DPF Regeneration failure on 2012 VW Touareg TDI
MMC
New Member
Ireland
UC700574 (2nd hand?)
Last time I seen a P0299 on a vw it was the variable vein unit on the turbo partially seized, check to see if it is free or watch the actuator for movement when you do ur vcds test
   #62
amizan
C?ID=340128
so here's an update for everyone:
the problem with the boost pressure was a cracked intercooler on the driver side. The connector to the intake manifold was cracked and was leaking.
I used a fog machine and pumped smoke into the intake manifold and I noticed where the smoke was coming from. Very good trick for those who don't know it.
Changed the intercooler for $120 from Ebay and all my problems are solved. So to recap I had:
1. DPF replaced - pain in the ass
2. O2 sensor right before DPF replaced
3. Intercooler to intake manifold connector pipe cracked. Replaced intercooler.
Now waiting for the readiness to kick in to go pass smog... I have driven over 200 miles and still nothing.
amizan
C?ID=340128
So a week ago, i went into limp mode.
DPF filter light came on for maybe 10 miles before i was put into limp mode but i was away from home and i kept driving.
Speed will not go over 50 mph. i drove another 30 miles home and stopped.
plugged in VCDS i have same problem again with the DPF...
I initiate emergency regeneration procedure through VCDS - Particle Filter Service Regeneration by following the procedure here:
but it gets aborted due to "safety reasons".
here's my autoscan. Does anyone know why i get aborted? Could it really be due to my parking brake malfunction?
Wednesday,02,March,2022,18:05:21:45649
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVGEK9BP1CD005604   License Plate:
Mileage: 396654km-246469mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGEK9BP1CD005604   Mileage: 396654km-246469miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI EDC17  H17 0005
   Revision: 56H17---    CVN: 0FF473B738D3FF8238D3FF82
   Coding: 292A4012233600050000
   Shop #: WSC 02330 444 92460
   ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
   ROD: EV_ECM30TDI0117P0907401J_001.rod
   VCID: 3635DA6018CC58AB25E-8062
   VINID: 9E65D56C94A00535000051801004E1B29D
5188 - Particle Filter
          P2463 00 [167] - Excessive Soot Accumulation
                    Mileage: 396654 km
                    Date: 2022.03.02
                    Time: 06:02:17
                    Engine RPM: 760.00 /min
                    Normed load value: 25.9 %
                    Coolant temperature: 75 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.420 V
                    P Flt Ld fac Ash Cor: 0.9513
                    Particul.filter diff.pressure: 10 hPa
                    Exh t Adap T Oxi Cat Ds: 140.8 °C
                    Exh t Adap TP Flt Ds: 112.5 °C
                    Exhaust gas jet volume in particle filter: 37.2 m³/h
                    Current operating mode_2-Bits 0-7: 00000000
                    Current operating mode_2-Bits 0-7: 00010000
5189 - Particulate Trap Bank 1
          P2002 00 [039] - Efficiency Below Threshold
                    Mileage: 396654 km
                    Date: 2022.03.02
                    Time: 06:02:17
                    Ambient temperature: 20.1 °C
                    DPF: offset for differential pressure: 4 hPa
                    Particle filter: soot mass measured: 36.84 g
                    Particle filter: soot mass calculated: 39.77 g
                    Particle filter: kilometers since last regeneration: 959762 m
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 00000000
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 1857
   Serial number:                CVN: 15844593
   Coding: 001368
   Shop #: WSC 42005 002 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 3039EC78FAA8769B7F2-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 427310010EC010
   Coding: 5B7613C349242558DAFAC89392D6A4407300
   Shop #: WSC 31414 790 00001
   ROD: EV_ESPMK25A00800.rod
   VCID: 44D1B0A85E10FA3BABA-8010
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Component: BCM2 2.0      H31 0333
   Coding: 09860000000000000000
   VCID: 73B323744BBE0D83C20-8026
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0511000056915016
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000221683004
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B606200A80
   VCID: 7EA50240707C50EBBDE-802A
          U1101 00 [008] - Active
                    Reset counter: 76
                    Mileage: 396265 km
                    Date: 2022.02.20
                    Time: 04:06:34
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 61
                    Mileage: 395356 km
                    Date: 2022.02.07
                    Time: 19:47:45
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001111655
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6B833B14138ED5430A0-803E
   Component: WWS    111021  31  0020
   Serial number: 90243400111028231403
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10264691
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001110110267
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0S3807
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L0000JX0X
   Coding: 000000000000000000000000000000003235
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DFB9BC4102EF1380C-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1172706H59
   Serial number: 3575LRB40690T3R6A0UV
   Serial number: 3585LRB40690T3R69HP0
   Serial number: 3515RRB40550OPMK49H%
   Serial number: 3525RRB405B0OPMKH9NP
   Serial number: 3555NRB40590PIJQEGOO
   Serial number: 3565NRB40550PIJQKHEI
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815KJP0005S
