistent codes relating to the reference voltage and throttle body (see end of autoscan). Any thoughts or input would be much appreciated! Thanks in advance!
Monday,03,February,2020,10:23:37:06582
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZAUZEW325829   License Plate: KS14UAB
Mileage: 120186km-74680mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZEW325829   Mileage: 120186km-74680miles
Address 01: Engine (CHHB)       Labels:
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   ASAM Dataset: EV_ECM20TFS0215G0906259 001011
   ROD: N/A
   VCID: 6B963AA6029C461762-803E
14 Faults Found:
15219 - Accelerator Position Sensor (G79)
          P2122 00 [167] - Signal too Low
                    Date: 2000.15.00
                    Time: 31:63:63
                    Engine speed: 0.00 /min
                    Coolant temperature: 54 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 12.128 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 112 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 0.000000 %
                    FUP_H_SAE: 28000.0 kPa
17789 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [109] - -
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:16
                    Coolant temperature: 62 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.246 V
                    Engine temp. management actuator: raw value: 0
                    Engine temperature management actuator: stop open: 137
                    Engine temperature management actuator: after-run stop: 3965
                    RVC_SP: 199.61 °
                    RVC_AV: 0.00 °
                    RVCPWM: 0.000 %
15472 - Engine Coolant Level Sensor/Switch
          P2556 00 [096] - Electrical Malfunction
                    Date: 2000.15.00
                    Coolant temperature: 25 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.304 V
                    RVC_SP: 138.67 °
                    RVC_AV: 0.00 °
                    RVCPWM: -100.000 %
15373 - Sensor Reference Voltage A
          P0642 00 [175] - Voltage too Low
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:15
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 105 kPa
15348 - Throttle Body Actuator Bank 1 (J338)
          P0638 00 [032] - Implausible Signal
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:32
                    Coolant temperature: 61 °C
                    Voltage terminal 30: 8.828 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 106 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.773 V
15341 - Throttle Body Actuator Bank 1 (J338)
          P0638 00 [172] - Implausible Signal
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:25:35
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.285 V
                    T_AST_SAE: 0 s
15138 - Control Module Malfunction - DBW Throttle Monitoring
          P1388 00 [167] - -
                    Date: 2000.15.00
                    Time: 31:63:63
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 11.914 V
                    ENVD_0_MON: 129
                    ENVD_1_MON: 110
                    ENVD_2_MON: 0
                    ENVD_3_MON: 0
                    STATE_ERR_ABC_PRED: 7
18171 - Reset-Resistant Limp-Mode Active
          P1680 00 [167] - -
                    Date: 2000.15.00
                    Time: 31:63:63
                    ENVD_0_MON_3: 0
                    ENVD_1_MON_3: 0
                    ENVD_2_MON_3: 0
                    ENVD_3_MON_3: 0
14833 - Internal Control Module
          P0606 00 [237] - Processor Fault
                    Date: 2000.15.00
                    Time: 31:63:63
                    Vehicle speed: 255 km/h
                    Coolant temperature: 59 °C
                    Voltage terminal 30: 12.324 V
                    STATE_LS_SAE[1]: OL_ERR
                    T_AST_SAE: 0 s
14846 - Turbocharger Boost Control Position Sensor Circuit
          P2563 00 [109] - Implausible Signal
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:31
                    Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
                    Charge air pressure control valve uncond voltage sensor: 4.5801 V
                    Charge air pressure control valve position: target value: 0.00 %
                    Charge air pressure control valve position: actual value: 0.00 %
                    Charge air pressure control valve activation pulse duty factor: -31.97 %
                    Charge air pressure control valve voltage: position closed: 4.0694 V
                    STATE_BPA[0]: AD
15122 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [236] - Implausible Signal
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 15:37:31
                    Coolant temperature: 24 °C
