Halogen to xenon conversion vw golf gt
vw754
C?ID=52227
2104 golf....fitted all the loom and xenon headlamps with drl factory ones.
was originally halogen,now xenon.
they flicker when coming on,then go off.
can someone advise on what needs to be done now .....as far as the customer has told me is the above.
Wednesday,13,November,2019,16:07:06:07086
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZAUZEW274749   License Plate: 14 GOLF GT
Mileage: 153586km-95433mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW274749   Mileage: 153586km-95433miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5520
   Revision: 83H22---
   Coding: 011D0012034505082000
   Shop #: WSC 56055 001 104857
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AF1E1A6FDC4F79FE9-802E
17156 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 61
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:53
                    Engine speed: 771.00 /min
                    Normed load value: 22.7 %
                    Coolant temperature: 75 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 14.580 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
   Part No SW: 0D9 300 040 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4305
   Revision: 05852204    Serial number: TFK01401100385
   ROD: EV_TCMDQ250021.rod
   VCID: 2241F9C635D45F5F91-8076
11 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21156 - Gear 4
          P072F 00 [002] - Not Selectable
21157 - Gear 5
          P073A 00 [002] - Not Selectable
21158 - Gear 6
          P073B 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
21207 - Pressure Control Solenoid 3
          P0797 00 [002] - Stuck ON
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 600840000002BA
   Coding: 01FA8AA124270970037E060441CC2980512490C0608294F3F8625078C202
   VCID: 7CFDE7BEF7F0C9AFFB-8028
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Fault Frequency: 62
                    Reset counter: 73
                    Date: 2018.07.19
                    Time: 02:07:12
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 67
                    Date: 2018.07.19
                    Time: 02:07:12
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   VCID: 356B329A945AD8E744-8060
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:53
                    Outside air temperature: 16.5 °C
                    Engine speed: 700 /min
                    Temperature after evaporator: 19.3 °C
                    System run time-Engine running time: 255 s
                    System run time-Terminal 15 on: 255 s
          B10CD 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 113
                    Mileage: 153575 km
                    Date: 2018.09.29
                    Time: 04:25:58
                    Voltage terminal 30: 10.7 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011402101731
   Coding: 03001842C241027B0BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 79F3FEAAF8C2FC87E0-802C
   Component: WWS    140113  042 0551
   Serial number:         140115152225
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M01D28H09M50S48S6
   Coding: 00A8DD
   Serial number: 000000000ZY163083DWY
10762 - Bulb for Right Tail Light
          B12BF 15 [009] - Open or Short to Plus
                    Reset counter: 74
                    Mileage: 153586 km
                    Date: 2018.10.21
                    Time: 01:29:15
12307 - License Plate Light
          B12CA 01 [009] - Electrical Failure
                    Reset counter: 74
                    Mileage: 153586 km
                    Date: 2018.10.21
                    Time: 01:29:15
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [009] - -
                    Reset counter: 74
                    Mileage: 153586 km
                    Date: 2018.10.21
                    Time: 01:29:09
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331402002548
   Coding: 0071051011
   VCID: 3E792DB6A16C1BBF95-806A
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Coding: 2B00608151FFC728949C810560400600000000000000000000
   VCID: 3C7D27BEB77009AFBB-8068
8 Faults Found:
2185 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 14.3 V
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
          U1101 00 [009] - Active
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
1074 - Databus
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
                    Voltage terminal 15: 14.4 V
1227 - Databus
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
1127 - Databus
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
1218 - Databus
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
1219 - Databus
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR030GBH
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F0710B2E6E6D2B7DE-802A
   Belt Pretensioner left:
   Serial number: 34169677B27101540506
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B26101540020
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 112 16