   Coding: 000015
   VCID: 3635DA60184C58AB25E-8062
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0124203
00886 - Turn Signal Switch (E2)
                    Fault Frequency: 72
                    Reset counter: 82
                    Mileage: 394864 km
                    Date: 2022.02.02
                    Time: 23:36:08
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658221011593041
   Coding: 8B7733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47CBA7A46F26D1234E8-8012
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000291319
   Coding: 0001037500
   GVL: FB0F40451D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3829D45812D8AEDB372-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650843827
12290 - Quiescent Current
          U1406 00 [009] - Too High
                    Reset counter: 43
                    Mileage: 396654 km
                    Date: 2022.02.28
                    Time: 03:00:30
                    Voltage terminal 30: 12.3 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 47 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 83
                    Mileage: 396654 km
                    Date: 2022.02.28
                    Time: 04:00:40
                    Control Module temperature: 46 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Revision: AA000000    Serial number: 00000016937431
   Coding: 0058130000004001000001010101202020202121202020
   VCID: 3431E0680E304ABB1BA-8060
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000121063960
   Coding: 011D07205E00453005080000
   VCID: 44D1B0A85E90FA3BABA-8010
   Revision: 00002001    Serial number: 0161545821
   Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 284119591
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO13391685
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1336156%
   Coding: 191100
00985 - Right Tail Light (M2)
                    Fault Status: 11101100
                    Reset counter: 7
                    Mileage: 394425 km
                    Date: 2022.01.27
                    Time: 02:44:49
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000121426575
   VCID: 3B23CB54236E85C3DA0-806E
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A11A070021C
   Coding: 00000000
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
0024 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät EPB - System nicht kalibriert]
                    Voltage: 12.4 V
12652550 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät EPB - Codierungsfehler]
                    Voltage: 12.4 V
0018 - Switch for Electric Parking Brake
          C100C 01 [009] - Electrical Failure
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:39
                    Voltage: 12.6 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Coding: 010A00010F000400
   VCID: 7CA10848666042FB93A-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: 130000
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Component: Radio U SIRIU H53 0133
   Revision: AB001007    Serial number: 156J20B7565751
   Coding: 020007020100000001
   VCID: 24111028BED0DA3B8BA-8070
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H44 0706
   Revision: --------    Serial number: 445J 0B7521662
   Coding: 010200050040E1EE41022B0C00000003F00001010000000000
   VCID: 392FD15C2952B7D3C8C-806C
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9L79004S3
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:42
                    Text: DUA001,Front,M,0,0,6
00658 - Control Head
                    Reset counter: 50
                    Mileage: 394548 km
                    Date: 2022.01.29
                    Time: 22:14:30
                    Voltage: 12.10 V
03175 - Invalid Data Set
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:40
                    Voltage: 12.60 V
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000121490349
   Coding: 011C07200000253005080000
   VCID: 3A2DCE502C54BCCBC16-806E
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000050575
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDBBF4437F699E3F68-806A
8389634 - Radio Frequency Interference
          C105C 00 [008] - -
                    Reset counter: 63
                    Mileage: 395459 km
                    Date: 2022.02.08
                    Time: 23:59:08
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 35
                    Mileage: 396202 km
                    Date: 2022.02.17
                    Time: 06:21:50
                    Vehicle speed: 80 km/h
                    Outside temperature: 19.5 °C
                    Reception level antenna 1: 710 mV
                    Offset level antenna 1: 680 mV
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 42
                    Mileage: 396524 km
                    Date: 2022.02.23
                    Time: 03:12:02
                    Vehicle speed: 46 km/h
                    Outside temperature: 15.5 °C
                    Reception level antenna 1: 740 mV
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000160938100
   Coding: 020D000000000000
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H04000    Serial number: 525 PA8J192588
   Coding: 0110001
   VCID: 372BD7641346A1A33E8-8062
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 294100187
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D27C54C3DFA8BF3E44-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000121399453
End----------(Elapsed Time: 02:07, VBatt start/end: 14.3V/14.3V)-----------
Address 08: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 46: DTCs cleared
amizan
C?ID=340128
What are your calculated and measured soot readings?
