Side assist retro install in MK6?
MikeLyons27
United States
C?ID=104983
I was doing some searching on Google, and stumbled upon this:
http://www.aliexpress.com/item/vw-V...-Side-Assist-FOR-Passat-B7-CC/1683757869.html
It is a side assist (Blind spot) indicator that fits in the side mirrors.
I did some more searching and I can not find any info about what is involved in the install of this item.
Does anyone know if it will work in a VW mk6 GTI? Is the mk6 capable in VAG-COM to activate something like this?
The mirrors in mk6 GTI look exactly the same as the ones pictured.
I just found this website, but its all in German (I think) of the install
http://www.bronken.de/sideassist/
any one have any input on this?
--Mike
GaryM
Oxford, UK
C?ID=226919
I don't think any of the Mk6 Golfs had "front assist" or "lane assist" functions did they? (I believe that only arrived on the Mk7 IIRC). If the Mk6 doesn't then I'm fairly certain it won't have the required electronics to support "side assist" capabilities, or even the option of retrofitting it because whatever control module is needed / responsible for that (probably a different BCM) most likely won't be compatible with the rest of the electronics already on the car.
MikeLyons27
United States
C?ID=104983
Gary,
That might be true, but the PLA 2.0 with park assist wasn't available for the MK6 as well, but it can be retro fitted, and it works great from what I see in some videos.
I was just curious if anyone has made an attempt on this. I would love to install this in my car. The Drivers in my area are crazy, and a blind spot indicator would be awesome.
--Mike
That page talks about retrofitting Side Assist in a Passat B6. I'll translate the first blue info box for you:
"If you wish to install Side Assist in your Passat B6, you must first install both a B7 Gateway and a B7 Instrument Cluster".
MikeLyons27
United States
C?ID=104983
Uwe,
Thank you for the translation! I was able to translate the entire site using google translate: http://translate.googleusercontent....ssist/&usg=ALkJrhit8fe7RZTghZROJ1uK9a6v9bfy8w
I don't know if these parts are correct, but they may fit into an mk6?
The gateway I believe fits according to the description http://m.aliexpress.com/item/2037530616.html?tracelog=storedetail2mobilesitedetail
The cluster: http://m.aliexpress.com/promotion/instrument-cluster-needles.html?tracelog=wssearch2mobilesearch
If these are correct (I am not sure they are) it looks like this install would be expensive to retro... $500 for the sensors, $40 for the gateway, and $500 for the cluster...
Just so you don't wait for further feedback from me: I have no knowledge whether those parts are correct or would work.
GaryM
Oxford, UK
C?ID=226919
Well there are certainly a couple of examples of the ''7N0 907 530 AN" CAN Gateway having been fitted to a Mk6 Golf and successfully coded / working so it looks like that is at least compatible. The associated instrument cluster that is needed however is a different ball game as there seem to be a minefield of different part numbers available. I guess you would need a compatible Golf Mk6 cluster unless you know that one from a Passat B7 would physically fit but looking at some pictures though they appear to be different.
Also keep in mind that the immobiliser is in the instrument cluster so if you were to get another cluster, you would also need to deal with coding the immobiliser in the new cluster. I believe the Mk6 Golf has a 5th Generation immobiliser which isn't supported by VCDS.
Eddie-NL
C?ID=41179
Passat Cluster won't fit, Immobilser is built into your cluster and not in Passat Cluster.
Your cluster or a newer version might be ok, but you will have to fit the kit to find out.
Also mirrors are different between Passat and Golf 6
Spacewalker
Poland
C?ID=159607
Side assist will never apear in Golf / Eos, Tiguan/ Touran cluster menu so you will not be able to Enable / Disable that.
Only Passat cluster can handle it.
ALso - brand new parts are not calibrate. Read about calibration 1st
golfi_vend
Tartu, Estonia
C?ID=195131
But Passat cluster doesn't have immobiliser.
Or is there way to activate it in there, or also missing hardware inside cluster for pickup coil?
GaryM
Oxford, UK
C?ID=226919
According to Eddie-NL, a Passat B7 cluster won't fit a Golf Mk6 anyway so the lack of an immobiliser in the Passat cluster is going to be pretty much irrelevant.
And with no functionality in the Golf Mk6 clusters to handle side assist capabilities it looks to me like it's probably game over unfortunately.
golfi_vend
Tartu, Estonia
C?ID=195131
Yes the outside casing is different, but according to another forum the internal PCB is same.
GaryM
Oxford, UK
C?ID=226919
Good point. Not game over then (yet). Just a bit more work involved to swap the Passat cluster electronics into the Golf cluster casing before it could be tried out.
It would be certainly be interesting to see if the Passat B7 cluster internals are compatible with the Golf Mk6.