                    Voltage terminal 30: 12.382 V
                    T_AST_SAE: 23 s
                    MAP_MES_SAE: 44 kPa
15214 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [096] - Implausible Signal
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:52
                    T_AST_SAE: 0 s
15338 - Throttle Position Sensor (G69)
          P0122 00 [167] - Signal too Low
15340 - Angle Sensor 2 for Throttle (G188)
          P0222 00 [167] - Signal Too Low
Readiness: N/A
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 60454000001751
   Coding: 01FA93A134222971037F0602C1CCA980C92C94C0608395F7F440507AC009
   VCID: 075E6616BE348277E6-8052
10 Faults Found:
0297 - Steering angle sensor
          B1168 16 [137] - Voltage Too Low
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 12:49:17
8252 - Databus
          U1121 00 [136] - Missing Message
          [FCAN: Motor_11 message is not received]
                    Reset counter: 110
                    Mileage: 120186 km
                    Date: 2020.02.03
                    Time: 00:21:48
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 110
                    Mileage: 120186 km
                    Date: 2020.02.03
                    Time: 00:21:48
8274 - Databus
          [FCAN: MO_Fahrpedalgradient signal is invalid]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:26:24
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Fault Frequency: 27
                    Reset counter: 110
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:27:10
8296 - Databus
          [FCAN: MO_QBit_Drehzahl_01 signal is invalid]
                    Fault Frequency: 34
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:26:24
8330 - Databus
          [FCAN: MO_QBit_Fahrpedalrohwert signal is invalid]
                    Fault Frequency: 13
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.02.03
                    Time: 00:21:48
          C1146 02 [137] - Signal Failure
                    Reset counter: 69
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 12:49:17
32865 - Databus
          [IPB_BUS: Motor_12 / MO_Drehzahl_01]
                    Reset counter: 69
                    Date: 2020.01.31
                    Time: 13:18:32
32872 - Databus
          [IPB-BUS: Motor_20 / MO_Fahrpedalrohwert_01invalid]
                    Reset counter: 69
                    Date: 2020.01.31
                    Time: 13:18:32
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0912
   Revision: 00001K06
   Coding: 00120004200100011005000000101000
   VCID: 383CD5EA834A3D8F5F-806C
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011405003531
   Coding: 03000A42C20122FB0B244080B10C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BB60AE6F2FCD697F2-802E
   Component: WWS    140216  042 0551
   Serial number:         140218195432
   Component: RLFS  024 0042
   Serial number: Y14M02D24H20M48S27S6
   Coding: 00A8DD
   Serial number: 000000000ZY140344GP8
   Serial number: 00000000000058805282
   Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0042
   Revision: --------    Serial number: 61131401601597
   Coding: 0131061041
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 40CCBD0ADB9A754FE7-8014
13637426 - Databus
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 18021476510550
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3620DBD2895ECBFF4D-8062
8 Faults Found:
1056 - Databus
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 69
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 12.4 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 69
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 69
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
1089 - Databus
          [FAULT_CIS_GP_INVALID]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
1046 - Databus
          [FAULT_CIS_RPM_INVALID]
                    Fault Frequency: 8
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
1078 - Databus
          [FAULT_CIS_SAS_INIT]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 12:49:18
                    Control Module temperature: 12 °C
                    Voltage terminal 15: 12.1 V
0281 - Databus
          [FAULT_CIM_TIMEOUT_TSK_06]
                    Reset counter: 110
                    Mileage: 120186 km
                    Date: 2020.02.03
                    Time: 00:21:48
                    Control Module temperature: 18 °C
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 69
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR03Y7RF
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F4EFEF6E6E4CAB7DE-802A
   Belt Pretensioner left:
   Serial number: 34169661C13021450068
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169662C18021450027