   Serial number: 3576700000044201EE1P
   Subsystem 4 - Part No SW: -----------    HW: 480 000 512 16
   Serial number: 35867000000309053028
   Subsystem 5 - Part No SW: -----------    HW: 480 401 701 14
   Serial number: 3516502B312FAE351214
   Subsystem 6 - Part No SW: -----------    HW: 480 401 801 14
   Serial number: 3526502A513013E3637-
   Subsystem 7 - Part No SW: -----------    HW: 480 402 105 14
   Serial number: 3556502A5156E9F181ET
9447251 - Seat Occupied Sensor; Passenger's Side
          B1027 53 [009] - Deactivated
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:55
9634901 - Control Module for Front Left Belt Tensioner
          B1304 55 [009] - Not configured
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:53
9635157 - Control Module for Front Right Belt Tensioner
          B1305 55 [009] - Not configured
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 18011404221220
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BFFE4A2F2FECE97F2-802E
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
617752 - ROD - Unknown Error Code
          - 00 [024]
                    Reset counter: 111
                    Mileage: 153540 km
                    Date: 2018.07.19
                    Time: 19:33:42
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         204 3390
   Coding: 27A419082780260001886A01040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 2855EBEE53E8B50FCF-807C
16776960 - Databus
                    Reset counter: 112
                    Mileage: 153574 km
                    Date: 2018.09.26
                    Time: 03:36:23
16776962 - Databus
                    Reset counter: 112
                    Mileage: 153574 km
                    Date: 2018.09.26
                    Time: 03:36:23
16776964 - Databus
                    Reset counter: 112
                    Mileage: 153574 km
                    Date: 2018.09.26
                    Time: 03:36:24
16776961 - Databus
                    Reset counter: 112
                    Mileage: 153574 km
                    Date: 2018.09.26
                    Time: 03:36:23
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 111
                    Mileage: 153574 km
                    Date: 2018.09.25
                    Time: 00:39:54
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001451211
   Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3F8750B2A66612B79E-806A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 27160003150250046483
   Coding: 2DFFFF
   Serial number: 3749282303
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:54
                    Supply voltage: Terminal 30: 14.4 V
                    Terminal 15: On
   Serial number: 191116EKI29844
   Coding: 003F1220D001048000001000
   VCID: 438F5C42CA8E7657FA-8016
   Serial number: 00000000000012491354
   Coding: 0D0000
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:06:53
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   Shop #: WSC 56055 001 1048576
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 4183564AD0926447E8-8014
   Serial number: 201116EKJ2206A
   Coding: 003F1020DE01048000801000
   VCID: 42815946D5947F5FF1-8016
   Serial number: 00000000000012416054
   Coding: 150000
                    Reset counter: 67
                    Mileage: 153521 km
                    Date: 2018.07.19
                    Time: 02:12:23
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    040 0430
   Serial number: V7F01301140661
   Coding: 02730001FF00000021111201002800001F0100060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 67D7A8D29E767A7706-8032
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9PJ903BTA
   Subsystem 2 - Part No SW: 5G0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
End-------------------------(Elapsed Time: 03:59)--------------------------
langers2k
C?ID=224085
For starters, the retrofit should be completed as it appears there is no headlight range module (address 55, AFS master) fitted...
vw754
C?ID=52227
Where is this fitted /located?
langers2k
C?ID=224085
I think the stock location would be in the dashboard near the CAN gateway but I'm not sure.
It's probably also missing the suspension level sensor(s).
vw754
C?ID=52227
Thanks, I suppose that's why they not working properly, il let the guy know.
hmm......... how were the Leuchte-sets in the BCM re-programmed to accommodation the new HID lamps?
Retrofitted looms are always problematic in these projects because they can cross-wire the factory arrangement on the BCM connectors. This will have the effect of negating the factory assignment of the Leucthe-sets to particular lamps. The other confounder with retro-fitted (read, third-party) light fittings is that they vary greatly in their ability to be plug-and-play. This can result in highly unpredictable (and completely individual) symptoms.
But perhaps, reviewing how the car was re-coded after the physical retrofit would be a good starting-point (maybe)?