I doubt it.
39.77 just like the autoscan says
   #66
amizan
C?ID=340128
replaced with used OEM. unsure of the soot accumulation in it at the time but as soon as it was replaced, car worked fine until now of course.
   #68
amizan
C?ID=340128
any ideas anyone?
   #69
amizan
C?ID=340128
an update here. i think that the DPF clogged up because i had the mechanic replace a temp sensor that was hard to get to a month ago and then (at the time of reassembly) he plugged in the cable to the EGR sensor, he messed up the plug and it was not touching. i fixed it but only after 3 weeks of driving with a check engine light. i think that could have caused the DPF to be clogged up.... any input?
well, i fixed the connection but the DPF remained clogged up.
i have the car on jackstands to remove it and hopefully clean it manually.
   #70
deepseafortydog
TX, USA
C?ID=38538
I’m following this one carefully. My 2011 Treg TDI is dead in the driveway since Monday.
   #71
amizan
C?ID=340128
i removed the DPF today. it was a b**tch getting it out...
have been cleaning it with EZ off and water per the insturctions of Jack @ European Parts .... i should be able to put it back on sometime this week and see what happens
amizan
C?ID=340128
so here is the update on my repairs of the DPF...
i was able to remove the DPF i had to cut one of the rusted nuts with a dremel and had to replace with standard m8-1.25 hex nuts from Amazon (VW does not even list that part and home depot was typically out of stock) and cleaned it per the instructions provided by Jack @ European Parts. EZ Off, wait 15-30 mins and hot water, even soak in hot water, and rinse and repeat a few times until clean water was coming off. surprisingly there was not that much black water that came off overall but in the end none would come off. I am not sure if the EZ off would seep through the honeycomb structure of the DPF but i did the best i could... I reinstalled the DPF and told the car via VCDS that new DPF has been installed.
The error related to the DPF went away. My question is whether i can measure the ACTUAL soot level in the DPF now. I mean, i told the car that a new DPF has been installed but i don't know for sure if the soot level was at zero after the repair. is there a way to tell what the actual soot level is? I tried to do a VCDS test of particulate filter under Basic Settings and again a forced regeneration but they both abort. I am not sure why. i do have still a CEL maybe that's the reason...?
another issue that came up during the repair however is that the DEF injector part number 3C0131113C that is part of the SCR system that plugs in the exhaust right after the DPF and before the Catalytic Converter broke off. the plastic was too old and it just broke off. i had to eventually replace it but i have another code now related to that. i will start a new thread here related to that for input as i have to fix that issue now.
below is my new Autoscan for reference
Wednesday,30,March,2022,19:49:02:45649
Mileage: 397255km-246842mi   Repair Order:
          69 6C 6D 72
VIN: WVGEK9BP1CD005604   Mileage: 397255km-246842miles
9645 - Reductant
          P20E8 00 [101] - Pressure too Low
                    Mileage: 397255 km
                    Date: 2022.03.30
                    Time: 07:16:56
                    Engine RPM: 674.50 /min
                    Normed load value: 27.8 %
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.200 V
                    Pressure sensor for reducing agent: measured pressure: 1 hPa
                    Sensor for reducing agent fill level: fill level: 50.74 %
                    Sensor for reducing agent tank temperature: temperature: 48.9 °C
                    Reducing agent pump: activation: 80.00 %
   Coding: 001368
   Coding: B606200A80
                    Reset counter: 100
                    Mileage: 397245 km
                    Date: 2022.03.30
                    Time: 00:42:28
   Coding: 004DBD
   Coding: 025223
   Coding: 000015
                    Reset counter: 99
                    Mileage: 397138 km
                    Date: 2022.03.29
                    Time: 09:22:59
   Coding: 0001037500
   Coding: 191100
   Coding: 191100
                    Fault Status: 00101100
                    Reset counter: 100
                    Mileage: 396654 km
                    Date: 2022.03.02
                    Time: 06:07:30
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
                    Reset counter: 99
                    Mileage: 397216 km
                    Date: 2022.03.29
                    Time: 22:05:31
   Coding: 00000000
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
0025 - No Calibration
          B2010 F0 [008] - Deviation from Expected Range
          [Steuergerät EPB - Kalibrierung fehlgeschlagen]
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.12
                    Time: 04:19:48
                    Voltage: 14.2 V
          B2010 00 [009] - -
