NEW TO AUDI NEW TO VCDS NEED SERIOUS HELP!!!
   #41
The 4E A8 is one of the most power-hungry cars every made. If you're going to be working on this car extensively and don't wish to run the engine while scanning, you're going to need a good battery charger, 20-30A at the absolute minimum.
BostonSlaya
Rhode Island
C?ID=240768
I did this and the battery level meter shows up but not the suspension, oil or anything else that might have shown up when doing this
Looks like most of your problems are voltages as Eric said in a previous post, I would connect a battery charger to this car and let it charge right up and then clear out the DTC's. Keep in mind for some reason sometimes when you go clear all DTC's it doesn't. I always go into the Modules in question by double clicking on it and clear it out individually. Also when you run a full AutoScan a Battery charger should always be connected to get a proper scan. After you do these steps please post up another full AutoScan...
   #44
BostonSlaya
Rhode Island
C?ID=240768
so the battery in the vehicle is not an Audi battery, and with the key turned on but not over before the complete scan is ran I get a energy management message on the dash display, or am I supposed to run it with the car started instead? and I took the battery to get tested and I keep getting told its a good battery and im not sure it was coded to the vehicle, its a Super Start Extreme battery and I was told its less than a year old after tracking down the last owner and asking him
Do yourself a favor get an OEM Varta Battery from Audi!! then code it to the car, For now you can code this aftermarket one by just changing one number of the serial number in VCDS.
   #45
sheed44
C?ID=297477
so this is my scan after clearing all DTC's and with the battery charger hooked up. also for the bulbs that I need to replace can I get them from the auto parts store or do I have to get them from Audi also? or the internet?
Tuesday,31,January,2017,13:29:35:42098
VCDS Version: 17.1.2.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170131 DS267.1
VIN: WAUML44E04N018154   License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E04N018154   Mileage: 228150km-141765miles
38-Roof Electronics -- Status: Malfunction 0010
   Part No SW: 4E0 910 560 P    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0020
   Revision: --------    Serial number: AUX3Z0D0532489
   Coding: 0007773
   Shop #: WSC 24103 444 84355
   VCID: 2E06043A5C1D02578FF-807A
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
                    Fault Status: 01101000
                    Mileage: 228157 km
                    Temperature: 27.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 11.684 V
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0028405
   Coding: 0000002
   Shop #: WSC 02313 785 00200
   VCID: 2412E61202D1B80769B-8070
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
   Component: ESP 5.7 allrad  H44 0500
   Coding: 0007597
   Shop #: WSC 24103 000 00000
   VCID: 221EE00A18C5B6371B7-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0D0532489
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58EA82E20E192CE7353-800C
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H07  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   VCID: 2310E50E07DFBF3F101-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 B    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 346AB047509000
   Coding: 0000000
   VCID: 211CEF061DC3AD2F02D-8074
   Subsystem 1 - Part No: 4E0 910 609 C
   Component: Bedienteil MMI  H42 0100
   Subsystem 2 - Serial number: 390FU057502768
   Subsystem 3 - Serial number: 7422.06.0500000000290B0023ÿ
   Subsystem 4 - Serial number: 0B0023ÿ
            000 -  -
                    Time Indication: 15
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000034086
   Coding: 1085761
   VCID: 5AEE98EA70153EF7037-800E
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO16012004065A000000000424ÿ†89
   Subsystem 5 - Serial number: 000424ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO16012004065A00000000
   Subsystem 7 - Serial number: 65A000000000467ÿ
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: 2A0E082A60F56E77537-807E
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H40 0380
   Coding: 00000036
   Shop #: WSC 02313
01498 - Bulb for Parking Lamps; Right (M3)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 214
                    Mileage: 228157 km
                    Date: 2017.01.31
                    Time: 13:14:25
01494 - Bulb for Parking Lamps; Left (M1)
                    Reset counter: 214
                    Mileage: 228157 km
                    Date: 2017.01.31
                    Time: 13:14:26
                    Reset counter: 214
                    Mileage: 228157 km