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 102 14
   Serial number: 3576700000033A151F0N
   Subsystem 4 - Part No SW: -----------    HW: 480 002 402 14
   Serial number: 35867000000A1B80DE00
   Subsystem 5 - Part No SW: -----------    HW: 480 402 102 14
   Serial number: 3516502B5142B1C0D174
   Subsystem 6 - Part No SW: -----------    HW: 480 402 102 14
   Serial number: 3526502A1142B1C4630Z
   Subsystem 7 - Part No SW: -----------    HW: 480 401 702 14
   Serial number: 35565029F107DB42406C
1053957 - Databus
          [NWD: 0x121 Motor_20 error value MO_Fahrpedalrohwert_01]
                    Fault Frequency: 17
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 12:49:18
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 24021404220931
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   Part No SW: 5G6 920 970     HW: 5G6 920 970
   Component: KOMBI         314 2210
   Coding: 27AD01002F90260001886A01040000
   VCID: 6D9234BEBC8848277C-8038
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001603737
   Coding: 030100042B085900EF00027E080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FCEBEF6A6640AB79E-806A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0038
   Serial number: 27140000325230094085
   Coding: 2CFFFF
   Serial number: 4882922503
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Reset counter: 109
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:37:04
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Serial number: 21021401100866
   Coding: 003F0220D001048100001000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8303
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3522DCDE9458C0E744-8060
22532 - Databus
          [MOTOR_12 Botschaft - SNA-Check]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
                    Motor status: 03
                    System status: Driving mode
                    Supply voltage: 12.50 V
                    Temperature: 20.0 °C
                    KFC: 58
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 12.59 V
                    uAdSensI_SwitchedKl30_xdu16: 12.59 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
23044 - Databus
          [MOTOR_20 Botschaft - SNA-Check]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:18:31
                    Motor status: 03
                    KFC: 5A
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 12.44 V
                    uAdSensI_SwitchedKl30_xdu16: 12.44 V
22276 - Databus
          [KFC_MOTOR_11 Botschaft - SNA-Check]
                    Reset counter: 110
                    Mileage: 120186 km
                    Date: 2020.01.31
                    Time: 13:27:11
                    Motor status: 03
                    Supply voltage: 12.00 V
                    Temperature: 19.0 °C
                    KFC: 57
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.17 V
                    uAdSensI_SwitchedKl30_xdu16: 12.16 V
16135 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 7.0 °C
                    KFC: 3F
                    KFA: 00 07
                    uioUdNotFilt_xdu16: 12.33 V
                    uAdSensI_SwitchedKl30_xdu16: 12.34 V
   Serial number: 17021404080267
   Coding: 003F0020DE01048100801000
   Coding: 029E01000B000200
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    040 0430
   Serial number: V7F01402140699
   Coding: 02730001FF00000021111201002800001F0203060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 679E46969E74627706-8032
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9NJ9032EN
   Subsystem 2 - Part No SW: 5G0 919 866 AJ    HW: -----------
   Component:  ECE 2019  --- 0078
   Component: SAS-GEN 2     H06 0013
   Serial number: 140212200476
   VCID: 6B963AA6829C461762-803E
End----------(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.0V)-----------
Gateway Installation List:  5Q0 907 530 Q
                Address 01: Engine       Labels: 06K-907-425-V1.clb
Control Module Part Number: 5G0 906 259     HW: 06K 907 425 B
  Component and/or Version: 2.0l R4 TFSI  H13 0007
           Software Coding: 091900322444050B2000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_ECM20TFS0215G0906259 001011 (VW37)
                       ROD: EV_ECM20TFS0215G0906259.rod
14 Faults Found:
                    Date: 2000.15.00
                    Time: 31:63:63
                    Coolant temperature: 46 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.796 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 110 kPa
          P00B7 00 [047] - -
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:16
                    RVC_SP: 199.61 °
                    RVC_AV: 0.00 °
                    RVCPWM: 0.000 %
                    Date: 2000.15.00
