DPF Regeneration failure on 2012 VW Touareg TDI
   #81
does this reasoning make sense?
You really need to fix everything else ailing this engine first, otherwise the DPF will just get clogged up again.
amizan
C?ID=340128
So... Uwe you were correct (or maybe the Autoscan was correct). After inspection of the air intake, one of the large hoses to the driver's side intercooler had come undone! I am not sure if it came undone because i drove 5 miles in limp mode and put a strain on the system or because the mechanic that messed up the EGR sensor connection also left this without a clip.... Now the air intake issues are gone and the Differential Pressure Sensor issue is gone as well. The only thing remaining is the DPF clogging.
The Differential Pressure Sensor readings in the Adv. Measuring Values section are similar to before and i also have these two as well on the DPF:
IDE00435 Particle filter: soot mass measured: 34.00 g
IDE00434 Particle filter: soot mass calculated: 60.45 g
The strange thing is that the Autoscan reads this:
Partile filter: soot mass measured: 149.30 g - what is this so different than what appears in the Adv. Measuring Value?
Particle filter: soot mass calculated: 60.35 g
Particul.filter diff.pressure: 160 hPa - The sensor reads 360hPA in the Adv. Measuring Value....?
I also read that the DPF might be near the end of its life if it is actually full of Ash (not soot). do you know what this symbolizes below in the autoscan?
"P Flt Ld fac Ash Cor: 1.0000 "
I feel that the EZ off solution did not work and I am back to square one having to remove and try clean the DPF... I might just take it to have it baked and professionally cleaned.
See below updated Autoscan.
Wednesday,20,April,2022,17:17:00:45649
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4615.4
Data version: Unknown DS336.1
VIN: WVGEK9BP1CD005604   License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGEK9BP1CD005604   Mileage: 398622km-247692miles
Address 01: Engine (J623-CATA)       Labels: None
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI EDC17  H17 0005
   Revision: 56H17---    CVN: 0FF473B738D3FF8238D3FF82
   Coding: 292A4012233600050000
   Shop #: WSC 02330 444 92460
   ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
   ROD: EV_ECM30TDI0117P0907401J_001.rod
   VCID: 3635DA6018CC58AB25E-8062
   VINID: 9E65D56C94A00535000051801004E1B29D
5188 - Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 398622 km
                    Date: 2022.04.20
                    Time: 04:48:26
                    Engine RPM: 979.50 /min
                    Normed load value: 30.2 %
                    Coolant temperature: 27 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.520 V
                    Exh t Adap T Oxi Cat Ds: 49.8 °C
                    Exh t Adap TP Flt Ds: 25.4 °C
                    Exhaust gas jet volume in particle filter: 42.5 m³/h
                    Current operating mode_2-Bits 0-7: 00000000
                    Current operating mode_2-Bits 0-7: 00010000
                    Current operating mode_2-Bits 0-7: 00001110
5189 - Particulate Trap Bank 1
          P2002 00 [047] - Efficiency Below Threshold
                    Mileage: 398622 km
                    Date: 2022.04.20
                    Time: 04:48:26
                    Ambient temperature: 16.5 °C
                    DPF: offset for differential pressure: 4 hPa
                    Particle filter: soot mass measured: 149.30 g
                    Particle filter: kilometers since last regeneration: 32676 m
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 00000000
Readiness: 1 1 0 0 1
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 1857
   Serial number:                CVN: 15844593
   Coding: 001368
   Shop #: WSC 42005 002 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 3039EC78FAA8769B7F2-8064
Address 03: ABS Brakes (J104)       Labels:* None
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 427310010EC010
   Coding: 5B7613C349242558DAFAC89392D6A4407300
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 44D1B0A85E10FA3BABA-8010
Address 05: Acc/Start Auth. (J393)       Labels: None
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Coding: 09860000000000000000
   VCID: 73B323744BBE0D83C20-8026
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0511000056915016
   Serial number: 2311000221683004
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B606200A80
   VCID: 7EA50240707C50EBBDE-802A
15360256 - Component Protection
          U1101 00 [008] - Active
                    Reset counter: 124
                    Mileage: 397245 km
                    Date: 2022.03.30
                    Time: 00:42:28
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001111655
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6B833B14138ED5430A0-803E
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119
   Component: WWS    111021  31  0020
   Serial number: 90243400111028231403
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D
   Component: RLFS  H09 0011
   Serial number: 10264691
   Coding: 025223
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001110110267
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0S3807
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L0000JX0X
   Coding: 000000000000000000000000000000003235
   VCID: 41DFB9BC4102EF1380C-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1172706H59
   Serial number: 3575LRB40690T3R6A0UV
   Serial number: 3585LRB40690T3R69HP0
   Serial number: 3515RRB40550OPMK49H%
   Serial number: 3525RRB405B0OPMKH9NP
   Serial number: 3555NRB40590PIJQEGOO
   Serial number: 3565NRB40550PIJQKHEI
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815KJP0005S
   Coding: 000015
   VCID: 3635DA60184C58AB25E-8062
   Serial number: 0124203
00886 - Turn Signal Switch (E2)