                    Date: 2017.01.31
                    Time: 13:14:26
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111
   Component: CD-Changer      H43 0470
   Revision: 00000501    Serial number: AUZ5ZBC1022182
   VCID: 1C62DEF23AA180C7D1B-8048
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H13 0040
   Coding: 0012241
   VCID: 6594BB16496B810FBE5-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3D0006575
   Coding: 0016203
   VCID: 5CE29EF27A21C0C711B-8008
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503C08128A
   Coding: FCFE7BDD1B2304
   VCID: 2616FC1A74ED4A1777F-8072
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   VCID: 2514FB1609EB410F7E5-8070
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
                    Fault Status: 11101010
                    Reset counter: 214
                    Mileage: 228157 km
                    Date: 2017.01.31
                    Time: 13:25:04
   Component: Sitzmemory FS  H07  0060
   Coding: 4071522
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H43 1100
   Revision: 00000000    Serial number: 355AM047515059
   VCID: 382A2262AE59CCE7D53-806C
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000334300180
   Coding: 0003989
   VCID: 1D64D3F621BB89CF265-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0028196
   VCID: 5EE694FA6C3DD2D77FF-800A
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040312180022
   Coding: 0065150
   VCID: 2708F11E73E7531F4C9-8072
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel      H06 0060
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H02 0020
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 214
                    Mileage: 213427 km
                    Date: 2003.10.09
                    Time: 20:24:59
                    Fault Status: 01101100
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 M    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0450
   Revision: Dev_D01     Serial number: 00000000674361
   Coding: 0000016
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 216
                    Mileage: 160971 km
                    Date: 2010.11.11
                    Time: 19:44:50
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000031180
   Coding: 0010111
   VCID: 1E66D4FA2CBD92D73FF-804A
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T0B79E
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM007 0110
   Coding: 0028196
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 24103 444 52497
02434 - Supply Voltage for Control Module for Left Channel
            006 - Short to Plus - MIL ON
                    Fault Status: 11110110
                    Fault Frequency: 25
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 110
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 61
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   Coding: 0000001
   VCID: 629EA00A5845F6375B7-8036
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0620
   Revision: 00000000    Serial number: 304AH047557504
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000006225939
   Shop #: WSC 24101 444 01039
   VCID: 1F18E9FE2BB79BDF349-804A
   Subsystem 1 - Part No: 000 915 105 AK
   Component: von VA0  1401010139
   Coding: 303030393135313035414B56413031343031303130313339
   Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM007 0110
   Coding: 0028196
   VCID: 5DE493F6613BC9CF665-8008
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   VCID: 5F98A9FE6B37DBDF749-800A
01477 - System Switched Off
            000 -  -
                    Reset counter: 214
                    Mileage: 228157 km
                    Date: 2017.01.31
                    Time: 13:26:13
                    Temperature: 7.0°C
                    Error Code: 32768
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM007 0110
   Coding: 0028196
Address 75: Telematics        Labels: None
   Part No SW: 4E0 910 616     HW: 4E0 035 616 A
   Component: Telematik USA1      0070
   Revision: 00000004    Serial number: 0000ATD3007687
   Coding: 0000005
   VCID: 609AAA025659E4274D3-513C
   Subsystem 1 - Part No: 4E0 910 616
No Faults Found
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H11 0010
   Revision: --.--.--    Serial number: 00000400900020
   Coding: 0001208
End----------(Elapsed Time: 02:51, VBatt start/end: 11.6V/11.7V)-----------
   #46
BostonSlaya
Rhode Island
C?ID=240768
Now that looks a lot better!!! starting to get somewhere...The bulbs you have in question are they actually burned out? This could just be the wiring and not the bulb. Some of these might not be a problem getting at a regular part store, others like the Fog lights will more then likely be dealer or online only. This car is just way to temperamental for anything aftermarket, This includes the Battery.
