Codeblock V0.4215 is now on the release channel. It is designed to be used with a new version of the USB utility and has a number of new features, including but not limited to:
V0.4215
* Support for new update version 2.0+ update utility
* Fixes for certain CAN modules, particularly for service 22 ID
* TP1.6 tries to fall back to kline if it doesn't receive the sync byte
* Fixes for text measuring values (display and logging)
* Retry on no response to service 22 ID
* Fix for downloading data
* Fix for TP2.0 comms with certain
New USB utility is found here:
New 2.xxx utilities for V0.42xx+
Windows/Linux:
HexNetConfigV2.005.jar
Mac:
HexNetConfigV2.005
There are also several other updates that go along with this, including a new dataset with improvements to VIN management and a new with some optimizations
Check the changelog for more details
Important Note: The first time you install v0.42xx, (from v0.41xx) you must do so using the web interface (-Mobile: [Options] -> [Check for Updates]. You cannot update from 0.41xx to 0.42xx using the PC-based utility. Once you've got a v0.42xx in your HEX-NET, the old utility v1.9xx is deprecated and can no longer be used. You should then replace it with the current v2.xxx utility, and you should be able to use the new utility for all updates after that. Of course, you should also be able to do updates via the web interface if you choose.
