Sticky Jacks Professional Problem Solver Guide. "JPPSG"
Sticky
   #21
Gone But Not Forgotten
Amendment to JPPSG!
Check for FOD duplicate VIN #s observed or for currently for violation of Title 18 for the USA.
https://www.nicb.org/theft_and_fraud_awareness/vincheck
https://www.justice.gov/usam/crimin...certain-motor-vehicles-or-motor-vehicle-parts
Tuners indeed violate the Title 18, 40 and 41 rule for VIN tampering, especially when using or tying functionality to a VIN # and or expressing conformity violating the EPA CAA or NHTSA Fast Act for altering , setting readiness to always ready etc. !
Defeat device? YUP!
   #23
Baholli
Kosovo
C?ID=309191
You Jack are big man thank you very much for everything
   #24
DTC.................compilation!
I didn't use code tags on purpose & so you can see surrounding codes in a group.
Use "Control F" to hot search a DTC!
P000100 Fuel Volume Regulator Control Circuit/Open
P000A00 A Camshaft Position Slow Response (Bank 1)
P000B00 B Camshaft Position Slow Response (Bank 1)
P000C00 A Camshaft Position Slow Response (Bank 2)
P000D00 B Camshaft Position Slow Response (Bank 2)
P001000 A Camshaft Position Actuator Circuit/Open (Bank1)
P001100 A Camshaft Position (Bank1) Timing over-advanced or System Performance
P001200 A Camshaft Position (Bank1) Timing over-retarded
P001300 B Camshaft Position Actuator Circuit/Open (Bank1)
P001400 B Camshaft Position (Bank1) Timing over-advanced or System Performance
P001500 B Camshaft Position (Bank1) Timing over-retarded
P001600 Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A
P001700 Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor B
P001800 Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor A
P001900 Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor B
P002000 A Camshaft Position ActuatorCircuit(Bank2)
P002100 A Camshaft Position (Bank2) Timing over-advanced or System Performance
P002200 A Camshaft Position (Bank2) Timing over-retarded
P002300 B Camshaft Position Actuator Circuit(Bank2)
P002400 B Camshaft Position (Bank2) Timing over-advanced or System Performance
P002500 B Camshaft Position (Bank2) Timing over-retarded
P003000 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1)
P003100 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) Low
P003200 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1) High
P003300 Turbo Charger Bypass Valve Control Circuit
P003400 Turbo Charger Bypass Valve Control Circuit Low
P003500 Turbo Charger Bypass Valve Control Circuit High
P003600 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2)
P003700 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) Low
P003800 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) High
P003900 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P004000 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
P004100 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P004200 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3)
P004300 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3) Low
P004400 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 3) High
P004500 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit/Open
P004700 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit Low
P004800 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit High
P004900 Turbocharger/Supercharger Turbine Overspeed
P004A00 Turbocharger/Supercharger Boost Control Solenoid "B" Circuit / Open
P004C00 Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Low
P004D00 Turbocharger/Supercharger Boost Control Solenoid "B" Circuit High
P005000 O2 Sensor Heater Contr. Circ.(Bank2 Sensor 1)
P005100 O2 Sensor Heater Contr. Circ.(Bank2 Sensor 1) Low
P005200 O2 Sensor Heater Contr. Circ.(Bank2 Sensor1) High
P005600 O2 Sensor Heater Contr. Circ.(Bank2 Sensor 2)
P005700 O2 Sensor Heater Contr. Circ.(Bank2 Sensor 2) Low
P005800 O2 Sensor Heater Contr. Circ.(Bank2 Sensor2) High
P006200 HO2S Heater Control Circuit
P006300 HO2S Heater Control Circuit Low
P006400 HO2S Heater Control Circuit High Bank2 Sensor3
P006500 Air Assisted Injector Control Range/Performance
P006600 Air Assisted Injector Control Circuit low
P006700 Air Assisted Injector Control Circuit high
P006800 MAP/MAF - Throttle Position Correlation
P006900 Manifold Absolute Pressure - Barometric Pressure Correlation
P007000 Ambient Air Temperature Sensor Circuit
P007100 Ambient Air Temperature Sensor Circuit Range/Performance
P007200 Ambient Air Temperature Sensor Circuit Low
P007300 Ambient Air Temperature Sensor Circuit High
P007400 Ambient Air Temperature Sensor Circuit Intermittent
P007C00 Charge Air Cooler Temperature Sensor Circuit Low Bank 1
P007D00 Charge Air Cooler Temperature Sensor Circuit High Bank 1
P008700 Fuel Rail/System Pressure - Too Low
P008800 Fuel Rail/System Pressure - Too High
P008900 Fuel Pressure Regulator 1 Performance
P008A00 Low Pressure Fuel System Pressure - Too Low
P008B00 Low Pressure Fuel System Pressure - Too High
P009000 Fuel Pressure Regulator 1Control Circuit
P009100 Fuel Pressure Regulator 1 Control Circuit Low
P009200 Fuel Pressure Regulator 1 Control Circuit High
P009500 Intake Air Temperature Sensor 2 Circuit
P009600 Intake Air Temperature Sensor 2 Circuit Bank 1 Range/Performance
P009700 Intake Air Temperature Sensor 2 Circuit Low
P009800 Intake Air Temperature Sensor 2 Circuit High
P009900 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
P009B00 Fuel Pressure Relief Control Circuit/Open
P009C00 Fuel Pressure Relief Control Circuit Low
P009D00 Fuel Pressure Relief Control Circuit High
P009E00 Fuel Pressure Relief Control Performance/Stuck Off
P009F00 Fuel Pressure Relief Control Stuck on
P00A200 Charge Air Cooler Temperature Sensor Circuit Low Bank 2
P00A300 Charge Air Cooler Temperature Sensor Circuit High Bank 2
P00A600 Intake Air Temperature Sensor 2 Circuit Bank 2 Range/Performance
P00AF00 Turbocharger/Supercharger Boost Control "A" Module Performance
P00B000 Turbocharger/Supercharger Boost Control "B" Module Performance
P00C600 Fuel Rail Pressure Too Low - Engine Cranking
P010000 Mass or Volume Air Flow Circuit
P010100 Mass or Volume Air Flow Circ. Range/Performance
P010200 Mass or Volume Air Flow Circ. Low Input
P010300 Mass or Volume Air Flow Circ. High Input
P010400 Mass or Volume Air Flow Circuit Intermittent
P010500 Manifolt Absolut Pressure/Barometic Pressure Circuit
P010600 Manifold Abs.Pressure or Bar.Pressure Range/Performance
P010700 Manifold Abs.Pressure or Bar.Pressure Low Input
P010800 Manifold Abs.Pressure or Bar.Pressure High Input
P010A00 Mass or Volume Air Flow "B" Circuit
P010B00 Mass or Volume Air Flow "B" Circuit Range/Performance
P010C00 Mass or Volume Air Flow "B" Circuit Low Input
P010D00 Mass or Volume Air Flow "B" Circuit High Input
P010E00 Mass or Volume Air Flow "B" Circuit Intermittent/Erratic
P010F00 Mass or Volume Air Flow Sensor A/B Correlation
P011000 Intake Air Temperature Sensor 1 Circuit
P011100 Intake Air Temp.Circ. Range/Performance
P011200 Intake Air Temp.Circ. Low Input
P011300 Intake Air Temp.Circ. High Input
P011400 Intake Air Temp.Circ. Intermittend
P011500 Engine Coolant Temperature Sensor 1 Circuit
P011600 Engine Coolant Temperature Sensor 1 Circuit Range/Performance
P011700 Engine Coolant Temperature Sensor 1 Circuit Low
P011800 Engine Coolant Temperature Sensor 1 Circuit High
P011A00 Engine Coolant Temperature Sensor 1/2 Correlation
P012000 Throttle/Pedal Pos.Sensor A Circ. Malfunction
P012100 Throttle/Pedal Pos.Sensor A Circ. Range/Performance
P012200 Throttle/Pedal Pos.Sensor A Circ. Low Input
P012300 Throttle/Pedal Pos.Sensor A Circ. High Input
P012500 Insufficient Coolant Temp.for Closed Loop Fuel Control
P012800 Coolant Termostat ( Coolant Temperature Below Thermostat Regulating Temperature)
P012A00 Turbocharger/Supercharger Inlet Pressure Sensor Circuit
P012B00 Turbocharger/Supercharger Inlet Pressure Sensor Circuit Range/Performance
P012C00 Turbocharger/Supercharger Inlet Pressure Sensor Circuit Low
P012D00 Turbocharger/Supercharger Inlet Pressure Sensor Circuit High
P013000 O2 Sensor Circ.,Bank1-Sensor1 Malfunction
P013100 O2 Sensor Circ.,Bank1-Sensor1 Low Voltage
P013200 O2 Sensor Circ.,Bank1-Sensor1 High Voltage
P013300 O2 Sensor Circ.,Bank1-Sensor1 Slow Response
P013400 O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
P013500 O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
P013600 O2 Sensor Circ.,Bank1-Sensor2 Malfunction
P013700 O2 Sensor Circ.,Bank1-Sensor2 Low Voltage
P013800 O2 Sensor Circ.,Bank1-Sensor2 High Voltage
P013900 O2 Sensor Circ.,Bank1-Sensor2 Slow Response
P014000 O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
P014100 O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction
P014200 O2 Sensor Circ.,Bank1-Sensor3
P014300 O2 Sensor Circ.,Bank1-Sensor3 Low Voltage
P014400 O2 Sensor Circ.,Bank1-Sensor3 High Voltage
P014500 O2 Sensor Circ.,Bank1-Sensor3 Slow Response
P014600 O2 Sensor Circ.,Bank1-Sensor3 No Activity Detected
P014700 O2 Sensor Heater Circ.,Bank1-Sensor3
P014800 Fuel Delivery Error
P014900 Fuel Timing Error
P015000 O2 Sensor Circ.,Bank2-Sensor1 Malfunction
P015100 O2 Sensor Circ.,Bank2-Sensor1 Low Voltage
P015200 O2 Sensor Circ.,Bank2-Sensor1 High Voltage
P015300 O2 Sensor Circ.,Bank2-Sensor1 Slow Response
P015400 O2 Sensor Circ.,Bank2-Sensor1 No Activity Detected
P015500 O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
P015600 O2 Sensor Circ.,Bank2-Sensor2 Malfunction
P015700 O2 Sensor Circ.,Bank2-Sensor2 Low Voltage
P015800 O2 Sensor Circ.,Bank2-Sensor2 High Voltage
P015900 O2 Sensor Circ.,Bank2-Sensor2 Slow Response
P016000 O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected
P016100 O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction
P016200 O2 Sensor Circ.,Bank2-Sensor3 Malfunction
P016300 O2 Sensor Circ.,Bank2-Sensor3 Low Voltage
P016400 O2 Sensor Circ.,Bank2-Sensor3 High Voltage
P016500 O2 Sensor Circ.,Bank2-Sensor3 Slow Response
P016600 O2 Sensor Circ.,Bank2-Sensor3 No Activity Detected
P016700 O2 Sensor Heater Circ.,Bank2-Sensor3 Malfunction
P016900 Incorrect Fuel Composition
P017000 Fuel Trim,Bank1 Malfunction
P017100 Fuel Trim,Bank1 System too Lean
P017200 Fuel Trim,Bank1 System too Rich
P017300 Fuel Trim,Bank2 Malfunction
P017400 Fuel Trim,Bank2 System too Lean
P017500 Fuel Trim,Bank2 System too Rich
P017700 Fuel Composition Sensor Circuit Range/Performance
P017800 Fuel Composition Sensor Circuit Low
P017900 Fuel Composition Sensor Circuit High
P018100 Fuel Temperature Sensor A Circuit Range/Performance
P018200 Fuel Temperature Sensor A Circuit Low Input
P018300 Fuel Temperature Sensor A Circuit High Input
P018600 Fuel Temperature Sensor B Circuit Range/Performance
P018700 Fuel Temperature Sensor B Circuit Low
P018800 Fuel Temperature Sensor B Circuit High
P018A00 Fuel Pressure Sensor "B" Circuit
P018B00 Fuel Pressure Sensor "B" Circuit Range/Performance
P018C00 Fuel Pressure Sensor "B" Circuit Low
P019000 Fuel Rail Pressure Sensor "A" Circuit
P019100 Fuel Rail Pressure Sensor "A" Circuit Range/Performance
P019200 Fuel Rail Pressure Sensor "A" Circuit Low Input
P019300 Fuel Rail Pressure Sensor "A" Circuit High Input
P019400 Fuel Rail Pressure Sensor "A" Circuit intermittent
P019500 Engine Oil Temperature Sensor Circuit
P019600 Engine Oil Temperature Sensor Circuit range/performance
P019700 Engine Oil Temperature Sensor Circuit low
P019800 Engine Oil Temperature Sensor Circuit high
P019900 Engine Oil Temperature Sensor Circuit Intermittent/Erratic
P020000 Injector Circuit open
P020100 Cylinder 1- Injector Circuit
P020200 Cylinder 2- Injector Circuit
P020300 Cylinder 3- Injector Circuit
P020400 Cylinder 4- Injector Circuit
P020500 Cylinder 5- Injector Circuit
P020600 Cylinder 6- Injector Circuit
P020700 Cylinder 7- Injector Circuit
P020800 Cylinder 8- Injector Circuit
P020900 Cylinder 9- Injector Circuit
P020A00 Cylinder 1 Injection Timing
P020B00 Cylinder 2 Injection Timing
P020C00 Cylinder 3 Injection Timing
P020D00 Cylinder 4 Injection Timing
P020E00 Cylinder 5 Injection Timing
P020F00 Cylinder 6 Injection Timing
P021000 Cylinder 10- Injector Circuit
P021100 Cylinder 11- Injector Circuit
P021200 Cylinder 12- Injector Circuit
P021500 Engine Shutoff Solenoid
P021600 Injection Timing Control Circuit
P021800 Transmission Fluid Over Temperature Condition
P021900 Engine Overspeed Condition
P021A00 Cylinder 7 Injection Timing
P021B00 Cylinder 8 Injection Timing
P021C00 Cylinder 9 Injection Timing
P021D00 Cylinder 10 Injection Timing
P021E00 Cylinder 11 Injection Timing
P021F00 Cylinder 12 Injection Timing
P022100 Throttle/Pedal Position Sensor/Switch B Range/Performance
P022200 Throttle/Pedal Position Sensor/Switch B Low Input
P022300 Throttle/Pedal Position Sensor/Switch B High Input
P022500 Throttle/Pedal Position Sensor/Switch C
P022600 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance
P022700 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P022800 Throttle/Pedal Position Sensor/Switch C Circuit High Input
P022A00 Charge Air Cooler Bypass Control "A" Circuit /Open
P022B00 Charge Air Cooler Bypass Control "A" Circuit Low
P022C00 Charge Air Cooler Bypass Control "A" Circuit High
P023000 Fuel Pump Primary Circuit
P023400 Turbo/Super Charger Overboost Condition
P023500 Turbo/Super Charger Boost Sensor A Circ.
P023600 Turbocharger Boost Sensor (A) Circ. Range/Performance
P023700 Turbocharger Boost Sensor (A) Circ. Low Input
P023800 Turbocharger Boost Sensor (A) Circ. High Input
P023F00 Fuel Pump Secondary Circuit/Open
P024000 Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance
P024100 Turbo/Super Charger Boost Sensor "B" Circuit Low
P024200 Turbo/Super Charger Boost Sensor "B" Circuit High
P024300 Turbo/Super Charger Wastegate Solonoid A
P024500 Turbo/Super Charger Wasteg.Solonoid A Low
P024600 Turbo/Sup.Charger Wasteg.Solonoid A High
P024900 Turbo/Super Charger Wastegate Solenoid "B" Low
P024A00 Charge Air Cooler Bypass Control "A" Range/Performance
P024B00 Charge Air Cooler Bypass Control "A" Stuck
P025000 Turbo/Super Charger Wastegate Solenoid "B" High
P025100 Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector)
P025200 Injection Pump Fuel Metering Control A Range/Performance (Cam/Rotor/Injector)
P025A00 Fuel Pump Module Control Circuit/Open
P025B00 Fuel Pump Module Control Circuit Range/Performance
P025C00 Fuel Pump Module Control Circuit Low
P025D00 Fuel Pump Module Control Circuit High
P026100 Cylinder 1- Injector Circuit Low
P026200 Cylinder 1- Injector Circuit High
P026300 Cylinder 1 Contribution/Balance
P026400 Cylinder 2- Injector Circuit Low
P026500 Cylinder 2- Injector Circuit High
P026600 Cylinder 2 Contribution/Balance
P026700 Cylinder 3- Injector Circuit Low
P026800 Cylinder 3- Injector Circuit High
P026900 Cylinder 3 Contribution/Balance
P027000 Cylinder 4- Injector Circuit Low
P027100 Cylinder 4- Injector Circuit High
P027200 Cylinder 4 Contribution/Balance
P027300 Cylinder 5- Injector Circuit Low
P027400 Cylinder 5- Injector Circuit High
P027500 Cylinder 5 Contribution/Balance
P027600 Cylinder 6- Injector Circuit Low
P027700 Cylinder 6- Injector Circuit High
P027800 Cylinder 6 Contribution/Balance
P027900 Cylinder 7- Injector Circuit Low
P028000 Cylinder 7- Injector Circuit High
P028100 Cylinder 7 Contribution/Balance
P028200 Cylinder 8- Injector Circuit Low
P028300 Cylinder 8- Injector Circuit High
P028400 Cylinder 8 Contribution/Balance
P028500 Cylinder 9- Injector Circuit Low
P028600 Cylinder 9- Injector Circuit High
P028700 Cylinder 9 Contribution/Balance
P028800 Cylinder 10- Injector Circuit Low
P028900 Cylinder 10- Injector Circuit High
P029000 Cylinder 10 Contribution/Balance
P029100 Cylinder 11- Injector Circuit Low
P029200 Cylinder 11- Injector Circuit High
P029300 Cylinder 11 Contribution/Balance
P029400 Cylinder 12- Injector Circuit Low
P029500 Cylinder 12- Injector Circuit High
P029600 Cylinder 12 Contribution/Balance
P029900 Turbo/Super Charger Underboost
P02CA00 Turbocharger/Supercharger "B" Overboost Condition
P02CB00 Turbocharger/Supercharger "B" Underboost Condition
P02CD00 Cylinder 1 Fuel Injector Offset Learning At Max Limit
P02CF00 Cylinder 2 Fuel Injector Offset Learning At Max Limit
P02D100 Cylinder 3 Fuel Injector Offset Learning At Max Limit
P02D300 Cylinder 4 Fuel Injector Offset Learning At Max Limit
P030000 Random/Multiple Cylinder Misfire Detected
P030100 Cyl.1 Misfire Detected
P030200 Cyl.2 Misfire Detected
P030300 Cyl.3 Misfire Detected
P030400 Cyl.4 Misfire Detected
P030500 Cyl.5 Misfire Detected
P030600 Cyl.6 Misfire Detected
P030700 Cyl.7 Misfire Detected
P030800 Cyl.8 Misfire Detected
P030900 Cyl.9 Misfire Detected
P031000 Cyl.10 Misfire Detected
P031100 Cyl.11 Misfire Detected
P031200 Cyl.12 Misfire Detected
P031300 Misfire Detected with Low Fuel
P031400 Single Cylinder Misfire
P031800 Rough Road Sensor "A" Signal Circuit
P032100 Ign./Distributor Eng.Speed Inp.Circ. Range/Performance
P032200 Ign./Distributor Eng.Speed Inp.Circ. No Signal
P032400 Knock Control System Error
P032500 Knock Sensor 1 Circuit Malfunktion
P032600 Knock Sensor 1 Circuit Range/Performance
P032700 Knock Sensor 1 Circ. Low Input
P032800 Knock Sensor 1 Circ. High Input
P033000 Knock Sensor 2 Circuit
P033100 Knock Sensor 2 Circuit Range/Performance
P033200 Knock Sensor 2 Circ. Low Input
P033300 Knock Sensor 2 Circ. High Input
P033500 Crankshaft Position Sensor A Circuit
P033600 Crankshaft Position Sensor A Circuit Range/Performance
P033700 Crankshaft Pos.Sensor (A) Circ. Low Input
P033900 Crankshaft Position Sensor "A" Circuit Intermittent
P034000 Camshaft Position Sensor Circuit
P034100 Camshaft Pos.Sensor Circ. Range/Performance
P034200 Camshaft Pos.Sensor Circ. Low Input
P034300 Camshaft Pos.Sensor Circ. High Input
P034500 Camshaft Position Sensor Circuit Bank2
P034600 Camshaft Pos.Sensor Circ. (Bank2) Range/Performance
P034700 Camshaft Pos.Sensor "A" Circ. (Bank2) Low
P034800 Camshaft Pos.Sensor "A" Circ. (Bank2) High
P035100 Ignition Coil A Primary/secondary Circuit
P035200 Ignition Coil B Primary/secondary Circuit
P035300 Ignition Coil C Primary/secondary Circuit
P035400 Ignition Coil D Primary/secondary Circuit
P035500 Ignition Coil E Primary/secondary Circuit
P035600 Ignition Coil F Primary/secondary Circuit
P035700 Ignition Coil G Primary/secondary Circuit
P035800 Ignition Coil H Primary/secondary Circuit
P035900 Ignition Coil I Primary/secondary Circuit
P036000 Ignition Coil J Primary/secondary Circuit
P036100 Ignition Coil K Primary/secondary Circuit
P036200 Ignition Coil L Primary/secondary Circuit
P036300 Misfire Detected - Fueling Disabled
P036500 Camshaft Position Sensor "B" Circuit (Bank 1)
P036600 Camshaft Pos.Sensor "B" Circ. (Bank 1) Range/Performance
P036700 Camshaft Pos.Sensor "B" Circ. (Bank 1) Low Input
P036800 Camshaft Pos.Sensor "B" Circ. (Bank 1) High Input
P038000 Glow Plug/Heater Circuit "A"
P038100 Glow Plug/Heater Indicator Circuit
P038300 Glow Plug Control Module Control Circuit Low
P038400 Glow Plug Control Module Control Circuit High
P039000 Camshaft Position Sensor "B" Circuit (Bank 2)
P039100 Camshaft Pos.Sensor "B" Circ. (Bank 2) Range/Performance
P039200 Camshaft Pos.Sensor "B" Circ. (Bank 2) Low Input
P039300 Camshaft Pos.Sensor "B" Circ. (Bank 2) High Input
P039B00 Cylinder 1 Pressure Too High
P03A500 Cylinder 2 Pressure Too High
P03AF00 Cylinder 3 Pressure Too High
P03B900 Cylinder 4 Pressure Too High
P03C300 Cylinder 5 Pressure Too High
P03CD00 Cylinder 6 Pressure Too High
P040000 Exhaust Gas Recirc."A" Flow
P040100 Exhaust Gas Recirc.Flow Insufficient Detected
P040200 Exhaust Gas Recirc.Flow Excessive Detected
P040300 Exhaust Gas Recirculation Circuit
P040400 Exhaust Gas Recirculation Circuit Range/Performance
P040500 Exhaust Gas Recirculat.Sensor A Circuit Low
P040600 Exhaust Gas Recirculat.Sensor A Circuit High
P040700 Exhaust Gas Recirculat.Sensor B Circuit Low
P040800 Exhaust Gas Recirculat.Sensor B Circuit High
P040B00 Exhaust Gas Recirculation Temperature Sensor "A" Circuit Range/Performance
P040C00 Exhaust Gas Recirculation Temperature Sensor "A" Circuit Low
P040D00 Exhaust Gas Recirculation Temperature Sensor "A" Circuit High
P041000 Sec.Air Inj.Sys. Malfunction
P041100 Sec.Air Inj.Sys. Incorrect Flow Detected
P041200 Sec.Air Inj.Sys.Switching Valve A Circ. Malfunction
P041300 Sec.Air Inj.Sys.Switching Valve A Circ. Open
P041400 Sec.Air Inj.Sys.Switching Valve A Circ. Shorted
P041500 Sec.Air Inj.Sys.Switching Valve B Circ. Malfunction
P041600 Sec.Air Inj.Sys.Switching Valve B Circ. Open
P041700 Sec.Air Inj.Sys.Switching Valve B Circ. Shorted
P041800 Sec. Air Injection System Relay A Circuit
P041900 Sec. Air Injection System Relay B Circuit
P042000 Catalyst System,Bank1 Efficiency Below Threshold
P042100 Warm Up Catalyst, Bank1 Efficiency Below Threshold
P042200 Main Catalyst,Bank1 Efficiency Below Threshold
P042500 Catalyst Temperature Sensor Circuit
P042600 Catalyst Temperature Sensor Circuit Range/Performance
P042700 Catalyst Temperature Sensor Bank1 Low Input
P042800 Catalyst Temperature Sensor Bank1 High Input
P043000 Catalyst System, Bank2 Efficiency Below Threshold
P043100 Warm Up Catalyst, Bank2 Efficiency Below Threshold
P043200 Main Catalyst,Bank2 Efficiency Below Threshold
P043600 Catalyst Temperature Sensor Bank2 Range/performance
P043700 Catalyst Temperature Sensor Bank2 Low Input
P043800 Catalyst Temperature Sensor Bank2 High Input
P044000 EVAP Emission Contr.Sys. Malfunction
P044100 EVAP Emission Contr.Sys.Incorrect Purge Flow
P044200 EVAP Emission Contr.Sys.(Small Leak) Leak Detected
P044300 Evaporativ Emiss.System Purge Control Valve Circ.
P044400 Evaporativ Emiss.System Purge Control Valve Circ. Open
P044500 Evaporativ Emiss.System Purge Control Valve Circ. Shorted
P044900 Evaporativ Emiss.System Vent Valve/Solenoid Circ.
