Yep, and I'm a bit saddened by this because their quad-motor setup with independent control over the torque applied to each wheel is (IMO) the right way to make an EV, particularly one that's intended to have off-road capabilities.Rivian seems to be facing a bumpy road recently
So they're using the car's engine to do what a fossil-fuel power plant would if you plugged it in. I suppose that's not something you'd normally do, but as they said, it has might have its uses. How much AC can that vehicle provide to external loads? Uwe goes here. Looks like 1500 W.bad use of energy
Maybe. At first glance, running a 2.4 liter engine to do that seems terribly inefficient. But remember the duty cycle. 90 minutes to put 16 kWh in the battery, which will then presumably supply 1.5 kW for 10 hours with the engine off, while the little Honda would have to run the entire time. But I don't disagree that such a comparison would be interesting.I want to see the test where they start with a full tank of fuel, let it charge the battery and then re-fill the tank to see how much fuel it consumed to recharge (roughly) 16kWh. My thoughts are that's gotta be far less efficient than charging from the grid and/or just using an efficient 2,200 watt Honda inverter type generator if you were camping or in a power out situation at home.
I think BEVs have a place, a good use case, but there are certainly use-cases where they are far from optimal. I've said it before and I'll say it again: There's no way I'd use a BEV for the the PA<->FL trip that I run regularly. I'm not willing to waste time at charging stops, nor do I wanna deal with the range anxiety issues.we've went all in on pure electric PHEVs work for the masses
Like this?I want Mazda to bring back the rotary purely as a range-extending generator for an EV.
There are two kinds of hybrids -- serial and parallel. IMO, an "EV" with a built-in range extender would also be considered a (serial) hybrid.Sort of. I think that technically qualifies as a hybrid.
It all depends use case. For local use, a BEV is likely great (except they still cost too much). For long distance use, ICE wins. For mixed use, a PHEV is a good compromise, but the downside is the added complexity compared to straight BEV or ICE -- more stuff that can (and will at so point) fail.As a bit of a PHEV evangelist (I had a PHEV in the past, and then an EV but currently only have two manual ICE vehicles), my confirmation bias appreciated this video:
I agree that there is added complexity but given the frequency of failures in recent VAG ICE vehicles (cough, water pumps, cough) I wonder if it all balances out. My A3 e-tron used about 200 gallons lifetime:It all depends use case. For local use, a BEV is likely great (except they still cost too much). For long distance use, ICE wins. For mixed use, a PHEV is a good compromise, but the downside is the added complexity compared to straight BEV or ICE -- more stuff that can (and will at so point) fail.
