Tuesday,19,April,2022,10:09:03:45649
VCDS Version: 22.3.0.1 (x64) HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVGEK9BP1CD005604 License Plate:
Mileage: 398622km-247692mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: WVGEK9BP1CD005604 Mileage: 398622km-247692miles
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI EDC17 H17 0005
Revision: 56H17--- CVN: 0FF473B738D3FF8238D3FF82
Coding: 292A4012233600050000
Shop #: WSC 02330 444 92460
ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
ROD: EV_ECM30TDI0117P0907401J_001.rod
VCID: 3635DA6018CC58AB25E-8062
VINID: 9E65D56C94A00535000051801004E1B29D
7 Faults Found:
5188 - Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
Mileage: 398590 km
Date: 2022.04.15
Time: 11:04:03
Engine RPM: 1350.50 /min
Normed load value: 4.7 %
Vehicle speed: 39 km/h
Coolant temperature: 86 °C
Intake air temperature: 21 °C
Voltage terminal 30: 13.880 V
P Flt Ld fac Ash Cor: 1.0000
Particul.filter diff.pressure: 900 hPa
Exh t Adap T Oxi Cat Ds: 390.4 °C
Exh t Adap TP Flt Ds: 202.4 °C
Exhaust gas jet volume in particle filter: 202.3 m³/h
Current operating mode_2-Bits 0-7: 00000000
Current operating mode_2-Bits 0-7: 00000100
Current operating mode_2-Bits 0-7: 00000010
5158 - Diesel Particulate Filter; Differential Pressure Sensor
P2456 00 [109] - Intermittent
Mileage: 398589 km
Date: 2022.04.15
Time: 10:44:30
Engine RPM: 1294.50 /min
Normed load value: 99.6 %
Coolant temperature: 66 °C
Intake air temperature: 27 °C
Voltage terminal 30: 13.920 V
Sensor for particle filter differential press: raw value: 563 hPa
Particle filter: difference pressure: 554 hPa
DPF: offset for differential pressure: 1 hPa
Particle filter: differential pressure: dynamic offset: 0 hPa
Outside temperature: 17.5 °C
Particle filter: soot mass measured: 0.00 g
Particle filter: soot mass calculated: 0.01 g
4817 - Leak in Air Intake System
P2279 00 [237] - -
Mileage: 398591 km
Date: 2022.04.15
Time: 11:05:03
Engine RPM: 1742.00 /min
Normed load value: 96.9 %
Vehicle speed: 50 km/h
Coolant temperature: 89 °C
Intake air temperature: 20 °C
Voltage terminal 30: 14.060 V
Charge Pressure Actuator: activation: 99.63 %
Charge air pressure actuator: acknowledgment: 99.43 %
Ambient temperature: 13.0 °C
Charge air pressure: specified value: 1475 hPa
Accelerator pedal travel: 30.42 %
Air mass: actual value (mg/stroke): 973.9 mg/stroke
Actual charge pressure: 983 hPa
5171 - Boost Pressure Regulation
P0299 00 [101] - Control Range Not Reached
Mileage: 398590 km
Date: 2022.04.15
Time: 11:03:35
Engine RPM: 1800.50 /min
Normed load value: 46.7 %
Vehicle speed: 47 km/h
Coolant temperature: 81 °C
Intake air temperature: 23 °C
Voltage terminal 30: 13.680 V
Charge Pressure Actuator: activation: 99.55 %
Charge air pressure actuator: acknowledgment: 97.55 %
Ambient temperature: 12.8 °C
Charge air pressure: specified value: 1665 hPa
Accelerator pedal travel: 32.32 %
Air mass: actual value (mg/stroke): 1044.1 mg/stroke
8863 - Diesel Particulate Filter
P2459 00 [101] - Regeneration Frequency
Mileage: 398589 km
Date: 2022.04.15
Time: 10:46:02
Engine RPM: 965.50 /min
Normed load value: 27.5 %
Vehicle speed: 2 km/h
Coolant temperature: 71 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.120 V
Exhaust gas jet volume in particle filter: 73.2 m³/h
Particle filter: difference pressure: 499 hPa
Particle filter: soot mass measured: 34.00 g
Particle filter: soot mass calculated: 34.00 g
Exhaust gas temperature sensor 3: 240.0 °C
Exhaust gas temperature sensor 4: 124.7 °C
12896 - Boost Pressure Regulation
Mileage: 398590 km
Date: 2022.04.15
Time: 11:03:35
Charge Pressure Actuator: activation: 99.73 %
5189 - Particulate Trap Bank 1
P2002 00 [047] - Efficiency Below Threshold
Mileage: 398590 km
Date: 2022.04.15
Time: 11:04:03
Ambient temperature: 12.7 °C
DPF: offset for differential pressure: 2 hPa
Particle filter: soot mass measured: 93.54 g
Particle filter: soot mass calculated: 34.04 g
Particle filter: kilometers since last regeneration: 794 m
Particle filter field regeneration: cancel conditions-Bits 0-7: 00000000
Particle filter field regeneration: cancel conditions-Bits 0-7: 00000001
Readiness: 1 2 0 0 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 1857
Serial number: CVN: 15844593
Coding: 001368
Shop #: WSC 42005 002 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: 3039EC78FAA8769B7F2-8064