P045000 Evaporative Emission System Pressure Sensor/Switch
P045100 Evaporative Emission System Pressure Sensor/Switch Range/Performance
P045200 EVAP Emission Contr.Sys.Press.Sensor Low Input
P045300 EVAP Emission Contr.Sys.Press.Sensor High Input
P045500 EVAP Emission Contr.Sys.(Gross Leak) Leak Detected
P045600 EVAP Emission Contr. Sys. (very small Leak) Leak Detected
P045800 Evaporative Emission System Purge Control Valve Circuit Low
P045900 Evaporative Emission System Purge Control Valve Circuit High
P045A00 Exhaust Gas Recirculation "B" Control Circuit
P045B00 Exhaust Gas Recirculation "B" Control Circuit Range/Performance
P045C00 Exhaust Gas Recirculation "B" Control Circuit Low
P045D00 Exhaust Gas Recirculation "B" Control Circuit High
P045E00 Exhaust Gas Recirculation "B" Control Stuck Open
P045F00 Exhaust Gas Recirculation "B" Control Stuck Closed
P046100 Fuel Level Sensor Circ. Range/Performance
P046200 Fuel Lever Sensor Circuit Low Input
P046300 Fuel Lever Sensor Circuit High Input
P046C00 Exhaust Gas Recirculation Sensor "A" Circuit Range/Performance
P046E00 Exhaust Gas Recirculation Sensor "B" Circuit Range/Performance
P047000 Exhaust Pressure Sensor "A"
P047100 Exhaust Pressure Sensor "A" Range/Performance
P047200 Exhaust Pressure Sensor "A"Low
P047300 Exhaust Pressure Sensor "A" High
P047500 Exhaust Pressure Control Valve "A"
P047600 Exhaust Pressure Control Valve "A" Range/Performance
P047700 Exhaust Pressure Control Valve "A" Low
P047800 Exhaust Pressure Control Valve "A" High
P047A00 Exhaust Pressure Sensor "B"
P047B00 Exhaust Pressure Sensor "B" Range/Performance
P047C00 Exhaust Pressure Sensor "B" Low
P047D00 Exhaust Pressure Sensor "B" High
P047F00 Exhaust Pressure Control Valve "A" Stuck Open
P048000 Cooling Fan 1 Control Circuit
P048100 Cooling Fan 2 Control Circuit
P048600 Exhaust Gas Recirculation Sensor "B" Circuit
P048900 Exhaust Gas Recirculation Control Circuit Low
P048A00 Exhaust Pressure Control Valve "A" Stuck Closed
P048B00 Exhaust Pressure Control Valve Position Sensor/Switch Circuit
P048C00 Exhaust Pressure Control Valve Pos. Sensor/Switch Circuit Range/Performance
P048E00 Exhaust Pressure Control Valve Pos. Sensor/Switch Circuit High
P049000 Exhaust Gas Recirculation Control Circuit High
P049100 Secondary Air Injection System (Bank 1) insufficient flow
P049200 Secondary Air Injection System (Bank 2)
P049800 Evaporative Emission System Vent Valve Control Circuit Low
P049900 Evaporative Emission System Vent Valve Control Circuit High
P049A00 Exhaust Gas Recirc."B" Flow
P049D00 Exhaust Gas Recirculation "A" Control Position Exceeded Learning Limit
P049E00 Exhaust Gas Recirculation "B" Control Position Exceeded Learning Limit
P050100 Vehicle Speed Sensor "A" Range/Performance
P050200 Vehicle Speed Sensor "A" Circuit Low Input
P050300 Vehicle Speed Sensor "A" Intermittend/Erratic/High
P050500 Idle Control System
P050600 Idle Control System RPM Lower than Expected
P050700 Idle Control System RPM Higher than Expected
P050A00 Cold Start Idle Air Control System Performance
P050B00 Cold Start Ignition Timing Performance
P051000 Closed Throttle Pos.Switch Malfunction
P051300 Incorrect Immobilizer Key
P053100 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P053200 A/C Refrigerant Pressure Sensor Circuit low Input
P053300 A/C Refrigerant Pressure Sensor Circuit high Input
P053700 A/C Evaporator Temperature Sensor Circuit Low
P053800 A/C Evaporator Temperature Sensor Circuit High
P053A00 Positive Crankcase Ventilation Heater Control Circuit /Open
P053B00 Positive Crankcase Ventilation Heater Control Circuit Low
P053C00 Positive Crankcase Ventilation Heater Control Circuit High
P054400 Exhaust Gas Temperatur Sensor Circuit - Bank 1
P054500 Exhaust Gas Temperatur Sensor Circuit - Bank 1 Low
P054600 Exhaust Gas Temperatur Sensor Circuit - Bank 1 High
P054700 Exhaust Gas Temperatur Sensor Circuit - Bank 2
P054800 Exhaust Gas Temperatur Sensor Circuit - Bank 2 Low
P054900 Exhaust Gas Temperatur Sensor Circuit - Bank 2 High
P055000 Power Steering Pressure Circuit
P055100 Power Steering Pressure Sensor Circuit Range/Performance
P056000 System Voltage Malfunction
P056100 System Voltage Unstable
P056200 System Voltage Low Voltage
P056300 System Voltage High Voltage
P056800 Cruise Control Set Signal
P057100 Cruise/Brake Switch (A) Circ. Malfunction
P059700 Thermostat Heater Control Circuit Open
P059800 Thermostat Heater Control Circuit Low
P059900 Thermostat Heater Control Circuit High
P060000 Serial Link Communication
P060100 Internal Contr.Module Memory Check Sum Error
P060200 Control Modul Programming Error
P060300 Internal Contr.Module (KAM) Error
P060400 Internal Contr.Module Random Access Memory (RAM) Error
P060500 Internal Contr.Module ROM Test Error
P060600 ECM/PCM Processor
P060700 Control Module Performance
P060800 Control Module VSS Output "A"
P060900 Control Module VSS Output "B"
P060A00 Internal Control Module Monitoring Processor Performance
P061000 Control Module Vehicle Options Error
P061300 TCM Processor
P061400 ECM/TCM Incompatible
P061500 Starter Relay Circuit
P061600 Starter Relay Circuit Low
P061700 Starter Relay Circuit High
P062700 Fuel Pump "A" Control Circuit/Open
P062800 Fuel Pump "A" Control Circuit Low
P062900 Fuel Pump "A" Control Circuit High
P062B00 Internal Control Module Fuel Injector Control Performance
P062F00 Internal Control Module EEPROM Error
P063400 PCM/ECM/TCM Internal Temperature Too High
P063800 Throttle Actuator Control (Bank1) Range/Performance
P063900 Throttle Actuator Control (Bank2) Range/Performance
P064100 Sensor Reference Voltage "A" Circuit Open
P064200 Sensor Reference Voltage "A" Circuit Low
P064300 Sensor Reference Voltage "A" Circuit High
P064500 AC clutch relais circuit
P064C00 Glow Plug Control Module
P065000 Malfunction Indicator Lamp Control Circ.
P065100 Sensor Reference Voltage "B" Circuit Open
P065200 Sensor Reference Voltage "B" Circuit Low
P065300 Sensor Reference Voltage "B" Circuit High
P065400 Engine RPM Output Circuit
P065600 Fuel Level Output Circuit
P065700 Actuator Supply Voltage "A" Circuit/Open
P065800 Actuator Supply Voltage "A" Circuit Low
P065900 Actuator Supply Voltage "A" Circuit High
P066000 Intake Manifold Tuning Control Circuit - Bank1
P066100 Intake Manifold Tuning Control Circuit - Bank1 Low
P066200 Intake Manifold Tuning Control Circuit - Bank1 High
P066600 PCM/ECM/TCM Internal Temperature Sensor "A" Circuit
P066700 PCM/ECM/TCM Internal Temperature Sensor "A" Range/Performance
P066800 PCM/ECM/TCM Internal Temperature Sensor "A" Circuit Low
P066900 PCM/ECM/TCM Internal Temperature Sensor "A" Circuit High
P066A00 Cylinder 1 Glow Plug Control Circuit Low
P066C00 Cylinder 2 Glow Plug Control Circuit Low
P066E00 Cylinder 3 Glow Plug Control Circuit Low
P067000 Glow Plug Module Control Circuit
P067100 Cylinder 1 Glow Plug Circuit
P067200 Cylinder 2 Glow Plug Circuit
P067300 Cylinder 3 Glow Plug Circuit
P067400 Cylinder 4 Glow Plug Circuit
P067500 Cylinder 5 Glow Plug Circuit
P067600 Cylinder 6 Glow Plug Circuit
P067700 Cylinder 7 Glow Plug Circuit
P067800 Cylinder 8 Glow Plug Circuit
P067900 Cylinder 9 Glow Plug Circuit
P067A00 Cylinder 4 Glow Plug Control Circuit Low
P067C00 Cylinder 5 Glow Plug Control Circuit Low
P067E00 Cylinder 6 Glow Plug Control Circuit Low
P068000 Cylinder 10 Glow Plug Circuit
P068100 Cylinder 11 Glow Plug Circuit
P068200 Cylinder 12 Glow Plug Circuit
P068400 Glow Plug Control Module to PCM Comm.Circuit Range/Performance
P068500 EMC/PCM Power Relay Control Circuit Open
P068600 EMC/PCM Power Relay Control Circuit Low
P068700 EMC/PCM Power Relay Control Circuit High
P068800 EMC/PCM Power Relay Sense Circuit Open
P068A00 ECM/PCM Power Relay De-Energized Performance - Too Early
P068B00 ECM/PCM Power Relay De-Energized Performance - Too Late
P068C00 Cylinder 7 Glow Plug Control Circuit Low
P068E00 Cylinder 8 Glow Plug Control Circuit Low
P069100 Cooling Fan 1 Control Circuit Low
P069200 Cooling Fan 1 Control Circuit High
P069300 Cooling Fan 2 Control Circuit Low
P069400 Cooling Fan 2 Control Circuit High
P069700 Sensor Reference Voltage "C" Circuit Open
P069800 Sensor Reference Voltage "C" Circuit Low
P069900 Sensor Reference Voltage "C" Circuit High
P069A00 Cylinder 9 Glow Plug Control Circuit Low
P069C00 Cylinder 10 Glow Plug Control Circuit Low
P06A300 Sensor Reference Voltage "D" Circuit/Open
P06B900 Cylinder 1 Glow Plug Circuit Range/Performance
P06BA00 Cylinder 2 Glow Plug Circuit Range/Performance
P06BB00 Cylinder 3 Glow Plug Circuit Range/Performance
P06BC00 Cylinder 4 Glow Plug Circuit Range/Performance
P06BD00 Cylinder 5 Glow Plug Circuit Range/Performance
P06BE00 Cylinder 6 Glow Plug Circuit Range/Performance
P06BF00 Cylinder 7 Glow Plug Circuit Range/Performance
P06C000 Cylinder 8 Glow Plug Circuit Range/Performance
P06C100 Cylinder 9 Glow Plug Circuit Range/Performance
P06C200 Cylinder 10 Glow Plug Circuit Range/Performance
P06C300 Cylinder 11 Glow Plug Circuit Range/Performance
P06C400 Cylinder 12 Glow Plug Circuit Range/Performance
P06C500 Cylinder 1 Glow Plug Incorrect
P06C600 Cylinder 2 Glow Plug Incorrect
P06C700 Cylinder 3 Glow Plug Incorrect
P06C800 Cylinder 4 Glow Plug Incorrect
P06C900 Cylinder 5 Glow Plug Incorrect
P06CA00 Cylinder 6 Glow Plug Incorrect
P06CB00 Cylinder 7 Glow Plug Incorrect
P06CC00 Cylinder 8 Glow Plug Incorrect
P06CD00 Cylinder 9 Glow Plug Incorrect
P06CE00 Cylinder 10 Glow Plug Incorrect
P06CF00 Cylinder 11 Glow Plug Incorrect
P06D000 Cylinder 12 Glow Plug Incorrect
P06D200 Sensor Reference Voltage "E" Circuit/Open
P06E000 Cylinder 11 Glow Plug Control Circuit Low
P06E200 Cylinder 12 Glow Plug Control Circuit Low
P070000 Transm.Contr.System Malfunction
P070100 Transm.Contr.System Range/Performance
P070200 Transm.Contr.System Electrical
P070300 Torque Converter/Brake Switch B Circ. Malfunction
P070400 Clutch Switch Input Circuit
P070500 Transm.Range Sensor "A" Circ.(PRNDL Inp.) Malfunction
P070600 Transm.Range Sensor "A" Circ. Range/Performance
P070700 Transm.Range Sensor "A" Circ. Low Input
P070800 Transm.Range Sensor "A" Circ. High Input
P071000 Transm.Fluid Temp.Sensor Circ. Malfunction
P071100 Transm.Fluid Temp.Sensor Circ. Range/Performance
P071200 Transm.Fluid Temp.Sensor Circ. Low Input
P071300 Transm.Fluid Temp.Sensor Circ. High Input
P071400 Transm.Fluid Temp.Sensor Circ. Intermittent
P071500 Input Turbine/Speed Sensor "A" Circ.
P071600 Input Turbine/Speed Sensor "A"Circ. Range/Performance
P071700 Input Turbine/Speed Sensor "A"Circ. No Signal
P072000 Output Speed Sensor Circ. Malfunction
P072100 Output Speed Sensor Circ. Range/Performance
P072200 Output Speed Sensor Circ. No Signal
P072500 Engine Speed Input Ciruit
P072600 Engine Speed Inp.Circ. Range/Performance
P072700 Engine Speed Inp.Circ. No Signal
P072900 Gear 6 Incorrect Ratio
P072B00 Stuck in Reverse
P072C00 Stuck in Gear 1
P072D00 Stuck in Gear 2
P072E00 Stuck in Gear 3
P072F00 Stuck in Gear 4
P073000 Gear Incorrect Ratio
P073100 Gear 1 Incorrect Ratio
P073200 Gear 2 Incorrect Ratio
P073300 Gear 3 Incorrect Ratio
P073400 Gear 4 Incorrect Ratio
P073500 Gear 5 Incorrect Ratio
P073600 Reverse Incorrect Ratio
P073A00 Stuck in Gear 5
P073B00 Stuck in Gear 6
P073C00 Stuck in Gear 7
P073E00 Unable to Engage Reverse
P073F00 Unable to Engage Gear 1
P074000 Torque Converter Clutch Circ. Malfunction
P074100 Torque Converter Clutch Circ. Performance or Stuck Off
P074300 Torque Converter Clutch Circ. Electrical
P074600 Pressure Contr.Solenoid A Performance or Stuck Off
P074700 Pressure Contr.Solenoid A Stuck On
P074800 Pressure Contr.Solenoid A Electrical
P074900 Pressure Contr.Solenoid A Intermittent
P074A00 Unable to Engage Gear 2
P074B00 Unable to Engage Gear 3
P074C00 Unable to Engage Gear 4
P074D00 Unable to Engage Gear 5
P074E00 Unable to Engage Gear 6
P074F00 Unable to Engage Gear 7
P075000 Shift Solenoid A Malfunction
P075100 Shift Solenoid A Performance or Stuck Off
P075200 Shift Solenoid A Stuck On
P075300 Shift Solenoid A Electrical
P075400 Shift Solenoid "A" Intermittent
P075600 Shift Solenoid B Performance or Stuck Off
P075700 Shift Solenoid B Stuck On
P075800 Shift Solenoid B Electrical
P076100 Shift Solenoid C Performance or Stuck Off
P076200 Shift Solenoid C Stuck On
P076300 Shift Solenoid C Electrical
P076400 Shift Solenoid "C" Intermittent
P076600 Shift Solenoid D Performance or Stuck Off
P076800 Shift Solenoid D Electrical
P077100 Shift Solenoid E Performance or Stuck Off
P077300 Shift Solenoid E Electrical
P077600 Pressure Contr.Solenoid B Performance or Stuck Off
P077700 Pressure Contr.Solenoid B Stuck On
P077800 Pressure Contr.Solenoid B Electrical
P077900 Pressure Contr.Solenoid B Intermittent
P078000 Shift
P078100 1-2 Shift
P078200 2-3 Shift
P078300 3-4 Shift
P078400 4-5 Shift
P078500 Shift/Timing Solenoid
P079000 Normal/Performance Switch Circ. Malfunction
P079100 Intermediate Shaft Speed Sensor "A" Circuit
P079600 Pressure Contr.Solenoid C Performance or Stuck Off
P079700 Pressure Contr.Solenoid C Stuck On
P079800 Pressure Contr.Solenoid C Electrical
P079900 Pressure Contr.Solenoid C Intermittent
P080500 Clutch Position Sensor Circuit
P080700 Clutch Position Sensor Circuit Low
P080800 Clutch Position Sensor Circuit High
P081000 Clutch Position Control Error
P081100 Excessive Clutch Slippage
P081500 Upshift Switch Circuit
P081600 Downshift Switch Circuit
P081700 Starter Disable Circuit
P082000 Gear Lever X-Y Position Sensor Circuit
P082600 Up and Down Shift Switch Circuit
P082900 5-6 Shift
P084000 Transmission Fluid Pressure Sensor/Switch A
P084100 Transmission Fluid Pressure Sensor/Switch A Range/Performance
P084200 Transmission Fluid Pressure Sensor/Switch "A" Circuit Low
P084300 Transmission Fluid Pressure Sensor/Switch "A" Circuit High
P084400 Transmission Fluid Pressure Sensor/Switch "A" Intermittend
P084500 Transmission Fluid Pressure Sensor/Switch B
P084600 Transmission Fluid Pressure Sensor/Switch B Range/Performance
P084700 Transmission Fluid Pressure Sensor/Switch "B" Circuit Low
P084800 Transmission Fluid Pressure Sensor/Switch "B" Circuit High
P084900 Transmission Fluid Pressure Sensor/Switch "B" Intermittend
P085000 Park/Neutral Switch Input Circuit
P085100 Park/Neutral Switch Input Circuit Low
P085200 Park/Neutral Switch Input Circuit High
P086300 TCM Communication Circuit
P086400 TCM Communication Circuit Range/Performance
P086500 TCM Communication Circuit Low
P086800 Transmission Fluid Pressure Low
P088400 TCM Power Input Signal Intermittent
P088600 TCM Power Relay Control Circuit Low
P088700 TCM Power Relay Control Circuit High
P088900 TCM Power Relay Sense Circuit Range/Performance
P089000 TCM Power Relay Sense Circuit Low
P089100 TCM Power Relay Sense Circuit High
P089200 TCM Power Relay Sense Circuit Intermittent
P089700 Transmission Fluid Deteriorated
P090400 Gate Select Position Circuit
P090500 Gate Select Position Circuit Range/Performance
P090600 Gate Select Position Low
P090700 Gate Select Position Circuit High
P091400 Gear Shift Position Circuit
P091600 Gear Shift Position Circuit Low
P091700 Gear Shift Position Circuit High
P091900 Gear Shift Position Control Error
P092800 Gear Shift Lock Solenoid Control Circuit/Open
P092900 Gear Shift Lock Solenoid Control Circuit Range/Performance
P093000 Gear Shift Lock Solenoid Control Circuit Low
P093100 Gear Shift Lock Solenoid Control Circuit High
P094400 Hydraulic Pressure Unit Loss of Pressure
P094500 Hydraulic Pump Relay Circuit/Open
P094700 Hydraulic Pump Relay Circuit Low
P094800 Hydraulic Pump Relay Circuit High
P0A0900 DC/DC Converter Status Circuit Low
P0A0A00 High Voltage System Inter-Lock Circuit
P0A1F00 Battery Energy Control Module
P0A2A00 Drive Motor "A" Temperature Sensor Circuit
P0A2B00 Drive Motor "A" Temperature Sensor Circuit Range/Performance
P0A2C00 Drive Motor "A" Temperature Sensor Circuit Low
P0A2D00 Drive Motor "A" Temperature Sensor Circuit High
P0A4000 Drive Motor "A" Position Sensor Circuit Range/Performance
P0A4100 Drive Motor "A" Position Sensor Circuit Low
P0A4200 Drive Motor "A" Position Sensor Circuit High
P0A4400 Drive Motor "A" Position Sensor Circuit Overspeed
P0A5200 Drive Motor "A" Current Sensor Circuit Range/Performance
P0A5300 Drive Motor "A" Current Sensor Circuit Low
P0A5400 Drive Motor "A" Current Sensor Circuit High
P0A5D00 Drive Motor "A" Phase U Current
P0A5E00 Drive Motor "A" Phase U Current Low
P0A5F00 Drive Motor "A" Phase U Current High
P0A6000 Drive Motor "A" Phase V Current
P0A6100 Drive Motor "A" Phase V Current Low
P0A6200 Drive Motor "A" Phase V Current High
P0A7E00 Hybrid Battery Pack Over Temperature
P0A7F00 Hybrid Battery Pack Deterioration
P0A8000 Replace Hybrid Battery Pack
P0A8B00 14 Volt Power Module System Voltage
P0A8D00 14 Volt Power Module System Voltage Low
P0A8E00 14 Volt Power Module System Voltage High
P0A9000 Drive Motor "A" Performance
P0A9500 High Voltage Fuse
P0A9D00 Hybrid Battery Temperature Sensor "A" Circuit Low
P0A9E00 Hybrid Battery Temperature Sensor "A" Circuit High
P0AA600 Hybrid Battery Voltage System Isolation Fault
P0AAE00 Hybrid Battery Pack Air Temperature Sensor "A" Circuit Low
P0AAF00 Hybrid Battery Pack Air Temperature Sensor "A" Circuit High
P0AB300 Hybrid Battery Pack Air Temperature Sensor "B" Circuit Low
P0AB400 Hybrid Battery Pack Air Temperature Sensor "B" Circuit High
P0ABB00 Hybrid Battery Pack Voltage Sense "A" Circuit Range/Performance
P0ABC00 Hybrid Battery Pack Voltage Sense "A" Circuit Low
P0ABD00 Hybrid Battery Pack Voltage Sense "A" Circuit High
P0ABF00 Hybrid Battery Pack Current Sensor "A" Circuit
P0AC000 Hybrid Battery Pack Current Sensor "A" Circuit Range/Performance
P0AC100 Hybrid Battery Pack Current Sensor "A" Circuit Low
P0AC200 Hybrid Battery Pack Current Sensor "A" Circuit High
P0AC700 Hybrid Battery Temperature Sensor "B" Circuit Low
P0AC800 Hybrid Battery Temperature Sensor "B" Circuit High
P0AED00 Drive Motor Inverter Temperature Sensor "A" Circuit
P0AEE00 Drive Motor Inverter Temperature Sensor "A" Circuit Range/Performance
P0AEF00 Drive Motor Inverter Temperature Sensor "A" Circuit Low
P0AF000 Drive Motor Inverter Temperature Sensor "A" Circuit High
P0AF800 Hybrid Battery System Voltage
P0AFA00 Hybrid Battery System Voltage Low
P0AFB00 Hybrid Battery System Voltage High
P0AFC00 Hybrid Battery Pack Sensor Module
P0AFD00 Hybrid Battery Pack Temperature Too Low
P0B1500 Hybrid Battery Pack Voltage Sense "B" Circuit Range/Performance
P0B1600 Hybrid Battery Pack Voltage Sense "B" Circuit Low
P0B1700 Hybrid Battery Pack Voltage Sense "B" Circuit High
P0B2400 Hybrid Battery "A" Voltage Unstable
P0B2500 Hybrid Battery "A" Voltage Low
P0B2600 Hybrid Battery "A" Voltage High
P0B2900 Hybrid Battery "B" Voltage Low
P0B2A00 Hybrid Battery "B" Voltage High
P100000 Cyl.9-Fuel Inj.Circ. -N299 Malfunction
P100100 Cyl.10-Fuel Inj.Circ. -N300 Malfunction
P100200 Cyl.11-Fuel Inj.Circ. -N301 Malfunction
P100300 Cyl.12-Fuel Inj.Circ. -N302 Malfunction
P100400 Torque difference cylinder 1 Limiting value exceeded
P100500 Torque difference cylinder 2 Limiting value exceeded
P100600 Torque difference cylinder 3 Limiting value exceeded
P100700 Torque difference cylinder 4 Limiting value exceeded
P100800 Air mass meter 1/2 Implausible signal
P100900 Air mass meter 1/2 implausible signal from load detection
P100A00 Recirculating valve for turbocharger bank 2 Electrical malfunction
P100B00 Recirculating valve for turbocharger bank 2 Short-circuit to ground
P100C00 Recirculating valve for turbocharger bank 2 Short circuit to B+
P100D00 Turbocharger Adjustment difficulty of movement or blocked
P100E00 Torque intervention due to turbocharger protection
P100F00 Fuel injector Mechanical malfunction
P101000 Cyl.9-Fuel Inj.Circ. -N299 Open circuit
P101100 Cyl.10-Fuel Inj.Circ. -N300 Open circuit
P101200 Cyl.11-Fuel Inj.Circ. -N301 Open circuit
P101300 Cyl.12-Fuel Inj.Circ. -N302 Open circuit
P101400 Bypass Flap Filter Valve -N275- Short circuit to B+
P101500 Bypass Flap Filter Valve -N275- Short-circuit to ground
P101600 Bypass Flap Filter Valve -N275- Open circuit
P101700 Intake Manifold Runner Bank 2 Upper stop not reached
P101800 Intake Manifold Runner Bank 2 lower limit not reached
P101900 NOX Sensor -G295 Slow Response
P101A00 Activation of turbocharger adjustment Short circuit to ground/open circuit
P101B00 Activation of turbocharger adjustment Short circuit to B+
P101C00 Activation of turbocharger adjustment bank 2 Short circuit to ground/open circuit
P101D00 Activation of turbocharger adjustment bank 2 Short circuit to B+
P101E00 Rpm limit due to excess temperature
P101F00 Fuel high pressure Maximum exceeded
P102000 Fuel Pressure Regulation Value above upper control limit
P102100 'A' Camshaft Position (Bank 1) Timing Over-Advanced or System Performance
P102200 'A' Camshaft Position (Bank 1) Timing Over-Advanced or System Performance
P102300 Fuel Pressure Regulator Valve Short-circuit to ground
P102400 Fuel Pressure Regulator Valve Open circuit
P102500 Fuel Pressure Regulator Valve Mechanical malfunction
P102600 Intake manifold Runner Control (IMRC) Short circuit to B+
P102700 Intake manifold Runner Control (IMRC) Short-circuit to ground
P102800 Intake manifold Runner Control (IMRC) Open circuit
P102900 Intake Manifold Runner Control (IMRC) Valve -N316- Upper stop not reached
P102A00 Torque limitation due to coolant temperature
P102B00 Torque limitation due to engine oil temperature
P102C00 Torque limitation due to fuel temperature
P102D00 Torque limitation due to intake air temperature
P102E00 Torque limitation due to exhaust temperature
P103000 Intake Manifold Runner Control (IMRC) Valve -N316- lower limit not reached
P103100 Intake Manifold Runner Control (IMRC) Valve -N316- Target value not reached
P103200 NOX Sensor Signal too high
P103300 NOX Sensor Signal too low
P103400 NOX Sensor Signal outside tolerance
P103500 NOX Sensor Implausible signal
P103600 Heater activation sensor for NOX Short circuit to B+
P103700 Heater activation sensor for NOX Short-circuit to ground
P103800 Heater activation sensor for NOX Open circuit
P103900 Fuel Injector Group "A" Supply Voltage Circuit Short circuit
P104000 Fuel Injector Group "A" Supply Voltage Circuit Malfunction
P104100 Fuel Injector Group "B" Supply Voltage Circuit Short circuit
P104200 Fuel Injector Group "B" Supply Voltage Circuit Malfunction
P104300 Fuel Injector Group -C- Supply Voltage Circuit Short circuit
P104400 Fuel Injector Group C - Supply voltage circuit Malfunction
P104500 Fuel Injector Group -D- Supply Voltage Circuit Short circuit
P104600 Fuel Injector Group -D- Supply Voltage Circuit Malfunction
P104700 Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Malfunction
P104800 Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Short circuit to B+
P104900 Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Short-circuit to ground
P105000 Bank1, Camshaft Adjustment Valve 1 (exhaust) -N318- Open circuit
P105100 Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Malfunction
P105200 Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Short circuit to B+
P105300 Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Short-circuit to ground
P105400 Bank2, Camshaft Adjustment Valve2 (exhaust) -N319- Open circuit
P105500 Bank 1, camshaft adjustment, exhaust Short circuit to B+
P105600 Bank 1, camshaft adjustment, exhaust Short-circuit to ground
P105700 Bank 1, camshaft adjustment, exhaust Open circuit
P105800 Bank2, camshaft adjustment, exhaust Short circuit to B+
P105900 Bank2, camshaft adjustment, exhaust Short-circuit to ground
P106000 Bank2, camshaft adjustment, exhaust Open circuit
P106100 'A' Camshaft Position (Bank 2) Timing Over-Advanced or System Performance
P106200 'A' Camshaft Position (Bank 2) Timing Over-Advanced or System Performance
P106300 Fuel Pressure Regulation Value below lower control limit
P106400 Fuel pressure system Mechanical malfunction
P106500 Fuel Pressure Regulation Control difference
P106600 Intake Air Switch-over valve -N335- Short circuit to B+
P106700 Intake Air Switch-over valve -N335- Short-circuit to ground
P106800 Intake Air Switch-over valve -N335- Open circuit
P106900 NOX Sensor -G295- heating control signal Short-circuit to ground
P106A00 Bank 2 Intake manifold press/air mass <-> throttle valve angle deviation
P106B00 Throttle valve difficulty of movement or blocked
P106C00 Throttle valve 2 difficulty of movement or blocked
P107000 NOX Sensor -G295- heating control signal Short circuit to B+
P107100 NOX Sensor -G295- heating control signal Implausible signal
P107200 NOX Sensor -G295- heating control signal Electrical malfunction in circuit
P107300 Mass Air Flow (MAF) Sensor 2 -G246 Signal too low
P107400 Mass Air Flow (MAF) Sensor 2 -G246 Signal too high
P107500 Oxygen sensor control, emissions bank 3 System too lean
P107600 Oxygen sensor control, emissions bank 3 System too rich
P107700 Oxygen sensor control, emissions bank 4 System too lean
P107800 Oxygen sensor control, emissions bank 4 System too rich
P107900 Oxygen sensor control, emissions bank 3 Implausible control value
P108000 Oxygen sensor control, emissions bank 4 Implausible control value
P108100 Exhaust bank3, mixture adaptation range 1 System too lean
P108200 Exhaust bank3, mixture adaptation range 2 System too lean
P108300 Exhaust bank3, mixture adaptation range 1 System too rich
P108400 Exhaust bank3, mixture adaptation range 2 System too rich
P108500 Exhaust bank4, mixture adaptation range 1 System too lean
P108600 Exhaust bank4, mixture adaptation range 2 System too lean
P108700 Exhaust bank4, mixture adaptation range 1 System too rich
P108800 Exhaust bank4, mixture adaptation range 2 System too rich
P108900 Bank2, mixture adaptation range 1 System too lean
P109000 Bank2, mixture adaptation range 2 System too lean
