Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 2006 A6 Q 3.2 BKH Transmission Replacement
    Jun 2018
    Carmel, IN, USA
    I got this A6 with a bad transmission. The transmission replacement is complete. I understand I need to code the new transmission to the existing controller.
    Please find scan attached:
    Wednesday,05,February,2020,21:41:48:28853
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WAUDG74F76N033087   License Plate:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 65 67 72 76 77
    VIN: WAUDG74F76N033087   Mileage: 270040km-167795miles
    67-Voice Control -- Status: Malfunction 0010
    Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
       Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0040
       Revision: --H15---    Serial number:
       Coding: 01050106190F0120
       Shop #: WSC 98765 666 36249
       VCID: 2E05F2144C104E276BB-807A
    000821 - Crankshaft Position Sensor (G28)
                   P0335 - 006 - Malfunction - Intermittent
                        Reset counter: 40
                        Mileage: 270040 km
                        Date: 2005.02.07
                        Time: 15:52:09
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 9.0°C
                            Engine Off
                        Bin. Bits: 00000001
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 008 -
                        Reset counter: 40
                        Mileage: 270040 km
                        Date: 2005.02.07
                        Time: 15:52:17
                        RPM: 1440 /min
                        Mass Air / Rev.: 218.0 mg/str
                        Temperature: 10.5°C
                            Idle
                        Load: 21.6 %
    Readiness: 0110 0101
       Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
       Component: AG6 09L 3,2 FSI USA 0030
       Revision: --H01---    Serial number:        4065592
       Shop #: WSC 02331 785 00200
       VCID: 313FE9685D2E51DF769-8064
    005889 - Transmission Control Unit
                   P1701 - 000 - Locked
                        Reset counter: 40
                        Mileage: 270040 km
                        Date: 2005.02.02
                        Time: 23:12:58
                        (no units): 30.0
                        (no units): 21.0
                        Temperature: 12.0°C
                        T.B. Angle: 0.0°
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H03 0090
       Coding: 0020895
       Shop #: WSC 02327 785 00200
       VCID: 2D07F5184116353F521-8078
                        Fault Frequency: 13
                        Reset counter: 128
                        Mileage: 270040 km
                        Date: 2005.02.02
                        Time: 23:13:05
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0024
                        Hex Value: 0x0196
                        Hex Value: 0x00FF
       Component: FBSAUDIC6 ELV   H30 0180
       Revision: 30070501    Serial number: 10600300182362
       Coding: 0000015
       Shop #: WSC 44401 000 1048576
       VCID: 639353205752B34FB45-8036
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 KSG   H26 0080
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H01 0053
    7 Faults Found:
    00179 - Access/Start Authorization Antenna; Drivers Side (R134)
                        Fault Status: 00110110
                        Reset counter: 64
                        Mileage: 251317 km
                        Date: 2017.08.02
                        Time: 19:39:02
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01110010
                        Fault Frequency: 30
                        Reset counter: 107
                        Mileage: 265241 km
                        Date: 2018.06.13
                        Time: 09:08:56
    00532 - Supply Voltage B+
                        Reset counter: 168
                        Mileage: 270040 km
                        Date: 2018.10.19
                        Time: 10:58:14
                        Fault Frequency: 11
                        Reset counter: 168
                        Mileage: 270040 km
                        Date: 2018.10.19
                        Time: 10:56:38
                        Fault Status: 00100001
                        Reset counter: 168
                        Mileage: 270040 km
                        Date: 2005.02.01
                        Time: 12:04:47
    00447 - Function Limitation due to Over-Voltage
                        Fault Frequency: 11
                        Reset counter: 168
                        Mileage: 270040 km
                        Date: 2005.02.01
                        Time: 12:00:01
    02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
                        Reset counter: 128
                        Mileage: 270040 km
                        Date: 2005.02.01
                        Time: 18:12:42
       Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 303FH057501249
       Coding: 0000003
       Shop #: WSC 02335 785 00200
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H07 0010
       Subsystem 2 - Serial number: 00000000174635
       Subsystem 3 - Serial number: 0107.06.050000000100011081ÿ
       Subsystem 4 - Serial number: 011081ÿ
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000000151665
       Coding: 0524326
       VCID: 5BE36BC06F228B8FFC5-800E
    00739 - Coolant Circulation Pump (V50)
                        Fault Frequency: 15
                        Reset counter: 168
                        Mileage: 270040 km
                        Date: 2005.02.02
                        Time: 22:52:37
                        Temperature: 31.0°C
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H14 0080
       Coding: 0013123
       VCID: 66954A34A460C66753B-8032
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Subsystem 3 - Part No: 4F0 910 279
       Subsystem 4 - Part No: 4F1 910 113
       Subsystem 5 - Part No: 4E0 910 557
    No Faults Found
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7182428
       VCID: 1C6128DC2AACCCB735F-8048
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 D    HW: 4E0 035 593
       Component: SDAR SIRIUS     H04 0670
       Revision: 00000000    Serial number: AUZ4Z7E3011089
       VCID: 2809040C6EF41017A17-807C
    16344 - Control Module - RAM Error
                        Fault Status: 00101110
                        Reset counter: 168
                        Mileage: 258911 km
                        Date: 2018.03.15
                        Time: 17:19:27
                        Reset counter: 128
                        Mileage: 270040 km
                        Date: 2005.02.02