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 J HW: 7P0 907 379 A
Component: MK25A H36 0433
Revision: -------- Serial number: 427310010EC010
Coding: 5B7613C349242558DAFAC89392D6A4407300
Shop #: WSC 31414 790 00001
ROD: EV_ESPMK25A00800.rod
VCID: 44D1B0A85E10FA3BABA-8010
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0333
Coding: 09860000000000000000
VCID: 73B323744BBE0D83C20-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG 0051
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B606200A80
VCID: 7EA50240707C50EBBDE-802A
U1101 00 [008] - Active
Reset counter: 124
Mileage: 397245 km
Date: 2022.03.30
Time: 00:42:28
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001111655
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 6B833B14138ED5430A0-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 111021 31 0020
Serial number: 90243400111028231403
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10264691
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000001110110267
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0S3807
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag025 H05 0025
Revision: -------- Serial number: 003L0000JX0X
Coding: 000000000000000000000000000000003235
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 41DFB9BC4102EF1380C-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1172706H59
Serial number: 3575LRB40690T3R6A0UV
Serial number: 3585LRB40690T3R69HP0
Serial number: 3515RRB40550OPMK49H%
Serial number: 3525RRB405B0OPMKH9NP
Serial number: 3555NRB40590PIJQEGOO
Serial number: 3565NRB40550PIJQKHEI
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Revision: -------- Serial number: 90815KJP0005S
Coding: 000015
VCID: 3635DA60184C58AB25E-8062
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0124203
00886 - Turn Signal Switch (E2)
Fault Frequency: 7
Reset counter: 123
Mileage: 397601 km
Date: 2022.04.06
Time: 00:00:45
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658221011593041
Coding: 8B7733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 47CBA7A46F26D1234E8-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000291319
Coding: 0001037500
GVL: FB0F40451D7F000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 3829D45812D8AEDB372-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650843827
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000016937431
Coding: 0058130000004001000001010101202020202121202020
VCID: 3431E0680E304ABB1BA-8060
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000121063960
Coding: 011D07205E00453005080000
VCID: 44D1B0A85E90FA3BABA-8010
Fault Status: 01101100
Reset counter: 74
Mileage: 397798 km
Date: 2022.04.08
Time: 00:19:07
Revision: 00002001 Serial number: 0161545821
Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 284119591
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO13391685
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO1336156%
Coding: 191100
00985 - Right Tail Light (M2)
Fault Status: 00101100
Reset counter: 100
Mileage: 396654 km
Date: 2022.03.02
Time: 06:07:30
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
Reset counter: 99
Mileage: 397216 km
Date: 2022.03.29
Time: 22:05:31
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000121426575
VCID: 3B23CB54236E85C3DA0-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11A070021C
Coding: 00000000
ROD: EV_ParkbA7.rod
Slave 1:
Slave 3:
0025 - No Calibration
B2010 F0 [008] - Deviation from Expected Range
[Steuergerät EPB - Kalibrierung fehlgeschlagen]
Reset counter: 45
Mileage: 396654 km
Date: 2022.03.12
Time: 04:19:48
Voltage: 14.2 V
0024 - No Basic Setting
B2010 00 [009] - -
[Steuergerät EPB - System nicht kalibriert]
Voltage: 14.0 V
12652550 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät EPB - Codierungsfehler]
Voltage: 14.0 V
0018 - Switch for Electric Parking Brake
C100C 01 [009] - Electrical Failure
Reset counter: 45
Mileage: 396654 km
Date: 2022.03.23
Time: 22:48:03
Voltage: 12.2 V
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
VCID: 7CA10848666042FB93A-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: 130000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H53 0133
Revision: AB001007 Serial number: 156J20B7565751
Coding: 020007020100000001
VCID: 24111028BED0DA3B8BA-8070