                    Voltage: 14.0 V
          U1014 00 [009] - -
                    Voltage: 14.0 V
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.23
                    Time: 22:48:03
                    Voltage: 12.2 V
   Coding: 130000
   Coding: 130000
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:42
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:40
                    Voltage: 12.60 V
          C105C 00 [008] - -
                    Reset counter: 63
                    Mileage: 395459 km
                    Date: 2022.02.08
                    Time: 23:59:08
                    Reset counter: 47
                    Mileage: 396702 km
                    Date: 2022.03.24
                    Time: 05:50:50
                    Vehicle speed: 92 km/h
                    Outside temperature: 31.5 °C
                    Reception level antenna 1: 680 mV
                    Offset level antenna 1: 660 mV
8397569 - Rear Left TPMS Sensor
          C1052 04 [009] - Internal System Fault
                    Reset counter: 52
                    Mileage: 396850 km
                    Date: 2022.03.27
                    Time: 06:39:37
                    Vehicle speed: 164 km/h
                    Outside temperature: 17 °C
                    Sensor identification number (sensor ID): 2081098832
                    CURRENT pressure: 2.6 bar
                    CURRENT temperature: 30 °C
                    Reset counter: 53
                    Mileage: 396851 km
                    Date: 2022.03.27
                    Time: 09:32:29
                    Vehicle speed: 42 km/h
                    Reception level antenna 1: 750 mV
   Coding: 0110001
   Coding: 0533314003
End----------(Elapsed Time: 02:08, VBatt start/end: 13.6V/14.0V)-----------
The ECU determines that based on readings from the differential pressure sensor. Check that value, both with key on but engine not running, and again with the engine at idle.
amizan
C?ID=340128
Uwe,
Car went into limp mode again.... i measured the readings:
not running:
Particle Filter - difference Pressure: 2hPA
DPF: Offset for differential pressure 1hPA
Particulate Filter bank 1 - Diff pressure: 0.30kPA
At idle:
Particle Filter - difference Pressure: 377hPA
Particulate Filter bank 1 - Diff pressure: 37.60kPA
Now i am also getting all kinds of errors too regarding the Differential Pressure Sensor... Is it possible that the sensor is kaput? or is the filter still clogged?
   #77
Please post a scan showing these faults.
Certainly that's possible. Not running, it should be 0. And 377 hPA is very high.
amizan
C?ID=340128
here's the last autoscan
Tuesday,19,April,2022,10:09:03:45649
Mileage: 398622km-247692mi   Repair Order:
          69 6C 6D 72
VIN: WVGEK9BP1CD005604   Mileage: 398622km-247692miles
7 Faults Found:
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 398590 km
                    Date: 2022.04.15
                    Time: 11:04:03
                    Engine RPM: 1350.50 /min
                    Normed load value: 4.7 %
                    Vehicle speed: 39 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.880 V
                    P Flt Ld fac Ash Cor: 1.0000
                    Particul.filter diff.pressure: 900 hPa
                    Exh t Adap T Oxi Cat Ds: 390.4 °C
                    Exh t Adap TP Flt Ds: 202.4 °C
                    Exhaust gas jet volume in particle filter: 202.3 m³/h
                    Current operating mode_2-Bits 0-7: 00000100
                    Current operating mode_2-Bits 0-7: 00000010
5158 - Diesel Particulate Filter; Differential Pressure Sensor
          P2456 00 [109] - Intermittent
                    Mileage: 398589 km
                    Date: 2022.04.15
                    Time: 10:44:30
                    Engine RPM: 1294.50 /min
                    Normed load value: 99.6 %
                    Coolant temperature: 66 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 13.920 V
                    Sensor for particle filter differential press: raw value: 563 hPa
                    Particle filter: difference pressure: 554 hPa
                    DPF: offset for differential pressure: 1 hPa
                    Particle filter: differential pressure: dynamic offset: 0 hPa
                    Outside temperature: 17.5 °C
                    Particle filter: soot mass measured: 0.00 g
                    Particle filter: soot mass calculated: 0.01 g
4817 - Leak in Air Intake System
          P2279 00 [237] - -
                    Mileage: 398591 km
                    Date: 2022.04.15
                    Time: 11:05:03
                    Engine RPM: 1742.00 /min
                    Normed load value: 96.9 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 14.060 V
                    Charge Pressure Actuator: activation: 99.63 %
                    Charge air pressure actuator: acknowledgment: 99.43 %
                    Ambient temperature: 13.0 °C
