Hello so I just purchased this used 2004 Audi A8 with 135,000 miles on it and noticed some things off with it so instead of taking it to the dealership I opted to purchase the VagCom from Ross Tech I scanned my vehicle and now need a little help figuring out exactly what all the data is so I can start repairs from cheapest to most expensive PLEASE HELP.
sheed44 is online now Report Post
Tuesday,24,January,2017,10:30:48:42098
VCDS Version: 17.1.2.0 (x64) HEX-V2 CB: 0.4334.4
Data version: 20170107 DS267.0
VIN: WAUML44E04N018154 License Plate:
Mileage: 226430km-140697mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E04N018154 Mileage: 226430km-140697miles
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0020
Revision: -------- Serial number: AUX3Z0D0532489
Coding: 0007773
Shop #: WSC 24103 444 84355
VCID: 2E06043A5C1D02578FF-807A
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Fault Status: 01101000
Mileage: 226432 km
RPM: 690 /min
Load: 19.6 %
Temperature: 63.0°C
Temperature: 15.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.970 V
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Mileage: 226432 km
RPM: 663 /min
Load: 19.6 %
Temperature: 63.0°C
Temperature: 15.0°C
Voltage: 14.097 V
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Mileage: 226432 km
RPM: 582 /min
Load: 27.4 %
Temperature: 84.0°C
Temperature: 34.0°C
Voltage: 14.097 V
Readiness: 0010 1100
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0028405
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2412E61202D1B80769B-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 24103 000 00000
VCID: 221EE00A18C5B6371B7-8076
01200 - ABS Valves Supply Voltage
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0532489
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58EA82E20E192CE7353-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
VCID: 2310E50E07DFBF3F101-8076
Address 07: Control Head
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000034086
Coding: 1085761
VCID: 5AEE98EA70153EF7037-800E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO16012004065A000000000424ÿ†89
Subsystem 5 - Serial number: 000424ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO16012004065A00000000
Subsystem 7 - Serial number: 65A000000000467ÿ
Fault Frequency: 16
Reset counter: 232
Mileage: 223215 km
Date: 2003.10.10
Time: 16:26:34
01232 - A/C Compressor Regulator Valve (N280)
Fault Status: 00101010
Reset counter: 219
Mileage: 224444 km
Date: 2003.10.08
Time: 08:31:31
Load: 90.0 %
Current: 0.000 A
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A0E082A60F56E77537-807E
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H40 0380
Coding: 00000036
Shop #: WSC 02313
01498 - Bulb for Parking Lamps; Right (M3)
Fault Status: 01101010
Reset counter: 193
Mileage: 226432 km
Date: 2003.10.08
Time: 00:01:53
00908 - Control Module for Wiper Motor
Reset counter: 232
Mileage: 226310 km
Date: 2003.10.08
Time: 15:47:41
01494 - Bulb for Parking Lamps; Left (M1)
Reset counter: 193
Mileage: 226432 km
Date: 2003.10.08
Time: 00:01:54
02071 - Local Databus
Reset counter: 232
Reset counter: 193
Mileage: 226432 km
Date: 2003.10.08
Time: 00:01:57
Address 0E: Media Player 1
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: 6594BB16496B810FBE5-8030
Component: Lenkradmodul H04 0080
Fault Status: 01100010
Fault Frequency: 14
Mileage: 223170 km
Date: 2003.10.09
Time: 22:03:47
Reset counter: 233
Fault Status: 00101110
Reset counter: 233
Date: 2063.15.31
Time: 31:63:18
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D0006575
Coding: 0016203
VCID: 5CE29EF27A21C0C711B-8008
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503C08128A
Coding: FCFE7BDD1B2304
VCID: 2616FC1A74ED4A1777F-8072
00384 - Optical Databus
Reset counter: 193
Mileage: 226432 km
Date: 2003.10.08
Time: 00:30:10
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2514FB1609EB410F7E5-8070
8 Faults Found:
Fault Frequency: 109
Reset counter: 233
Mileage: 222857 km
Date: 2003.10.09
Time: 05:46:40
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
Fault Status: 11101010
Fault Frequency: 106
Reset counter: 193
Mileage: 222857 km
Date: 2003.10.09
Time: 05:46:48
01772 - Signal from Level Control Pressure Sensor (G291)
Fault Frequency: 81
Reset counter: 168
Mileage: 222858 km
Date: 2003.10.09
Time: 05:49:09
01400 - Suspension Level Control
Reset counter: 222
Mileage: 224136 km
Date: 2003.10.14
Time: 19:28:06
01598 - Drive Battery Voltage
Reset counter: 0
Mileage: 226310 km
Date: 2003.10.08
Time: 15:48:19
Reset counter: 220
Mileage: 223170 km
Date: 2003.10.09
Time: 21:56:01
01398 - Signal Conductor for Central Locking; Doors Open
Reset counter: 232
Mileage: 223175 km
Date: 2003.10.10
Time: 15:18:29
01487 - System Function Test
Reset counter: 209
Component: Sitzmemory FS H07 0060
Coding: 4071522
Reset counter: 232
Mileage: 224580 km
Date: 2012.11.17
Time: 08:36:01
Address 37: Navigation
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000334300180
Coding: 0003989
VCID: 1D64D3F621BB89CF265-8048