                    Fault Frequency: 7
                    Reset counter: 123
                    Mileage: 397601 km
                    Date: 2022.04.06
                    Time: 00:00:45
Address 17: Instruments (J285)       Labels:* None-SRI1
   Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658221011593041
   Coding: 8B7733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47CBA7A46F26D1234E8-8012
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000291319
   Coding: 0001037500
   GVL: FB0F40451D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3829D45812D8AEDB372-806C
   Serial number: 00000000005650843827
   Revision: AA000000    Serial number: 00000016937431
   Coding: 0058130000004001000001010101202020202121202020
   VCID: 3431E0680E304ABB1BA-8060
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000121063960
   Coding: 011D07205E00453005080000
   VCID: 44D1B0A85E90FA3BABA-8010
                    Reset counter: 74
                    Mileage: 397798 km
                    Date: 2022.04.08
                    Time: 00:19:07
Address 46: Central Conv. (J393)       Labels: None
   Revision: 00002001    Serial number: 0161545821
   Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 284119591
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO13391685
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1336156%
   Coding: 191100
00985 - Right Tail Light (M2)
                    Fault Status: 00101100
                    Reset counter: 100
                    Mileage: 396654 km
                    Date: 2022.03.02
                    Time: 06:07:30
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
                    Reset counter: 99
                    Mileage: 397216 km
                    Date: 2022.03.29
                    Time: 22:05:31
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000121426575
   VCID: 3B23CB54236E85C3DA0-806E
Address 53: Parking Brake (J540-)       Labels:* None
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A11A070021C
   Coding: 00000000
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
0025 - No Calibration
          B2010 F0 [008] - Deviation from Expected Range
          [Steuergerät EPB - Kalibrierung fehlgeschlagen]
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.12
                    Time: 04:19:48
                    Voltage: 14.2 V
0024 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät EPB - System nicht kalibriert]
                    Voltage: 14.0 V
12652550 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät EPB - Codierungsfehler]
                    Voltage: 14.0 V
0018 - Switch for Electric Parking Brake
          C100C 01 [009] - Electrical Failure
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.23
                    Time: 22:48:03
                    Voltage: 12.2 V
Address 55: Headlight Range (J745)       Labels: None
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   VCID: 7CA10848666042FB93A-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo rechts  H01 0006
   Coding: 130000
Address 56: Radio (R)       Labels: None
   Component: Radio U SIRIU H53 0133
   Revision: AB001007    Serial number: 156J20B7565751
   Coding: 020007020100000001
   VCID: 24111028BED0DA3B8BA-8070
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H44 0706
   Revision: --------    Serial number: 445J 0B7521662
   Coding: 010200050040E1EE41022B0C00000003F00001010000000000
   VCID: 392FD15C2952B7D3C8C-806C
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9L79004S3
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:42
                    Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:40
                    Voltage: 12.60 V
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000121490349
   Coding: 011C07200000253005080000
   VCID: 3A2DCE502C54BCCBC16-806E
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000050575
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDBBF4437F699E3F68-806A
8389634 - Radio Frequency Interference
          C105C 00 [008] - -
                    Reset counter: 117
                    Mileage: 395459 km
                    Date: 2022.02.08
                    Time: 23:59:08
8389635 - Radio Frequency Interference
          C105C 00 [008] - -
                    Reset counter: 128
                    Mileage: 397416 km
                    Date: 2022.04.01
                    Time: 07:04:36
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 77
                    Mileage: 397944 km
                    Date: 2022.04.09
                    Time: 10:19:04
                    Vehicle speed: 10 km/h
                    Outside temperature: 20 °C
                    Reception level antenna 1: 720 mV
                    Offset level antenna 1: 680 mV
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 70
                    Mileage: 397748 km
                    Date: 2022.04.07
                    Time: 06:58:16
                    Vehicle speed: 102 km/h
                    Outside temperature: 35.5 °C
                    Reception level antenna 1: 700 mV
                    Offset level antenna 1: 660 mV
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000160938100
   Coding: 020D000000000000
Address 6C: Back-up Cam.        Labels: None
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H04000    Serial number: 525 PA8J192588
   Coding: 0110001
   VCID: 372BD7641346A1A33E8-8062
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 294100187
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D27C54C3DFA8BF3E44-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000121399453
End----------(Elapsed Time: 02:12, VBatt start/end: 13.5V/14.1V)-----------
Ash can't really be measured; it's calculated. I would guess that's some kind of correction factor that affects the calculation.
