VW Caddy Life 2017: RCD330 Head Unit & Genuine VW Reverse Camera - No image on Screen
dhd
My factory fitted VW Composite Colour head unit wouldn't accept the genuine VW Rear View Lowline Camera that I fitted to the car, apparently only some versions of this head unit work with the camera and mine isn't one of them.
So, I bought an RCD330 Noname 187B version from China, recycled out of a new VW car. I wired the unit via a MIB-MQB quadlock adapter and fitted the blue plug with composite +/- camera input cables at ports 6 & 12 directly into the head unit in the quadlock. The head unit is coded for a RVC in the radio module. Unfortunately, I don't get an image on the screen when selecting reverse, only a message saying: The "Rear View" camera system is currently not available. The car has factory fitted OPS and the Park Pilot screen appears ok. I used VCDS to try changing the 'Visual Display for Park Assit' from 'OPS display' to 'Rearview camera' in Park Assist, UDS Adaptation, but had the message 'Request out of range'
I'm also getting fault codes in the Radio & CAN BUS modules which I didn't get with the original radio:
a) CAN BUS - 1 Fault Code 03158: Control Module for Information Electronics 1 (J794) 004: No signal/communication
b) RADIO - 1 Fault Code 02873: Control Module for Back-up Camera (J772) 004: No signal/communication
Is there a way to pair these two please?
dhd
Sunday,18,February,2018,20:10:25:43454
VCDS Version: 18.2.0.3
VIN: WV2ZZZ2KZHX088161   License Plate:
Mileage: 1920km-1193mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 52 5F 61
VIN: WV2ZZZ2KZHX088161   Mileage: 1920km-1193miles
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 HA    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1804
   Revision: 8AH20---
   Coding: 011D001204250D090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI01104L906016HA 001003
   ROD: EV_ECM20TDI01104L906016HA_001_VN35.rod
   VCID: 6FC32B30B634B23CF1-803A
17158 - Databus
                    Mileage: 21 km
                    Date: 2017.12.29
                    Time: 11:44:29
                    Engine speed: 0.00 /min
                    Coolant temperature: 13 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.000 V
                    Unlearning counter according OBD: 31
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
17262 - Terminal 30
          U140A 00 [040] - Open Circuit
                    Vehicle speed: 255 km/h
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Voltage terminal 30: 9.700 V
                    Unlearning counter according OBD: 13
                    Limitation: torque: 1000.0 Nm
                    Accelerator pedal travel: raw value: 0.00 %
                    Engine torque: -500.0 Nm
                    Generator: load signal: 0.00 %
Readiness: 0 1 0 0 0
   Part No SW: 02E 300 064 L    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 4919
   Revision: 06454104    Serial number: 00001611200441
   Shop #: WSC 35110 377 08192
   VCID: 2061180CF36A5D4438-8074
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Revision: 00000000    Serial number: 43516000000814
   Coding: 1079409B926AA4860876027C498325D379F100
   VCID: 3FA3BB70A6D402BC21-806A
0297 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 59
                    Mileage: 21 km
                    Date: 2017.12.29
                    Time: 11:44:02
   Part No SW: 1K8 907 426 AR    HW: 1K8 907 426 AR
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004083
   VCID: 032B77808ABCA65C05-8056
   Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
   Component: BCM PQ35 M+   122 0184
   Revision: BD122001
   Coding: 491A0A3E8025E16B088800829400016403D10008426F8320648087000041
   VCID: 73CB2740D21C96DC15-8026
   Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 01121  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 051216 04  42  0106
   Coding: 0228DD
03789 - Terminal 75 Limp Mode Active
            000 -  -  - Intermittent
                    Reset counter: 41
                    Mileage: 20 km
                    Date: 2017.12.11
                    Time: 21:19:06
                        Term 15 Off
                    Voltage: 11.05 V
   Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0480
   Revision: --------    Serial number: 39261633500978
   Coding: 0001150011
   ASAM Dataset: EV_EPHVA14VW364GP00 001007
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 3753D3508EE43AFCE9-8062
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 17121604380615
   Coding: 00001000FE0339