P109100 Bank2, mixture adaptation range 1 System too rich
P109200 Bank2, mixture adaptation range 2 System too rich
P109300 Bank1, fuel measuring system 2 Malfunction
P109400 Bank2, fuel measuring system 2 Malfunction
P109500 Intake Manifold Runner Position Sensor -G336 Short circuit to B+
P109600 Intake Manifold Runner Position Sensor -G336 Short-circuit to ground
P109700 Intake Manifold Runner Position Sensor -G336 Open circuit
P109800 Intake Manifold Runner Position Sensor -G336 Open circuit/short circuit to B+
P109900 Intake manifold Runner Control (IMRC) Electrical malfunction
P10A000 Actuation regulating flap for intake air Electrical malfunction
P10A100 Actuation regulating flap for intake air Short circuit to B+
P10A200 Actuation regulating flap for intake air Short-circuit to ground
P10A300 Actuation regulating flap for intake air Open circuit
P10A400 Regulating flap for intake air Mechanical malfunction
P10A500 Potentiometer regulating flap for intake air Signal too high
P10A600 Potentiometer regulating flap for intake air Signal too low
P10A700 Adaptation regulating flap for intake air soiled
P10A800 Adaptation regulating flap for intake air lower limit not reached
P10A900 Magnetic clutch for mechanical charger does not open
P10AA00 Magnetic clutch for mechanical charger does not close
P10AB00 Magnetic clutch for mechanical charger excessive wear
P10AC00 Magnetic clutch for mechanical charger Short-circuit to ground
P10AD00 Magnetic clutch for mechanical charger Open circuit
P10AE00 Current sensor for magnetic clutch for mechanical charger Electrical malfunction
P10AF00 Magnetic clutch for mechanical charger Malfunction
P10B000 Magnetic clutch for mechanical charger Short circuit to B+
P10B100 Monitoring of fuel injector for cylinder 1 failure detected
P10B200 Monitoring of fuel injector for cylinder 2 failure detected
P10B300 Monitoring of fuel injector for cylinder 3 failure detected
P10B400 Monitoring of fuel injector for cylinder 4 failure detected
P110000 O2 Sensor Heater Circ.,Bank1-Sensor2 Performance too low
P110100 O2 Sensor Circuit,Bank1-Sensor1 Voltage too low/air leak
P110200 O2 Sensor Heater Circ.,Bank1-Sensor1 Short circuit to B+
P110300 O2 Sensor Heater Circ.,Bank1-Sensor1 Performance too low
P110400 O2 Sensor Circuit,Bank1-Sensor2 Voltage too low/air leak
P110500 O2 Sensor Heater Circ.,Bank1-Sensor2 Short circuit to B+
P110600 O2 Sensor Circuit,Bank2-Sensor1 Voltage too low/air leak
P110700 O2 Sensor Heater Circ.,Bank2-Sensor1 Short circuit to B+
P110800 O2 Sensor Heater Circ.,Bank2-Sensor1 Performance too low
P110900 O2 Sensor Circuit,Bank2-Sensor2 Voltage too low/air leak
P110A00 Fuel Pressure Regulator Valve Short-circuit to ground
P110B00 Fuel Pressure Regulator Valve Open circuit
P110C00 Fuel Pressure Regulator Valve Mechanical malfunction
P110D00 Intake manifold Runner Control (IMRC) Short circuit to B+
P110E00 Intake manifold Runner Control (IMRC) Short-circuit to ground
P110F00 Intake manifold Runner Control (IMRC) Open circuit
P111000 O2 Sensor Heater Circ.,Bank2-Sensor2 Short circuit to B+
P111100 Oxygen sensor control (Bank 1) System too lean
P111200 Oxygen sensor control (Bank 1) System too rich
P111300 Bank 1, sensor 1 Internal resistance too Large
P111400 Bank 1, sensor 2 Internal resistance too Large
P111500 O2 Sensor Heater Circ.,Bank1-Sensor1 Short-circuit to ground
P111600 O2 Sensor Heater Circ.,Bank1-Sensor1 Open circuit
P111700 O2 Sensor Heater Circ.,Bank1-Sensor2 Short-circuit to ground
P111800 O2 Sensor Heater Circ.,Bank1-Sensor2 Open circuit
P111900 O2 Sensor Heater Circ.,Bank2-Sensor1 Short-circuit to ground
P111A00 NOX Sensor -G295 Signal too low
P111B00 NOX Sensor -G295 Signal outside tolerance
P111C00 NOX Sensor -G295 Implausible signal
P111D00 Heater activation sensor for NOX Short circuit to B+
P111E00 Heater activation sensor for NOX Short-circuit to ground
P111F00 Heater activation sensor for NOX Open circuit
P112000 O2 Sensor Heater Circ.,Bank2-Sensor1 Open circuit
P112100 O2 Sensor Heater Circ.,Bank2-Sensor2 Short-circuit to ground
P112200 O2 Sensor Heater Circ.,Bank2-Sensor2 Open circuit
P112300 Long Term Fuel Trim Add.Air.,Bank1 System too rich
P112400 Long Term Fuel Trim Add.Air.,Bank1 System too lean
P112500 Long Term Fuel Trim Add.Air.,Bank2 System too rich
P112600 Long Term Fuel Trim Add.Air.,Bank2 System too lean
P112700 Long Term Fuel Trim mult.,Bank1 System too rich
P112800 Long Term Fuel Trim mult.,Bank1 System too lean
P112900 Long Term Fuel Trim mult.,Bank2 System too rich
P113000 Long Term Fuel Trim mult.,Bank2 System too lean
P113100 Bank 2, sensor 1 Internal resistance too Large
P113200 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Short circuit to B+
P113300 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Malfunction
P113400 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Short circuit to B+
P113500 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Malfunction
P113600 Long Term Fuel Trim Add.Fuel,Bank1 System too lean
P113700 Long Term Fuel Trim Add.Fuel,Bank1 System too rich
P113800 Long Term Fuel Trim Add.Fuel,Bank2 System too lean
P113900 Long Term Fuel Trim Add.Fuel,Bank2 System too rich
P114000 Bank 2, sensor 2 Internal resistance too Large
P114100 Load detection implausible value
P114200 Load detection value below lower limit
P114300 Load detection value above upper limit
P114400 Mass Air Flow (MAF) Sensor -G70- Open circuit/short circuit to ground
P114500 Mass Air Flow (MAF) Sensor -G70- Short circuit to B+
P114600 Mass Air Flow (MAF) Sensor -G70- Supply voltage
P114700 Oxygen sensor control, Bank 2 System too lean
P114800 Oxygen sensor control, Bank 2 System too rich
P114900 Oxygen sensor control, Bank 1 Implausible control value
P115000 Oxygen sensor control, Bank 2 Implausible control value
P115100 Bank1, mixture adaptation, range 1 System too lean
P115200 Bank1, mixture adaptation, range 2 System too lean
P115300 Oxygen sensors behind catalytic converter Swapped
P115400 Two-path intake manifold Malfunction
P115500 Manifold Absolute Pressure (MAP) Sensor -G71 Short circuit to B+
P115600 Manifold Absolute Pressure (MAP) Sensor -G71 Open circuit/short circuit to ground
P115700 Manifold Absolute Pressure (MAP) Sensor -G71 Supply voltage
P115800 Manifold Absolute Pressure (MAP) Sensor -G71 Implausible signal
P115900 Signal of Mass Air Flow (MAF) sensor 1/2 Implausible relation
P115A00 Manifold Absolute Pressure (MAP) Sensor 2 Implausible signal
P115B00 Manifold Absolute Pressure (MAP) Sensor 2 Signal too low
P115C00 Manifold Absolute Pressure (MAP) Sensor 2 Signal too high
P115D00 Sensor 2 for air pressure Implausible signal
P115E00 Sensor 2 for air pressure Signal too low
P115F00 Sensor 2 for air pressure Signal too high
P116000 Manifold Temp.Sensor Circ. -G72 Short-circuit to ground
P116100 Manifold Temp.Sensor Circ. -G72 Open circuit/short circuit to B+
P116200 Fuel Temperature Sensor A Circuit Low Input -G81 Short-circuit to ground
P116300 Fuel Temperature Sensor A Circuit Low Input -G81 Open circuit/short circuit to B+
P116400 Fuel Temperature Sensor A Circuit Low Input -G81 Implausible signal
P116500 Bank1, mixture adaptation, range 1 System too rich
P116600 Bank1, mixture adaptation, range 2 System too rich
P116700 Mass Air Flow (MAF) Sensor 2 -G246 Implausible signal
P116800 Mass Air Flow (MAF) Sensor 2 -G246 Open circuit/short circuit to ground
P116900 Mass Air Flow (MAF) Sensor 2 -G246 Short circuit to B+
P116A00 Intake manifold press./air press. - Throttle valve pos. bank 2 Correlation at idle
P116B00 Intake manifold press./air press. - Throttle valve pos. bank 2 Correlation in partial throttle
P116C00 Leaking air in intake system, bank 2
P116F00 Mass air flow sensor interrupted signal
P117000 Mass Air Flow (MAF) Sensor 2 -G246 Supply voltage
P117100 Throttle/Pedal Position Sensor/Switch -B- Circuit -G188 Implausible signal
P117200 Throttle/Pedal Position Sensor/Switch -B- Circuit -G188 Signal too low
P117300 Throttle/Pedal Position Sensor/Switch -B- Circuit -G188 Signal too high
P117400 Bank 1, fuel calculation system Injection Timing Deviation
P117500 Pre-injection switched off
P117600 O2 Correction Behind Catalyst,B1 Control limit reached
P117700 O2 Correction Behind Catalyst,B2 Control limit reached
P117800 Linear oxygen sensor/pump current Open circuit
P117900 Linear oxygen sensor/pump current Short-circuit to ground
P117A00 Bank1, Lambda correction center sensor Control limit reached
P117B00 Bank2, Lambda correction center sensor Control limit reached
P117C00 Bank3,oxygen sensor correction behind cat Lean control limit exceeded
P117D00 Bank3,oxygen sensor correction behind cat Rich control limit exceeded
P117E00 Bank4,oxygen sensor correction behind cat Lean control limit exceeded
P117F00 Bank4,oxygen sensor correction behind cat Rich control limit exceeded
P118000 Linear oxygen sensor/pump current Short circuit to B+
P118100 Linear oxygen sensor/reference voltage Open circuit
P118200 Linear oxygen sensor/reference voltage Short-circuit to ground
P118300 Linear oxygen sensor/reference voltage Short circuit to B+
P118400 linear Lambda probe / common ground wire Open circuit
P118500 linear Lambda probe / common ground wire Short-circuit to ground
P118600 linear Lambda probe / common ground wire Short circuit to B+
P118700 linear Lambda probe/compensat. resistor Open circuit
P118800 linear Lambda probe/compensat. resistor Short-circuit to ground
P118900 linear Lambda probe/compensat. resistor Short circuit to B+
P118A00 Bank3-sensor1 Voltage too low/air leak
P118B00 Bank4-sensor1 Voltage too low/air leak
P119000 Linear oxygen sensor/reference voltage Implausible
P119100 linear Lambda probe before catalyst swapped
P119200 Fuel Pressure Sensor -G247- Supply voltage
P119300 Fuel Pressure Sensor -G247- Open circuit/short circuit to B+
P119400 Fuel Pressure Regulator Valve Short circuit to B+
P119500 Fuel Pressure Regulator Valve Open circuit/short circuit to ground
P119600 O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
P119700 O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
P119800 O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction
P119900 O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction
P119A00 Fuel Pressure Sensor -G247- Malfunction
P119B00 Fuel pressure sensor 2 Malfunction
P119C00 Fuel Volume Regulator Control Exceeded Learning lower Limit
P119D00 Fuel Volume Regulator Control Exceeded Learning upper Limit
P11A100 Cam Shift Actuator "A" Cylinder 1 Circuit/Open
P11A200 Cam Shift Actuator "A" Cylinder 1 Range/Performance
P11A300 Cam Shift Actuator "B" Cylinder 1 Circuit/Open
P11A400 Cam Shift Actuator "B" Cylinder 1 Range/Performance
P11A500 Cam Shift Actuator "A" Cylinder 2 Circuit/Open
P11A600 Cam Shift Actuator "A" Cylinder 2 Range/Performance
P11A700 Cam Shift Actuator "B" Cylinder 2 Circuit/Open
P11A800 Cam Shift Actuator "B" Cylinder 2 Range/Performance
P11A900 Cam Shift Actuator "A" Cylinder 3 Circuit/Open
P11AA00 Cam Shift Actuator "A" Cylinder 3 Range/Performance
P11AB00 Cam Shift Actuator "B" Cylinder 3 Circuit/Open
P11AC00 Cam Shift Actuator "B" Cylinder 3 Range/Performance
P11AD00 Cam Shift Actuator "A" Cylinder 4 Circuit/Open
P11AE00 Cam Shift Actuator "A" Cylinder 4 Range/Performance
P11AF00 Cam Shift Actuator "B" Cylinder 4 Circuit/Open
P11B000 Cam Shift Actuator "B" Cylinder 4 Range/Performance
P11B100 Cam Shift Actuator "A" Cylinder 5 Circuit/Open
P11B200 Cam Shift Actuator "A" Cylinder 5 Range/Performance
P11B300 Cam Shift Actuator "B" Cylinder 5 Circuit/Open
P11B400 Cam Shift Actuator "B" Cylinder 5 Range/Performance
P11B500 Cam Shift Actuator "A" Cylinder 6 Circuit/Open
P11B600 Cam Shift Actuator "A" Cylinder 6 Range/Performance
P11B700 Cam Shift Actuator "B" Cylinder 6 Circuit/Open
P11B800 Cam Shift Actuator "B" Cylinder 6 Range/Performance
P11B900 Camshaft adjustment bank 1 Supply voltage
P11BA00 Camshaft adjustment bank 2 Supply voltage
P120000 Recirculating valve for turbocharger -N249, Mechanical malfunction
P120100 Cylinder 1 Fuel Injector -N30- electrical malfunction in circuit
P120200 Cylinder 2 Fuel Injector -N31- electrical malfunction in circuit
P120300 Cylinder 3 Fuel Injector -N32- electrical malfunction in circuit
P120400 Cylinder 4 Fuel Injector -N33- electrical malfunction in circuit
P120500 Cylinder 5 Fuel Injector -N83- electrical malfunction in circuit
P120600 Cylinder 6 Fuel Injector -N84- electrical malfunction in circuit
P120700 Cylinder 7 Fuel Injector -N85- electrical malfunction in circuit
P120800 Cylinder 8 Fuel Injector -N86- electrical malfunction in circuit
P120900 Cylinder Shut-off, Intake Deactivation Valves Short-circuit to ground
P120A00 Injectors control module 1 Electrical malfunction in circuit
P120B00 Injectors control module 2 Electrical malfunction in circuit
P120C00 Injectors control module 1 Short circuit between activation wires, Low-Side
P120D00 Injectors control module 2 Short circuit between activation wires, Low-Side
P121000 Cylinder Shut-off, Intake Deactivation Valves Short circuit to B+
P121100 Cylinder Shut-off, Intake Deactivation Valves Open circuit
P121200 Cylinder shut-off, bank 1
P121300 Cylinder 1 Fuel Injector -N30- Short circuit to B+
P121400 Cylinder 2 Fuel Injector -N31- Short circuit to B+
P121500 Cylinder 3 Fuel Injector -N32- Short circuit to B+
P121600 Cylinder 4 Fuel Injector -N33- Short circuit to B+
P121700 Cylinder 5 Fuel Injector -N83- Short circuit to B+
P121800 Cylinder 6 Fuel Injector -N84- Short circuit to B+
P121900 Cylinder 7 Fuel Injector -N85- Short circuit to B+
P122000 Cylinder 8 Fuel Injector -N86- Short circuit to B+
P122100 Cylinder Shut-off, Exhaust Deactivation Valves Short-circuit to ground
P122200 Cylinder Shut-off, Exhaust Deactivation Valves Short circuit to B+
P122300 Cylinder Shut-off, Exhaust Deactivation Valves Open circuit
P122400 Cylinder shut-off, bank 2
P122500 Cylinder 1 Fuel Injector -N30- Short-circuit to ground
P122600 Cylinder 2 Fuel Injector -N31- Short-circuit to ground
P122700 Cylinder 3 Fuel Injector -N32- Short-circuit to ground
P122800 Cylinder 4 Fuel Injector -N33- Short-circuit to ground
P122900 Cylinder 5 Fuel Injector -N83- Short-circuit to ground
P123000 Cylinder 6 Fuel Injector -N84- Short-circuit to ground
P123100 Cylinder 7 Fuel Injector -N85- Short-circuit to ground
P123200 Cylinder 8 Fuel Injector -N86- Short-circuit to ground
P123300 Load detection Malfunction
P123400 fuel lead missing
P123500 O2 Correction Behind Catalyst, exhaust gas bank 3 Control limit reached
P123600 O2 Correction Behind Catalyst, exhaust gas bank 4 Control limit reached
P123700 Cylinder 1 Fuel Injector -N30- Open circuit
P123800 Cylinder 2 Fuel Injector -N31- Open circuit
P123900 Cylinder 3 Fuel Injector -N32- Open circuit
P124000 Cylinder 4 Fuel Injector -N33- Open circuit
P124100 Cylinder 5 Fuel Injector -N83- Open circuit
P124200 Cylinder 6 Fuel Injector -N84- Open circuit
P124300 Cylinder 7 Fuel Injector -N85- Open circuit
P124400 Cylinder 8 Fuel Injector -N86- Open circuit
P124500 Needle Lift Sensor -G80 Short-circuit to ground
P124600 Needle Lift Sensor -G80 Implausible signal
P124700 Needle Lift Sensor -G80 Open circuit/short circuit to B+
P124800 Commencement of injection regulation Control difference
P124900 Fuel consumption signal Electrical malfunction in circuit
P125000 Fuel level too low
P125100 Commencement of injection valve -N108 Short circuit to B+
P125200 Commencement of injection valve -N108 Open circuit/short circuit to ground
P125300 Fuel consumption signal Short-circuit to ground
P125400 Fuel consumption signal Short circuit to B+
P125500 Engine Coolant Temperature (ECT) Sensor -G62 Short-circuit to ground
P125600 Engine Coolant Temperature (ECT) Sensor -G62 Open circuit/short circuit to B+
P125700 Coolant Thermostat/Valve. Open circuit
P125800 Coolant Thermostat/Valve. Short circuit to B+
P125900 Coolant Thermostat/Valve. Short-circuit to ground
P125E00 Valve for pump/injector Short circuit control wire
P125F00 Valve for pump/injector not completely discharged
P126000 Unit injector solenoid valve - cylinder 1-N240 Implausible signal
P126100 Unit injector solenoid valve - cylinder 1-N240 Value above upper control limit
P126200 Unit injector solenoid valve - cylinder 1-N240 Value below lower control limit
P126300 Unit injector solenoid valve - cylinder 2-N241 Implausible signal
P126400 Unit injector solenoid valve - cylinder 2-N241 Value above upper control limit
P126500 Unit injector solenoid valve - cylinder 2-N241 Value below lower control limit
P126600 Unit injector solenoid valve - cylinder 3-N242 Implausible signal
P126700 Unit injector solenoid valve - cylinder 3-N242 Value above upper control limit
P126800 Unit injector solenoid valve - cylinder 3-N242 Value below lower control limit
P126900 Unit injector solenoid valve - cylinder 4-N243 Implausible signal
P127000 Unit injector solenoid valve - cylinder 4-N243 Value above upper control limit
P127100 Unit injector solenoid valve - cylinder 4-N243 Value below lower control limit
P127200 Unit injector solenoid valve - cylinder 5-N244 Implausible signal
P127300 Unit injector solenoid valve - cylinder 5-N244 Value above upper control limit
P127400 Unit injector solenoid valve - cylinder 5-N244 Value below lower control limit
P127500 Unit injector solenoid valve - cylinder 6-N245 Implausible signal
P127600 Unit injector solenoid valve - cylinder 6-N245 Value above upper control limit
P127700 Unit injector solenoid valve - cylinder 6-N245 Value below lower control limit
P127800 Fuel Metering Valve Short circuit to B+
P127900 Fuel Metering Valve Open circuit/short circuit to ground
P128000 Fuel Inj.Air Contr.Valve Circ. -N212 Flow too Low
P128100 Fuel Metering Valve Short-circuit to ground
P128200 Fuel Metering Valve Open circuit
P128300 Fuel Inj.Air Contr.Valve Circ. -N212 electrical malfunction in circuit
P128400 Fuel Inj.Air Contr.Valve Circ. -N212 Open circuit
P128500 Fuel Inj.Air Contr.Valve Circ. -N212 Short-circuit to ground
P128600 Fuel Inj.Air Contr.Valve Circ. -N212 Short circuit to B+
P128700 Recirculating valve for turbocharger -N249, Open circuit
P128800 Recirculating valve for turbocharger -N249, Short circuit to B+
P128900 Recirculating valve for turbocharger -N249, Short-circuit to ground
P128F00 A/C Engine Coolant Temperature (ECT) Sensor -Radiator Outlet Electrical malfunction
P129000 Engine Coolant Temperature (ECT) Sensor (on Radiator) -G83- Signal too high
P129100 Engine Coolant Temperature (ECT) Sensor (on Radiator) -G83- Signal too low
P129200 Map Controlled Engine Cooling Thermostat -F265- Open circuit
P129300 Map Controlled Engine Cooling Thermostat -F265- Short circuit to B+
P129400 Map Controlled Engine Cooling Thermostat -F265- Short-circuit to ground
P129500 Bypass turbocharger Throughput faulty
P129600 Malfunction in cooling system
P129700 Connection charger-throttle valve Pressure drop
P129800 Engine Coolant Temperature (ECT) Sensor (on Radiator) -G83- Implausible signal
P129900 Fuel Metering Valve Malfunction
P129A00 Fuel Pressure Regulator Valve -N276, Bank 2 Mechanical malfunction
P129B00 Fuel Pressure Regulator Valve -N276, Bank 2 Open circuit
P129C00 Fuel Pressure Regulator Valve -N276, Bank 2 Short-circuit to ground
P129D00 Fuel Pressure Regulator Valve -N276, Bank 2 Short circuit to B+
P129E00 Low Pressure Fuel System Pressure Too Low
P129F00 Low Pressure Fuel System Pressure Too High
P12A000 Low Pressure Fuel System Performance
P130000 Random/Multiple Cylinder. Misfire Detected Reason: Low fuel
P130100 Cyl.9-Knock Contr Control limit reached
P130200 Cyl.10-Knock Contr Control limit reached
P130300 Cyl.11-Knock Contr Control limit reached
P130400 Cyl.12-Knock Contr Control limit reached
P130500 Ignition control cylinder 9 Open circuit
P130600 Ignition control cylinder 9 Short circuit to B+
P130700 Ignition control cylinder 9 Short-circuit to ground
P130800 Ignition control cylinder 10 Open circuit
P130900 Ignition control cylinder 10 Short circuit to B+
P130A00 Hide cylinder
P131000 Ignition control cylinder 10 Short-circuit to ground
P131100 Ignition control cylinder 11 Open circuit
P131200 Ignition control cylinder 11 Short circuit to B+
P131300 Ignition control cylinder 11 Short-circuit to ground
P131400 Ignition control cylinder 12 Open circuit
P131500 Ignition control cylinder 12 Short circuit to B+
P131600 Ignition control cylinder 12 Short-circuit to ground
P131700 Cyl.13-Knock Contr Control limit reached
P131800 Cyl.14-Knock Contr Control limit reached
P131900 Knock Sensor (KS) 1 -G61 Short-circuit to ground
P132000 Knock Sensor (KS) 2 -G66 Short-circuit to ground
P132100 Knock Sensor (KS) 3 -G198 Signal too low
P132200 Knock Sensor (KS) 3 -G198 Signal too high
P132300 Knock Sensor (KS) 4 -G199 Signal too low
P132400 Knock Sensor (KS) 4 -G199 Signal too high
P132500 Cyl.1-Knock Contr Control limit reached
P132600 Cyl.2-Knock Contr Control limit reached
P132700 Cyl.3-Knock Contr Control limit reached
P132800 Cyl.4-Knock Contr Control limit reached
P132900 Cyl.5-Knock Contr Control limit reached
P132A00 Knock Sensor (KS) 3 Electrical malfunction in circuit
P132B00 Knock Sensor (KS) 4 Electrical malfunction in circuit
P133000 Cyl.6-Knock Contr Control limit reached
P133100 Cyl.7-Knock Contr Control limit reached
P133200 Cyl.8-Knock Contr Control limit reached
P133300 Cyl.15-Knock Contr Control limit reached
P133400 Cyl.16-Knock Contr Control limit reached
P133500 Engine torque monitoring 2 Value above upper control limit
P133600 Engine torque monitoring Value above upper control limit
P133700 Camshaft Pos. (CMP) Sensor, Bank1=>-G40 Short-circuit to ground
P133800 Camshaft Pos. (CMP) Sensor, Bank1=>-G40 Open circuit/short circuit to B+
P133900 Crankshaft Pos./Engine Speed Sensor swapped
P134000 Camshaft Position Sensor-G40,Engine Speed Sensor-G28 Incorrect allocation
P134100 Ignition output 1 Short-circuit to ground
P134200 Ignition output 1 Short circuit to B+
P134300 Ignition output 2 Short-circuit to ground
P134400 Ignition output 2 Short circuit to B+
P134500 Ignition output 3 Short-circuit to ground
P134600 Ignition output 3 Short circuit to B+
P134700 Camshaft Position Sensor 2-G163/Engine Speed (RPM) Sensor -G28 Incorrect allocation
P134800 Ignition output 1 Open circuit
P134900 Ignition output 2 Open circuit
P135000 Ignition output 3 Open circuit
P135100 Camshaft Pos. (CMP) Sensor, Bank1=>-G40 Implausible signal during start
P135200 Bank1, camshaft adjustment Specification not reached
P135300 Engine Coolant Temperature/Intake Air Temperature Correlation
P135400 Modulating piston movement sender -G149 electrical malfunction in circuit
P135500 Ignition control cylinder 1 Open circuit
P135600 Ignition control cylinder 1 Short circuit to B+
P135700 Ignition control cylinder 1 Short-circuit to ground
P135800 Ignition control cylinder 2 Open circuit
P135900 Ignition control cylinder 2 Short circuit to B+
P136000 Ignition control cylinder 2 Short-circuit to ground
P136100 Ignition control cylinder 3 Open circuit
P136200 Ignition control cylinder 3 Short circuit to B+
P136300 Ignition control cylinder 3 Short-circuit to ground
P136400 Ignition control cylinder 4 Open circuit
P136500 Ignition control cylinder 4 Short circuit to B+
P136600 Ignition control cylinder 4 Short-circuit to ground
P136700 Ignition control cylinder 5 Open circuit
P136800 Ignition control cylinder 5 Short circuit to B+
P136900 Ignition control cylinder 5 Short-circuit to ground
P137000 Ignition control cylinder 6 Open circuit
P137100 Ignition control cylinder 6 Short circuit to B+
P137200 Ignition control cylinder 6 Short-circuit to ground
P137300 Ignition control cylinder 7 Open circuit
P137400 Ignition control cylinder 7 Short circuit to B+
P137500 Ignition control cylinder 7 Short-circuit to ground
P137600 Ignition control cylinder 8 Open circuit
P137700 Ignition control cylinder 8 Short circuit to B+
P137800 Ignition control cylinder 8 Short-circuit to ground
P137900 Cylinder 13 Random/Multiple Cylinder. Misfire Detected
P138000 Cylinder 14 Random/Multiple Cylinder. Misfire Detected
P138100 Cylinder 15 Random/Multiple Cylinder. Misfire Detected
P138200 Cylinder 16 Random/Multiple Cylinder. Misfire Detected
P138300 Portion of alternative fuels not adapted
P138400 Engine control module 2 faulty
P138500 Control module defective
P138600 Control module defective
P138700 Control module defective
P138800 Control module defective
P138900 Diesel Direct Fuel Injection (DFI) Engine ECM 2 -J494- Defective
P139100 Camshaft Pos. (CMP) Sensor, Bank2=>-G163 Short-circuit to ground
P139200 Camshaft Pos. (CMP) Sensor, Bank2=>-G163 Open circuit/short circuit to B+
P139300 Ignition output 1 electrical malfunction in circuit
P139400 Ignition output 2 electrical malfunction in circuit
P139500 Ignition output 3 electrical malfunction in circuit
P139600 Engine speed sender -G28 Range/Performance
P139700 Sensor Wheel for Engine Speed adaptation limit reached
P139800 Engine speed signal, TD Short-circuit to ground
P139900 Engine speed signal, TD Short circuit to B+
P139A00 Engine speed (RPM) validation
P13A000 Signal wire 1 ion current system bank 1 Short circuit to B+
P13A100 Signal wire 2 ion current system bank 1 Short circuit to B+
P13A200 Signal wire 1 ion current system bank 1 Short-circuit to ground
P13A300 Signal wire 2 ion current system bank 1 Short-circuit to ground
P13A400 Signal wire 1 ion current system bank 2 Short circuit to B+
P13A500 Signal wire 2 ion current system bank 2 Short circuit to B+
P13A600 Signal wire 1 ion current system bank 2 Short-circuit to ground
P13A700 Signal wire 2 ion current system bank 2 Short-circuit to ground
P13A800 Ion current system cylinder 1 Trouble code detected?