Reset counter: 221
Mileage: 224296 km
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Reset counter: 217
Mileage: 224232 km
Date: 2003.10.15
Time: 18:37:00
00410 - Pre-Selection Signal for Opening Sunroof
Fault Status: 00100111
Fault Frequency: 15
Reset counter: 224
Mileage: 225436 km
Date: 2003.10.08
Time: 00:41:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: 5EE694FA6C3DD2D77FF-800A
Reset counter: 221
Mileage: 224576 km
Date: 2003.10.08
Time: 08:36:08
02111 - Motor for Window Regulator
Reset counter: 221
Mileage: 224576 km
Date: 2003.10.08
Time: 08:36:28
Reset counter: 221
Mileage: 224576 km
Date: 2003.10.08
Time: 08:36:28
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040312180022
Coding: 0065150
VCID: 2708F11E73E7531F4C9-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 193
Mileage: 213427 km
Date: 2003.10.09
Time: 20:24:59
Fault Status: 01101100
Reset counter: 102
Mileage: 219722 km
Date: 2016.01.03
Time: 16:39:11
01829 - Bulb for Tail-Lamp; Right
Fault Status: 00101001
Reset counter: 197
Mileage: 223044 km
Date: 2003.10.10
Time: 05:43:04
Reset counter: 102
Mileage: 219722 km
Date: 2016.01.03
Time: 16:39:11
01828 - Bulb for Tail-Lamp; Left
Reset counter: 197
Mileage: 223044 km
Date: 2003.10.10
Time: 05:43:04
01503 - Bulb for 3rd Brake Light (M25)
Reset counter: 200
Mileage: 223170 km
Date: 2003.10.09
Time: 21:56:15
Address 47: Sound System
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000031180
Coding: 0010111
VCID: 1E66D4FA2CBD92D73FF-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0B79E
Fault Status: 00110010
Reset counter: 221
Mileage: 224580 km
Date: 2003.10.08
Time: 08:36:00
Fault Frequency: 20
Reset counter: 221
Mileage: 224040 km
Date: 2003.10.14
Time: 09:34:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
Reset counter: 221
Mileage: 224576 km
Date: 2003.10.08
Time: 08:36:08
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 24103 444 52497
Fault Status: 00101101
Fault Frequency: 23
Reset counter: 233
Mileage: 226304 km
Date: 2003.10.08
Time: 02:41:30
Voltage: 13.04 V
Count: 236
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 192
Voltage: 10.35 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 629EA00A5845F6375B7-8036
02234 - Right Headlight Power Output Stage (J668)
Fault Frequency: 0
Reset counter: 203
Mileage: 223048 km
Date: 2003.10.08
Time: 00:42:50
00070 - Starting Battery Voltage
Reset counter: 180
Mileage: 223176 km
Date: 2003.10.09
Time: 21:55:27
02233 - Left Headlight Power Output Stage (J667)
Fault Frequency: 0
Mileage: 223176 km
Date: 2003.10.09
Time: 21:55:27
Fault Frequency: 0
Reset counter: 203
Mileage: 223048 km
Date: 2003.10.08
Time: 00:42:50
Fault Frequency: 0
Mileage: 223176 km
Date: 2003.10.09
Time: 21:55:27
Address 56: Radio
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000006225939
Shop #: WSC 24101 444 01039
VCID: 1F18E9FE2BB79BDF349-804A
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1401010139
Coding: 303030393135313035414B56413031343031303130313339
Shop #: WSC 00000 128 00289
02272 - Quiescent Current Stage 1
Fault Frequency: 9
Mileage: 222857 km
Date: 2003.10.09
Time: 05:31:04
02273 - Quiescent Current Stage 2
Fault Frequency: 71
Mileage: 222857 km
Date: 2003.10.09
Time: 05:34:15
02276 - Quiescent Current Stage 5
Fault Frequency: 65
Mileage: 222857 km
Date: 2003.10.09
Time: 05:34:25
02277 - Quiescent Current Stage 6
Mileage: 226361 km
Date: 2003.10.08
Time: 03:21:37
Reset counter: 232
Mileage: 224042 km
Date: 2003.10.14
Time: 09:35:28
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: 5DE493F6613BC9CF665-8008
Reset counter: 232
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5F98A9FE6B37DBDF749-800A
002 - Lower Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100010
Reset counter: 212
Mileage: 224042 km
Date: 2003.10.14
Time: 09:34:26
Speed: 255.0 km/h
Voltage: 8.10 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
Reset counter: 233
Mileage: 226310 km
Date: 2003.10.08
Time: 02:19:04
Temperature: 0.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
004 - No Signal/Communication - Intermittent - MIL ON
Fault Status: 10100100
Fault Frequency: 24
Reset counter: 233
Mileage: 224572 km
Date: 2003.10.08
Time: 00:47:55
Speed: 17.0 km/h
Temperature: -9.0°C
Error Code: 32768
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 202
Mileage: 223216 km
Date: 2003.10.10
Time: 19:05:06
Reset counter: 221
Mileage: 224576 km
Date: 2003.10.08
Time: 08:36:08
Reset counter: 230
Mileage: 225984 km
Date: 2003.10.09
Time: 03:13:10
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3007687
Coding: 0000005
VCID: 609AAA025659E4274D3-513C
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000400900020
Coding: 0001208
VCID: 211CEF061DC3AD2F02D-8074
Reset counter: 232
Mileage: 223170 km
Date: 2003.10.09
Time: 23:20:14
Reset counter: 217
Mileage: 224042 km
Date: 2003.10.14
Time: 09:34:14
Reset counter: 199
Mileage: 223170 km
Date: 2003.10.09
Time: 21:55:41
End----------(Elapsed Time: 01:59, VBatt start/end: 11.6V/11.6V)-----------