                    Charge air pressure: specified value: 1475 hPa
                    Accelerator pedal travel: 30.42 %
                    Air mass: actual value (mg/stroke): 973.9 mg/stroke
                    Actual charge pressure: 983 hPa
5171 - Boost Pressure Regulation
          P0299 00 [101] - Control Range Not Reached
                    Mileage: 398590 km
                    Date: 2022.04.15
                    Time: 11:03:35
                    Engine RPM: 1800.50 /min
                    Normed load value: 46.7 %
                    Vehicle speed: 47 km/h
                    Coolant temperature: 81 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 13.680 V
                    Charge Pressure Actuator: activation: 99.55 %
                    Charge air pressure actuator: acknowledgment: 97.55 %
                    Ambient temperature: 12.8 °C
                    Charge air pressure: specified value: 1665 hPa
                    Accelerator pedal travel: 32.32 %
                    Air mass: actual value (mg/stroke): 1044.1 mg/stroke
8863 - Diesel Particulate Filter
          P2459 00 [101] - Regeneration Frequency
                    Mileage: 398589 km
                    Date: 2022.04.15
                    Time: 10:46:02
                    Engine RPM: 965.50 /min
                    Normed load value: 27.5 %
                    Vehicle speed: 2 km/h
                    Coolant temperature: 71 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 14.120 V
                    Exhaust gas jet volume in particle filter: 73.2 m³/h
                    Particle filter: difference pressure: 499 hPa
                    Particle filter: soot mass measured: 34.00 g
                    Particle filter: soot mass calculated: 34.00 g
                    Exhaust gas temperature sensor 3: 240.0 °C
                    Exhaust gas temperature sensor 4: 124.7 °C
12896 - Boost Pressure Regulation
                    Mileage: 398590 km
                    Date: 2022.04.15
                    Time: 11:03:35
                    Charge Pressure Actuator: activation: 99.73 %
          P2002 00 [047] - Efficiency Below Threshold
                    Mileage: 398590 km
                    Date: 2022.04.15
                    Time: 11:04:03
                    Ambient temperature: 12.7 °C
                    DPF: offset for differential pressure: 2 hPa
                    Particle filter: soot mass measured: 93.54 g
                    Particle filter: soot mass calculated: 34.04 g
                    Particle filter: kilometers since last regeneration: 794 m
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 00000001
Readiness: 1 2 0 0 1
   Coding: 001368
   Component: FBSTOUAREGIDG  0051
   Coding: B606200A80
                    Reset counter: 124
                    Mileage: 397245 km
                    Date: 2022.03.30
                    Time: 00:42:28
   Coding: 004DBD
   Coding: 025223
   Coding: 000015
                    Fault Frequency: 7
                    Reset counter: 123
                    Mileage: 397601 km
                    Date: 2022.04.06
                    Time: 00:00:45
   Coding: 0001037500
                    Fault Status: 01101100
                    Reset counter: 74
                    Mileage: 397798 km
                    Date: 2022.04.08
                    Time: 00:19:07
   Coding: 191100
   Coding: 191100
                    Reset counter: 100
                    Mileage: 396654 km
                    Date: 2022.03.02
                    Time: 06:07:30
                    Reset counter: 99
                    Mileage: 397216 km
                    Date: 2022.03.29
                    Time: 22:05:31
   Coding: 00000000
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.12
                    Time: 04:19:48
                    Voltage: 14.2 V
          B2010 00 [009] - -
                    Voltage: 14.0 V
          U1014 00 [009] - -
                    Voltage: 14.0 V
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.23
                    Time: 22:48:03
                    Voltage: 12.2 V
   Coding: 130000
   Coding: 130000
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:42
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:40
                    Voltage: 12.60 V
          C105C 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 117
                    Mileage: 395459 km
                    Date: 2022.02.08
                    Time: 23:59:08
8389635 - Radio Frequency Interference
          C105C 00 [008] - -
                    Reset counter: 128
                    Mileage: 397416 km
                    Date: 2022.04.01
                    Time: 07:04:36
                    Reset counter: 77
                    Mileage: 397944 km
                    Date: 2022.04.09
                    Time: 10:19:04
                    Vehicle speed: 10 km/h
                    Outside temperature: 20 °C
                    Reception level antenna 1: 720 mV