                        Time: 23:13:14
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 66 AIRBAG AUDI8RH29 0300
       Revision: 10H29000    Serial number: 00359D08CWPL
       Coding: 0013878
       Shop #: WSC 02136 444 53368
       VCID: 2A0DFE0470F82207B73-807E
       Subsystem 1 - Part No: 4F0 910 339
       Component: BF-Gewichtsens. 002 0040
       Subsystem 2 - Serial number: 6332CSME0A3F4B206
       Subsystem 3 - Serial number: 6342CSME0A4A7978H
       Subsystem 4 - Serial number: 6352QSME02221B713
       Subsystem 5 - Serial number: 6362QSME051941637
       Subsystem 6 - Serial number: 63734SME02013A59V
       Subsystem 7 - Serial number: 63834SME0214240DS
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026051520382
       Coding: 0002041
       Shop #: WSC 02323 785 00200
       Component: Lenkradmodul    H07 0080
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
       Component: KOMBIINSTR. M73 H15 0630
       Revision: 01000000    Serial number: 4PY31ZY55
       Coding: 2129263
       Shop #: WSC 05300 758 69175
       VCID: 211F19280DCEE15FE69-8074
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 12008055298123
       Coding: ECFE73CD1B7904
       Shop #: WSC 02325 785 00200
       VCID: 270B073063EA1F6FA8D-8072
                        Reset counter: 128
                        Mileage: 270040 km
                        Date: 2005.02.02
                        Time: 23:01:55
       Coding: 0082954
       VCID: 619F59284D4EA15FA69-8034
       Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
       Component: MNS US          H44 0740
       Revision: 00000000    Serial number: 355FP057548041
       VCID: 3829D44CBE548097317-806C
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00-00000
       Coding: 0051947
       VCID: 290F010875FE291FBE9-807C
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01008329410000
       Coding: 4618301
                        Reset counter: 128
                        Mileage: 133920 km
                        Date: 2013.09.24
                        Time: 15:47:46
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H09 0240
       Revision: PROD_01     Serial number: 00000000788720
       Coding: 0000026
       VCID: 25170D3819E60D7F9A1-8070
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000002567
       Coding: 0002114
       VCID: 5EE562D47C309EA79BB-800A
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00-00000
       Coding: 0051947
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       Shop #: WSC 02334 785 00200
       VCID: 5DE765D8713685BF821-8008
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000016
       VCID: 26150A3464E0066793B-8072
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
    02071 - Local Databus
                        Reset counter: 40
                        Mileage: 270040 km
                        Date: 2005.02.02
                        Time: 23:13:51
    02627 - Dynamic Cornering Light Motor; Left (V318)
                        Fault Status: 11101010
                        Fault Frequency: 7
                        Reset counter: 40
                        Mileage: 270040 km
                        Date: 2005.02.05
                        Time: 21:56:25
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
       Revision: 00000000    Serial number: 394F/057556693
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000048807
       Shop #: WSC 02136 444 53427
       VCID: 2313132017D2F34FF45-8076
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  1506051281
       Coding: 344630393135313035432056413031353036303531323831
       Shop #: WSC 00000 384 00290
    02256 - Quiescent Current
                        Reset counter: 168
                        Mileage: 270040 km
                        Date: 2005.02.06
                        Time: 04:55:44
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0051754
       VCID: 698F4108B57EE91F7E9-803C
       Part No SW: 4F0 910 273     HW: 4F0 907 273
       Component: Reifendruck 3   H04 0080
       Revision: 00040080    Serial number: 00000900006860
       Coding: 0062221
       VCID: 60995C2C4644A857A97-8034
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000506130141
       Shop #: WSC 12336 024 394758
       VCID: 3431E07CA23C64F71DF-8060
                        Fault Status: 00110100
                        Reset counter: 168
                        Mileage: 270040 km
                        Date: 2005.02.05
                        Time: 22:40:35
                        Reset counter: 128
                        Mileage: 270040 km
                        Date: 2005.02.02
                        Time: 23:14:19
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H11 0030
       Coding: 0051754
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0020
       Revision: 00H09000    Serial number: 11720515003701
       Coding: 0001206
    02070 - Rear Parking Aid Sensors
                        Reset counter: 128
                        Mileage: 270040 km
                        Date: 2005.02.05
                        Time: 22:33:49
       Component: Handyvorb2      H11 1130
       Revision: 00000000    Serial number: 00000007501782
       Coding: 0010900
    End----------(Elapsed Time: 05:00, VBatt start/end: 12.1V/12.1V)-----------
    Did you know you can swap controller or see dealer for SVM permitted the Transmission is correct for application?
    Jun 2018
    Carmel, IN, USA
    Jack, I have an inside guy at the local dealer, another DIYer. I can get info through him from Audi. The replacement transmission came from Brickyard Imports....they are a used parts yard, so not a VAG specialist repair shop, but are the European specialists in Indiana. They provided the replacement trans based on the Audi trans code from the factory trunk label. I expect I have no way to lay hands on the donor TCM or any codes from that car. Rob
    Jun 2018
    Carmel, IN, USA
    Do I go to partslink24 and get those?
    Jun 2018
    Carmel, IN, USA
    And are you saying I need those for my car or from the donor car?
  7. #7
    Is not partslink for parts and Erwin for RTFB did you see link?
    Did I say that?
  8. #8
    005889 - Transmission Control Unit - Locked
    This is effectively a "Component Protection" fault. The only proper way to fix that is via on-line access to Audi's servers.
  9. Likes Jack@European_Parts, PetrolDave liked this post
  10. #9
    Jun 2018
    Carmel, IN, USA
    Uwe, so is this something done by me or Audi dealer only? Rob
  11. #10
    Quote Originally Posted by rprellidzynr View Post
    Audi dealer or independent with ODIS software who has jumped through all the hoops to get access to Audi's servers.