P13A900 Ion current system cylinder 1 Implausible signal
P13AA00 Ion current system cylinder 2 Trouble code detected?
P13AB00 Ion current system cylinder 2 Implausible signal
P13AC00 Ion current system cylinder 3 Trouble code detected?
P13AD00 Ion current system cylinder 3 Implausible signal
P13AE00 Ion current system cylinder 4 Trouble code detected?
P13AF00 Ion current system cylinder 4 Implausible signal
P13B000 Ion current system cylinder 5 Trouble code detected?
P13B100 Ion current system cylinder 5 Implausible signal
P13B200 Ion current system cylinder 6 Trouble code detected?
P13B300 Ion current system cylinder 6 Implausible signal
P13B400 Ion current system cylinder 7 Trouble code detected?
P13B500 Ion current system cylinder 7 Implausible signal
P13B600 Ion current system cylinder 8 Trouble code detected?
P13B700 Ion current system cylinder 8 Implausible signal
P13B800 Ion current system cylinder 9 Trouble code detected?
P13B900 Ion current system cylinder 9 Implausible signal
P13BA00 Ion current system cylinder 10 Trouble code detected?
P13BB00 Ion current system cylinder 10 Implausible signal
P13BC00 Ion current system cylinder 11 Trouble code detected?
P13BD00 Ion current system cylinder 11 Implausible signal
P13BE00 Ion current system cylinder 12 Trouble code detected?
P13BF00 Ion current system cylinder 12 Implausible signal
P13C000 Ion current system cylinder 13 Trouble code detected?
P13C100 Ion current system cylinder 13 Implausible signal
P13C200 Ion current system cylinder 14 Trouble code detected?
P13C300 Ion current system cylinder 14 Implausible signal
P13C400 Ion current system cylinder 15 Trouble code detected?
P13C500 Ion current system cylinder 15 Implausible signal
P13C600 Ion current system cylinder 16 Trouble code detected?
P13C700 Ion current system cylinder 16 Implausible signal
P13C800 Ion current system bank 1, Initialization error channel 1
P13C900 Ion current system bank 1, Initialization error channel 2
P13CA00 Ion current system bank 1, Initialization error channel 1/2
P13CB00 Ion current system bank 2, Initialization error channel 1
P13CC00 Ion current system bank 2, Initialization error channel 2
P13CD00 Ion current system bank 2, Initialization error channel 1/2
P13CE00 Sensor for internal pressure of cylinder 1 Electrical malfunction
P13CF00 Sensor for internal pressure of cylinder 1 Short circuit to ground
P13D000 Sensor for internal pressure of cylinder 1 Implausible signal
P13D100 Sensor for internal pressure of cylinder 2 Electrical malfunction
P13D200 Sensor for internal pressure of cylinder 2 Short circuit to ground
P13D300 Sensor for internal pressure of cylinder 2 Implausible signal
P13D400 Sensor for internal pressure of cylinder 3 Electrical malfunction
P13D500 Sensor for internal pressure of cylinder 3 Short circuit to ground
P13D600 Sensor for internal pressure of cylinder 3 Implausible signal
P13D700 Sensor for internal pressure of cylinder 4 Electrical malfunction
P13D800 Sensor for internal pressure of cylinder 4 Short circuit to ground
P13D900 Sensor for internal pressure of cylinder 4 Implausible signal
P13DA00 Sensor for internal pressure of cylinder 5 Electrical malfunction
P13DB00 Sensor for internal pressure of cylinder 5 Short circuit to ground
P13DC00 Sensor for internal pressure of cylinder 5 Implausible signal
P13DD00 Sensor for internal pressure of cylinder 6 Electrical malfunction
P13DE00 Sensor for internal pressure of cylinder 6 Short circuit to ground
P13DF00 Sensor for internal pressure of cylinder 6 Implausible signal
P13E000 Sensor for internal pressure of cylinder 1 Malfunction
P13E100 Sensor for internal pressure of cylinder 2 Malfunction
P13E200 Sensor for internal pressure of cylinder 3 Malfunction
P13E300 Sensor for internal pressure of cylinder 4 Malfunction
P13E400 Sensor for internal pressure of cylinder 5 Malfunction
P13E500 Sensor for internal pressure of cylinder 6 Malfunction
P13EA00 Cold Start Ignition Timing Performance Off Idle
P140000 EGR Vacuum Regulator Solenoid Valve electrical malfunction in circuit
P140100 EGR Vacuum Regulator Solenoid Valve Short-circuit to ground
P140200 EGR Vacuum Regulator Solenoid Valve Short circuit to B+
P140300 Exhaust gas recirculation system Control difference
P140400 Exhaust gas recirculation system Basic settings not carried out
P140500 Exhaust gas recirculation valve 2 -N213 Malfunction
P140600 EGR Temp.Sensor -G98 Implausible signal
P140700 EGR Temp.Sensor -G98 Signal too low
P140800 EGR Temp.Sensor -G98 Signal too high
P140900 Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 electrical malfunction in circuit
P140A00 EGR system 2 bank 1 Control difference
P140B00 EGR system 2 bank 2 Control difference
P140C00 EGR sensor 2 bank 1 Signal too low
P140D00 EGR sensor 2 bank 2 Signal too low
P140E00 EGR sensor 2 bank 1 Signal too high
P140F00 EGR sensor 2 bank 2 Signal too high
P141000 Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 Short circuit to B+
P141100 Bank2, secondary air system Flow too Low
P141200 Pressure sensor for exhaust gas recirculation Signal too low
P141300 Pressure sensor for exhaust gas recirculation Signal too high
P141400 Bank2, secondary air system leak detected
P141500 EGR valve, curve adaptation characteristic curve adaptation Lower limit exceeded
P141600 EGR valve, curve adaptation Upper limit exceeded
P141700 Fuel Level Sensor (A) Circuit Signal too low
P141800 Fuel Level Sensor (A) Circuit Signal too high
P141900 Exhaust Gas Recirculation (EGR) Cool Switch-over Valve 2 -N381 Short circuit to B+
P141A00 Exhaust temperature sensor 3 bank 2 Electrical malfunction
P141B00 Exhaust temperature sensor 3 bank 2 Implausible signal
P141C00 Exhaust temperature sensor 3 bank 2 Short-circuit to ground
P141D00 Exhaust temperature sensor 3 bank 2 Short circuit to B+
P141E00 Exhaust Gas Recirculation Contr. Circuit Bank 2 Control difference
P141F00 Exhaust gas temperature sensors Implausible
P142000 Secondary air inlet valve-N112 electrical malfunction in circuit
P142100 Secondary air inlet valve-N112 Short-circuit to ground
P142200 Secondary air inlet valve-N112 Short circuit to B+
P142300 Bank1, secondary air system Flow too Low
P142400 Bank1, secondary air system leak detected
P142500 Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 Short-circuit to ground
P142600 Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80 Open circuit
P142700 Brake vacuum pump activation Short circuit to B+
P142800 Brake vacuum pump activation Short-circuit to ground
P142900 Brake vacuum pump activation Open circuit
P142A00 Exhaust Gas Temperature Sensor 2 and 3 Circuit - Bank 1 deviation
P142B00 Exhaust Gas Temperature Sensor 2 and 3 Circuit - Bank 2 deviation
P142C00 Exhaust Gas Temperature Sensor 2 Circuit - Bank 1 and 2 deviation
P142D00 Exhaust Gas Temperature Sensor 3 Circuit - Bank 1 and 2 deviation
P142E00 EGR valve 2 bank 1 electrical malfunction in circuit
P142F00 EGR valve 2 bank 2 electrical malfunction in circuit
P143000 Brake vacuum pump activation Open circuit/short circuit to B+
P143100 Brake vacuum pump activation Open circuit/short circuit to ground
P143200 Secondary air inlet valve-N112 Open circuit
P143300 Secondary Air Injection (AIR) Pump Relay -J299 Open circuit
P143400 Secondary Air Injection (AIR) Pump Relay -J299 Short circuit to B+
P143500 Secondary Air Injection (AIR) Pump Relay -J299 Short-circuit to ground
P143600 Secondary Air Injection (AIR) Pump Relay -J299 electrical malfunction in circuit
P143700 EGR Vacuum Regulator Solenoid Valve 2 Short circuit to B+
P143800 EGR Vacuum Regulator Solenoid Valve 2 Open circuit/short circuit to ground
P143900 Exhaust gas recirculation potentiometer -G212 Malfunction in basic settings
P143A00 Bank 2 Particle Filter Post-Injection Metering Pump -V337- Short circuit to B+
P143B00 Bank 2 Particle Filter Post-Injection Metering Pump -V337- Short circuit to ground/open circuit
P143C00 Bank 1 Particle Filter Post-Injection Metering Pump -V336- Short circuit to B+
P143D00 Bank 1 Particle Filter Post-Injection Metering Pump -V336- Short circuit to ground/open circuit
P143E00 Particle Filter Post-Injection Metering Pump -V335- Short circuit to B+
P143F00 Particle Filter Post-Injection Metering Pump -V335- Short circuit to ground/open circuit
P144000 EGR Vacuum Regulator Solenoid Valve Open circuit
P144100 EGR Vacuum Regulator Solenoid Valve Open circuit/short circuit to ground
P144200 Exhaust gas recirculation potentiometer -G212 Signal too high
P144300 Exhaust gas recirculation potentiometer -G212 Signal too low
P144400 Exhaust gas recirculation potentiometer -G212 Implausible signal
P144500 Catalyst Temp.Sensor 2 Circ. -G132 Implausible signal
P144600 Catalyst Temp.Sensor 1 Circ. -G20 Short-circuit to ground
P144700 Catalyst Temp.Sensor 1 Circ. -G20 Open circuit/short circuit to B+
P144800 Catalyst Temp.Sensor 2 Circ. -G132 Short-circuit to ground
P144900 Catalyst Temp.Sensor 2 Circ. -G132 Open circuit/short circuit to B+
P144A00 EGR system 2 bank 1 Malfunction
P144B00 EGR system 2 bank 2 Malfunction
P144C00 EGR sensor 2 bank 1 Malfunction in basic settings
P144D00 EGR sensor 2 bank 2 Malfunction in basic settings
P144E00 EGR Vacuum Regulator Solenoid Valve 2 Electrical malfunction
P144F00 EGR Vacuum Regulator Solenoid Valve 2 Open circuit
P145000 Secondary air system Short circuit to B+
P145100 Secondary air system Short-circuit to ground
P145200 Secondary air system Open circuit
P145300 Exhaust Gas Temperature Sensor 1 Circuit, Bank 1 -G235- Open circuit/short circuit to B+
P145400 Exhaust Gas Temperature Sensor 1 Circuit, Bank 1 -G235- Short-circuit to ground
P145500 Exhaust Gas Temperature Sensor 1 Circuit, Bank 1 -G235- Implausible signal
P145600 Exhaust Gas Temperature Control Bank 1 Control limit reached
P145700 Exhaust temperature sensor 1 bank 2 - G236 Open circuit/short circuit to B+
P145800 Exhaust temperature sensor 1 bank 2 - G236 Short-circuit to ground
P145900 Exhaust temperature sensor 1 bank 2 - G236 Implausible signal
P145A00 Exhaust Gas Temperature Sensor 3 Circuit Electrical malfunction
P145B00 Exhaust Gas Temperature Sensor 3 Circuit Implausible signal
P145C00 Exhaust Gas Temperature Sensor 3 Circuit Short-circuit to ground
P145D00 Exhaust Gas Temperature Sensor 3 Circuit Short circuit to B+
P145E00 Air mass throughput in regeneration operation is too low
P145F00 Mass air flow in regeneration operation too high
P146000 Exhaust Gas Temperature Control Bank 2 Control limit reached
P146100 Exhaust Gas Temperature Control Bank 1 Implausible signal
P146200 Exhaust Gas Temperature Control Bank 2 Implausible signal
P146300 Sec.Air Inj.Sys., Bank 3 Malfunction
P146400 Sec.Air Inj.Sys., Bank 4 Malfunction
P146500 Metering pump for cleaning solution Short circuit to B+
P146600 Metering pump for cleaning solution Open circuit/short circuit to ground
P146700 Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Short circuit to B+
P146800 Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Short-circuit to ground
P146900 Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Open circuit
P146A00 Malfunction Diesel particle filter bank 1 Temperature increase too low
P146B00 Malfunction Diesel particle filter bank 2 Temperature increase too low
P146C00 Acknowledgement of heating 1 for reducing agent Electrical malfunction
P146D00 Acknowledgement of heating 1 for reducing agent Short circuit to B+
P146E00 Acknowledgement of heating 2 for reducing agent Electrical malfunction
P146F00 Acknowledgement of heating 2 for reducing agent Short circuit to B+
P147000 Leak diagnosis pump - tank breather system electrical malfunction in circuit
P147100 Leak diagnosis pump - tank breather system Short circuit to B+
P147200 Leak diagnosis pump - tank breather system Short-circuit to ground
P147300 Leak diagnosis pump - tank breather system Open circuit
P147400 Evaporative Emission (EVAP) Canister Purge Solenoid -N115 Electrical malfunction in circuit
P147500 Leak diagnosis pump - tank breather system malfunction/no signal
P147600 Leak diagnosis pump - tank breather system malfunction/vacuum to low
P147700 Leak diagnosis pump - tank breather system Malfunction
P147800 Leak diagnosis pump - tank breather system blocked pipe detected
P147900 Brake vacuum system Mechanical malfunction
P147A00 Brake vacuum pump activation Electrical malfunction
P148000 Brake vacuum pump
P148100 Secondary Air Injection (AIR) Pump Relay 2 -J545- Open circuit
P148200 Secondary Air Injection (AIR) Pump Relay 2 -J545- Short circuit to B+
P148300 Secondary Air Injection (AIR) Pump Relay 2 -J545- Short-circuit to ground
P148400 Secondary Air Injection (AIR) Pump Relay 2 -J545- electrical malfunction in circuit
P148500 Secondary Air Injection (AIR) Solenoid Valve 2 -N320- Open circuit
P148600 Secondary Air Injection (AIR) Solenoid Valve 2 -N320- electrical malfunction in circuit
P148700 Secondary Air Injection (AIR) Solenoid Valve 2 -N320- Short-circuit to ground
P148800 Secondary Air Injection (AIR) Solenoid Valve 2 -N320- Short circuit to B+
P148900 Evaporative Emission (EVAP) Canister Purge Regulator -N333 Short circuit to B+
P148A00 Sensor for reducing agent fill level Implausible fill level
P148B00 End stage for reducing agent heating Defective
P148C00 End stage 2 for reducing agent heating Defective
P148F00 Exhaust Gas Recirculation (EGR) Cool Switch-Over Valve 2 Electrical malfunction
P149000 Evaporative Emission (EVAP) Canister Purge Regulator -N333 Short-circuit to ground
P149100 Evaporative Emission (EVAP) Canister Purge Regulator -N333 Open circuit
P149200 Evaporative Emission (EVAP) Canister Purge Regulator -N333 electrical malfunction in circuit
P149300 Brake vacuum pump Performance too low
P149400 EVAP Emission Control System 2 Throughput faulty
P149500 Radiator Exhaust Gas Recirculation Switch-over Valve -N345 Open circuit/short circuit to ground
P149600 Radiator Exhaust Gas Recirculation Switch-over Valve -N345 Short circuit to B+
P149700 Sec.Air Inj.Sys., Bank 3 Incorrect Flow Detected
P149800 Sec.Air Inj.Sys., Bank 4 Incorrect Flow Detected
P149900 Exhaust Gas Recirculation (EGR) Cool Switch-over Valve 2 -N381 Open circuit/short circuit to ground
P149A00 EGR Coolant pump Short-circuit to ground
P149B00 EGR Coolant pump Short circuit to B+
P149C00 EGR Coolant pump Open circuit
P149D00 Transfer pump for reducing agent Open circuit
P149E00 Transfer pump for reducing agent Short-circuit to ground
P149F00 Transfer pump for reducing agent Short circuit to B+
P14A000 Exhaust temperature sensor 1 bank 3 Implausible signal
P14A100 Exhaust temperature sensor 1 bank 3 Short-circuit to ground
P14A200 Exhaust temperature sensor 1 bank 3 Short circuit to B+
P14A300 Exhaust temperature sensor 1 bank 4 Implausible signal
P14A400 Exhaust temperature sensor 1 bank 4 Short-circuit to ground
P14A500 Exhaust temperature sensor 1 bank 4 Short circuit to B+
P14A600 Sensor 3a for exhaust temperature bank 1 Electrical malfunction
P14A700 Sensor 3a for exhaust temperature bank 1 Implausible signal
P14A800 Sensor 3a for exhaust temperature bank 1 Short-circuit to ground
P14A900 Sensor 3a for exhaust temperature bank 1 Short circuit to B+
P150000 Fuel pump relay -J17 electrical malfunction in circuit
P150100 Fuel pump relay -J17 Short-circuit to ground
P150200 Fuel pump relay -J17 Short circuit to B+
P150300 Load signal from generator DF Implausible signal
P150400 Air intake system leak detected
P150500 Closed Throttle Position (CTP) Switch -F60 does not close/open circuit
P150600 Closed Throttle Position (CTP) Switch -F60 does not open/short circuit to Ground (GND)
P150700 Idling system learnt value - lower limit reached
P150800 Idling system learnt value - upper limit reached
P150900 Idling speed stabilization valve -N71 electrical malfunction in circuit
P150A00 Engine Off Timer Performance
P150B00 Acceleration monitoring Value above upper control limit
P150C00 RPM request from transmission cannot be performed
P150D00 Chain elongation
P150E00 Vehicle Speed Sensor (A) Implausible to ABS Control Module
P150F00 External control module incorrect code
P151000 Idling speed stabilization valve -N71 Short circuit to B+
P151100 Intake manifold change-over valve -N156 electrical malfunction in circuit
P151200 Intake manifold change-over valve -N156 Short circuit to B+
P151300 Intake Manifold Changover Valve 2 circuit -N261 Short circuit to B+
P151400 Intake Manifold Changover Valve 2 circuit -N261 Short-circuit to ground
P151500 Intake Manifold Changover Valve circuit -N156 Short-circuit to ground
P151600 Intake Manifold Changover Valve circuit -N156 Open circuit
P151700 Main relay electrical malfunction in circuit
P151800 Main relay Short circuit to B+
P151900 Bank1, camshaft adjustment Malfunction
P152000 Intake Manifold Changover Valve 2 circuit -N261 Open circuit
P152100 Intake Manifold Changover Valve 2 circuit -N261 Electrical malfunction in circuit
P152200 A Camshaft Position Actuator Control Circuit(Bank2) Malfunction
P152300 Crash Signal from Airbag Control Unit Implausible signal
P152400 Fuel pump relay -J17 Open circuit/short circuit to ground
P152500 Bank1, camshaft adjustment=>-N205 electrical malfunction in circuit
P152600 Bank1, camshaft adjustment=>-N205 Short circuit to B+
P152700 Bank1, camshaft adjustment=>-N205 Short-circuit to ground
P152800 Bank1, camshaft adjustment=>-N205 Open circuit
P152900 Intake camshaft control circuit Short circuit to B+
P153000 Intake camshaft control circuit Short-circuit to ground
P153100 Intake camshaft control circuit Open circuit
P153200 Idle regulation lean operation RPM below specified value
P153300 Bank2, camshaft adjustment=>-N208 electrical malfunction in circuit
P153400 Bank2, camshaft adjustment=>-N208 Short circuit to B+
P153500 Bank2, camshaft adjustment=>-N208 Short-circuit to ground
P153600 Bank2, camshaft adjustment=>-N208 Open circuit
P153700 Fuel Cut-Off Valve -N109- Malfunction
P153800 Fuel Cut-Off Valve -N109- Open circuit/short circuit to ground
P153900 Clutch pedal switch -F36 Implausible signal
P154000 Vehicle Speed Sensor (A) Signal too high
P154100 Fuel pump relay -J17 Open circuit
P154200 Angle sender 1 for throttle valve drive -G187 Implausible signal
P154300 Angle sender 1 for throttle valve drive -G187 Signal too low
P154400 Angle sender 1 for throttle valve drive -G187 Signal too high
P154500 Throttle valve control system Malfunction
P154600 Wastegate Bypass Regulator Valve -N75 Short circuit to B+
P154700 Wastegate Bypass Regulator Valve -N75 Short-circuit to ground
P154800 Wastegate Bypass Regulator Valve -N75 Open circuit
P154900 Wastegate Bypass Regulator Valve -N75 Open circuit/short circuit to ground
P154E00 Charge pressure regulation bank 2 Malfunction
P154F00 Turbo/Super Charger Boost Sensor (A) Circuit Malfunction
P155000 Charging pressure Control difference
P155100 Altitude sender-F96 Short circuit to B+
P155200 Altitude sender-F96 Open circuit/short circuit to ground
P155300 Barometric pressure sensor/manifold absolute pressure Implausible relation
P155400 Throttle valve control part-J338- Conditions f. basic setting not met
P155500 value above maximum charge pressure
P155600 Turbo/Super Charger Boost Sensor (A) Circuit Value below lower control limit
P155700 Turbo/Super Charger Boost Sensor (A) Circuit Value above upper control limit
P155800 Throttle Drive (for Electronic Power Control (EPC)) -G186 electrical malfunction in circuit
P155900 Throttle valve control part-J338- Malfunction in basic settings
P155A00 Turbo/Super Charger Boost Sensor (A) Circuit Charge air pressure not reached
P156000 Engine Overspeed Condition
P156100 Quantity adjuster-N146 Control difference
P156200 Quantity adjuster-N146 upper limit stop value
P156300 Quantity adjuster-N146 lower limit stop value
P156400 Throttle valve control part-J338- insufficient voltage during basic settings
P156500 Throttle valve control part-J338- lower stop not reached
P156600 A/C Refrigerant Pressure Sensor (A) Circuit Implausible signal
P156700 A/C Refrigerant Pressure Sensor (A) Circuit No signal
P156800 Throttle valve control part-J338- Mechanical malfunction
P156900 Cruise control system switch -E45 Implausible signal
P156A00 Filling/throttle valve position Validation
P156B00 Lower mechanical stop of throttle valve Implausible signal
P157000 Engine Control Module (ECM) disabled
P157100 Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Short circuit to B+
P157200 Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Short-circuit to ground
P157300 Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Open circuit
P157400 Left Electro-Hydraulic Engine Mount Solenoid Valve -N144- Electrical malfunction in circuit
P157500 Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Short circuit to B+
P157600 Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Short-circuit to ground
P157700 Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Open circuit
P157800 Right Electro-Hydraulic Engine Mount Solenoid Valve -N145- Electrical malfunction in circuit
P157900 Throttle valve control part-J338- Adaptation not initiated
P158000 Throttle valve drive - bank 1 Malfunction
P158100 Throttle valve control part-J338- Basic settings not carried out
P158200 Idle speed control adaptation limit reached
P158300 Transmission Mount Valve -1-/-2- -N262-/-N263- Short circuit to B+
P158400 Transmission Mount Valve -1-/-2- -N262-/-N263- Short-circuit to ground
P158500 Transmission Mount Valve -1-/-2- -N262-/-N263- Open circuit
P158600 L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Short circuit to B+
P158700 L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Short-circuit to ground
P158800 L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Open circuit
P158900 Temperature Selector Knob Potentiometer -G267- Short circuit to Ground (GND)
P159000 Temperature Selector Knob Potentiometer -G267- Open circuit
P159100 Wastegate Bypass Regulator Valve -N75 No function
P159200 Height sensor/charge pressure sensor Implausible relation
P159300 Altitude adaptation Signal outside tolerance
P159400 Engine Oil Temperature Sensor Circuit,Camshaft Control -G277 Short circuit to B+
P159500 Engine Oil Temperature Sensor Circuit,Camshaft Control -G277 Open circuit/short circuit to ground
P159600 Databus drivetrain Implausible message from level control system control module
P159700 Databus drivetrain missing message from level controls system control module
P159800 Engine Oil Temperature Sensor Circuit,Camshaft Control -G277 Implausible signal
P159900 Idle regulation lean operation RPM above specified value
P159B00 Oil Level Thermal Sensor Short circuit to B+
P159C00 Oil Level Thermal Sensor Short-circuit to ground
P159D00 Oil Level Thermal Sensor Implausible signal
P159E00 Oil Level Thermal Sensor No signal
P159F00 Function restriction by Transmission Control Module
P15A000 Neutral gear sensor Electrical malfunction
P15A100 Neutral gear sensor Implausible signal
P15A200 Neutral gear sensor Short-circuit to ground
P15A300 Neutral gear sensor Short circuit to B+
P15A400 vehicle shutdown activated
P160000 Voltage supply terminal 15 Low Voltage
P160100 Relay for Power Supply (B+) Terminal 30 -J317 Implausible signal
P160200 Power Supply (B+) Terminal 30 Low Voltage
P160300 Control module defective
P160400 Control module defective
P160500 Uneven road surface /acceleration sensor electrical malfunction in circuit
P160600 Rough Road Spec Engine Torque ABS-ECU electrical malfunction in circuit
P160700 Speed signal Malfunction message from instrument cluster
P160800 Steering angle signal Malfunction indication from steering angle sensor
P160900 Crash shut-off was triggered
P160A00 Control module defective
P160B00 See literature
P160C00 Coolant pump 2 Open circuit
P160D00 Coolant pump 2 Implausible signal
P160E00 Coolant pump 2 Short-circuit to ground
P160F00 Coolant pump 2 Short circuit to B+
P161000 Control module defective
P161100 Requirement - malfunction lamp on Short-circuit to ground
P161200 Engine Control Module (ECM) incorrect coding
P161300 Requirement - malfunction lamp on Open circuit/short circuit to B+
P161400 Requirement - malfunction lamp on Implausible signal
P161500 Engine Oil Temperature Sensor Circuit Implausible signal
P161600 Glow Plug Indicator Light -K29- Short circuit to B+
P161700 Glow Plug Indicator Light -K29- Open circuit/short circuit to ground
P161800 Glow plug relay -J52 Short circuit to B+
P161900 Glow plug relay -J52 Open circuit/short circuit to ground
P161A00 Glow plug cylinder 1 -Q10 Open circuit
P161B00 Glow plug cylinder 2 -Q11 Open circuit
P161C00 Glow plug cylinder 3 -Q12 Open circuit
P161D00 Glow plug cylinder 4 -Q13 Open circuit
P161E00 Glow plug cylinder 5 -Q14 Open circuit
P161F00 Glow plug cylinder 6 -Q15 Open circuit
P162000 Signal for coolant temperature Open/Short to B+
P162100 Signal for coolant temperature Short-circuit to ground
P162200 Signal for coolant temperature Implausible signal
P162300 Databus drivetrain No communication
P162400 Requirement - malfunction lamp on active
P162500 Databus drivetrain Implausible Message from Transm.Contr.