Eddie-NL
C?ID=41179
it is not only the shape
Immobiliser is not in cluster, so car ecu won't start as it doesn't receive ok to start
Passat has electronic steering lock and has electric handbrake, cluster won't be happy without signal from these
awnissa
United Arab Emirates
C?ID=182384
If you can feed me more about your car i can check for you with elsawin if it possible to fit or not possible ..
MikeLyons27
United States
C?ID=104983
I currently have a 2011 mk6 GTI White
below is the VCDS Scan I did a few months ago.
Monday,01,September,2014,16:36:02:34944
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWGV7AJ6BW123687   License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AP    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0403010A18070160
   VCID: 74C910381733AFBE8FF-8021
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 000 -  - Intermittent
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:29:44
                    Temperature: 98.0°C
                    Temperature: 67.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -  - Intermittent
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:28:41
                    Temperature: 97.0°C
                    Temperature: 69.0°C
                    Voltage: 12.065 V
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: 114B600C492400FD881106EC92200041B70800
   VCID: 78D12408CB5BCBDEA37-802D
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_SE36.rod
   VCID: 75CF2D3CD449B6B6B81-8020
   Part No SW: 1K0 937 086 L    HW: 1K0 937 086 L
   Component: BCM PQ35  M   104 0615
   Revision: 00104 AE
   Coding: 65180A3880272AC400080081700085C442010086534D8D60648020200040
   VCID: 3957E10CB0D112D69C9-806C
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 30091  26  0512
   Coding: 009795
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R014Z11
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3957E10CB8D112D69C9-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0005FCK400
   Serial number: 3572MSME036D2058ZZZU
   Serial number: 3582MSME70284358ZZZV
   Serial number: 3512QSME2C56711EZZZ$
   Serial number: 3522QSME321C6417ZZZS
   Serial number: 35527SME5F234C23ZZZM
   Crash sensor for front airbag; passenger side:
   Serial number: 35627SME4A176723ZZZH
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Revision: --------    Serial number: WHRPIuswHHHTf
   Coding: 188A100000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76CD2A30C94FBDAEB1B-8023
   Serial number: 0120646
   Coding: 820000
0516 - Databus
                    Reset counter: 133
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:24:34
49675 - Control Circuit for Ignition Key Lock Solenoid
          B114A 13 [009] - Open Circuit
                    Reset counter: 133
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:24:34
229211 - Cruise Control Switch
          B1154 13 [008] - Open Circuit
                    Reset counter: 173
                    Mileage: 66565 km
                    Date: 2043.14.23
                    Time: 16:28:39
   Part No SW: 5K6 920 971 C    HW: 5K6 920 971 C
   Component: KOMBI         H20 0420
   Coding: 270F01
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 354FED3C94C9F6B6781-8060
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 091010F1002062
   Coding: E9807F0640061200000002
   VCID: EDFF855CF419FE76C01-80B8
                    Reset counter: 128
                    Mileage: 66449 km
                    Date: 2043.14.21
                    Time: 00:34:52
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAF58E400DF7E94EA53-80BF
   Revision: A1001003    Serial number: 7668751036
   VCID: 2773377456659426FAD-8072
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2M0027834
   Coding: 04010041010006000000000A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 256F3D7C24698636C81-8070
   Component: NAR_V6N  0051
1048659 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 66449 km
                    Date: 2043.14.21
                    Time: 00:35:10
          B11CF 53 [009] - Deactivated
                    Reset counter: 128
                    Mileage: 66449 km
                    Date: 2043.14.21
                    Time: 00:35:05
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2151
   Coding: 0001270
   VCID: 334BD32452BDE886565-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 3147D92CA8A1DA96249-8064
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0001270
   VCID: 3449D03857B3EFBE4FF-8061
   Coding: 0001232
   Shop #: WSC 01357 011 1012551
   VCID: 354FED3C5CC9F6B6781-8060
   Coding: 0001232
   VCID: 364DEA3041CFFDAE71B-8063
golfi_vend
Tartu, Estonia
C?ID=195131
I did put a passat cluster in my golf today for "testing purposes". It didn't have any active codes in cluster itself, but it did show a ABS/ESP warning on dash, i guess it's because passat ABS is 3C0 and golf is 1K0.
Yes the immobilizer, but maybe some way to enable it? I know it's a long shot, but when i did have passat cluster in my car i was able to have the lighning and convience menu, what we don't have with mk6 cluster.
rojas
Spain
C?ID=261996
I've done this a retrofit seat leon, which not has as option the side assist, i have adapted the Audi A3. My main problem is that modules LED lights do not fit into the mirror, I had to adapt on the pillars inside . my other downside is that the cluster LED alarm is not operating, I guess it's because the EEPROM is not designed for my car this option, despite having the LED indicator on the cluster but not activated. I active on and deactive from the FIS.
https://www.youtube.com/watch?v=W10qYSblfR0
Cheers