EDIT: what's the story on the Component Protection error on hex13 module (with a matching DTC on the CP master module)? Has this car been in an accident - or was the front radar sensor retrofitted as well?
EDIT 2: .... and as to Langers2K question - was a leveling sensor fitted to the rear axel on the car (is this a legal requirement in UK)?
vw754
C?ID=52227
Cars been accident repaired.
Also spoke to the guy about xenon, he said he has fitted the kufutec xenon plug and play loom
vw754
C?ID=52227
Don't know, anything else, all I know it's been in an accident, been repaired, xenon headlamps all been off a donor car and fitted to this, with kufutec loom, plug and play
Westbury, UK
Except it's not plug and play since the retrofit isn't working :thanks: - not unknown for Kufatec 'kits' :banghead:
In the UK retrofitting Xenon headlamps is a legal tangle - strictly speaking (under the Road Vehicle Lighting Regulations) Xenon headlamps (except very dim ones like fitted to the Skoda Rapid) are required to have both self levelling and headlamp washers BUT the MOT test only checks that self levelling and headlamps washers work IF FITTED. However, the MOT tester (starting in May 2018) is supposed to check that the headlamps are suitable for Xenon use (which if you have swapped the complete headlamp assembly they will be).
"Plug & Play".
Kufatec keeps using that phrase.
I don't think it means what they think it means. ;)
vw754
C?ID=52227
Any idea to fix the issue please let me know
siLc
Tallinn, Estonia
C?ID=330192
downtime
Finland
C?ID=280813
SiLc is correct. For the xenons to properly work you'll need range control module and rear leveling sensor.
Also like Don already suggested, you're leuchte adaptation channels in BCM module are now set for halogen lights. They for example have reduced power and are set to PWM mode. You need to change the light types to xenon and pump the dimmwert value to 100 for the respective light channels.
Check the reference scan section of the forum. There I think I saw one Golf mk7 autoscan where also some adamaps were attached. You'll need a BCM adamap from a car with factory xenons.
vw754
C?ID=52227
Probably will be set for halogen lights, but in coding I couldn't see any box to tick for halogen or xenon, no option was available unless there in another module I've missed
downtime
Finland
C?ID=280813
For MQB cars you don't set anything for the light configuration in coding. All settings are done through adaptation channels.
But one more thing caught my eye in the autoscan. If I'm not entirely mistaken, the car has midline BCM which is not supporting xenon lights. This plug'play retrofit is starting to look a lot more than that :)
vw754
C?ID=52227
Cheers, well plug and play not much good lol.... Plug and 🙏 pray lol
^^^ following-on downtime's thoughts - check these adaptation channels in the BCM:
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 (left-side headlight)
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 (right-side headlight)
If the channels have the setting 11 - Abblendlicht, change to 3 - Xenon Abblendlicht
PS: I'm assuming of course that the new loom has retained the OEM Leuchte-set assignments
vw754
C?ID=52227
OK, thanks il ask guy get car here
m87a
Bosnia and Herzegovina
C?ID=156900
His bcm will have these settings just like any other halogen configured car, but his bcm doesn't support xenon lights and changing to these settings will trigger mfd error ( orange triangle error lights) with no dtc in 09.
(1)-Leuchte6ABL LC5-Lasttyp 6 --> 3 - Xenon Abblendlicht
(5)-Leuchte6ABL LC5-Lichtfunktion B 6 --> Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6 --> 127
(1)-Leuchte7ABL RB1-Lasttyp 7 --> 3 - Xenon Abblendlicht
(5)-Leuchte7ABL RB1-Lichtfunktion B 7 --> Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7 --> 127
^^^ thanks for the heads-up. But it's a simple matter of reverting the settings back if this happens - so in the absence of a more definitive solution and since you have used "may" (instead of "will") in your response - perhaps worth a try nevertheless?
But again - a worthwhile point to make for OP's benefit (and mine)!