P162600 Databus drivetrain Missing Message from Transm.Contr.
P162700 Databus drivetrain missing message from fuel injection pump
P162800 Databus drivetrain missing message from steering sensor
P162900 Databus drivetrain Missing message from ADR control module
P162A00 Glow plug cylinder 7 -Q16 Open circuit
P162B00 Glow plug cylinder 8 -Q17 Open circuit
P162C00 Glow/Time Control Module - voltage supply Load circuit open circuit
P162D00 Diesel Particle Filter Indicator Lamp -K231 Malfunction
P162E00 Glow plug cylinder 9 -Q18 Open circuit
P162F00 Glow plug cylinder 10 -Q19 Open circuit
P163000 Accelerator position sender-G79 Signal too low
P163100 Accelerator position sender-G79 Signal too high
P163200 Accelerator position sender-G79 Supply voltage
P163300 Accelerator pedal position sender 2 -G185 Signal too low
P163400 Accelerator pedal position sender 2 -G185 Signal too high
P163500 Databus drivetrain missing message f.air condition control
P163600 Databus drivetrain missing message from Airbag control
P163700 Databus drivetrain Missing message f.central electr. control
P163800 Databus drivetrain missing message from clutch control module
P163900 Throttle/Pedal Position Sensor/Switch -C- Circuit Implausible signal
P163A00 Glow/Time Control Module 2 - voltage supply Load circuit open circuit
P163B00 Wakeup request constantly detected
P163C00 Wakeup request not detected
P163D00 Indicator lamp for driving program Electrical malfunction in circuit
P163E00 Control module defective
P163F00 Glow timing control module 2
P164000 Control module defective
P164100 Read DTC memory of Air Condition ECU
P164200 Read DTC memory of Airbag ECU
P164300 Read DTC memory of read out select central control
P164400 Read DTC memory of clutch ECU
P164500 Databus drivetrain missing message f.all wheel drive contr
P164600 Read DTC memory of four wheel drive electronics
P164700 Checking coding/versions of control modules in CAN-bus
P164800 Databus drivetrain Defective
P164900 Databus drivetrain missing message from break ECU
P164A00 Oil pressure switch Implausible signal
P164B00 Oil pressure switch Malfunction
P164C00 Oil pressure switch for reduced oil pressure Implausible signal
P164D00 Oil pressure switch for reduced oil pressure Malfunction
P164E00 Oil pressure regulation valve Electrical malfunction
P164F00 Torque withdrawal
P165000 Databus drivetrain missing message from instrument panel ECU
P165100 Databus drivetrain missing messages
P165200 Read DTC memory of transmission ECU
P165300 Read DTC memory of break ECU
P165400 Read DTC memory of instrument cluster
P165500 Read DTC memory of distance control ECU
P165600 AC Clutch Relay Control Circuit Short-circuit to ground
P165700 AC Clutch Relay Control Circuit Short circuit to B+
P165800 Databus drivetrain range/performance from distance control
P165900 Fan 1 control circuit Short circuit to B+
P165A00 Temperature sensor - fresh air intake duct Short circuit to B+
P165B00 Temperature sensor - fresh air intake duct Short-circuit to ground
P165C00 Temperature sensor - fresh air intake duct Electrical malfunction
P165D00 Refrigerant pressure too high
P165E00 Refrigerant pressure too low
P165F00 Oil pressure regulation valve Short-circuit to ground
P166000 Fan 1 control circuit Short-circuit to ground
P166100 Fan 2 control circuit Short circuit to B+
P166200 Fan 2 control circuit Short-circuit to ground
P166300 Activation of unit injectors Short circuit to B+
P166400 Activation of unit injectors Electrical malfunction in circuit
P166500 Activation of unit injectors Mechanical malfunction
P166600 Unit injector solenoid valve - cylinder 1-N240 Electrical malfunction in circuit
P166700 Unit injector solenoid valve - cylinder 2-N241 Electrical malfunction in circuit
P166800 Unit injector solenoid valve - cylinder 3-N242 Electrical malfunction in circuit
P166900 Unit injector solenoid valve - cylinder 4-N243 Electrical malfunction in circuit
P166A00 Oil temperature sensor 2 Electrical malfunction
P166B00 Oil temperature sensor 2 Short-circuit to ground
P166C00 Oil temperature sensor 2 Implausible signal
P166D00 Engine control module incorrect installation
P167000 Unit injector solenoid valve - cylinder 5-N244 Electrical malfunction in circuit
P167100 Unit injector solenoid valve - cylinder 6-N245 Electrical malfunction in circuit
P167200 Fan 1 control circuit Open circuit/short circuit to ground
P167300 Speed signal Malfunction message from ABS control module
P167400 Databus drivetrain implausible message from instrument panel ECU
P167500 Databus drivetrain fuel pump control module
P167600 Drive by Wire-MIL Circ. -K132 electrical malfunction in circuit
P167700 Drive by Wire-MIL Circ. -K132 Short circuit to B+
P167800 Drive by Wire-MIL Circ. -K132 Short-circuit to ground
P167900 Drive by Wire-MIL Circ. -K132 Open circuit
P167A00 Indicator light start/stop Electrical malfunction
P167B00 Driver's belt buckle Malfunction
P167C00 Driving program switch Electrical malfunction
P167D00 Switch for start/stop Electrical malfunction
P167F00 Injection system initialization error or impermissible operating condition
P168000 Reset-resistant emergency running
P168100 Control unit programming programming not finished
P168200 Databus drivetrain Implausible message from ABS control module
P168300 Databus drivetrain Implausible message from airbag control module
P168400 Control unit programming Malfunction in data transfer
P168500 Databus drivetrain implausible message from steering angle sensor
P168600 Control module defective Programming error
P168700 Databus drivetrain Implausible message from climate control module
P168800 Databus drivetrain implausible message from all wheel drive electronic
P168900 Databus drivetrain implausible message f.central electr. control
P169000 Malfunction Indicator Lamp (MIL) -K83- electrical malfunction in circuit
P169100 Malfunction Indicator Lamp (MIL) -K83- Open circuit
P169200 Malfunction Indicator Lamp (MIL) -K83- Short-circuit to ground
P169300 Malfunction Indicator Lamp (MIL) -K83- Short circuit to B+
P169400 Malfunction Indicator Lamp (MIL) -K83- Open circuit/short circuit to ground
P169500 Databus drivetrain implausible message from clutch control ECU
P169600 Databus drivetrain implausible signal from Steering Column Electronic
P169700 Steering angle sensors please read DTC
P169800 Steering Column Electronic Systems please read DTC
P169900 Databus drivetrain missing message from Steering Column Electronic
P169A00 Loading mode active
P169B00 Glow plug cylinder 1 Implausible signal
P169C00 Glow plug cylinder 2 Implausible signal
P169D00 Glow plug cylinder 3 Implausible signal
P169E00 Glow plug cylinder 4 Implausible signal
P169F00 Glow plug cylinder 5 Implausible signal
P16A000 Glow plug cylinder 6 Implausible signal
P16A100 Glow plug cylinder 7 Implausible signal
P16A200 Glow plug cylinder 8 Implausible signal
P16A300 Glow plug cylinder 9 Implausible signal
P16A400 Glow plug cylinder 10 Implausible signal
P16A500 Glow plug cylinder 11 Implausible signal
P16A600 Glow plug cylinder 12 Implausible signal
P16A700 Glow plug cylinder 1 Incorrect installation
P16A800 Glow plug cylinder 2 Incorrect installation
P16A900 Glow plug cylinder 3 Incorrect installation
P16AA00 Glow plug cylinder 4 Incorrect installation
P16AB00 Glow plug cylinder 5 Incorrect installation
P16AC00 Glow plug cylinder 6 Incorrect installation
P16AD00 Glow plug cylinder 7 Incorrect installation
P16AE00 Glow plug cylinder 8 Incorrect installation
P16AF00 Glow plug cylinder 9 Incorrect installation
P16B000 Glow plug cylinder 10 Incorrect installation
P16B100 Glow plug cylinder 11 Incorrect installation
P16B200 Glow plug cylinder 12 Incorrect installation
P170000 Brake Pressure Switch -F270- Implausible signal
P170100 Transmission control unit locked
P170200 Malfunction cannot activate contr. mod. replacem. func., since another malfunction with equal priority is present
P170300 Emergency running, control unit reset
P170400 Kick Down Switch -F8- electrical malfunction in circuit
P170500 Gear Ratio adaptation limit reached
P170600 Gearbox faulty
P170700 Interference in Mechatronic unit
P170800 Engine Control Modules (ECM) exchanged
P170900 Gear position switch 1-3 High Voltage
P170A00 Hill holder Incline limit exceeded
P170B00 Hill holder Malfunction
P170C00 Gear position switch 5-7 High Voltage
P170D00 Gear position switch 5-7 Low Voltage
P170E00 Gear position switch 5-7 Signal error
P170F00 Gear position switch 6-4 High Voltage
P171000 Gear position switch 6-4 Low Voltage
P171100 Wheel speed signal 1=>Left Front ABS Wheel Speed Sensor -G47 Implausible signal
P171200 Gear position switch R-2 High Voltage
P171300 Gear position switch R-2 Low Voltage
P171400 Gear position switch R-2 Signal error
P171500 Gear position switch 6-4 Signal error
P171600 Wheel speed signal 2=>Right Front ABS Wheel Speed Sensor -G45 Implausible signal
P171700 Gear position switch 1-3 Low Voltage
P171800 Gear position switch 1-3 Signal error
P171900 Function restriction by Engine Control Module
P171A00 Ignition key removal lock Open circuit
P171B00 Ignition key removal lock Short circuit to B+
P171C00 Ignition key removal lock Short-circuit to ground
P171D00 Ignition key removal lock Electrical malfunction
P171E00 Transmission Input Speed (RPM) Sensor 2 No signal
P171F00 Transmission Input Speed (RPM) Sensor 2 Implausible signal
P172000 Transmission output speed 1 Implausible signal
P172100 Wheel speed signal 3=>Left Rear ABS Wheel Speed Sensor -G46 Implausible signal
P172200 Transmission output speed 2 Implausible signal
P172300 Signal for starter lock Open circuit
P172400 Signal for starter lock Short-circuit to ground
P172500 Compare transmission output speeds 1 + 2 Implausible signal
P172600 Wheel speed signal 4=>Right Rear ABS Wheel Speed Sensor -G44 Implausible signal
P172700 Transmission Driving direction implausible
P172800 Differing wheel speeds Implausible signal
P172900 Signal for starter lock Short circuit to B+
P172A00 Clutch adjuster valve Open circuit
P172B00 Clutch adjuster valve Short-circuit to ground
P172C00 Clutch adjuster valve Short circuit to B+
P172D00 Clutch adjuster valve Electrical malfunction
P172E00 Switch actuator Mechanical malfunction
P172F00 Gear Position Distance Sensor 1 for gear selector Electrical malfunction
P173000 Gear Position Distance Sensor 2 for gear selector Electrical malfunction
P173100 Gear Position Distance Sensor 3 for gear selector Electrical malfunction
P173200 Gear Position Distance Sensor 4 for gear selector Electrical malfunction
P173300 Tiptronic Switch -F189-, down Short-circuit to ground
P173400 Starter release from the selector lever sensor system
P173500 Position sensor for clutch 1 Electrical malfunction
P173600 Position sensor for clutch 2 Electrical malfunction
P173700 Transmission hydraulic pressure sensor 1 Open circuit/short circuit to B+
P173800 Transmission hydraulic pressure sensor 2 Open circuit/short circuit to B+
P173900 Tiptronic Switch -F189-, up Short-circuit to ground
P173A00 Gear Position Distance Sensor 1 for gear selector Implausible signal
P173B00 Gear Position Distance Sensor 2 for gear selector Implausible signal
P173C00 Gear Position Distance Sensor 3 for gear selector Implausible signal
P173D00 Gear Position Distance Sensor 4 for gear selector Implausible signal
P173E00 Valve 1 in partial transmission 1 Electrical malfunction
P173F00 Valve 2 in partial transmission 1 Electrical malfunction
P174000 Clutch temperature monitoring
P174100 Clutch pressure adaptation at limit
P174200 Clutch torque adaptation, adaptation limit reached
P174300 Clutch slip monitoring Signal too high
P174400 Tiptronic Switch -F189-, recognition Short-circuit to ground
P174500 Transm.Contr.Unit Relay Short circuit to B+
P174600 Transm.Contr.Unit Relay electrical malfunction in circuit
P174700 Transm.Contr.Unit Relay Open circuit/short circuit to ground
P174800 Control module defective
P174900 Automatic gearbox control unit incorrect code
P174A00 Valve 3 in separate transmission 1 Electrical malfunction
P174B00 Valve 4 in partial transmission 1 Electrical malfunction
P174C00 Valve 1 in partial transmission 2 Electrical malfunction
P174D00 Valve 2 in partial transmission 2 Electrical malfunction
P174E00 Valve 3 in separate transmission 2 Electrical malfunction
P174F00 Valve 4 in partial transmission 2 Electrical malfunction
P175000 Voltage supply Low Voltage
P175100 Voltage supply High Voltage
P175200 Voltage supply Implausible signal
P175300 Tiptronic Switch -F189- Implausible signal
P175400 Tiptronic Switch, up F189 Open circuit/short circuit to B+
P175500 Tiptronic Switch, return F189 Open circuit/short circuit to B+
P175600 Tiptronic Switch -F189-, recognition Open circuit/short circuit to B+
P175700 Voltage supply Open circuit
P175800 Voltage supply terminal 15 Open circuit
P175900 Transmission fluid temperature Exceeded multiple times
P175A00 Actuator gear control unit separate transmission 1 Tolerance limit reached
P175B00 Actuator gear control unit separate transmission 2 Tolerance limit reached
P175C00 Actuator double clutch Tolerance limits reached
P175D00 Clutch 1 opens unintentionally
P175E00 Clutch 1 closes unintentionally
P175F00 Transmission system Basic settings not carried out
P176000 Shift lock solenoid =>solenoid -N110 electrical malfunction in circuit
P176100 Shift lock solenoid =>solenoid -N110 Short-circuit to ground
P176200 Shift lock solenoid =>solenoid -N110 Short circuit to B+
P176300 Shift lock solenoid =>solenoid -N110 Open circuit
P176400 Transmission temperature monitoring
P176500 Hydraulic pressure sender 2 -G194 adaptation limit reached
P176600 Throttle Angel Signal Open circuit/short circuit to B+
P176700 Throttle Angel Signal Short-circuit to ground
P176800 Hydraulic pressure sender 2 -G194 Signal too high
P176900 Hydraulic pressure sender 2 -G194 Signal too low
P176A00 Gear selector 1 cannot be regulated
P176B00 Gear selector 2 cannot be regulated
P176C00 Gear selector 3 cannot be regulated
P176D00 Gear selector 4 cannot be regulated
P176E00 Clutch 2 opens unintentionally
P176F00 Clutch 2 closes unintentionally
P177000 Load Signal Implausible signal
P177100 Load Signal Open circuit/short circuit to B+
P177200 Load Signal Short-circuit to ground
P177300 Hydraulic pressure sender 1 -G193 Signal too high
P177400 Hydraulic pressure sender 1 -G193 Signal too low
P177500 Hydraulic pressure sender 1 -G193 adaptation limit reached
P177600 Hydraulic pressure sender 1 -G193 Implausible signal
P177700 Hydraulic pressure sender 2 -G194 Implausible signal
P177800 Valve 7 electrical malfunction in circuit
P177900 Transmission input shaft 1 Overspeed
P177A00 Transmission input shaft 2 Overspeed
P177B00 Coupling 1 Tolerance limit reached
P177C00 Coupling 2 Tolerance limit reached
P177D00 Double clutch Torque too high
P177E00 Function restriction due to pressure drop
P177F00 Hydraulic pump motor Insuff. voltage
P178000 Torque withdrawal faulty
P178100 Torque reduction signal Open circuit/short circuit to ground
P178200 Torque reduction signal Short circuit to B+
P178300 Clutch torque adaptation 2 adaptation limit reached
P178400 Up/down shift wire Open circuit/short circuit to ground
P178500 Up/down shift wire Short circuit to B+
P178600 Reversing light signal Open circuit
P178700 Reversing light signal Short-circuit to ground
P178800 Reversing light signal Short circuit to B+
P178900 Idling speed adjustment Error Message from Engine Contr.
P178A00 Hydraulic pump Electrical malfunction
P178B00 Hydraulic pump Implausible behavior
P178C00 Clutch 1 to clutch 2 Implausible
P178D00 Synchronizer ring Wear
P178E00 Function limitation due to excessive temperature
P178F00 Pressure control valve soiled
P179000 Signal for selector range display Open circuit
P179100 Signal for selector range display Short-circuit to ground
P179200 Signal for selector range display Short circuit to B+
P179300 Output Speed Sensor 2 Circ. No signal
P179500 Signal for driving speed Open circuit
P179600 Signal for driving speed Short-circuit to ground
P179700 Signal for driving speed Short circuit to B+
P179800 Output Speed Sensor 2 Circ. Implausible signal
P179900 Output Speed Sensor 2 Circ. Rpm too High
P179A00 Solenoid valve Electrical malfunction
P179B00 Separate transmission valve Electrical malfunction
P179C00 Main pressure valve Electrical malfunction
P179D00 Cooling oil valve Electrical malfunction
P179E00 Sensor for transmission range Electrical malfunction
P179F00 Sensor for transmission range Malfunction
P17A000 Accumulator 1 temperature monitoring
P17A100 Accumulator 2 temperature monitoring
P17A200 Differential fluid pressure monitoring
P17A300 Differential fluid temperature monitoring
P17A400 Transverse acceleration monitoring
P17A500 Longitudinal acceleration monitoring
P17A600 Selector lever position P position1
P17A700 Selector lever position P position2
P17A800 Shift Lever Forward Valve 1 Open circuit
P17A900 Shift Lever Forward Valve 1 Short-circuit to ground
P17AA00 Shift Lever Forward Valve 1 Short circuit to B+
P17AB00 Shift Lever Forward Valve 1 Electrical malfunction
P17AC00 Shift Lever Forward Valve 2 Open circuit
P17AD00 Shift Lever Forward Valve 2 Short-circuit to ground
P17AE00 Shift Lever Forward Valve 2 Short circuit to B+
P17AF00 Shift Lever Forward Valve 2 Electrical malfunction
P17B000 Shift Lever Forward Valve 3 Open circuit
P17B100 Shift Lever Forward Valve 3 Short-circuit to ground
P17B200 Shift Lever Forward Valve 3 Short circuit to B+
P17B300 Shift Lever Forward Valve 3 Electrical malfunction
P17B400 Shift Lever Forward Valve 4 Open circuit
P17B500 Shift Lever Forward Valve 4 Short-circuit to ground
P17B600 Shift Lever Forward Valve 4 Short circuit to B+
P17B700 Shift Lever Forward Valve 4 Electrical malfunction
P17B800 Gear Recognition Potentiometer 1 Implausible signal
P17B900 Gear Recognition Potentiometer 1 Signal too low
P17BA00 Gear Recognition Potentiometer 1 Signal too high
P17BB00 Gear Recognition Potentiometer 2 Implausible signal
P17BC00 Gear Recognition Potentiometer 2 Signal too low
P17BD00 Gear Recognition Potentiometer 2 Signal too high
P17BE00 Hydraulic pump Excess temperature
P17BF00 Hydraulic pump Play protection
P17C000 Sport program button Open circuit
P17C100 Selector lever position display unit Electrical malfunction
P17C200 Selector lever position display unit Supply voltage
P17C300 Selector lever Defective
P17C400 Selector lever position display unit Defective
P17C500 Selector lever Implausible signal
P17C600 Clutch valve Electrical malfunction
P17C700 Transmission Input Speed (RPM) Sensor 3 electrical malfunction in circuit
P17C800 Transmission Input Speed (RPM) Sensor 3 Implausible signal
P17C900 Transmission Input Speed (RPM) Sensor 3 No signal
P17CA00 Basic calibration Data implausible
P17CB00 Clutch valve Defective
P17CC00 Clutch valve 2 Defective
P17CD00 Coupling 1 Drag torque too high
P17CE00 Coupling 2 Drag torque too high
P17CF00 Coupling 1 Slip too great
P17D000 Coupling 2 Slip too great
P17D100 Coupling 1 Pressure upper limit exceeded
P17D200 Coupling 2 Pressure upper limit exceeded
P17D300 Electrohydraulic control unit Characteristic curve deviation
P17D400 Valve 3 in separate transmission 1 Mechanical malfunction
P17D500 Valve 3 in separate transmission 2 Mechanical malfunction
P17D600 Coupling 1 Pressure too high
P17D700 Coupling 2 Pressure too high
P17D800 Torque limitation due to clutch temperature
P17D900 Gear selector sensor Characteristic curve deviation
P17DA00 Gear position sensor 1 Implausible
P17DB00 Gear position sensor 2 Implausible
P17DC00 Gear position sensor 3 Implausible
P17DD00 Gear position sensor 4 Implausible
P17DE00 Gear Position Distance Sensors 1 and 3 Electrical malfunction
P17DF00 Gear Position Distance Sensors 2 and 4 Electrical malfunction
P17E000 Gear selector 1 Mechanical malfunction
P17E100 Gear selector 2 Mechanical malfunction
P17E200 Gear selector 3 Mechanical malfunction
P17E300 Gear selector 4 Mechanical malfunction
P17E400 Selector lever position display unit Short circuit to B+
P17E500 Selector lever position sensor Mechanical malfunction
P17E600 Selector lever position sensor Implausible signal
P17E700 Selector lever position sensor Defective
P17E800 Locking solenoid Electrical malfunction
P17E900 Locking solenoid Short circuit to B+
P17EA00 Locking solenoid Defective
P17EB00 Unlock button Short-circuit to ground
P17EC00 Unlock button Electrical malfunction
P17ED00 Unlock button sticks
P17EE00 Unlock button Implausible signal
P17EF00 Solenoid for pressure accumulator Short circuit to B+
P17F000 Solenoid for pressure accumulator Short-circuit to ground
P17F100 Solenoid for pressure accumulator Open circuit
P17F200 Solenoid for pressure accumulator Electrical malfunction
P17F300 Solenoid for parking lock Short circuit to B+
P17F400 Solenoid for parking lock Short-circuit to ground
P17F500 Solenoid for parking lock Open circuit
P17F600 Solenoid for parking lock Electrical malfunction
P17F700 Sensor for parking lock Implausible signal
P17F800 Sensor for parking lock Electrical malfunction
P17F900 Parking lock Mechanical malfunction
P17FA00 Pressure control valve 8 electrical malfunction in circuit
P17FB00 Pressure control valve 8 Open circuit
P17FC00 Pressure control valve 8 Open circuit/short circuit to ground
P17FD00 Pressure control valve 8 Short circuit to B+
P180000 Hydraulic Actuator Valve -N331- Electrical malfunction in circuit
P180100 Signal buzzer activation Short circuit to B+
P180200 Clutch pedal switch -F194 Implausible signal
P180300 Planetary post-switch stage Mechanical malfunction
P180400 Hydraulic Actuator Range Sender -G302- Electrical malfunction in circuit
P180500 Hydraulic Actuator Range Sender -G302- Upper limit exceeded
P180600 Hydraulic Actuator Range Sender -G302- Lower limit not reached
P180700 Hydraulic Actuator Range Sender -G302- no or incorrect basic setting/adaptation
P180800 Hydraulic Actuator Range Sender -G302- Implausible signal
P180900 4-Low Range Hydraulic Pump -V190- Electrical malfunction in circuit
P180A00 Gear selector 1 Leaving Neutral not allowed
P180B00 Gear selector 2 Leaving Neutral not allowed
P180C00 Gear selector 3 Leaving Neutral not allowed
P180D00 Gear selector 4 Leaving Neutral not allowed
P180E00 Position sensor for clutch 1 Implausible signal
P180F00 Position sensor for clutch 2 Implausible signal
P181300 Pressure control valve 1 -N215 electrical malfunction in circuit
P181400 Pressure control valve 1 -N215 Open circuit/short circuit to ground
P181500 Pressure control valve 1 -N215 Short circuit to B+
P181800 Pressure control valve 2 -N216 electrical malfunction in circuit
P181900 Pressure control valve 2 -N216 Open circuit/short circuit to ground
P182000 Pressure control valve 2 -N216 Short circuit to B+
P182300 Pressure control valve 3 -N217 electrical malfunction in circuit
P182400 Pressure control valve 3 -N217 Open circuit/short circuit to ground
P182500 Pressure control valve 3 -N217 Short circuit to B+
P182800 Pressure control valve 4 -N218 electrical malfunction in circuit
P182900 Pressure control valve 4 -N218 Open circuit/short circuit to ground
P183000 Pressure control valve 4 -N218 Short circuit to B+
P183300 Pressure regulating valve -5- for automatic transmission electrical malfunction in circuit
P183400 Pressure regulating valve -5- for automatic transmission Open circuit/short circuit to ground
P183500 Pressure regulating valve -5- for automatic transmission Short circuit to B+
P183800 Pressure Regulating Valve 6-N371 Electrical malfunction in circuit
P183900 Pressure Regulating Valve 6-N371 Open circuit/short circuit to ground
P184000 Pressure Regulating Valve 6-N371 Short circuit to B+
P184100 Engine control module/Transmission Control Module (TCM) Versions not compatible
P184200 Read DTC memory of instrument cluster
P184300 Read DTC memory of distance control ECU
P184400 Read DTC memory of read out select central control
P184500 Read DTC memory of Steering Column Electronic Systems Control Module -J527-
P184700 Read DTC memory of break ECU
P184800 Read DTC memory of engine ECU
P184900 Read DTC memory of transmission ECU
P184A00 Main pressure adaptation Offset upper limit exceeded
P184B00 Main pressure adaptation Malfunction
P185000 Databus drivetrain Missing Message from Engine Contr
P185100 Databus drivetrain missing message from break ECU
P185200 Databus drivetrain Implausible Message from Engine Contr.