                    RVC_SP: 138.67 °
                    RVC_AV: 0.00 °
                    RVCPWM: -100.000 %
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:15
                    T_AST_SAE: 0 s
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:24:32
                    T_AST_SAE: 0 s
                    Mileage: 120186 km
                    Date: 2020.02.01
                    Time: 13:25:35
                    T_AST_SAE: 0 s
          P1388 00 [167] - -
                    Date: 2000.15.00
                    Time: 31:63:63
                    Voltage terminal 30: 11.582 V
                    ENVD_0_MON: 129
                    ENVD_1_MON: 201
                    ENVD_2_MON: 0
                    ENVD_3_MON: 0
          P1680 00 [167] - -
                    Date: 2000.15.00
                    Time: 31:63:63
                    ENVD_0_MON_3: 0
                    ENVD_1_MON_3: 0
                    ENVD_2_MON_3: 0
                    ENVD_3_MON_3: 0
                    Date: 2000.15.00
                    Time: 31:63:63
                    T_AST_SAE: 0 s
Readiness: 1110 0001
Address 01: DTCs cleared
Fault Codes have been Erased
          P0642 00 [167] - Voltage too Low
                    Mileage: 120186 km
                    Date: 2020.02.03
                    Time: 10:25:56
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.855 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 44 kPa
                    Mileage: 120186 km
                    Date: 2020.02.03
                    Time: 10:25:56
                    Voltage terminal 30: 11.679 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 78 kPa
                    Mileage: 120186 km
                    Date: 2020.02.03
                    Time: 10:25:56
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 78 kPa
Bruce
Near Philadelphia, PA, USA
Have you inspected the grounds to the control module? Could it be that in the washing, a ground connection was corroded and is now a poor connection?
My reason to suspect that is that so many of the reference voltages are reporting issues... The only thing I can think of that would be in common is a ground connection at the controller.
The processor fault in the engine ECU would be my next concern after inspecting/testing the grounds... Did water get into the ecu?
Jim Beagley
C?ID=349735
Thanks Bruce - that is good thinking regarding the grounds - I will check that first.
The processeor fault also concerns me. I have checked the ECU connectors (after removing that annoying ECU cage with security bolts) and all looks clean and dry. Im pretty sure the ECU did not get wet when the engine was washed. They are usually fairly well sealed anyway?
Jim Beagley
C?ID=349735
I have checked the eart points and cleaned them up - no luck so far. Does anyone have an ECU pinout or an engine wiring diagram please?
Gone But Not Forgotten
Jim
Did you know that there is a TSB for the wiring to the TV?
Did you know it's a pretty common problem for the wiring to fail due to being made out of Straw and Human feces equivalent in materials?
Did you know any consumer or faulty fuse or corroded fuse block could be directly browning out and shorting the BUS or a supply power relay and also making the ECU have faults in MCU?
Did you try unplugging each sensor and consumer to isolate the engine bay or ECU connector to engine harness side and then clearing the DTC's and re-code to default the ECU to qualify each by decade box using WD?
JPPSG Yet the entire thread?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Reset counter: 109
Mileage: 120186 km
Date: 2020.01.31
Time: 13:37:04
Terminal 15: OFF
Jim Beagley
C?ID=349735
Thankyou for your help Jack.
I have checked the wiring between the TV and the ECU for continuity, and all seems good. I have had a good look on ErWin for the associated TSB, but not had any luck - where do they hide them? I have downloaded the wiring diagrams.
I have unplugged each component on the engine loom in turn, and cleared faults each time to see what comes back - nothing obvious there, and faults are coming up as expected. The reference voltage seems to be sitting at around 1.8-2V, not the expected 5V. It would seem to me that this is the cause of all the faults? I have tried unplugging the sensors and consumers on the engine loom with a multimeter connected to see if the refernce voltage recovers, but it seems unaffected.
While working on the car with the ignition on, I have noticed that the power supply relay is switching on and off intermittently which leads me on to your suggestion of a short somewhere along the line. I have swapped the power relays between the interior and under-bonnet fuse boards (same part number) with no change.