Part No SW: 7P6 035 664 D HW: 7P6 035 664
Component: H-BN-NA H44 0706
Revision: -------- Serial number: 445J 0B7521662
Coding: 010200050040E1EE41022B0C00000003F00001010000000000
VCID: 392FD15C2952B7D3C8C-806C
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9L79004S3
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Reset counter: 7
Mileage: 394316 km
Date: 2022.01.25
Time: 19:42:42
Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
Reset counter: 7
Mileage: 394316 km
Date: 2022.01.25
Time: 19:42:40
Voltage: 12.60 V
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000121490349
Coding: 011C07200000253005080000
VCID: 3A2DCE502C54BCCBC16-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000050575
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDBBF4437F699E3F68-806A
8389634 - Radio Frequency Interference
C105C 00 [008] - -
Fault Frequency: 8
Reset counter: 117
Mileage: 395459 km
Date: 2022.02.08
Time: 23:59:08
8389635 - Radio Frequency Interference
C105C 00 [008] - -
Reset counter: 128
Mileage: 397416 km
Date: 2022.04.01
Time: 07:04:36
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Reset counter: 77
Mileage: 397944 km
Date: 2022.04.09
Time: 10:19:04
Vehicle speed: 10 km/h
Outside temperature: 20 °C
Reception level antenna 1: 720 mV
Offset level antenna 1: 680 mV
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Reset counter: 70
Mileage: 397748 km
Date: 2022.04.07
Time: 06:58:16
Vehicle speed: 102 km/h
Outside temperature: 35.5 °C
Reception level antenna 1: 700 mV
Offset level antenna 1: 660 mV
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001 Serial number: 00000160938100
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H04000 Serial number: 525 PA8J192588
Coding: 0110001
VCID: 372BD7641346A1A33E8-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 294100187
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D27C54C3DFA8BF3E44-8068
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000121399453
End----------(Elapsed Time: 03:02, VBatt start/end: 13.1V/14.4V)-----------
Wednesday,20,April,2022,11:57:34:45649
VCDS Version: 22.3.0.1 (x64) HEX-V2 CB: 0.4615.4
69 6C 6D 72
Mileage: 398622 km
Date: 2022.04.18
Time: 22:09:40
Engine RPM: 789.00 /min
Normed load value: 22.7 %
Coolant temperature: 39 °C
Intake air temperature: 22 °C
Voltage terminal 30: 13.440 V
Particul.filter diff.pressure: 241 hPa
Exh t Adap T Oxi Cat Ds: 130.2 °C
Exh t Adap TP Flt Ds: 74.0 °C
Exhaust gas jet volume in particle filter: 61.3 m³/h
Current operating mode_2-Bits 0-7: 00010000
Mileage: 398622 km
Date: 2022.04.18
Time: 22:09:40
Ambient temperature: 18.0 °C
DPF: offset for differential pressure: 3 hPa
Particle filter: soot mass calculated: 60.23 g
Particle filter: kilometers since last regeneration: 32676 m
Readiness: 1 1 0 0 1
Coding: 001368
Component: FBSTOUAREGIDG H04 0051
Serial number: 0511000056915016
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000221683004
Coding: B606200A80
Reset counter: 124
Mileage: 397245 km
Date: 2022.03.30
Time: 00:42:28
Coding: 004DBD
Coding: 025223
Coding: 000015
Fault Frequency: 7
Reset counter: 123
Mileage: 397601 km
Date: 2022.04.06
Time: 00:00:45
Coding: 0001037500
Reset counter: 74
Mileage: 397798 km
Date: 2022.04.08
Time: 00:19:07
Coding: 191100
Coding: 191100
Reset counter: 100
Mileage: 396654 km
Date: 2022.03.02
Time: 06:07:30
Reset counter: 99
Mileage: 397216 km
Date: 2022.03.29
Time: 22:05:31
Coding: 00000000
ROD: EV_ParkbA7.rod
Slave 1:
Slave 3:
Reset counter: 45
Mileage: 396654 km
Date: 2022.03.12
Time: 04:19:48
Voltage: 14.2 V
B2010 00 [009] - -
Voltage: 14.0 V
U1014 00 [009] - -
Voltage: 14.0 V
Reset counter: 45
Mileage: 396654 km
Date: 2022.03.23
Time: 22:48:03
Voltage: 12.2 V
Coding: 130000
Coding: 130000
Reset counter: 7
Mileage: 394316 km
Date: 2022.01.25
Time: 19:42:42
Reset counter: 7
Mileage: 394316 km
Date: 2022.01.25
Time: 19:42:40
Voltage: 12.60 V
C105C 00 [008] - -
Fault Frequency: 8
Reset counter: 117
Mileage: 395459 km
Date: 2022.02.08
Time: 23:59:08
C105C 00 [008] - -
Reset counter: 128
Mileage: 397416 km
Date: 2022.04.01
Time: 07:04:36
Reset counter: 77
Mileage: 397944 km
Date: 2022.04.09
Time: 10:19:04
Reset counter: 70
Mileage: 397748 km
Date: 2022.04.07
Time: 06:58:16
Coding: 0110001
Coding: 0533314003
End----------(Elapsed Time: 02:16, VBatt start/end: 13.5V/14.3V)-----------