P185300 Databus drivetrain Implausible message from ABS control module
P185400 Databus drivetrain Defective
P185500 Databus drivetrain Software version monitoring
P185600 Throttle valve potentiometer -G69- Error Message from Engine Contr.
P185700 Load Signal Error Message from Engine Contr.
P185800 Engine Speed Input Circ. Error Message from Engine Contr.
P185900 Brake Light Switch -F Error Message from Engine Contr.
P186000 Kick Down Switch -F8- Error Message from Engine Contr.
P186100 Accelerator position sender-G79 Malfunction indication from Engine Control Module (ECM)
P186200 Databus drivetrain missing message from instrument panel ECU
P186300 Databus drivetrain missing message from steering angle sensor
P186400 Databus drivetrain Missing message from ADR control module
P186500 Databus drivetrain missing message f.central electr. control
P186600 Databus drivetrain missing messages
P186700 Databus drivetrain missing message from -J527-
P186800 Transmission Mount Valve -1- -N262- Short circuit to B+
P186900 Transmission Mount Valve -1- -N262- Short-circuit to ground
P187000 Transmission Mount Valve -1- -N262- Open circuit
P187100 Transmission Mount Valve -2- -N263- Short circuit to B+
P187200 Transmission Mount Valve -2- -N263- Short-circuit to ground
P187300 Transmission Mount Valve -2- -N263- Open circuit
P187400 Valve for torque support mount Short circuit to B+
P187500 Valve for torque support mount Short-circuit to ground
P187600 Valve for torque support mount Open circuit
P187700 Control Coolant System Gearbox intermittent Open circuit
P187800 Control Coolant System Gearbox intermittent Short circuit to B+
P187900 Control Coolant System Gearbox intermittent Short-circuit to ground
P188000 Databus missing message from Diagnostic Interface ECU
P188100 Data Bus missing message
P188200 Databus drivetrain missing message from electrical brake system ECU
P188300 Park/Neutral Switch Input Circuit Implausible signal
P188400 Reversing light signal Short-circuit to ground
P188500 Reversing light signal Short circuit to B+
P188600 Reversing light signal Open circuit
P188700 Vehicle Speed Signal wheel speed from brake control module Implausible signal
P188800 valve for coolant system circuit Short circuit to B+
P188900 valve for coolant system circuit Short circuit to ground/open circuit
P188A00 Coolant shut-off valve Electrical malfunction
P189000 Signal wire for Tiptronic Electrical malfunction
P189100 Signal wire for Tiptronic Implausible signal
P189200 Selector lever position detection Defective
P189300 Signal wire for gear display in selector lever Electrical malfunction
P189400 Signal wire for gear display in selector lever Implausible signal
P189500 Function restriction due to pressure drop
P189600 Coupling 1 Temperature shock
P189700 Coupling 2 Temperature shock
P189800 Coupling 1 Function restriction
P189900 Coupling 2 Function restriction
P189A00 Coupling 1 Clearance too small
P189B00 Coupling 2 Clearance too small
P189C00 Function restriction due to insufficient pressure build-up
P190000 Fan 2 control circuit Open circuit/short circuit to ground
P190100 After-Run Coolant Fan Control (FC) Control Module -J138- Short circuit to B+
P190200 After-Run Coolant Fan Control (FC) Control Module -J138- Open circuit/short circuit to ground
P190300 Coolant Fan Valve -N313- Short circuit to B+
P190400 Coolant Fan Valve -N313- Open circuit/short circuit to ground
P190500 Charge Air Cooling Pump Relay -J536- Short circuit to B+
P190600 Charge Air Cooling Pump Relay -J536- Open circuit/short circuit to ground
P190700 Engine databus/engine Defective
P190800 Engine databus/engine Software version monitoring
P190900 Engine databus/engine Missing message from Engine Control Module (ECM) 1
P190A00 Coolant pump for charge pressure cooler Electrical malfunction
P190B00 Coolant pump for charge pressure cooler Temperature shut-off
P190C00 Coolant pump for charge pressure cooler No signal
P190D00 Coolant pump for charge pressure cooler Mechanical malfunction
P190E00 Coolant pump for charge pressure cooler Supply voltage
P190F00 Coolant pump for charge pressure cooler Electrical malfunction in load circuit
P191000 Engine databus/engine Missing message from Engine Control Module (ECM) 2
P191100 Synchronization wire engine/engine Electrical malfunction in circuit
P191200 Pressure sensor for brake booster Open circuit/short circuit to B+
P191300 Pressure sensor for brake booster Short-circuit to ground
P191400 Pressure sensor for brake booster Implausible signal
P191500 Coolant Circulation Pump Relay -J151 Short circuit to B+
P191600 Coolant Circulation Pump Relay -J151 Short-circuit to ground
P191700 Coolant Circulation Pump Relay -J151 Open circuit
P191800 Load signal from generator DF Open circuit/short circuit to B+
P191900 Load signal from generator DF Short-circuit to ground
P191A00 Loss of crankshaft synchronization
P191B00 Coolant Fan Control (FC) Control Module Implausible signal
P191C00 Control module 2 for cooling fan Implausible signal
P191D00 Coolant pump for charge pressure cooler Implausible signal
P191E00 Actuator for structure-borne noise
P191F00 Pressure sensor for brake booster Electrical malfunction
P192000 L/R Electr-Hydr Eng. Mount Sol Valve -N144/N145 Open circuit/short circuit to ground
P192100 Outside Air Temperature Sensor 2 -G249- Short-circuit to ground
P192200 Outside Air Temperature Sensor 2 -G249- Open circuit/short circuit to B+
P192300 Check DTC memory of Engine Control Module (ECM) 2
P192400 Control module pin coding Implausible signal
P192500 Auxiliary Engine Coolant (EC) Pump Relay Short circuit to B+
P192600 Auxiliary Engine Coolant (EC) Pump Relay Short-circuit to ground
P192700 Auxiliary Engine Coolant (EC) Pump Relay Open circuit
P192800 Immobilizer inquiry not yet performed
P192900 Radiator fan -V7 Open circuit
P193000 Coolant Fan -2- Open circuit
P193100 Coolant Fan Control (FC) Control Module -J293 Malfunction
P193200 Databus drivetrain implausible message from ctrl. for access start authorization
P193300 Throttle plate control 2 Malfunction
P193400 Drive Circuit Cooling Fan Temperature Sensor -G382- Signal too low
P193500 Drive Circuit Cooling Fan Temperature Sensor -G382- Signal too high
P193600 Generator switch off Open circuit/short circuit to ground
P193700 Generator switch off Short circuit to B+
P193800 Auxiliary Engine Coolant (EC) Pump Relay -J496 Open circuit/short circuit to ground
P193900 Databus drivetrain missing message from ctrl. for access start authorization
P194000 Databus drivetrain missing message f. battery monitoring control module
P194100 Databus drivetrain implausible message f. battery monitoring control module
P194200 Databus drivetrain missing message from level control system control module
P194300 Databus drivetrain implausible message from level control system control module
P194400 Control module 1 for cooling fan Excess temperature
P194500 Coolant Fan Control (FC) Control Module 1, fan activation Short circuit
P194600 Control module 1 for cooling fan Faulty/open circuit in voltage supply
P194700 Control module 2 for cooling fan Excess temperature
P194800 Coolant Fan Control (FC) Control Module 2, fan activation Short circuit
P194900 Control module 2 for cooling fan Faulty/open circuit in voltage supply
P195000 Radiator fan -V7 difficulty of movement/blocked
P195100 Coolant Fan -2- difficulty of movement/blocked
P195200 Turbocharger (TC) control module 1 Defective
P195300 Turbocharger (TC) control module 2 Defective
P195400 Glow Plug Module 2, Control Circuit Electrical malfunction in circuit
P195500 Glow Plug Control Module 2 to PCM Comm.Circuit Implausible signal
P195600 Exhaust temperature sensor 2 bank 1 Electrical malfunction
P195700 Exhaust temperature sensor 2 bank 1 Short-circuit to ground
P195800 Exhaust temperature sensor 2 bank 1 Short circuit to B+
P195900 Exhaust temperature sensor 2 bank 1 Implausible signal
P196000 Exhaust temperature control circuit exhaust bank 3 Value above upper control limit
P196100 Exhaust temperature sensor 2 bank 2 - G449 Electrical malfunction
P196200 Exhaust temperature sensor 2 bank 2 - G449 Short-circuit to ground
P196300 Exhaust temperature sensor 2 bank 2 - G449 Short circuit to B+
P196400 Exhaust temperature sensor 2 bank 2 - G449 Implausible signal
P196500 Exhaust temperature control circuit exhaust bank 4 Value above upper control limit
P196600 Sec.Air Inj.Sys.Pump C Relay Circ Open circuit
P196700 Sec.Air Inj.Sys.Pump C Relay Circ Short circuit to B+
P196800 Sec.Air Inj.Sys.Pump C Relay Circ Short-circuit to ground
P196900 Sec.Air Inj.Sys.Pump C Relay Circ electrical malfunction in circuit
P197000 Sec.Air Inj.Sys.Pump D Relay Circ Open circuit
P197100 Sec.Air Inj.Sys.Pump D Relay Circ Short circuit to B+
P197200 Sec.Air Inj.Sys.Pump D Relay Circ Short-circuit to ground
P197300 Sec.Air Inj.Sys.Pump D Relay Circ electrical malfunction in circuit
P197400 Sec.Air Inj.Valve 3 Circ electrical malfunction in circuit
P197500 Sec.Air Inj.Valve 3 Circ Short-circuit to ground
P197600 Sec.Air Inj.Valve 3 Circ Short circuit to B+
P197700 Sec.Air Inj.Valve 3 Circ Open circuit
P197800 Sec.Air Inj.Valve 4 Circ electrical malfunction in circuit
P197900 Sec.Air Inj.Valve 4 Circ Short-circuit to ground
P197A00 Sec.Air Inj.Valve 3 Circ Mechanical malfunction
P197B00 Sec.Air Inj.Valve 4 Circ Mechanical malfunction
P197C00 Secondary air injection bank 1 and bank 2 swapped
P198000 Sec.Air Inj.Valve 4 Circ Short circuit to B+
P198100 Sec.Air Inj.Valve 4 Circ Open circuit
P198200 Exhaust temperature control circuit exhaust bank 3 Implausible
P198300 Exhaust temperature control circuit exhaust bank 4 Implausible
P198400 Coolant fan 3 difficulty of movement/blocked
P198500 Coolant FC (Fan Control) Control Module 2 Malfunction
P198600 Coolant Fan Control (FC) Control Module 3, fan activation Short circuit
P198700 Function restriction due to brake temperature
P198800 Coolant Fan 3 Relay -J752- Open circuit
P198900 Coolant Fan 3 Relay -J752- Short circuit to B+
P199000 Coolant Fan 3 Relay -J752- Short-circuit to ground
P199100 Control module defective
P199200 Potentiometer 2 for EGR -G466- Malfunction in basic settings
P199300 Potentiometer 2 for EGR -G466- Signal too high
P199400 Potentiometer 2 for EGR -G466- Signal too low
P199500 Door open signal not recognized
P199600 Friction too high Code E1
P199700 Friction too high Code A1
P199800 Friction too high Code E2
P199900 Friction too high Code E2
P199A00 Temperature sensor for engine temperature management Signal too high
P199B00 Temperature sensor for engine temperature management Signal too low
P199C00 Thermostat for cylinder head Short-circuit to B+
P199D00 Thermostat for cylinder head Short circuit to ground
P199E00 Thermostat for cylinder head Open circuit
P199F00 Thermostat control for cylinder head Excess temperature
P19A000 Thermostat for transmission Short-circuit to B+
P19A100 Thermostat for transmission Short circuit to ground
P19A200 Thermostat for transmission Open circuit
P19A300 Thermostat control for transmission Excess temperature
P19A400 Actuator for engine temperature regulation Short-circuit to B+
P19A500 Actuator for engine temperature regulation Short circuit to ground
P19A600 Actuator for engine temperature regulation Open circuit
P1A0100 Crash signal monitoring failed
P1A0200 Hybrid battery system Insulation malfunction warning 1
P1A0300 Hybrid battery system Insulation malfunction warning 2
P1AFE00 Next output Diagnostic Test Mode (DTM) --> confirmation
P1AFF00 Actuator test end
P1B0000 Generator Mechanical malfunction
P1B0100 Generator Electrical malfunction
P1B0200 Control unit for battery monitoring Defective
P1B0300 Locking electronics solenoid Short-circuit to ground
P1B0400 Locking electronics solenoid Short circuit to B+
P1B0500 Locking electronics solenoid Open circuit
P1B0600 Locking electronics solenoid Resistance too small
P1B0700 Locking electronics solenoid Short circuit between coil A and B
P1B0800 Locking electronics switch Short-circuit to ground
P1B0900 Locking electronics sensor Short circuit to ground
P1B0A00 Locking electronics sensor Defective
P1B0B00 Locking electronics sensor Open circuit/short circuit to B+
P1B0C00 Lock hardware Mechanical malfunction
P200000 NOx Adsorber Efficiency Bank 1 Below Threshold
P200200 Particulate Trap Bank 1 Efficiency Below Threshold
P200300 Particulate Trap Bank 2 Efficiency Below Threshold
P200400 Intake Manifold Runner Control Bank 1 Stuck Open
P200500 Intake Manifold Runner Control Bank 2 Stuck Open
P200600 Intake Manifold Runner Control Bank 1 Stuck Closed
P200700 Intake Manifold Runner Control Bank 2 Stuck Closed
P200800 Intake Manifold Runner Bank 1 Control Circuit/Open
P200900 Intake Manifold Runner Bank 1 Control Circuit Low
P200A00 Intake Manifold Runner Bank 1 Performance
P200B00 Intake Manifold Runner Bank 2 Performance
P201000 Intake Manifold Runner Bank 1 Control Circuit High
P201100 Intake Manifold Runner Bank 2 Control Circuit/Open
P201200 Intake Manifold Runner Bank 2 Control Circuit Low
P201300 Intake Manifold Runner Bank 2 Control Circuit High
P201400 Intake Manifold Runner Position Sensor/Switch Circuit
P201500 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance
P201600 Intake Manifold Runner Position Sensor/Switch Circuit Low
P201700 Intake Manifold Runner Position Sensor/Switch Circuit High
P201900 Intake Manifold Runner Position Sensor/Switch Circuit Bank 2
P202000 Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 Range/Performance
P202100 Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 Low
P202200 Intake Manifold Runner Pos. Sen./Switch Circuit Bank 2 High
P202400 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit
P202500 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Performance
P202600 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit Low Voltage
P202700 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit High Voltage
P202A00 Reductant Tank Heater Control Circuit/Open
P202B00 Reductant Tank Heater Control Circuit Low
P202C00 Reductant Tank Heater Control Circuit High
P203100 Exhaust Gas Temperature Sensor 2, Bank 1 Circuit
P203200 Exhaust Gas Temperature Sensor 2, Bank 1 Circuit Low
P203300 Exhaust Gas Temperature Sensor 2, Bank 1 Circuit High
P203400 Exhaust Gas Temperature Sensor 2 Bank 2 Circuit
P203500 Exhaust Gas Temperature Sensor 2 Bank 2 Circuit Low
P203600 Exhaust Gas Temperature Sensor 2 Bank 2 Circuit High
P203A00 Reductant Level Sensor Circuit
P203B00 Reductant Level Sensor Circuit Range/Performance
P203C00 Reductant Level Sensor Circuit Low
P203D00 Reductant Level Sensor Circuit High
P204700 Reductant Injection Valve Circuit/Open Bank 1 Unit 1
P204800 Reductant Injection Valve Circuit Low Bank 1 Unit 1
P204900 Reductant Injection Valve Circuit High Bank 1 Unit 1
P204A00 Reductant Pressure Sensor Circuit
P204B00 Reductant Pressure Sensor Circuit Range/Performance
P204D00 Reductant Pressure Sensor Circuit High
P205A00 Reductant Tank Temperature Sensor Circuit
P205B00 Reductant Tank Temperature Sensor Circuit Range/Performance
P205C00 Reductant Tank Temperature Sensor Circuit Low
P207000 Intake Manifold Tuning (IMT) Valve Stuck Open
P207100 Intake Manifold Tuning (IMT) Valve Stuck Closed
P207300 Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Idle
P207400 Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load
P207500 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit
P207600 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Range/Performance
P207700 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Low
P207800 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit High
P207900 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Intermittent
P207F00 Reductant Quality Performance
P208000 Exhaust Gas Temperature Sensor Circuit Bank1 Range/Performance
P208200 Exhaust Gas Temperature Sensor Circuit Bank2 Range/Performance
P208400 Exhaust Gas Temperature Sensor 2 Circuit Range/Performance
P208600 Exhaust Gas Temperature Sensor 2 Circuit Bank 2 Range/Performance
P208800 A Camshaft Position Actuator Control Circuit Low - Bank 1
P208900 A Camshaft Position Actuator Control Circuit High - Bank 1
P208A00 Reductant Pump "A" Control Circuit/Open
P208B00 Reductant Pump "A" Control Range/Performance
P208C00 Reductant Pump "A" Control Circuit Low
P208D00 Reductant Pump "A" Control Circuit High
P208E00 Reductant Injection Valve Stuck Closed Bank 1 Unit 1
P209000 B Camshaft Position Actuator Control Circuit(Bank1) Low
P209100 B Camshaft Position Actuator Control Circuit(Bank1) High
P209200 A Camshaft Position Actuator Control Circuit(Bank2) Low
P209300 A Camshaft Position Actuator Control Circuit(Bank2) High
P209400 B Camshaft Position Actuator Control Circuit(Bank2) Low
P209500 B Camshaft Position Actuator Control Circuit(Bank2) High
P209600 Post Catalyst Fuel Trim System Bank1 Too Lean
P209700 Post Catalyst Fuel Trim System Bank 1 Too Rich
P209800 Post Catalyst Fuel Trim System Bank 2 Too Lean
P209900 Post Catalyst Fuel Trim System Bank2 Too Rich
P209F00 Reductant Tank Heater Control Circuit Performance
P20A000 Reductant Purge Control Valve Circuit /Open
P20A200 Reductant Purge Control Valve Circuit Low
P20A300 Reductant Purge Control Valve Circuit High
P20A500 Reductant Purge Control Valve Stuck Closed
P20B500 Reductant Metering Unit Heater Control Circuit/Open
P20B700 Reductant Metering Unit Heater Control Circuit Low
P20B800 Reductant Metering Unit Heater Control Circuit High
P20B900 Reductant Heater "A" Control Circuit/Open
P20BB00 Reductant Heater "A" Control Circuit Low
P20BC00 Reductant Heater "A" Control Circuit High
P20BD00 Reductant Heater "B" Control Circuit/Open
P20BF00 Reductant Heater "B" Control Circuit Low
P20C000 Reductant Heater "B" Control Circuit High
P20D800 Exhaust Aftertreatment Fuel Supply Control Performance
P20E800 Reductant Pressure Too Low
P20E900 Reductant Pressure Too High
P20EE00 SCR NOx Catalyst Efficiency Below Threshold Bank 1
P20F400 Reductant Consumption Too Low
P20F500 Reductant Consumption Too High
P210000 Throttle Actuator Control Motor Circuit/Open
P210100 Throttle Actuator Control Motor Circuit Range/performance
P210200 Throttle Actuator Control Motor Circuit Low
P210300 Throttle Actuator "A" Control Motor Circuit High
P210600 Throttle Actuator Control System Forced Limited Power
P210800 Throttle Actuator Control Module Performance
P210A00 Throttle Actuator "B" Control Motor Circuit/Open
P210B00 Throttle Actuator "B" Control Motor Circuit Range/Performance
P210C00 Throttle Actuator "B" Control Motor Circuit Low
P210D00 Throttle Actuator "B" Control Motor Circuit High
P211000 Throttle Actuator Control System - Forced Limited RPM
P211100 Throttle Actuator Control System - Stuck Open
P211200 Throttle Actuator Control System - Stuck closed
P211900 Throttle Actuator Control Throttle Body Range/Performance
P212200 Throttle/Pedal Pos. Sens./Switch D Circuit Low Input
P212300 Throttle/Pedal Pos. Sens./Switch D Circuit High Input
P212700 Throttle/Pedal Pos. Sens./Switch E Circuit Low Input
P212800 Throttle/Pedal Pos. Sens./Switch E Circuit High Input
P212B00 Throttle Position Sensor/Switch "G" Circuit Range/Performance
P212C00 Throttle Position Sensor/Switch "G" Circuit Low
P212D00 Throttle Position Sensor/Switch "G" Circuit High
P213100 Throttle/Pedal Position Sensor/Switch "F" Circuit Range/Performance
P213200 Throttle/Pedal Position Sensor/Switch "F" Circuit Low
P213300 Throttle/Pedal Position Sensor/Switch "F" Circuit High
P213500 Throttle/Pedal Position Sensor/Switch "A"/"B" Voltage Correlation
P213800 Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation
P214600 Fuel Injector Group "A" Supply Voltage Circuit Open
P214700 Fuel Injector Group "A" Supply Voltage Circuit Low
P214800 Fuel Injector Group "A" Supply Voltage Circuit High
P214900 Fuel Injector Group "B" Supply Voltage Circuit Open
P215000 Fuel Injector Group "B" Supply Voltage Circuit Low
P215100 Fuel Injector Group "B" Supply Voltage Circuit High
P215200 Fuel Injector Group "C" Supply Voltage Circuit/Open
P215300 Fuel Injector Group "C" Supply Voltage Circuit Low
P215400 Fuel Injector Group "C" Supply Voltage Circuit High
P215500 Fuel Injector Group "D" Supply Voltage Circuit/Open
P215600 Fuel Injector Group "D" Supply Voltage Circuit Low
P215700 Fuel Injector Group "D" Supply Voltage Circuit High
P215900 Vehicle Speed Sensor "B" Range/Performance
P216A00 Fuel Injector Group "E" Supply Voltage Circuit/Open
P216B00 Fuel Injector Group "E" Supply Voltage Circuit/Low
P216C00 Fuel Injector Group "E" Supply Voltage Circuit/High
P216D00 Fuel Injector Group "F" Supply Voltage Circuit/Open
P216E00 Fuel Injector Group "F" Supply Voltage Circuit/Low
P216F00 Fuel Injector Group "F" Supply Voltage Circuit/High
P217300 Throttle Actuator Control System - High Airflow Detected
P217500 Throttle Actuator Control System - Low Airflow Detected
P217700 System too lean off idle, Bank 1
P217800 System too rich off idle, Bank 1
P217900 System too lean off idle, Bank 2
P218000 System too rich off idle, Bank 2
P218100 Cooling System Performance
P218300 Engine Coolant Temperature Sensor 2 Circuit Range/Performance
P218400 Engine Coolant Temperature Sensor 2 Circuit Low
P218500 Engine Coolant Temperature Sensor 2 Circuit High
P218700 System too lean at idle, Bank 1
P218800 System too rich at idle, Bank 1
P218900 System too lean at idle, Bank 2
P219000 System too rich at idle, Bank 2
P219100 System Too Lean at Higher Load; Bank 1
P219200 System Too Rich at Higher Load; Bank 1
P219300 System Too Lean at Higher Load; Bank 2
P219400 System Too Rich at Higher Load; Bank 2
P219500 O2 Sensor Signal Stuck Lean Bank 1 Sensor 1
P219600 O2 Sensor Signal Stuck Rich Bank 1 Sensor 1
P219700 O2 Sensor Signal Stuck Lean Bank 2 Sensor 1
P219800 O2 Sensor Signal Stuck Rich Bank 2 Sensor 1
P219900 Intake Air Temperature Sensor 1/2 Correlation
P219A00 Bank 1 Air-Fuel Ratio Imbalance
P219B00 Bank 2 Air-Fuel Ratio Imbalance
P219C00 Cylinder 1 Air-Fuel Ratio Imbalance
P219D00 Cylinder 2 Air-Fuel Ratio Imbalance
P219E00 Cylinder 3 Air-Fuel Ratio Imbalance
P219F00 Cylinder 4 Air-Fuel Ratio Imbalance
P21A000 Cylinder 5 Air-Fuel Ratio Imbalance
P21A100 Cylinder 6 Air-Fuel Ratio Imbalance
P21A200 Cylinder 7 Air-Fuel Ratio Imbalance
P21A300 Cylinder 8 Air-Fuel Ratio Imbalance
P21A400 Cylinder 9 Air-Fuel Ratio Imbalance
P21A500 Cylinder 10 Air-Fuel Ratio Imbalance
P21A600 Cylinder 11 Air-Fuel Ratio Imbalance
P21A700 Cylinder 12 Air-Fuel Ratio Imbalance
P220000 NOx Sensor Bank 1 Sensor 1 Circuit
P220100 NOx Sensor Circuit Range/Performance Bank 1 Sensor 1
P220200 NOx Sensor Bank 1 Sensor 1 Circuit Low
P220300 NOx Sensor Bank 1 Sensor 1 Circuit High
P220900 NOx Sensor Heater Sense Bank 1 Sensor 1 Circuit Range/Performance
P220A00 NOx Sensor Supply Voltage Bank 1 Sensor 1 Circuit
P220B00 NOx Sensor Supply Voltage Bank 1 Sensor 2 Circuit
P222700 Barometric Pressure Circuit Range/Performance
P222800 Barometric Pressure Circuit Low
P222900 Barometric Pressure Circuit high
P223100 O2 Sensor Bank 1 Sensor 1 Signal Circuit Shorted to Heater Circuit
P223200 O2 Sensor Bank 1 Sensor 2 Signal Circuit Shorted to Heater Circuit
P223300 O2 Sensor Bank 1 Sensor 3 Signal Circuit Shorted to Heater Circuit
P223400 O2 Sensor Bank 2 Sensor 1 Signal Circuit Shorted to Heater Circuit
P223500 O2 Sensor Bank 2 Sensor 2 Signal Circuit Shorted to Heater Circuit
P223600 O2 Sensor Bank 2 Sensor 3 Signal Circuit Shorted to Heater Circuit
P223700 O2 Sensor Positive Current Control Circuit Bank 1 Sensor 1 Open
P223800 O2 Sensor Positive Current Control Circuit Bank 1 Sensor 1 Low
P223900 O2 Sensor Positive Current Control Circuit Bank 1 Sensor 1 High
P224000 O2 Sensor Positive Current Control Circuit Bank 2 Sensor 1 Open
P224100 O2 Sensor Positive Current Control Circuit Bank 2 Sensor 1 Low
P224200 O2 Sensor Positive Current Control Circuit Bank 2 Sensor 1 High
P224300 O2 Sensor Reference Voltage Circuit Bank 1 Sensor 1 Open
P224400 O2 Sensor Reference Voltage Bank 1 Sensor 1 Performance
P224500 O2 Sensor Reference Voltage Circuit Bank 1 Sensor 1 Low
P224600 O2 Sensor Reference Voltage Circuit Bank 1 Sensor 1 High
P224700 O2 Sensor Reference Voltage Circuit Bank 2 Sensor 1 Open
P224800 O2 Sensor Reference Voltage Bank 2 Sensor 1 Performance
P224900 O2 Sensor Reference Voltage Circuit Bank 2 Sensor 1 Low
P225000 O2 Sensor Reference Voltage Circuit Bank 2 Sensor 1 High
P225100 O2 Sensor Negative Current Control Circuit Bank 1 Sensor 1 open
P225200 O2 Sensor Negative Current Control Circuit Bank 1 Sensor 1 Low
P225300 O2 Sensor Negative Current Control Circuit Bank 1 Sensor 1 High
P225400 O2 Sensor Negative Current Control Circuit Bank 2 Sensor 1 open