I don't own a decade box, but i can see how it would be useful and I have ordered one off eBay. I have also ordered a 5V reference voltage supply unit, with the intention of bypassing the reference voltage supply in the ECU to see if it solves the problem. Could this work? Am I barking up the right tree?
Thank you for your help so far - I appreciate your input. Any futher suggestions would be much appreciated.
Jim Beagley
C?ID=349735
I forgot to mention - if I unplug the engine wiring harness from the ECU, and clear the codes, I still get the;
(...along with 32 other codes)
I have also measured the Reference voltage from the ECU with the engine harness disconnected and the ighnition on and it seems to be around 2.5V
I am not sure I am on the correct pin - the wiring diagrams downloaded from erwin do not give a very clear pinout, but maybe I am just being useless!
Are you a landscaper working on a car?
Did you know continuity tests without qualifying the harness can carry current is for white skinned yard ape interlopers?
But did you unplug ECU engine harness side at ECU directly and reset faults and then check for 5 volts at controller yet?
Well did you, the entire engine harness on engine side at ECU? :rolleyes:
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Please check the waterpump, it leaks inside. It has a sensor (5 volt) and a actuator (12 volt) I had the same problem a few weeks ago. in my case i also had to replace the throttle body and the ecu!
^^^^@Jim: Hi. I've been following your conversation with Jack with interest (I admire Jack's unique approach to diagnostics - I always learn heaps from his posts).
So - in respect of your tests on the 5 volt sensor rail -I assume that you are using a quality, high-impedance voltmeter. No offense intended - but far too often, folk mistakenly believe that a multi-meter reading is real!
Here's a section of the WD for the CHHB engine in your auto-scan showing the relevant pins on the ECU as well as some 5V sensors.
Notice the sensor earth for the 5V rail (i.e. circled "281"). I'm not sure where you made your measurements - have you placed the multi-meter leads across the positive/negative pins on the sensors?
Don,
Did you know It doesn't matter because if the fault doesn't reset with ECU unplugged on engine harness side, than there is a problem at ECU or to it from consumers/sensors/FEED inputs such as ground or supply terminals?
No jelly donut! :rolleyes:
Thank you though..........
^^^hmm....I hadn't thought that deeply about it, but it doesn't sound illogical (as a certain vulcan would say)
If I'm reading the WD correctly for the CHHB engine, the connection from J623 (ECU) to J533 (CAN Gateway) is made on the 91 PIN connector (i.e. CAN high=T91 /79 , CAN Low=T91 /80). By the "engine side" harness, I assume that you mean the 105 pin connector in my diagram above. I would have assumed that if this was disconnected, all communication between the ECU and pethora of sensors, senders etc would have been stopped. I'm surprised that in this state that the DTCs could be reset - but I accept your advice that they can.
As I have said, I learn much from your posts!!
Vehicle Identification No.WVWZZZAUZEW325829
ModelGolf 2.0 BlueMotion
Technology
GOLF
Date of production06.03.2014
Model year2014
Sales type5G19TX
Engine CodeCHHB
Transmission CodePNN
In regards to the 5 volt ref yes sir.
CAN high/low connection should be on plug side that is not engine harness side typically, in this case correct the T91 smaller connector since Simos Continental and ass backward of Bosch type.
I will go see though.....very good Don thank you for that correction, I will no longer state larger or smaller connector and just state not engine harness side for COM.
Early Simos same as Bosch go figure change shit around.........cost money, an engineering choice LOL!
Did you know then to measure the output of 5 volt ref with DVOM and com to ecu case or ground of battery?
Did you know I have come up with this test method outside the scope of the RTFB due to people sending me good controllers and having to hold their hands on the test process & painfully pin by pin due just stupid conditions or faulty wiring such as pedal POT circuit but yet an actual bad POT to date or faulty fuse/water ingress/corrosion bridge?
