I bought VCDS a few days ago. I have a clogged DPF on my 2012 Touareg TDI that put me into limp mode. Top speed is 35 mph right now so I cannot go into driving regeneration. I tried to do emergency regeneration using the guide on Ross-Tech http://wiki.ross-tech.com/wiki/inde..._Regeneration#2.7l.2F3.0l_V6_CR-TDI_.28CAN.29 and it aborts due to "safety error". I am not sure why because my readings do not exceed the safety levels from my understanding.
Soot Mass Calculated is 36 gr and it should be 60 or more to be in danger of being on fire right ?
Any insight on what I might be doing wrong or any help would be appreciated. Anyone has had this problem before?
Also, the Emergency stationary regeneration starts if my coolant temperature is below 70 (if I do it right after I start the engine) but I was afraid to complete it. Is it safe to do it like that with the engine cold? or is it going to abort once I reach operating temperature?
What are my options here...? am I doing something wrong?
Complete autoscan below.
I am a newbie and all help would be appreciated.
Alex.
Alex.
Friday,29,June,2018,19:25:25:45649
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WVGEK9BP1CD005604 License Plate:
Mileage: 315669km-196147mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: WVGEK9BP1CD005604 Mileage: 315669km-196147miles
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI EDC17 H17 0005
Revision: 56H17---
Coding: 292A4012233600050000
Shop #: WSC 02330 444 92460
ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
ROD: EV_ECM30TDI0117P0907401J_001.rod
VCID: 3635DA6018CC58A79BB-8062
5188 - Diesel Particle Filter
P2463 00 [040] - Excessive Soot Accumulation
Fault Frequency: 8
Mileage: 315648 km
Date: 2018.05.17
Time: 01:40:04
Engine speed: 976.00 /min
Normed load value: 23.5 %
Coolant temperature: 37 °C
Intake air temperature: 21 °C
Voltage terminal 30: 13.800 V
P Flt Ld fac Ash Cor: 0.9850
Particul.filter diff.pressure: 168 hPa
Exh t Adap T Oxi Cat Ds: 61.6 °C
Exh t Adap TP Flt Ds: 37.4 °C
Exhaust gas jet volume in particle filter: 45.3 m³/h
Current operating mode_2-Bit 0: 00000000
Current operating mode_2-Bit 16: 00001110
Current operating mode_2-Bit 24: 00010000
Current operating mode_2-Bit 8: 00000000
5158 - Diesel Particulate Filter; Differential Pressure Sensor
P2456 00 [040] - Intermittent
Mileage: 315649 km
Date: 2018.05.22
Time: 15:11:14
Engine speed: 1472.50 /min
Normed load value: 75.3 %
Vehicle speed: 33 km/h
Coolant temperature: 36 °C
Intake air temperature: 20 °C
Voltage terminal 30: 14.120 V
Sensor for particle filter differential press: raw value: 793 hPa
Particle filter: difference pressure: 790 hPa
Particle filter: offset for differential press.: 0 hPa
Particle filter: differential pressure: dynamic offset: 0 hPa
Outside air temperature: 20.5 °C
Particle filter: soot mass measured: 33.48 g
Particle filter: soot mass calculated: 34.69 g
4795 - Mass Air Flow Sensor (G70)
P0101 00 [237] - Implausible Signal
Mileage: 315650 km
Date: 2018.05.22
Time: 15:45:57
Engine speed: 1545.00 /min
Vehicle speed: 44 km/h
Coolant temperature: 62 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.280 V
Mean injection quantity: 0.00 mg/stroke
Control Module temperature: 29.5 °C
EGR_governor_deviation: -209.6 mg/stroke
Inj Ctl q Curr: 0.00 mg/stroke
Mass_air_flow_sensor_drift: 0.7510
Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 188.1 kg/h
Actual charge pressure: 1004 hPa
5171 - Boost Pressure Regulation
P0299 00 [109] - Control Range Not Reached
Mileage: 315649 km
Date: 2018.05.22
Time: 15:11:22
Engine speed: 1982.00 /min
Normed load value: 76.1 %
Coolant temperature: 40 °C
Voltage terminal 30: 14.200 V
Charge Pressure Actuator: activation: 87.38 %
Charge Pressure Actuator: acknowledgment: 86.69 %
Ambient temperature: 20.2 °C
Charge air pressure specified value: 2117 hPa
Accelerator pedal travel: 34.48 %
Air mass: actual value (mg/stroke): 1097.9 mg/stroke
Actual charge pressure: 1179 hPa
12896 - Boost Pressure Regulation
P0299 00 [237] - Control Range Not Reached
Mileage: 315649 km
Date: 2018.05.22
Time: 15:11:22
Charge Pressure Actuator: activation: 89.39 %
5189 - Particulate Trap Bank 1
P2002 00 [040] - Efficiency Below Threshold
Fault Frequency: 9
Mileage: 315648 km
Date: 2018.05.17
Time: 01:40:04
Ambient temperature: 17.2 °C
Particle filter: soot mass measured: 79.05 g
Particle filter: soot mass calculated: 34.07 g
Particle filter: kilometers since last regeneration: 896945 m
Particle filter field regeneration: cancel conditions-Bit 0: 00000000
Particle filter field regeneration: cancel conditions-Bit 8: 00000000
Readiness: 1 3 0 0 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 1857
Coding: 001368
Shop #: WSC 42005 002 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: 3039EC78FAA87697C17-8064
Address 03: ABS Brakes (J104) Labels:| 7P0-907-379.clb
Part No SW: 7P0 907 379 J HW: 7P0 907 379 A
Component: MK25A H36 0433
Revision: -------- Serial number: 427310010EC010
Coding: 5B7613C349242558DAFAC89392D6A4407300
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 44D1B0A85E10FA3715F-8010
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0333