P225500 O2 Sensor Negative Current Control Circuit Bank 2 Sensor 1 Low
P225600 O2 Sensor Negative Current Control Circuit Bank 2 Sensor 1 High
P225700 Secondary air injektion System Control "A" Circuit low
P225800 Secondary air injektion System Control "A" Circuit high
P226100 Turbo Boost Pressure Not Detected Mechanical
P226200 Turbocharger/Supercharger Boost Pressure Not Detected Mechanical
P226300 Turbocharger/Supercharger Boost System Performance
P227000 O2 Sensor Signal Stuck Lean; Bank 1 Sensor 2
P227100 O2 Sensor Signal Stuck Rich; Bank 1 Sensor 2
P227200 O2 Sensor Signal Stuck Lean; Bank 2 Sensor 2
P227300 O2 Sensor Signal Stuck Rich; Bank 2 Sensor 2
P227400 O2 Sensor Signal Stuck Lean; Bank 1 Sensor 3
P227500 O2 Sensor Signal Stuck Rich; Bank 1 Sensor 3
P227600 O2 Sensor Signal Stuck Lean; Bank 2 Sensor 3
P227700 O2 Sensor Signal Stuck Rich; Bank 2 Sensor 3
P227800 O2 Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
P227900 Intake Air System Leak
P228C00 Fuel Pressure Regulator 1 Exceeded Control Limits Pressure Too Low
P228D00 Fuel Pressure Regulator 1 Exceeded Control Limits Pressure Too High
P228E00 Fuel Pressure Regulator 1 Exceeded Learning Limits Too Low
P228F00 Fuel Pressure Regulator 1 Exceeded Learning Limits Too High
P229300 Fuel Pressure Regulator 2 Performance
P229400 Fuel Pressure Regulator 2 Control Circuit
P229500 Fuel Pressure Regulator 2 Control Circuit Low
P229600 Fuel Pressure Regulator 2 Control Circuit High
P229700 02 Sensor Bank 1 Sensor 1 Out of Range During Deceleration
P229800 02 Sensor Bank 2 Sensor 1 Out of Range During Deceleration
P229A00 Fuel Pressure Regulator 2 Exceeded Control Limits Pressure Too Low
P229B00 Fuel Pressure Regulator 2 Exceeded Control Limits Pressure Too High
P229E00 NOx Sensor Bank 1 Sensor 2 Circuit
P229F00 NOx Sensor Circuit Range/Performance Bank 1 Sensor 2
P22A000 NOx Sensor Bank 1 Sensor 2 Circuit Low
P22A100 NOx Sensor Bank 1 Sensor 2 Circuit High
P22A700 NOx Sensor Heater Sense Bank 1 Sensor 2 Circuit Range/Performance
P230000 Ignition Coil "A" Primary Control Circuit Low
P230100 Ignition Coil "A" Primary Control Circuit High
P230200 Ignition Coil "A" Secondary Circuit
P230300 Ignition Coil "B" Primary Control Circuit Low
P230400 Ignition Coil "B" Primary Control Circuit High
P230500 Ignition Coil "B" Secondary Circuit
P230600 Ignition Coil "C" Primary Control Circuit Low
P230700 Ignition Coil "C" Primary Control Circuit High
P230800 Ignition Coil "C" Secondary Circuit
P230900 Ignition Coil "D" Primary Control Circuit Low
P231000 Ignition Coil "D" Primary Control Circuit High
P231100 Ignition Coil "D" Secondary Circuit
P231200 Ignition Coil "E" Primary Control Circuit Low
P231300 Ignition Coil "E" Primary Control Circuit High
P231400 Ignition Coil "E" Secondary Circuit
P231500 Ignition Coil "F" Primary Control Circuit Low
P231600 Ignition Coil "F" Primary Control Circuit High
P231700 Ignition Coil "F" Secondary Circuit
P231800 Ignition Coil "G" Primary Control Circuit Low
P231900 Ignition Coil "G" Primary Control Circuit High
P232000 Ignition Coil "G" Secondary Circuit
P232100 Ignition Coil "H" Primary Control Circuit Low
P232200 Ignition Coil "H" Primary Control Circuit High
P232300 Ignition Coil "H" Secondary Circuit
P232400 Ignition Coil "I" Primary Control Circuit Low
P232500 Ignition Coil "I" Primary Control Circuit High
P232600 Ignition Coil "I" Secondary Circuit
P232700 Ignition Coil "J" Primary Control Circuit Low
P232800 Ignition Coil "J" Primary Control Circuit High
P232900 Ignition Coil "J" Secondary Circuit
P233000 Ignition Coil "K" Primary Control Circuit Low
P233100 Ignition Coil "K" Primary Control Circuit High
P233200 Ignition Coil "K" Secondary Circuit
P233300 Ignition Coil "L" Primary Control Circuit Low
P233400 Ignition Coil "L" Primary Control Circuit High
P233500 Ignition Coil "L" Secondary Circuit
P233600 Cylinder #1 Above Knock Threshold
P233700 Cylinder #2 Above Knock Threshold
P233800 Cylinder #3 Above Knock Threshold
P233900 Cylinder #4 Above Knock Threshold
P234000 Cylinder #5 Above Knock Threshold
P234100 Cylinder #6 Above Knock Threshold
P234200 Cylinder #7 Above Knock Threshold
P234300 Cylinder #8 Above Knock Threshold
P234400 Cylinder #9 Above Knock Threshold
P234500 Cylinder #10 Above Knock Threshold
P234600 Cylinder #11 Above Knock Threshold
P234700 Cylinder #12 Above Knock Threshold
P240000 Evaporative Emission System Leak Detection Pump Control Circuit/Open
P240100 Evaporative Emission System Leak Detection Pump Control Circuit Low
P240200 Evaporative Emission System Leak Detection Pump Control Circuit High
P240300 Evaporative Emission System Leak Detection Pump Sense Circuit/Open
P240400 Evaporative Emission System Leak Detection Pumpe Sense Circuit Range/Performance
P241300 Exhaust Gas Recirculation System Performance
P241400 02 Sensor Exhaust Sample Error, Bank 1 Sensor 1
P241500 02 Sensor Exhaust Sample Error, Bank 2 Sensor 1
P241600 Oxygen Sensor Signals Swapped Bank 1 Sensor 2 / Bank 1 Sensor 3
P241700 Oxygen Sensor Signals Swapped Bank 2 Sensor 2 / Bank 2 Sensor 3
P242100 Evaporative Emission System Vent Valve Stuck Open
P242200 Evaporative Emission System Vent Valve Stuck Closed
P242500 Exhaust Gas Recirculation Cooling Valve Control Circuit Open
P242600 Exhaust Gas Recirculation Cooling Valve Control Circuit Low
P242700 Exhaust Gas Recirculation Cooling Valve Control Circuit High
P242800 Exhaust Gas Temperature Too High Bank1
P242900 Exhaust Gas Temperature Too High Bank2
P242A00 Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 3
P242B00 Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 3 Range/Performance
P242C00 Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 3
P242D00 Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3
P242F00 Diesel Particulate Filter Restriction - Ash Accumulation
P243000 Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit
P243100 Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit Range/Performance
P243200 Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit Low
P243300 Secondary Air Injection System Air Flow/Pressure Bank 1 Sensor Circuit High
P244000 Secondary Air Injection System Switching Valve Stuck Open Bank1
P244200 Secondary Air Injection System Switching Valve Stuck Open Bank2
P244C00 Exhaust Temperature Too Low For Particulate Filter Regeneration Bank 1
P245200 Diesel Particulate Filter Differential Pressure Sensor Circuit
P245300 Diesel Particulate Filter Differential Pressure Sensor Circuit Range/Performance
P245400 Diesel Particulate Filter Differential Pressure Sensor Circuit Low
P245500 Diesel Particulate Filter Differential Pressure Sensor Circuit High
P245600 Diesel Particulate Filter Pressure Sensor "A" Circuit Intermittent/Erratic
P245700 Exhaust Gas Recirculation Cooling System Performance
P245B00 Exhaust Gas Recirculation Cooler Bypass Control Circuit Range/Performance
P245E00 Diesel Particulate Filter Pressure Sensor "B" Circuit
P246000 Diesel Particulate Filter Pressure Sensor "B" Circuit Low
P246300 Diesel Particulate Filter - Soot Accumulation
P246600 Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 3
P246700 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 3
P246800 Exhaust Gas Temperature Sensor Circuit Low Bank 2 Sensor 3
P246E00 Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 4
P246F00 Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 4 Range/Performance
P247000 Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 4
P247100 Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 4
P247300 Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 4
P247400 Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 4 Range/Performance
P247500 Exhaust Gas Temperature Sensor Circuit Low Bank 2 Sensor 4
P247600 Exhaust Gas Temperature Sensor Circuit High Bank 2 Sensor 4
P247800 Exhaust Gas Temperature Out of Range Bank 1 Sensor 1
P247A00 Exhaust Gas Temperature Out of Range Bank 1 Sensor 3
P251000 ECM/PCM Power Relay Sense Circuit Range/Performance
P251900 A/C Request "A" Circuit
P252000 A/C Request "A" Circuit Low
P252100 A/C Request "A" Circuit High
P253300 Ignition Switch Run/ Start Position Curciut
P253500 Ignition Switch Run/ Start Position Curciut High
P253900 Low Pressure Fuel System Sensor Circuit
P254000 Low Pressure Fuel System Sensor Circuit Range/Performance
P254100 Low Pressure Fuel System Sensor Circuit Low Input
P254200 Low Pressure Fuel System Sensor Circuit High Input
P254300 Low Pressure Fuel System Sensor Circuit Intermittent
P254500 Torque Management Request Input Signal "A" Range/Performance
P256200 Turbocharger Boost Control Position Sensor "A" Circuit
P256300 Turbocharger Boost Control Position Sensor Circuit Range/Performance
P256400 Turbocharger Boost Control Position Sensor Circuit Low
P256500 Turbocharger Boost Control Position Sensor Circuit High
P256600 Turbocharger Boost Control Position Sensor Circuit Intermittent
P256800 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Range/Performance
P256900 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Low
P257000 Direct Ozone Reduction Catalyst Temperature Sensor Circuit High
P257800 Turbocharger Speed Sensor "A" Circuit
P257900 Turbocharger Speed Sensor "A" Circuit Range/Performance
P258000 Turbocharger Speed Sensor "A" Circuit Low
P258100 Turbocharger Speed Sensor "A" Circuit High
P258200 Turbocharger Speed Sensor "A" Circuit Intermittent
P258800 Turbocharger Boost Control Position Sensor "B" Circuit Low
P258900 Turbocharger Boost Control Position Sensor "B" Circuit High
P259300 Turbocharger Speed Sensor "B" Circuit
P259400 Turbocharger Speed Sensor "B" Circuit Range/Performance
P259500 Turbocharger Speed Sensor "B" Circuit Low
P259600 Turbocharger Speed Sensor "B" Circuit High
P259700 Turbocharger Speed Sensor "B" Circuit Intermittent
P260000 Coolant Pump Control Circuit open
P260100 Coolant Pump Control Circuit range/performance
P260200 Coolant Pump Control Circuit low
P260300 Coolant Pump Control Circuit high
P261000 ECM/PCM Internal Engine Off Timer Performance
P261200 A/C Refrigerant Distribution Valve Control Circuit Low
P261300 A/C Refrigerant Distribution Valve Control Circuit High
P261A00 Coolant Pump "B" Control Circuit/Open
P261B00 Coolant Pump "B" Control Circuit Range/Performance
P261C00 Coolant Pump "B" Control Circuit Low
P261D00 Coolant Pump "B" Control Circuit High
P262600 O2 Sensor Pumping Current Trim Circuit/Open Bank 1, Sensor 1
P262900 O2 Sensor Pumping Current Trim Circuit/Open Bank 2, Sensor 1
P263200 Fuel Pump "B" Control Circuit Open
P263300 Fuel Pump "B" Control Circuit Low
P263400 Fuel Pump "B" Control Circuit High
P263700 Torque Management Feedback Signal "A"
P270000 Transmission Friction Element "A" Apply Time Range/Performance
P270100 Transmission Friction Element "B" Apply Time Range/Performance
P270200 Transmission Friction Element "C" Apply Time Range/Performance
P270300 Transmission Friction Element "D" Apply Time Range/Performance
P270400 Transmission Friction Element "E" Apply Time Range/Performance
P270500 Transmission Friction Element "F" Apply Time Range/Performance
P270800 Shift Solenoid F Stuck On
P271100 Unexpected Mechanical Gear Disengagement
P271400 Pressure Control Solenoid "D" Performance or Stuck Off
P271500 Pressure Control Solenoid "D" Stuck On
P271600 Pressure Control Solenoid "D" Electrical
P271700 Pressure Control Solenoid "D" Intermittent
P272300 Pressure Control Solenoid "E" Performance or Stuck Off
P272400 Pressure Control Solenoid "E" Stuck On
P272500 Pressure Control Solenoid "E" Electrical
P272600 Pressure Control Solenoid "E" Intermittent
P273200 Pressure Control Solenoid "F" Performance or Stuck Off
P273300 Pressure Control Solenoid "F" Stuck On
P273400 Pressure Control Solenoid "F" Electrical
P273500 Pressure Control Solenoid "F" Intermittent
P275300 Transmission Fluid Cooler Control Circuit/Open
P275400 Transmission Fluid Cooler Control Circuit Low
P275500 Transmission Fluid Cooler Control Circuit High
P276500 Input Turbine/Speed Sensor "B" Circuit
P276600 Input Turbine/Speed Sensor "B" Circuit Range/Performance
P278700 Clutch Temperature Too High
P278900 Clutch Adaptive Learning at Limit
P278B00 Kick Down Switch Circuit Range/Performance
P281000 Pressure Control Solenoid "G" Electrical
P281200 Pressure Control Solenoid "G" Control Circuit/Open
P281400 Pressure Control Solenoid "G" Control Circuit Low
P281500 Pressure Control Solenoid "G" Control Circuit High
P2BA700 NOx Exceedence - Empty Reagent Tank
P300000 Glow Plug Indicator Light -K29- Malfunction message from instrument cluster
P300100 Operating RPM regulation Control difference
P300200 Kick Down Switch -F8- Implausible signal
P300300 Low heat output relay-J359 Short circuit to B+
P300400 Low heat output relay-J359 Open circuit/short circuit to ground
P300500 High heat output relay -J360 Short circuit to B+
P300600 High heat output relay -J360 Open circuit/short circuit to ground
P300700 Camshaft Position (CMP) Sensor -G40- No signal
P300800 Camshaft Position (CMP) Sensor -G40- Signal outside tolerance
P300900 Relay for pump, fuel cooling -J445- Short circuit to B+
P300A00 Diesel Particulate Filter Differential Pressure Sensor Implausible signal
P300B00 Diesel Particulate Filter Differential Pressure Sensor Short-circuit to ground
P300C00 Diesel Particulate Filter Differential Pressure Sensor Short circuit to B+
P300D00 Diesel Particulate Filter Differential Pressure Sensor Electrical malfunction
P300E00 Particulate Trap Bank 2 restriction
P300F00 Fuel bypass valve Open circuit
P301000 Relay for pump, fuel cooling -J445- Open circuit/short circuit to ground
P301100 Fuel Pump (FP) 2 Relay -J49- Short circuit to B+
P301200 Fuel Pump (FP) 2 Relay -J49- Open circuit/short circuit to ground
P301300 Wastegate Bypass Regulator Valve 2 -N274- Short circuit to B+
P301400 Wastegate Bypass Regulator Valve 2 -N274- Open circuit/short circuit to ground
P301500 Fuel Bypass Valve -N312- Short circuit to B+
P301600 Fuel Bypass Valve -N312- Open circuit/short circuit to ground
P301700 Exhaust Flap Valve 1 -N321- Short circuit to B+
P301800 Exhaust Flap Valve 1 -N321- Short-circuit to ground
P301900 Exhaust Flap Valve 1 -N321- Open circuit
P301A00 Exhaust flap sensor bank 2 Electrical malfunction
P301B00 Exhaust flap sensor bank 2 Implausible signal
P301C00 Exhaust flap sensor bank 2 Short circuit to B+
P301D00 Exhaust flap bank 2 Electrical malfunction
P301E00 Exhaust flap bank 2 Control difference
P301F00 Exhaust flap bank 2 Short circuit to B+
P302000 Exhaust Flap Valve 1 -N321- Electrical malfunction in circuit
P302100 Exhaust Flap Valve 2 -N322- Short circuit to B+
P302200 Exhaust Flap Valve 2 -N322- Short-circuit to ground
P302300 Exhaust Flap Valve 2 -N322- Open circuit
P302400 Exhaust Flap Valve 2 -N322- Electrical malfunction in circuit
P302500 Throttle Drive Angle Sensor 1 -G297 Implausible signal
P302600 Throttle Drive Angle Sensor 1 -G297 Signal too low
P302700 Throttle Drive Angle Sensor 1 -G297 Signal too high
P302800 Throttle Drive Angle Sensor 2 -G298 Implausible signal
P302900 Throttle Drive Angle Sensor 2 -G298 Signal too low
P302A00 Low heat output relay Open circuit
P302B00 Relay for Preheating Coolant, High Heat Output Open circuit
P302C00 Low heat output relay Short-circuit to ground
P302D00 Relay for Preheating Coolant, High Heat Output Short-circuit to ground
P302E00 Relay for pump, fuel cooling Open circuit
P302F00 Relay for pump, fuel cooling Short-circuit to ground
P303000 Throttle Drive Angle Sensor 2 -G298 Signal too high
P303100 Throttle Actuator 2 electrical malfunction in circuit
P303200 Throttle Valve Control Module 2 -J544- Malfunction in basic settings
P303300 Intake Air Temp.Circ.2 Signal too low
P303400 Intake Air Temp.Circ.2 Signal too high
P303500 Throttle Valve Control Module 2 -J544- Mechanical malfunction
P303600 Throttle Valve Control Module 2 -J544- insufficient voltage during basic settings
P303700 Throttle Valve Control Module 2 -J544- Adaptation not initiated
P303800 Throttle Valve Control Module 2 -J544- lower stop not reached
P303900 Transmission request torque reduction Implausible
P303A00 Auxiliary Fuel Pump (FP) Relay Open circuit
P303B00 Auxiliary Fuel Pump (FP) Relay Short-circuit to ground
P303C00 Auxiliary Fuel Pump (FP) Relay Short circuit to B+
P303D00 Cold start valve Open circuit
P303E00 Cold start valve Short circuit to B+
P303F00 Cold start valve Short-circuit to ground
P304000 Transmission ratio Implausible
P304100 Databus drivetrain implausible engine temperature message from instrument ECU
P304200 Heater regulation Implausible signal
P304300 Throttle Transfer Fuel Pump (FP) Mechanical malfunction
P304400 Throttle Transfer Fuel Pump (FP) Short circuit
P304500 Fuel pump electronics Defective
P304600 Starter relay 1 Electrical malfunction in circuit (relay stuck/does not switch)
P304700 Activation starter relay 2 Short circuit to B+
P304800 Activation starter relay 2 Short-circuit to ground
P304900 Activation starter relay 2 Open circuit
P304A00 Starter relay 1 Short-circuit to ground
P304B00 Potentiometer for heater control Electrical malfunction
P305000 Starter relay 2 Electrical malfunction in circuit (relay stuck/does not switch)
P305100 Starter activation, return message terminal 50 Implausible signal
P305200 Starter activation, return message terminal 50 Short circuit to B+
P305300 Starter activation, return message terminal 50 Short circuit to ground/open circuit
P305400 Starter does not turn Mechanically blocked or electrical malfunction
P305500 Exhaust Pressure Sensor 2 Open circuit
P305600 Exhaust Pressure Sensor 2 Short-circuit to ground
P305700 Exhaust Pressure Sensor 2 Short circuit to B+
P305800 Exhaust Gas Recirc.Flow 2 Flow too Low
P305900 Exhaust Gas Recirc.Flow 2 throughput too large
P305A00 Gasoline operation Random/Multiple Cylinder. Misfire Detected
P306000 Cooling Bypass Valve, Exhaust Gas Recirculation Flow Electrical malfunction
P306100 Cooling Bypass Valve 2, Exhaust Gas Recirculation Flow Electrical malfunction
P306200 Turbo/Super Charger 2 Overboost Condition
P306300 Turbo/Super Charger 2 Underboost condition
P306400 Boost Pressure Contr.Valve 3 Circuit Electrical malfunction
P306500 Boost Pressure Contr.Valve 3 Circuit Short-circuit to ground
P306600 Boost Pressure Contr.Valve 3 Circuit Short circuit to B+
P306700 Boost Pressure Contr.Valve 4 Circuit Electrical malfunction
P306800 Boost Pressure Contr.Valve 4 Circuit Short-circuit to ground
P306900 Boost Pressure Contr.Valve 4 Circuit Short circuit to B+
P307000 Metering pump for cleaning solution Defective
P307100 Additive tank for particle filter empty
P307200 Voltage supply relay Electrical malfunction in circuit
P307300 Throttle Transfer Fuel Pump (FP) Electrical malfunction in circuit
P307400 Fuel Pump 2 Electrical malfunction in circuit
P307500 Turbo boost 1/2 Trim Adaptation Limit Attained
P307600 Engine Control Module (ECM) Error during coding
P307700 Fuel Pump Electronics, voltage supply Electrical malfunction
P307800 Throttle Valve Control Module Air Flow at idle too Low
P307900 Cold Start Fuel Pump (FP) Relay Short circuit to B+
P307A00 Intake system Air flow too low
P307B00 Activation Fuel pump module 2 Electrical malfunction/open
P307C00 Activation Fuel pump module 2 Implausible signal
P307D00 Activation Fuel pump module 2 Short-circuit to ground
P307E00 Activation Fuel pump module 2 Short circuit to B+
P308000 Cold Start Fuel Pump (FP) Relay -J748 Short circuit to ground/open circuit
P308100 Engine temperature too low
P308200 Clutch positioning sensor Implausible signal
P308300 Fuel level sensor for additive tank particulate trap, Electrical malfunction in circuit
P308400 Recirculating valve for turbocharger bank 2 Mechanical malfunction
P308500 Activation Intake Manifold Runner Bank 2 Control Electrical malfunction
P308600 Intake Manifold Runner Bank 2 Basic settings not carried out
P308700 Supply relay for engine components Electrical malfunction in circuit
P308800 Starter relay Electrical malfunction in circuit
P308900 Fuel pump electronics signal wire Electrical malfunction
P308A00 Fuel pump electronics NG operation signal wire Short circuit to B+
P308B00 Fuel pump electronics NG operation signal wire Short-circuit to ground
P308C00 Fuel pump electronics NG operation signal wire Open circuit
P308D00 Throttle Transfer Fuel Pump (FP) Engine speed too low
P308E00 Fuel pump electronics Excess temperature
P309000 Auxiliary heater signal not recognized
P309100 Auxiliary heater signal constant detected
P309200 Control module defective
P309300 Control module defective
P309400 Control module defective
P309500 Control module defective
P309600 Control module defective
P309700 Control module defective
P309800 Control module defective
P309900 Control module defective
P310000 Intake Flap Motor -V157 Short circuit to B+
P310100 Intake Flap Motor -V157 Open circuit/short circuit to ground
P310200 Intake Flap Motor -V157 No signal
P310300 Intake Flap Motor -V157 Defective
P310400 Intake manifold flap change-over valve- N239 Short circuit to B+
P310500 Intake manifold flap change-over valve- N239 Open circuit/short circuit to ground
P310600 Cylinder 7 Pump/Injector -N303- Implausible signal
P310700 Cylinder 7 Pump/Injector -N303- Value above upper control limit
P310800 Cylinder 7 Pump/Injector -N303- Value below lower control limit
P310900 Cylinder 7 Pump/Injector -N303- Electrical malfunction in circuit
P310A00 Low Fuel Pressure regulation Fuel pressure fluctuates
P310B00 Low Fuel Pressure regulation Fuel pressure outside specification
P310C00 Low Fuel Pressure regulation Fuel pressure breaks down sporadically
P310D00 Fuel Pressure Regulation Fuel pressure fluctuates
P310E00 Exhaust gas recirculation cooler bypass valve 2 Implausible signal
P311000 Cylinder 8 Pump/Injector -N304- Implausible signal
P311100 Cylinder 8 Pump/Injector -N304- Value above upper control limit
P311200 Cylinder 8 Pump/Injector -N304- Value below lower control limit
P311300 Cylinder 8 Pump/Injector -N304- Electrical malfunction in circuit
P311400 Cylinder 9 Pump/Injector -N305- Implausible signal
P311500 Cylinder 9 Pump/Injector -N305- Value above upper control limit
P311600 Cylinder 9 Pump/Injector -N305- Value below lower control limit
P311700 Cylinder 9 Pump/Injector -N305- Electrical malfunction in circuit
P311800 Cylinder 10 Pump/Injector -N306- Implausible signal
P311900 Cylinder 10 Pump/Injector -N306- Value above upper control limit
P312000 Cylinder 10 Pump/Injector -N306- Value below lower control limit
P312100 Cylinder 10 Pump/Injector -N306- Electrical malfunction in circuit
P312200 Cylinder 11 Pump/Injector -N307- Implausible signal
P312300 Cylinder 11 Pump/Injector -N307- Value above upper control limit
P312400 Cylinder 11 Pump/Injector -N307- Value below lower control limit
P312500 Cylinder 11 Pump/Injector -N307- Electrical malfunction in circuit
P312600 Cylinder 12 Pump/Injector -N308- Implausible signal
P312700 Cylinder 12 Pump/Injector -N308- Value above upper control limit
P312800 Cylinder 12 Pump/Injector -N308- Value below lower control limit
P312900 Cylinder 12 Pump/Injector -N308- Electrical malfunction in circuit
P313000 Exhaust Gas Recirculation (EGR) system Value above upper control limit
P313100 Exhaust Gas Recirculation (EGR) system Value below lower control limit
P313200 Glow Plug Module 2, Control Circuit Electrical malfunction in circuit
P313300 Automatic Glow Time Control Relay 2-J609 Implausible signal
P313400 Intake Manifold Runner Control (IMRC) Upper stop not reached
P313500 Intake Manifold Runner Control (IMRC) lower limit not reached
P313600 Intake Manifold Runner Control (IMRC) Target value not reached
P313700 Intake Manifold Runner Control (IMRC) Basic settings not carried out
P313800 Intake Manifold Runner Control (IMRC) Control difference
P313900 Intake Manifold Runner Control (IMRC) Signal outside tolerance
P313A00 Intake Manifold Runner Control (IMRC), bank 2 Signal outside tolerance
P313B00 Intake Manifold Runner Control (IMRC), bank 2 Control difference
P313C00 Intake Manifold Runner Control (IMRC), bank 2 difficulty of movement or blocked
P313D00 Intake Manifold Runner Control (IMRC) difficulty of movement or blocked
P314000 Valve for starting with empty tank -N349 Open circuit/short circuit to ground
P314100 Valve for starting with empty tank -N349 Short circuit to B+
P314200 Exhaust-bank2,sensor1,oxygen sensor signal implausible lean
P314300 Exhaust-bank2,sensor1,oxygen sensor signal Implausible rich
P314400 Exhaust-bank3,sensor1,oxygen sensor signal implausible lean
P314500 Exhaust-bank3,sensor1,oxygen sensor signal Implausible rich