Did you see In other thread I get accused of not helping but I'm not an F1 experienced engineer just a Jokeswagen tech from chicken & gravy Montgomery that figures out what alleged professional engineers fuck up.
https://forums.ross-tech.com/showthread.php?21785-2006-A6-Q-3-2-BKH-Transmission-Replacement
In this case Don see how OP said code won't clear with engine side disconnected, when that happens it tells me either ECU or wiring on other side and trust me these repairs are pissing techs off?
Some asshole engineer forgot a tree process that writes stuff on paper for RTFB and left the tech hung out to dry.
^^^ my apology to Jim for hijacking this thread (I promise not to do so for long)
@Jack - I'm sorry that we started this conversation, but it's like everything else that's new: the more I learn, the more I discover that I don't know!!. So, I've been trying to understand why your method of pulling the T105 connector works. Why does it mean that if the DTCs can be reset that the fault is in the ECU.
My first hypothesis was that the 5V rail in the engine prewiring harness was produced by the 2 x pins on the ECU that I have boxed in my WD above. But this doesn't make sense since your method allows for the DTC to remain with the T105 connector pulled (this implies that the 5Volt rail is produced elsewhere).
So -in usual mode, I sought inspiration from the WD: I searched for ALL instances of the term "D141 (Connection (5V) in engine prewiring harness)" and eventually I arrived at page 4/11 which is the Fuse assignment section of the WD - see copy below:
"Success - I've found the source of the 5V rail in the engine harness", I thought initially - but looking closer, how does the arrangement shown work? How can it work? How can a 12v fuse be connected to a 5V supply - even with the asterisk conditionality noted on the WD? I hate VW's WD s -What am I missing?
Like I said Don either fuse supply, ground, faulty consumer/sensor/corrosion bridge or ECU.
The engineers fucked this up or did they deliberately not want this data released since tests like mine will get them caught in chicanery? :p
I disagree I think everyone including OP will benefit from threads like this, we will know this based on the hits later, huh?
Did you know on the Bosch units here the 5 volt ref does come from the controller and the same can happen for what OP described even with connection unplugged and ECU not be bad still?
Did you know when testing to force circuits in either direction by decade box I inverse through a resistance of at least 1000 ohms to start with applying external 5 volts or using the controllers output of 5 volts to ground or from ref to respective sensor of error and through a decade box?
This way I can watch each sensor in VCDS blocks and change status of DTC created or vacated in simulation, see my point?
Sometimes I wire the respective sensor in too & then measure through meter or scope and plus watch in blocks to write my own test rules crosschecked to other new modules to reset DPF factors in EDC etc. or I do it directly in DMA, make sense?
Jim Beagley
C?ID=349735
Problem solved.
After receiving my ritual dose of abuse from Jack for being a landscaping "white skinned yard ape interloper", I took it upon myself to knuckle down to some serious study and spent many an hour pouring over current flow diagrams and individually testing components.
Unexpectedly, my MAP sensor had shorted internally.
I still find it fairly alarming that a single component can cause such a vast array of faults throughout the vehicle! I thought diagnostics was supposed to help pinpoint faults??? It seems I was wrong...
Thanks to all for your help
Problem solved.
Now to be fair, was it a question & not a statement Jim, rrrrrrrrrright? :rolleyes:
Would not an Interloper have failed where you succeeded?
I'm sure glad you are not an interloper!
https://forums.ross-tech.com/showth...engine-sensors&p=191053&viewfull=1#post191053
When trying to clear the code with engine harness unplugged did you only try in VAG mode 0x01 or did you try in OBD2 mode 0x33 because in some controllers of this era a DTC may not clear using VAG mode & sometimes needs to be done several times and is why I always request a default of ECU by re-coding?
Controller can sometimes be a tricky Dick, huh? .......... :p
Westbury, UK
Diagnostics are only as good as the failure modes and scenarios that the software designers considered, so they should only ever be regarded as a "hint" to the source of the problem and not as absolute truth.