                    Reset counter: 70
                    Mileage: 397748 km
                    Date: 2022.04.07
                    Time: 06:58:16
                    Vehicle speed: 102 km/h
                    Outside temperature: 35.5 °C
                    Reception level antenna 1: 700 mV
   Coding: 0110001
   Coding: 0533314003
End----------(Elapsed Time: 03:02, VBatt start/end: 13.1V/14.4V)-----------
Wednesday,20,April,2022,11:57:34:45649
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4615.4
          69 6C 6D 72
                    Mileage: 398622 km
                    Date: 2022.04.18
                    Time: 22:09:40
                    Engine RPM: 789.00 /min
                    Normed load value: 22.7 %
                    Coolant temperature: 39 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 13.440 V
                    Particul.filter diff.pressure: 241 hPa
                    Exh t Adap T Oxi Cat Ds: 130.2 °C
                    Exh t Adap TP Flt Ds: 74.0 °C
                    Exhaust gas jet volume in particle filter: 61.3 m³/h
                    Mileage: 398622 km
                    Date: 2022.04.18
                    Time: 22:09:40
                    Ambient temperature: 18.0 °C
                    DPF: offset for differential pressure: 3 hPa
                    Particle filter: soot mass calculated: 60.23 g
                    Particle filter: kilometers since last regeneration: 32676 m
Readiness: 1 1 0 0 1
   Coding: 001368
   Coding: B606200A80
                    Reset counter: 124
                    Mileage: 397245 km
                    Date: 2022.03.30
                    Time: 00:42:28
   Coding: 004DBD
   Coding: 025223
   Coding: 000015
                    Fault Frequency: 7
                    Reset counter: 123
                    Mileage: 397601 km
                    Date: 2022.04.06
                    Time: 00:00:45
   Coding: 0001037500
                    Reset counter: 74
                    Mileage: 397798 km
                    Date: 2022.04.08
                    Time: 00:19:07
   Coding: 191100
   Coding: 191100
                    Reset counter: 100
                    Mileage: 396654 km
                    Date: 2022.03.02
                    Time: 06:07:30
                    Reset counter: 99
                    Mileage: 397216 km
                    Date: 2022.03.29
                    Time: 22:05:31
   Coding: 00000000
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.12
                    Time: 04:19:48
                    Voltage: 14.2 V
          B2010 00 [009] - -
                    Voltage: 14.0 V
          U1014 00 [009] - -
                    Voltage: 14.0 V
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.23
                    Time: 22:48:03
                    Voltage: 12.2 V
   Coding: 130000
   Coding: 130000
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:42
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:40
                    Voltage: 12.60 V
          C105C 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 117
                    Mileage: 395459 km
                    Date: 2022.02.08
                    Time: 23:59:08
          C105C 00 [008] - -
                    Reset counter: 128
                    Mileage: 397416 km
                    Date: 2022.04.01
                    Time: 07:04:36
                    Reset counter: 77
                    Mileage: 397944 km
                    Date: 2022.04.09
                    Time: 10:19:04
                    Reset counter: 70
                    Mileage: 397748 km
                    Date: 2022.04.07
                    Time: 06:58:16
   Coding: 0110001
   Coding: 0533314003
End----------(Elapsed Time: 02:16, VBatt start/end: 13.5V/14.3V)-----------
I only see one fault that's obviously related to the differential pressure sensor, but the boost pressure and intake air leak faults need to be addressed as well. Faults of that nature are very likely to prevent regeneration of the DPF.
amizan
C?ID=340128
The Boost pressure and intake air leak faults were not there before this whole DPF fiasco started. I didn't have issues with the intake system before and if i do now, it's possible that it is a coincidental problem but it seems to me that they were generated when the car went into limp more because of the DPF. I think i will replace the sensor and then if that does not address any issues, try to have the DPF professionally baked in an oven. i found someone to do it for $400.
My best guess is that this started because the guy who replaced my engine temp sensor (previous thread) left the EGR sensor unplugged. I basically drove around without an EGR sensor for a couple of weeks and i read that this can get the DPF got clogged. I fixed the EGR sensor connection but it was too late and the DPF got clogged. then i cleaned it with EZ off etc. but maybe in the meantime the DPS failed. we will find out.. does this reasoning make sense?