P314600 Exhaust-bank4,sensor1,oxygen sensor signal implausible lean
P314700 Exhaust-bank4,sensor1,oxygen sensor signal Implausible rich
P314800 Exhaust bank 3, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P314900 Exhaust bank 3, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P315000 Exhaust bank 4, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P315100 Exhaust bank 4, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P315200 Exhaust gas bank3, sensor1 Internal resistance too Large
P315300 Exhaust gas bank4, sensor1 Internal resistance too Large
P315400 Exhaust-bank2-sensor1 Voltage too low/air leak
P315500 Emissions-bank3-sensor1 Voltage too low/air leak
P315600 Emissions-bank4-sensor1 Voltage too low/air leak
P315700 Exhaust-bank1,sensor1,oxygen sensor signal Voltage too low during deceleration
P315800 Exhaust-bank2,sensor1,oxygen sensor signal Voltage too low during deceleration
P315900 Exhaust-bank3,sensor1,oxygen sensor signal Voltage too low during deceleration
P316000 Exhaust-bank4,sensor1,oxygen sensor signal Voltage too low during deceleration
P316100 Linear oxy. sensor,exh-bank1/compensat. wire pump current Open circuit
P316200 Linear oxy. sensor,exh-bank2/compensat. wire pump current Open circuit
P316300 Linear oxy. sensor,exh-bank3/compensat. wire pump current Open circuit
P316400 Linear oxy. sensor,exh-bank4/compensat. wire pump current Open circuit
P316500 Exhaust-bank3,oxygen sensor correction behind cat Lean control limit exceeded
P316600 Exhaust-bank3,oxygen sensor correction behind cat Rich control limit exceeded
P316700 Exhaust-bank4,oxygen sensor correction behind cat Lean control limit exceeded
P316800 Exhaust-bank4,oxygen sensor correction behind cat Rich control limit exceeded
P316900 Exhaust-bank3 main catalytic converter Efficiency below threshold
P317000 Exhaust-bank4 main catalytic converter Efficiency below threshold
P317100 Exhaust-bank1, mixture adaptation range 3 System too lean
P317200 Exhaust-bank1, mixture adaptation range 3 System too rich
P317300 Exhaust-bank2, mixture adaptation range 3 System too lean
P317400 Exhaust-bank2, mixture adaptation range 3 System too rich
P317500 Exhaust bank3, mixture adaptation range 3 System too lean
P317600 Exhaust bank3, mixture adaptation range 3 System too rich
P317700 Exhaust bank4, mixture adaptation range 3 System too lean
P317800 Exhaust bank4, mixture adaptation range 3 System too rich
P317900 Cyl.13-Fuel Inj.Circ. Short-circuit to ground
P318000 Cyl.13-Fuel Inj.Circ. Short circuit to B+
P318100 Cyl.13-Fuel Inj.Circ. Open circuit
P318200 Cyl.14-Fuel Inj.Circ. Short-circuit to ground
P318300 Cyl.14-Fuel Inj.Circ. Short circuit to B+
P318400 Cyl.14-Fuel Inj.Circ. Open circuit
P318500 Cyl.15-Fuel Inj.Circ. Short-circuit to ground
P318600 Cyl.15-Fuel Inj.Circ. Short circuit to B+
P318700 Cyl.15-Fuel Inj.Circ. Open circuit
P318800 Cyl.16-Fuel Inj.Circ. Short-circuit to ground
P318900 Cyl.16-Fuel Inj.Circ. Short circuit to B+
P319000 Cyl.16-Fuel Inj.Circ. Open circuit
P319100 Intake Manifold Runner Control (IMRC) Basic setting aborted with mechanical impact open
P319200 Intake Manifold Runner Control (IMRC) Basic setting aborted with mechanical impact open
P319300 Intake Manifold Runner Control (IMRC) open impact outside valid range
P319400 Mass Air Flow (MAF) Sensor 3 -G456 Signal too low
P319500 Mass Air Flow (MAF) Sensor 3 -G456 Signal too high
P319600 Mass Air Flow (MAF) Sensor 4 -G457 Signal too low
P319700 Mass Air Flow (MAF) Sensor 4 -G457 Signal too high
P319800 Intake manifold Runner Control (IMRC) Implausible signal
P319900 Activation Intake Manifold Runner Bank 2 Control Implausible signal
P319A00 Air mass meter 3/4 Correlation
P319B00 Mass Air Flow (MAF) Sensor 3 -G456 Implausible signal
P319C00 Mass Air Flow (MAF) Sensor 4 -G457 Implausible signal
P319D00 Activation Intake Manifold Runner Bank 2 Control Short circuit to B+
P319E00 Activation Intake Manifold Runner Bank 2 Control Open circuit/short circuit to ground
P320000 Exhaust-bank3 -sensor1, heating circuit Short-circuit to ground
P320100 Exhaust-bank3 -sensor1, heating circuit Short circuit to B+
P320200 Exhaust-bank3 -sensor1, heating circuit Open circuit
P320300 Exhaust-bank3 -sensor1, heating circuit Malfunction
P320400 Emissions-bank3-sensor1 Internal resistance too Large
P320500 Emissions-bank3-sensor1 Low Voltage
P320600 Emissions-bank3-sensor1 High Voltage
P320700 Emissions-bank3-sensor1 electrical malfunction in circuit
P320800 Emissions-bank3-sensor1 No Activity Detected
P320900 Emissions-bank3-sensor1 Slow Response
P321000 Exhaust-bank3 -sensor1, heating circuit Performance too low
P321100 Exhaust-bank1-sensor1 Heater back-coupling
P321200 Exhaust-bank2-sensor1 Heater back-coupling
P321300 Emissions-bank3-sensor1 Heater back-coupling
P321400 Emissions-bank4-sensor1 Heater back-coupling
P321500 Emissions-bank3-sensor2,heater circuit Short-circuit to ground
P321600 Emissions-bank3-sensor2,heater circuit Short circuit to B+
P321700 Emissions-bank3-sensor2,heater circuit Open circuit
P321800 Emissions-bank3-sensor2,heater circuit Malfunction
P321900 Emissions-bank3-sensor2 Internal resistance too Large
P322000 Emissions-bank3-sensor2 Low Voltage
P322100 Emissions-bank3-sensor2 High Voltage
P322200 Emissions-bank3-sensor2 electrical malfunction in circuit
P322300 Emissions-bank3-sensor2 No Activity Detected
P322400 Emissions-bank3-sensor2 Slow Response
P322500 Exhaust-bank3,oxygen sensor correction behind cat Control limit reached
P322600 Exhaust-bank4,oxygen sensor correction behind cat Control limit reached
P322700 Exhaust-Bank1,Sensor1,Individual Cylinder Control Sensor dynamic to low
P322800 Exhaust-bank1,sensor1,oxygen sensor signal implausible lean
P322900 Exhaust-bank1,sensor1,oxygen sensor signal Implausible rich
P323000 Exhaust-bank4 -sensor1, heating circuit Short-circuit to ground
P323100 Exhaust-bank4 -sensor1, heating circuit Short circuit to B+
P323200 Exhaust-bank4 -sensor1, heating circuit Open circuit
P323300 Exhaust-bank4 -sensor1, heating circuit Malfunction
P323400 Emissions-bank4-sensor1 Internal resistance too Large
P323500 Emissions-bank4-sensor1 Low Voltage
P323600 Emissions-bank4-sensor1 High Voltage
P323700 Emissions-bank4-sensor1 electrical malfunction in circuit
P323800 Emissions-bank4-sensor1 No Activity Detected
P323900 Emissions-bank4-sensor1 Slow Response
P324000 Exhaust-bank4 -sensor1, heating circuit Performance too low
P324100 Intake Manifold Runner Control (IMRC) Temperature too high
P324200 Intake Manifold Runner Bank 2 Temperature too high
P324300 Idle Speed Contr.Throttle Pos. Electrical malfunction
P324400 Idle Speed Control Throttle Position 2 Electrical malfunction
P324500 Emissions-bank4-sensor2,heater circuit Short-circuit to ground
P324600 Emissions-bank4-sensor2,heater circuit Short circuit to B+
P324700 Emissions-bank4-sensor2,heater circuit Open circuit
P324800 Emissions-bank4-sensor2,heater circuit Malfunction
P324900 Emissions-bank4-sensor2 Internal resistance too Large
P325000 Emissions-bank4-sensor2 Low Voltage
P325100 Emissions-bank4-sensor2 High Voltage
P325200 Emissions-bank4-sensor2 electrical malfunction in circuit
P325300 Emissions-bank4-sensor2 No Activity Detected
P325400 Emissions-bank4-sensor2 Slow Response
P325500 Bank 1, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P325600 Bank 1, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P325700 Bank 2, O2 sensor before cat. conv., heater circuit Regulation at upper impact
P325800 Bank 2, O2 sensor before cat. conv., heater circuit Regulation at lower impact
P325900 Auxiliary fuel pump for engine start Malfunction
P326000 Exhaust bank 1/2 oxygen sensors before catalytic converter swapped
P326100 Exhaust bank 3/4 oxygen sensors before catalytic converter swapped
P326200 Exhaust bank 1/2 oxygen sensors behind catalytic converter swapped
P326300 Exhaust bank 3/4 oxygen sensors behind catalytic converter swapped
P326400 Pre-catalytic converter, emissions bank 3 Efficiency below threshold
P326500 Pre-catalytic converter, exhaust bank 4 Efficiency below threshold
P326600 Bank 1, sensor 1 Internal resistance too Large
P326700 Bank 2, sensor 1 Internal resistance too Large
P326800 Linear Lambda probe, exhaust gas bank 2 / pump current Open circuit
P326900 Linear Lambda probe, exhaust gas bank 2 / pump current Short-circuit to ground
P327000 Linear Lambda probe, exhaust gas bank 2 / pump current Short circuit to B+
P327100 Linear Lambda probe, exhaust gas bank 2 / reference voltage Open circuit
P327200 Linear Lambda probe, exhaust gas bank 2 / reference voltage Short-circuit to ground
P327300 Linear Lambda probe, exhaust gas bank 2 / reference voltage Short circuit to B+
P327400 Linear Lambda probe, exhaust gas bank 2 / reference voltage Implausible
P327500 Linear Lambda probe, exhaust bank 2 / common Ground (GND) wire Open circuit
P327600 Linear Lambda probe, exhaust bank 2 / common Ground (GND) wire Short-circuit to ground
P327700 Linear Lambda probe, exhaust bank 2 / common Ground (GND) wire Short circuit to B+
P327800 Linear Lambda probe, exhaust gas bank 3 / pump current Open circuit
P327900 Linear Lambda probe, exhaust gas bank 3 / pump current Short-circuit to ground
P328000 Linear Lambda probe, exhaust gas bank 3 / pump current Short circuit to B+
P328100 Linear Lambda probe, exhaust gas bank 3 / reference voltage Open circuit
P328200 Linear Lambda probe, exhaust gas bank 3 / reference voltage Short-circuit to ground
P328300 Linear Lambda probe, exhaust gas bank 3 / reference voltage Short circuit to B+
P328400 Linear Lambda probe, exhaust gas bank 3 / reference voltage Implausible
P328500 Linear Lambda probe, exhaust bank 3 / common Ground (GND) wire Open circuit
P328600 Linear Lambda probe, exhaust bank 3 / common Ground (GND) wire Short-circuit to ground
P328700 Linear Lambda probe, exhaust bank 3 / common Ground (GND) wire Short circuit to B+
P328800 Linear Lambda probe, exhaust gas bank 4 / pump current Open circuit
P328900 Linear Lambda probe, exhaust gas bank 4 / pump current Short-circuit to ground
P329000 Linear Lambda probe, exhaust gas bank 4 / pump current Short circuit to B+
P329100 Linear Lambda probe, exhaust gas bank 4 / reference voltage Open circuit
P329200 Linear Lambda probe, exhaust gas bank 4 / reference voltage Short-circuit to ground
P329300 Linear Lambda probe, exhaust gas bank 4 / reference voltage Short circuit to B+
P329400 Linear Lambda probe, exhaust gas bank 4 / reference voltage Implausible
P329500 Linear Lambda probe, exhaust bank 4 / common Ground (GND) wire Open circuit
P329600 Linear Lambda probe, exhaust bank 4 / common Ground (GND) wire Short-circuit to ground
P329700 Linear Lambda probe, exhaust bank 4 / common Ground (GND) wire Short circuit to B+
P329800 Catalytic converter system, exhaust-bank 3 Efficiency below threshold
P329900 Catalytic converter system, exhaust-bank 4 Efficiency below threshold
P330000 Bank1, Camshaft Position (CMP) Sensor, exhaust =>-G300 Short-circuit to ground
P330100 Bank1, Camshaft Position (CMP) Sensor, exhaust =>-G300 Open circuit/short circuit to B+
P330200 Bank2, Camshaft Position (CMP), exhaust =>Sensor -G301- Short-circuit to ground
P330300 Bank2, Camshaft Position (CMP), exhaust =>Sensor -G301- Open circuit/short circuit to B+
P330400 Bank1,exhaust-Camshaft Position (CMP) Sensor-G300/-G28 Incorrect allocation
P330500 Bank2, exhaust - Camshaft Position (CMP) Sensor-G301- / -G28- Incorrect allocation
P330600 Ignition control cylinder 13 Short-circuit to ground
P330700 Ignition control cylinder 13 Short circuit to B+
P330800 Ignition control cylinder 13 Open circuit
P330900 Ignition control cylinder 14 Short-circuit to ground
P331000 Ignition control cylinder 14 Short circuit to B+
P331100 Ignition control cylinder 14 Open circuit
P331200 Ignition control cylinder 15 Short-circuit to ground
P331300 Ignition control cylinder 15 Short circuit to B+
P331400 Ignition control cylinder 15 Open circuit
P331500 Ignition control cylinder 16 Short-circuit to ground
P331600 Ignition control cylinder 16 Short circuit to B+
P331700 Ignition control cylinder 16 Open circuit
P331800 Glow Plug/Heater Relay 2 Circ. Short circuit to B+
P331900 Glow Plug/Heater Relay 2 Circ. Open circuit/short circuit to ground
P332000 Unit Injector Valve Control 2 Short circuit to B+
P332100 Unit Injector Valve Control 2 Electrical malfunction in circuit
P332200 Relay 2 for Power Supply (B+) Terminal 30 Implausible signal
P332300 Voltage supply terminal 15 High Voltage
P332400 Voltage supply terminal 15 Open circuit
P332500 Voltage supply terminal 15 Implausible
P332600 Change-over valve for intake manifold flap 2 Short circuit to B+
P332700 Change-over valve for intake manifold flap 2 Open circuit/short circuit to ground
P332800 Intake Flap Motor 2 Short circuit to B+
P332900 Intake Flap Motor 2 Open circuit/short circuit to ground
P333000 Intake Flap Motor 2 No signal
P333100 Intake Flap Motor 2 Defective
P333200 Combustion detection in deceleration mode
P333300 Turbocharger (TC) control module 1 implausible message
P333400 Turbocharger (TC) control module 2 implausible message
P333500 Turbocharger (TC) control module 1 missing message
P333600 Turbocharger (TC) control module 2 missing message
P333700 Engine databus/engine implausible message
P333800 Activation glow time control module 1 Electrical malfunction in circuit
P333900 Activation glow time control module 2 Electrical malfunction in circuit
P334000 Charge Pressure Cooler Fan Relay Short circuit to B+
P334100 Charge Pressure Cooler Fan Relay Short-circuit to ground
P334200 Charge Pressure Cooler Fan Relay Open circuit
P334300 Exhaust turbocharger control module 1 Temperature too high
P334400 Exhaust turbocharger control module 1 Voltage supply outside the permissible range
P334500 Turbocharger 2 Control Module Temperature too high
P334600 Turbocharger 2 Control Module Voltage supply outside the permissible range
P334700 Glow Plug/Heater Relay Circ. Electrical malfunction
P334800 Activation turbocharger control unit bank 1 Electrical malfunction in circuit
P334900 Activation Turbocharger 2 Control Module Electrical malfunction in circuit
P334A00 Charge pressure actuator position sensor Electrical malfunction
P335000 Long Term Fuel Trim, NG Range 1 Too Lean
P335100 Long Term Fuel Trim, NG Range 1 Too Rich
P335200 Long Term Fuel Trim, NG Range 2 Too Lean
P335300 Long Term Fuel Trim, NG Range 2 Too Rich
P335400 Long Term Fuel Trim, NG Range 3 Too Lean
P335500 Long Term Fuel Trim, NG Range 3 Too Rich
P335600 Catalyst System,Bank1 during NG operation Efficiency below threshold
P335700 O2 Correction during NG operation Control limit reached
P335800 O2 Sensor Circ., exhaust gas Bank1-Sensor1 at NG operation Slow Response
P335900 O2 Sensor Circ., exhaust gas Bank1-Sensor1 at NG operation Heater back-coupling
P335A00 System too Lean at NG operation
P335B00 System Too Rich at NG operation
P335C00 Fuel tank pressure sensor high pressure Signal too high
P335D00 Fuel tank pressure sensor high pressure Signal too low
P336000 O2 Sensor Circ., exhaust gas Bank1-Sensor1 at NG operation No Activity Detected
P336100 NG operation Random/Multiple Cylinder. Misfire Detected
P336200 NG operation Cyl.1 Random/Multiple Cylinder. Misfire Detected
P336300 NG operation Cyl.2 Random/Multiple Cylinder. Misfire Detected
P336400 NG operation Cyl.3 Random/Multiple Cylinder. Misfire Detected
P336500 NG operation Cyl.4 Random/Multiple Cylinder. Misfire Detected
P336600 System pressure, NG too High
P336700 System pressure, NG too Low
P336800 O2 Sensor Signal Stuck Rich Bank 3 Sensor 1
P336900 O2 Sensor Signal Stuck Rich Bank 2 Sensor 1
P336A00 System pressure, NG Implausible signal
P336B00 NG temperature sensor Short circuit to B+
P336C00 NG temperature sensor Short-circuit to ground
P336D00 NG temperature sensor Implausible signal
P336E00 NG fuel pump relay Short circuit to B+
P336F00 NG fuel pump relay Short-circuit to ground
P337000 O2 Sensor Signal Stuck Rich Bank 3 Sensor 1
P337100 O2 Sensor Signal Stuck Rich Bank 2 Sensor 1
P337200 Intake Manifold Change-Over Valve Short circuit to B+
P337300 Intake Manifold Change-Over Valve Open circuit/short circuit to ground
P337400 Intake Manifold 2 Change-Over Valve Short circuit to B+
P337500 Intake Manifold 2 Change-Over Valve Open circuit/short circuit to ground
P337600 Intake Air Temperature Sensor 3 Signal too low
P337700 Intake Air Temperature Sensor 3 Signal too high
P337800 Intake Air Temperature Sensor 3 Implausible signal
P337900 NG High Pressure Valve Open circuit
P337A00 Voltage supply relay Short circuit to B+
P337B00 Voltage supply relay Short-circuit to ground
P337C00 Voltage supply relay Open circuit
P337D00 Relay for shut-off valve for high pressure valve Short circuit to B+
P337E00 Relay for shut-off valve for high pressure valve Short-circuit to ground
P337F00 Relay for shut-off valve for high pressure valve Open circuit
P338000 NG High Pressure Valve Short circuit to B+
P338100 NG High Pressure Valve Short-circuit to ground
P338200 Fuel Tank Pressure (FTP) Sensor -G400 Open circuit
P338300 Fuel Tank Pressure (FTP) Sensor -G400 Short circuit to B+
P338400 Fuel Tank Pressure (FTP) Sensor -G400 Short-circuit to ground
P338500 Fuel Rail Sensor Open circuit
P338600 Fuel Rail Sensor Short circuit to B+
P338700 Fuel Rail Sensor Short-circuit to ground
P338800 Fuel Injection Valve 1 Open circuit
P338900 Fuel Injection Valve 1 Short circuit to B+
P338A00 Fuel Tank Pressure (FTP) Sensor -G400 Implausible signal
P338B00 Fuel Tank Level Sensor Short circuit to B+
P338C00 Fuel Tank Level Sensor Short-circuit to ground
P338D00 Fuel Tank Level Sensor Implausible signal
P338E00 Indicator light for operating mode switch-over Short circuit to B+
P338F00 Indicator light for operating mode switch-over Short-circuit to ground
P339000 Fuel Injection Valve 1 Short-circuit to ground
P339100 Fuel Injection Valve 2 Open circuit
P339200 Fuel Injection Valve 2 Short circuit to B+
P339300 Fuel Injection Valve 2 Short-circuit to ground
P339400 Fuel Injection Valve 3 Open circuit
P339500 Fuel Injection Valve 3 Short circuit to B+
P339600 Fuel Injection Valve 3 Short-circuit to ground
P339700 Fuel Injection Valve 4 Open circuit
P339800 Fuel Injection Valve 4 Short circuit to B+
P339900 Fuel Injection Valve 4 Short-circuit to ground
P339A00 Shut-Off valve 1 for NG fuel tank Short circuit to B+
P339B00 Shut-Off valve 1 for NG fuel tank Short-circuit to ground
P339C00 Shut-Off valve 1 for NG fuel tank Open circuit
P339D00 Shut-Off valve 2 for NG fuel tank Short circuit to B+
P339E00 Shut-Off valve 2 for NG fuel tank Short-circuit to ground
P339F00 Shut-Off valve 2 for NG fuel tank Open circuit
P33A000 Shut-Off valve 3 for NG fuel tank Short circuit to B+
P33A100 Shut-Off valve 3 for NG fuel tank Short-circuit to ground
P33A200 Shut-Off valve 3 for NG fuel tank Open circuit
P33A300 Shut-Off valve 4 for NG fuel tank Short circuit to B+
P33A400 Shut-Off valve 4 for NG fuel tank Short-circuit to ground
P33A500 Shut-Off valve 4 for NG fuel tank Open circuit
Gone But Not Forgotten
I fail to see how that helps.
It was because it was displayed in bold larger characters & making it easier for me to read so I figured it would help others too.
I guess I could hold control and scroll the mouse too.....
:rolleyes:.
Maybe I should go get reading glasses & just admit defeat....... :p
   #30
When I was in my early 40s, I was sitting at me desk, soldering up a batch of ISO-COM interfaces and realized I really couldn't see what I was doing as well as I used to. So I went to see an Optometrist. He told me that there are three things in life that are inevitable: Death, taxes, and reading glasses. :cry:
   #31
Control / command + F still works, regardless of code tags :)
Yes indeed code tags work with search but it was the size of the characters I was having issue with.
Uwe I like your post for honesty not the actual situations described.........:cry:
JPPSG Amendment .........
Personal request please to gather technical data.
All scans please do the auto-scan and OBD2 mode scan 0x33 and especially post MODE 9 DATA please!
It will indeed help in certain cases to bifurcate an issue I am seeing & to better assist the collective.
I need further statistics to verify.
THANK YOU
   #33
Leospeedworks
Philippines
C?ID=64222
Hi Jack thanks for the Post. I need your help with getting the coding for my tranmission in which I accidentally cloned another car's transmission. How can I send it to you. Is it ok to post here? Thanks very much for the help in the community.
   #34
I don't get involved in third party transactions, unless with customers consent & written documented disclosure.
I positively DO NOT get involved with clones or cloning, I only do legitimate data transfers for controllers.
The word "Clone" implies there are two identities now in existence.
This forum is for VCDS and a qualified repair process, further related to the use of the Ross-Tech tool & used in conjunction of the RTFB for reference.
Undo what you did with the unqualified tools and start over with a real auto-scan and thread.
While I appreciate the gesture to solicit my help, Indeed I am not a player for this.
https://forums.ross-tech.com/showth...for-my-vehicle&p=138958&viewfull=1#post138958
Leospeedworks
Philippines
C?ID=64222
Hi Sir sorry to use the word clone. If I may explain the story. I have a car with a tuned dsg using alientech so I have the tuned dsg file. A friend with a similar car wanted his dsg tuned. I was able to back it up on eeprom mode but not in micro mode. Then upon programming i ended up copying the whole data of my car. Is there a way to buy the other car’s original dsg data/software to put it back. Yes i messed up and backup upped the wrong file.
   #36
Leospeedworks
Philippines
C?ID=64222
I can get consent for both cars since I own one and my friend owns the other one.
   #37
Hi Sir sorry to use the word clone. If I may explain the story. I have a car with a tuned dsg using alientech so I have the tuned dsg file. A friend with a similar car wanted his dsgtuned. I was able to back it up on eeprom mode but not in micro mode. Then upon programming i ended up copying the whole data of my car. Is there a way to buy the other car’s original dsg data/software to put it back. Yes i messed up and backup upped the wrong file.
Ever pray to God and ask why hasn't he/she answered my prayer?
Your apology is not accepted and you were set to ignore because God hates your position & is expecting you to suffer horribly or until full penance is completed in the basket!
Sometimes the answer is still NO!
I'd say contact the Gods at "Alien Tech" but you probably have a clone, right? ........... :rolleyes:
   #38
Leospeedworks
Philippines
C?ID=64222
I’m a registered alientech User with KTAG And KESS. Thank you for the quick and honest reply. You’re contribution here is a lot. I never use Fake and unlicensed stuff. That word came from the pcm flash. Had to use it because it can read/write on the MQB DQ250 without removing the mechstronic, opening and using my KTAG.
FOD = Foreign Object Damage!
When you see this it pays to listen..........
   #40
Time to add a tip amendment.
When seeking to cross check components being electronic, it maybe about time you added a decade box to your tool box collection.
A decade box is mechanical digitized resistor bank, with dial type or tap out digits.
https://en.m.wikipedia.org/wiki/Decade_box
It can be used to set gauge calibration or do a range of tests of sensors to see if a controller displays actual values on the scanner & to compare on a DVOM.
We know that tuners often shut down tests in ADP or setting readiness or even a false spoofed Calibration.
Further investigation has shown that they are also moving the base tables to reflect how a sensor will report actual values and not just specified.
With FOD in play being widespread you will embrace this!
No reason not to have one & when so cheap now, because in the old days this was a shop tool supplied by OEM dealer.
Example....
Recently got a CBFA that had no poop, no fault codes oh but indeed was FOD when stripping the flash block areas to do a quick compare of file versions from true stock verse FOD stock or excuse me dumb modified.
The actual values in tables for map sensor G71 were reported as in specification than what they really were.
So this car said it was boosting when it was actually low
& as specified. In this case double FOD!
I imagine this was someone's retaliation to the shitty WG spring on the turbo charger and was indeed bad!
Dont trust block values or any OBD data and use as a guide, than go verify it!
NostraJackASS Has Spoken!