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 364DDE5489EEC3F4F2-8062
   Part No SW: 2K5 959 655 C    HW: 2K5 959 655 C
   Component: VW10Airbag00K H08 0018
   Revision: --------    Serial number: 003V2001R0R5
   Coding: 00000000000000000000000000000000304B
   VCID: 3C59CC7CB7C219A404-8068
   Serial number: 3497ARB405N47TV0JI51
   Serial number: 3507ARB405N47TV0LA0P
   Serial number: 3517ARB400E57H92NJVN
   Serial number: 3527ARB405P48QM26OCV
   Part No SW: 1K5 953 521 CM    HW: 5K0 953 569 BC
   Revision: FF010042    Serial number: 20150928201238
   Coding: 1882460008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7AD50A64FD76E79456-802E
   Subsystem 1 - Part No SW: 2K0 959 442     HW: 2K0 959 442   Labels: 3C8-959-537.CLB
   Serial number: 2801513370301204BA1B
   Coding: 280000
   Part No SW: 2K5 920 976 E    HW: 2K5 920 976 E
   Coding: 410A011200
   VCID: 3851D06C83FA3584E0-806C
13654544 - Databus
                    Reset counter: 28
                    Mileage: 1921 km
                    Date: 2018.02.18
                    Time: 19:14:26
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 301116F1001181
   Coding: 357423
   VCID: 7BDB0F60FA4CDE9C4D-802E
03158 - Control Module for Information Electronics 1 (J794)
                    Reset counter: 28
                    Mileage: 1921 km
                    Date: 2018.02.18
                    Time: 19:15:06
   Component: IMMO          H03 1104
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AF53A248DD65714A6-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71C72D486800A4CCE7-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 3957D56870F02C8C1F-806C
Address 4C: Tire Pressure II
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72C522446D069FD41E-8026
   Component: Batt.regelung H56 1682
   Coding: 030F7873
   VCID: 71C72D48A800A4CCE7-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75410603001612101560
End-------------------------(Elapsed Time: 03:35)--------------------------
dhd
Is this scan any help?
downtime
Finland
C?ID=280813
First fix the can error with infotainment. Probably the wires are not properly seated to the adapter or something like that.
I thought the RCD330G did not need any adapters in older platforms as it was designed for PQxx platform cars anyway. It's not MQB.
golfi_vend
Tartu, Estonia
C?ID=195131
Caddy 2017 is pq35/mqb crossover.
Its headunit needs new paramaters as Caddy parameters don't support RVC. Cc for example.
Ask me how i know :D
downtime
Finland
C?ID=280813
Ahaaa.. Yes, I overlooked the model year, sorry :)
But the headunit is not the original he had, he got it from China.
So you mean that the original head unit would work just fine after parameterization? If that's the case I would go with golf_vendis suggestion and find someone who could re-parameterize the unit and throw the China RCD330G and adapter as far as the eye can see :)
Reactions: dhd
dhd
Thanks for the responses.
I'm quite happy to offload the RCD330, as it doesn't really live up to my expectations.
Are you saying I could get RVC functionality on the original Composition Colour head unit by 're-parameterisation'? (Can confidently say I've never used that term before!) How do I go about this please?
downtime
Finland
C?ID=280813
I've not done it but if golf_vendi writes it's possible, then it is.
Just Google mqb module upload data and you'll find the info you need.
golfi_vend
Tartu, Estonia
C?ID=195131
I'm not quite sure about Composition Color, but I've had success with parametering the Discover Media. In this particular case I also didn't have RVC image whatsoever. After loading CC parameters to it, it displayed image of RVC.
I'm not quite sure what is the difference between different model parameters(Tiguan/Sharan/CC/Caddy), so I'm not confident saying which parameters should be used.
dhd
Would VW Polo parameters work?
dhd
Can anyone help with this please?
Yes I would, if I could, I surely would
downtime
Finland
C?ID=280813
Unfortunately there's not much we can do. VCDS is not able to change the parameters, you need to get other tools or someone with those tools who can help you. Authorized workshops are no go either.
I would be more than happy to try out the parameterization for you but unfortunately it's a bit of a stretch to Finland from UK :)
dhd
Thanks downtime - appreciate your help on this.
So I can take this forward, are you please able to advise what tools are needed and what needs changing in the parameters?
Take this conversation to PM or e-mail please. :)
