Sunday,18,February,2018,20:10:25:43454
VCDS Version: 18.2.0.3
VIN: WV2ZZZ2KZHX088161 License Plate:
Mileage: 1920km-1193mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 52 5F 61
VIN: WV2ZZZ2KZHX088161 Mileage: 1920km-1193miles
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (J623-DFSD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 HA HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1804
Revision: 8AH20---
Coding: 011D001204250D090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016HA 001003
ROD: EV_ECM20TDI01104L906016HA_001_VN35.rod
VCID: 6FC32B30B634B23CF1-803A
17158 - Databus
Mileage: 21 km
Date: 2017.12.29
Time: 11:44:29
Coolant temperature: 13 °C
Intake air temperature: 13 °C
Voltage terminal 30: 12.000 V
Unlearning counter according OBD: 31
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 32
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
17262 - Terminal 30
U140A 00 [040] - Open Circuit
Time: 00:00:00
Vehicle speed: 255 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Voltage terminal 30: 9.700 V
Unlearning counter according OBD: 13
Limitation: torque: 1000.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
Accelerator pedal travel: raw value: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
Readiness: 0 1 0 0 0
Part No SW: 02E 300 064 L HW: 02E 927 770 AT
Component: GSG DSG AG6 541 4919
Revision: 06454104 Serial number: 00001611200441
Shop #: WSC 35110 377 08192
VCID: 2061180CF36A5D4438-8074
Address 03: ABS Brakes (J104) Labels:. 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 43516000000814
Coding: 1079409B926AA4860876027C498325D379F100
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FA3BB70A6D402BC21-806A
0297 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Reset counter: 59
Mileage: 21 km
Date: 2017.12.29
Time: 11:44:02
Part No SW: 1K8 907 426 AR HW: 1K8 907 426 AR
Component: AC Manuell H21 0909
Revision: 00001002
Coding: 0010004083
VCID: 032B77808ABCA65C05-8056
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0184
Revision: BD122001
Coding: 491A0A3E8025E16B088800829400016403D10008426F8320648087000041
VCID: 73CB2740D21C96DC15-8026
Subsystem 1 - Part No: 2K2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 01121 26 0512
Coding: 009795
Subsystem 2 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 051216 04 42 0106
Coding: 0228DD
Subsystem 3 - Part No: 7N0 951 172
Component: Sensor, DWA 0 005 0502
Subsystem 4 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
03789 - Terminal 75 Limp Mode Active
Reset counter: 41
Mileage: 20 km
Date: 2017.12.11
Time: 21:19:06
Term 15 Off
Voltage: 11.05 V
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 A HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0480
Revision: -------- Serial number: 39261633500978
Coding: 0001150011
ASAM Dataset: EV_EPHVA14VW364GP00 001007
ROD: EV_EPHVA14VW364GP00_VW36.rod
VCID: 3753D3508EE43AFCE9-8062
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 17121604380615
Coding: 00001000FE0339
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 364DDE5489EEC3F4F2-8062
Part No SW: 2K5 959 655 C HW: 2K5 959 655 C
Component: VW10Airbag00K H08 0018
Revision: -------- Serial number: 003V2001R0R5
Coding: 00000000000000000000000000000000304B
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
VCID: 3C59CC7CB7C219A404-8068
Serial number: 3497ARB405N47TV0JI51
Serial number: 3507ARB405N47TV0LA0P
Serial number: 3517ARB400E57H92NJVN
Serial number: 3527ARB405P48QM26OCV
Part No SW: 1K5 953 521 CM HW: 5K0 953 569 BC
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20150928201238
Coding: 1882460008
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7AD50A64FD76E79456-802E
Subsystem 1 - Part No SW: 2K0 959 442 HW: 2K0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 2801513370301204BA1B
Coding: 280000
Part No SW: 2K5 920 976 E HW: 2K5 920 976 E
Component: KOMBI H03 1104
Coding: 410A011200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
VCID: 3851D06C83FA3584E0-806C
13654544 - Databus
Reset counter: 28
Mileage: 1921 km
Date: 2018.02.18
Time: 19:14:26
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 301116F1001181
Coding: 357423
VCID: 7BDB0F60FA4CDE9C4D-802E
03158 - Control Module for Information Electronics 1 (J794)
Reset counter: 28
Mileage: 1921 km
Date: 2018.02.18
Time: 19:15:06
Component: IMMO H03 1104
VCID: 6AF53A248DD65714A6-803E
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0131632
VCID: 71C72D486800A4CCE7-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 3957D56870F02C8C1F-806C
Address 4C: Tire Pressure II
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0131632
VCID: 72C522446D069FD41E-8026
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: 030F7873
VCID: 71C72D48A800A4CCE7-8024
Subsystem 1 - Part No SW: 2K0 915 181 HW: 2K0 915 181
Component: J367-BDMConti H03 1050
Serial number: 75410603001612101560
End-------------------------(Elapsed Time: 03:35)--------------------------