Please have a look at:
IDE00433 -- Particle filter: oil ash volume
I'm not gonna go back and re-read the whole thread. Is this the original DPF on the vehicle? Because if it is, at almost 250,000 miles, it has exceeded its design life by a factor of two. A professional cleaning might indeed be worth trying. While it's out, make sure that that the plumbing between the exhaust and the differential pressure sensor is up to snuff, in other words, check for leaks and obstructions. With a new (or freshly cleaned) DPF, I would also consider installing a new differential pressure sensor.
JMR
Romania
C?ID=432218
at least it worked for that long ! :thumbs:
  • Agree
Yep. If it's the original one, it doesn't owe anyone anything. :)
amizan
C?ID=340128
Here's the udpate:
Uwe - in answer to your question, this was a replacement DPF that i had bought used from junk yard. i don't really recall the mileage of the car that it came out of but i believe it was in the 60-80K plus i put about 40K miles since i put it on, so that would put it at 100-120K.
Removed the DPF again and took it for some professional baking at Clean Diesel Specialists in Santa Ana, CA. For those that are local, they charged me $250 and told me that the DPF lost about 60gr of weight after the cleaning. I visually checked the hoses from the DPF to the Differential Pressure Sensor and found no cracks. I also replaced the DEF injector i had bought on Ebay with a used OEM one. I suspect that the one i had bought was a counterfeit OEM part after looking and comparing the two...
I went the extra mile and replaced the Differential Pressure Sensor as well with an OEM part from the dealership (although post-mortem i think my part was working fine). Installed the DPF after the cleaning and got same errors and same Adv. Measuring values.
Went to Basis Settings and did: Relearn values of particle filter.
Errors went away but i have not driven it anywhere yet (just down the block).
I now get the following:
Ignition on - engine not running - Difference Pressure: 0-1 hPa
Engine running: Pressure 6-7 hPa
Particulate filter bank 1 - differential pressure 0.60kPA
Soot mass caclualated: 0.13 gr
So now fingers crossed until i take it for some real driving...
Below is the full autoscan.
Monday,25,April,2022,18:24:51:45649
          69 6C 6D 72
   Coding: 001368
   Coding: B606200A80
                    Reset counter: 124
                    Mileage: 397245 km
                    Date: 2022.03.30
                    Time: 00:42:28
   Coding: 004DBD
   Coding: 025223
   Coding: 000015
                    Fault Frequency: 7
                    Reset counter: 123
                    Mileage: 397601 km
                    Date: 2022.04.06
                    Time: 00:00:45
   Coding: 0001037500
                    Reset counter: 74
                    Mileage: 397798 km
                    Date: 2022.04.08
                    Time: 00:19:07
   Coding: 191100
   Coding: 191100
                    Reset counter: 100
                    Mileage: 396654 km
                    Date: 2022.03.02
                    Time: 06:07:30
                    Reset counter: 99
                    Mileage: 397216 km
                    Date: 2022.03.29
                    Time: 22:05:31
   Coding: 00000000
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.12
                    Time: 04:19:48
                    Voltage: 14.2 V
          B2010 00 [009] - -
                    Voltage: 14.0 V
          U1014 00 [009] - -
                    Voltage: 14.0 V
                    Reset counter: 45
                    Mileage: 396654 km
                    Date: 2022.03.23
                    Time: 22:48:03
                    Voltage: 12.2 V
   Coding: 130000
   Coding: 130000
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:42
                    Reset counter: 7
                    Mileage: 394316 km
                    Date: 2022.01.25
                    Time: 19:42:40
                    Voltage: 12.60 V
          C105C 00 [008] - -
                    Reset counter: 117
                    Mileage: 395459 km
                    Date: 2022.02.08
                    Time: 23:59:08
          C105C 00 [008] - -
                    Reset counter: 128
                    Mileage: 397416 km
                    Date: 2022.04.01
                    Time: 07:04:36
                    Reset counter: 77
                    Mileage: 397944 km
                    Date: 2022.04.09
                    Time: 10:19:04
                    Reset counter: 70
                    Mileage: 397748 km
                    Date: 2022.04.07
                    Time: 06:58:16
   Coding: 0110001
   Coding: 0533314003
End----------(Elapsed Time: 02:15, VBatt start/end: 13.9V/14.1V)-----------
   #87
Did you also re-learn the differential pressure sensor?
Those seem pretty reasonable.
  • Agree
Reactions: JMR
   #88
amizan
C?ID=340128
no i didn't know that needed re-learning as well. i will make sure to do that before i go anywhere
   #89
amizan
C?ID=340128
So, the issue with the DPF has been fully addressed and i was able to do a full cycle service regeneration just to check it out. Car drives normally. Drove it for 300 miles but now has another issue. I will post a separate thread since this issue has been solved.
