Jetta 97
- Apr 22, 2014
- 810
- 764
- Dallas (McKinney) ,TX ,USA
- C?ID=81680
You do not need to replace it , you can clean it .Hi Marin, you had done an ECU reprogram for me a few months back (thanks!)
So you are saying that it's most likely the DPF? I can get a hold of a used DPF for $400-$500 and from what I see changing it on the Touareg does not require a lot of labor if you have a few swivel wrenches. Going in to get measurements on that damn sensor is a pain because it's so tight and hot in there next to the firewall so I'm considering biting the bullet and changing the DPF because I am afraid that this will fix the whole thing since i'm pretty confident that I did the sensor replacement correctly.
Jack has very good susses with Easy off oven cleaner, Aks Jack which one is good.
After that with VCDS you can tell ECU that DPF is replaced and you should be good to go.