I will start from the top of your scan, 01:Engine - 18062 ABS Controller (This could very well be because of your rear brakes DTC being worn) I would start by inspecting both rear brakes to see how much is left on both side os the rotors then report back. They just might need to be replaced and then coded, or they where replaced and somebody didn't code the module correctly. Also please check that Alarm Horn for bad wiring or bad Alarm, Most likely it's going to be the Alarm itself.
65:Tire pressure (Looks like it's switched off so why not pull the fuse and code the TPS out of the install list 19.. Telematics I would pull the front driver seat out and remove it from the black box and then pull the fuse and code that out as well.. I purchase all my parts from a wonderful source great OEM parts at a fantastic price www.fcpeuro.com... I would stop going zig zag on things and work on one DTC at a time and report your findings.
   #47
BostonSlaya
Rhode Island
C?ID=240768
34:Level Control DTC
Possible causes:
Wiring and / or connections faulty
(G290) defect
Possible solutions:
Check / repair wiring and connections
Check (measuring blocks) / replace (G290)
This also could be that the compressor is getting hot by working to hard, There are air Compressor rebuild kits out there for real cheap and easy for a DIY. Best way to tell is do you here the compressor loader then normal? You should barely hear it, mine was running HOT and I rebuilt it with a new piston ring and it is now extra quite and works amazing.
sheed44
C?ID=297477
Ok thank you and the fog light on the passenger side is burnt out and so are the parking lamps these are also displayed on the instrument display,i will check the rear brake pads today, and I will check the alarm horn, I appreciate all of your help im going to have an amazing running machine here in a sec lol
   #49
BostonSlaya
Rhode Island
C?ID=240768
I would absolutely check the Rear Brakes for sure, I know you don't want them to get to a point it causes more damage if they are truly bad. The website I listed above will give you the price but better yet a full diagram of the vehicle to give you part #'s This is what I use for sure..
   #50
sheed44
C?ID=297477
im still having the issue of something draining the battery after about 6-8 hours of the car sitting it will light up and the key will turn but it will not start instead it makes a ticking sound like the battery is completely dead but it's not then after I put the charger on it for about a minute it starts right up?? what could be drawing this power from the battery? based off of my latest scan?
   #51
BostonSlaya
Rhode Island
C?ID=240768
Have you checked the Alarm Horn wiring like I stated in a previous post? Did you order the Alarm horn? Did you order the MOST loop?
When you shut all doors and lock the car do you hear the alarm beep? After you lock the car after about 15 mins look at the Hazzars button and or the shift lights, are they still lite up? The loop will bypass the CD player that's showing a DTC, if the Can Bus cannot communicate with all modules then it will not go to sleep, it will countinue to try over and over this is another battery drain issue. Again you need the alarm horn/alarm siren and at lease one loop to start fixing things.
sheed44
C?ID=297477
I did order the MOST loop, and no alarm beeps when locking the car and yes the shift lights stay on but not sure how long exactly will time it in the am and look at the horn/alarm also and will post after doing so
BostonSlaya
Rhode Island
C?ID=240768
Awesome! The loop is a life saver. The alarm doesn't beep because there is a problem with the alarm wiring or the alarm it self. My money is you need a new alarm. The lights will stay on until it's forced to turn off when the battery drains lol. When the loop get in let me know and I'll walk you through it. Have you found the location of the alarm?
   #54
sheed44
C?ID=297477
No I actually just texted you asking for the location of the alarm, and how do I code out a function as in the tire sensor you said I should since its turned off?
   #55
NostraJackAss
   #56
BostonSlaya
Rhode Island
C?ID=240768
Here is a question I have. How do you go about checking battery drain in an A8 with a meter? I ask because it doesn't work like normal cars. I took the negative battery terminal off and put the red from meter to negative cable and black from meter to negative post of the battery and automatic it turns the sound system and alarm goes off? Thanks