Coding: 09860000000000000000
VCID: 73B323744BBE0D8F7C5-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0511000056915016
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000221683004
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B606200A80
VCID: 7EA50240707C50E703B-802A
U1101 00 [008] - Active
Reset counter: 79
Mileage: 315630 km
Date: 2017.11.14
Time: 13:33:32
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001111655
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 6B833B14138ED54FB45-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 111021 31 0020
Serial number: 90243400111028231403
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10264691
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000001110110267
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0S3807
Fault Status: 01101100
Reset counter: 43
Mileage: 315650 km
Date: 2018.05.28
Time: 21:36:00
Reset counter: 43
Mileage: 315650 km
Date: 2018.05.28
Time: 21:36:00
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag025 H05 0025
Revision: -------- Serial number: 003L0000JX0X
Coding: 000000000000000000000000000000003235
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 41DFB9BC4102EF1F3E9-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1172706H59
Serial number: 3575LRB40690T3R6A0UV
Serial number: 3585LRB40690T3R69HP0
Serial number: 3515RRB40550OPMK49H%
Serial number: 3525RRB405B0OPMKH9NP
Serial number: 3555NRB40590PIJQEGOO
Serial number: 3565NRB40550PIJQKHEI
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KJP0005S
Coding: 000015
VCID: 3635DA60184C58A79BB-8062
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0124203
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658221011593041
Coding: 8B7733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 47CBA7A46F26D12FF0D-8012
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000291319
Coding: 0001037500
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 3829D45812D8AED7897-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650843827
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000016937431
Coding: 0058130000004001000001010101202020202121202020
VCID: 3431E0680E304AB7A5F-8060
03776 - Motor for Lumbar Support Adjustment
Fault Status: 01100101
Reset counter: 195
Mileage: 288200 km
Date: 2017.05.10
Time: 16:03:52
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000121063960
Coding: 011D07205E00453005080000
VCID: 44D1B0A85E90FA3715F-8010
Revision: 00002001 Serial number: 0161545821
Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 284119591
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO13391685
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO1336156%
Coding: 191100
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000121426575
VCID: 3B23CB54236E85CF645-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11A070021C
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA10848666042F72DF-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: 130000
5275953 - Power Output Module for Left Headlamp
C1081 31 [008] - No Signal
Fault Frequency: 82
Reset counter: 83
Mileage: 315630 km
Date: 2017.11.12
Time: 05:45:07
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 156J20B7565751
Coding: 020007020100000001
VCID: 1F1B1FC497B6F9EF68D-804A
Fault Status: 00101011
Reset counter: 79
Voltage: 11.90 V
Reset counter: 79
Mileage: 315630 km
Date: 2017.11.14
Time: 13:38:40
Voltage: 12.00 V
Part No SW: 7P6 035 664 B HW: 7P6 035 664
Component: H-BN-NA H44 0319
Revision: -------- Serial number: 445J 0B7521662
Coding: 010200050040E1EE41022B0C00000003F0000101
VCID: 372BD7641F46A1AF80D-8062
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9L79004S3
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000121490349
Coding: 011C07200000253005080000
VCID: 3A2DCE502C54BCC77F3-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000050575
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDBBF4437F699EF48D-806A
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001 Serial number: 00000160938100
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H04000 Serial number: 525 PA8J192588
Coding: 0110001
VCID: 372BD7641346A1AF80D-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 294100187
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D27C54C3DFA8BFF5A1-8068
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000121399453
End----------(Elapsed Time: 02:09, VBatt start/end: 14.3V/14.3V)-----------
Friday,29,June,2018,19:32:38:45649
Address 01: Engine
Control Module Part Number: 7P0 907 401 J
Component and/or Version: 3.0TDI EDC17 H17 0005
Software Coding: 292A4012233600050000
Work Shop Code: WSC 02330
Advanced Identification/FAZIT
Identification: BPG-810
Revision: 56H17---
Date: 28.10.11
Manufacturer number: 1329
Test stand number: 0172
Flash Status
Programming Attempts(application): 2/2/2
Successful Attempts(application): 2/2/2
Flash Date: 13.03.11
Misc.
Hardware number: 7P0 907 401 E
Workshop System Name: J623
ASAM Dataset Revision: 001005
Car Info
Chassis Number: WVGEK9BP1CD005604
Engine code: CATA
VCDS Info:
Labels: 059-907-401-V2.clb
Readiness: No script available
