2104 golf....fitted all the loom and xenon headlamps with drl factory ones.
was originally halogen,now xenon.
they flicker when coming on,then go off.
can someone advise on what needs to be done now .....as far as the customer has told me is the above.
Wednesday,13,November,2019,16:07:06:07086
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZAUZEW274749 License Plate: 14 GOLF GT
Mileage: 153586km-95433mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW274749 Mileage: 153586km-95433miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 011D0012034505082000
Shop #: WSC 56055 001 104857
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AF1E1A6FDC4F79FE9-802E
17156 - Databus
U1123 00 [047] - Received Error Message
Fault Frequency: 61
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:53
Engine speed: 771.00 /min
Normed load value: 22.7 %
Coolant temperature: 75 °C
Intake air temperature: 55 °C
Voltage terminal 30: 14.580 V
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Acceleration: 0.000 m/s²
Part No SW: 0D9 300 040 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4305
Revision: 05852204 Serial number: TFK01401100385
ROD: EV_TCMDQ250021.rod
VCID: 2241F9C635D45F5F91-8076
11 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
21207 - Pressure Control Solenoid 3
P0797 00 [002] - Stuck ON
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000 Serial number: 600840000002BA
Coding: 01FA8AA124270970037E060441CC2980512490C0608294F3F8625078C202
VCID: 7CFDE7BEF7F0C9AFFB-8028
8309 - Engine Control Module Incorrectly Coded
P1612 00 [009] - -
Fault Frequency: 62
Reset counter: 73
Date: 2018.07.19
Time: 02:07:12
32951 - Control Module for Electronic Parking Brake
C10E2 54 [137] - Missing Calibration / Basic Setting
Reset counter: 67
Date: 2018.07.19
Time: 02:07:12
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00120104202100001000000000000000
VCID: 356B329A945AD8E744-8060
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:53
Outside air temperature: 16.5 °C
Engine speed: 700 /min
Temperature after evaporator: 19.3 °C
System run time-Engine running time: 255 s
System run time-Terminal 15 on: 255 s
B10CD 00 [008] - -
Fault Frequency: 16
Reset counter: 113
Mileage: 153575 km
Date: 2018.09.29
Time: 04:25:58
Voltage terminal 30: 10.7 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
CAN input signal(s) status-Back-up light: OFF
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011402101731
Coding: 03001842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
VCID: 79F3FEAAF8C2FC87E0-802C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140113 042 0551
Serial number: 140115152225
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y14M01D28H09M50S48S6
Coding: 00A8DD
Serial number: 000000000ZY163083DWY
10762 - Bulb for Right Tail Light
B12BF 15 [009] - Open or Short to Plus
Reset counter: 74
Mileage: 153586 km
Date: 2018.10.21
Time: 01:29:15
12307 - License Plate Light
B12CA 01 [009] - Electrical Failure
Reset counter: 74
Mileage: 153586 km
Date: 2018.10.21
Time: 01:29:15
267012 - No Communications with Anti-Theft Siren / Alarm Horn
U10F3 00 [009] - -
Reset counter: 74
Mileage: 153586 km
Date: 2018.10.21
Time: 01:29:09
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331402002548
Coding: 0071051011
VCID: 3E792DB6A16C1BBF95-806A
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 3QF 907 572
Coding: 2B00608151FFC728949C810560400600000000000000000000
VCID: 3C7D27BEB77009AFBB-8068
8 Faults Found:
2185 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
Control Module temperature: 39 °C
Voltage terminal 15: 14.3 V
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
U1101 00 [009] - Active
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
1074 - Databus
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
Voltage terminal 15: 14.4 V
1227 - Databus
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
1127 - Databus
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
1218 - Databus
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
1219 - Databus
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR030GBH
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F0710B2E6E6D2B7DE-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B27101540506
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B26101540020
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 112 16
Serial number: 3576700000044201EE1P
Subsystem 4 - Part No SW: ----------- HW: 480 000 512 16
Serial number: 35867000000309053028
Subsystem 5 - Part No SW: ----------- HW: 480 401 701 14
Serial number: 3516502B312FAE351214
Subsystem 6 - Part No SW: ----------- HW: 480 401 801 14
Serial number: 3526502A513013E3637-
Subsystem 7 - Part No SW: ----------- HW: 480 402 105 14
Serial number: 3556502A5156E9F181ET
9447251 - Seat Occupied Sensor; Passenger's Side
B1027 53 [009] - Deactivated
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:55
9634901 - Control Module for Front Left Belt Tensioner
B1304 55 [009] - Not configured
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:53
9635157 - Control Module for Front Right Belt Tensioner
B1305 55 [009] - Not configured
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 18011404221220
Coding: 0C10
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 7BFFE4A2F2FECE97F2-802E
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
617752 - ROD - Unknown Error Code
- 00 [024]
Reset counter: 111
Mileage: 153540 km
Date: 2018.07.19
Time: 19:33:42
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 204 3390
Coding: 27A419082780260001886A01040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: 2855EBEE53E8B50FCF-807C
16776960 - Databus
Reset counter: 112
Mileage: 153574 km
Date: 2018.09.26
Time: 03:36:23
16776962 - Databus
Reset counter: 112
Mileage: 153574 km
Date: 2018.09.26
Time: 03:36:23
16776964 - Databus
Reset counter: 112
Mileage: 153574 km
Date: 2018.09.26
Time: 03:36:24
16776961 - Databus
Reset counter: 112
Mileage: 153574 km
Date: 2018.09.26
Time: 03:36:23
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 111
Mileage: 153574 km
Date: 2018.09.25
Time: 00:39:54
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001451211
Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3F8750B2A66612B79E-806A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 27160003150250046483
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3749282303
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:54
Supply voltage: Terminal 30: 14.4 V
Terminal 15: On
Component: TSG FS 020 0041
Serial number: 191116EKI29844
Coding: 003F1220D001048000001000
VCID: 438F5C42CA8E7657FA-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012491354
Coding: 0D0000
65799 - Door Warning / Entry Lighting
B1775 01 [009] - Electrical Failure
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:06:53
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
Shop #: WSC 56055 001 1048576
ROD: EV_SteerAssisMQB_010.rod
VCID: 4183564AD0926447E8-8014
Component: TSG BFS 020 0041
Serial number: 201116EKJ2206A
Coding: 003F1020DE01048000801000
VCID: 42815946D5947F5FF1-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012416054
Coding: 150000
Reset counter: 67
Mileage: 153521 km
Date: 2018.07.19
Time: 02:12:23
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 874 HW: 5G0 035 874
Component: MU-S-ND-ER 040 0430
Serial number: V7F01301140661
Coding: 02730001FF00000021111201002800001F0100060100010045
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 67D7A8D29E767A7706-8032
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9PJ903BTA
Subsystem 2 - Part No SW: 5G0 919 866 F HW: -----------
Component: ECE 2014 --- 0036
End-------------------------(Elapsed Time: 03:59)--------------------------
