looking to enable lane assist on my late build 2015 passat bitdi, i assume its a 2016MY, pretty sure it has MIB2 which i think is part of the problem i am having
i am trying to follow this info: http://www.stemei.de/pages/coding/vw-passat-b8/lane-assist-freischalten.php
but for example steps 11-18 i dont even have those fields listed, so something has changed...
i have dynamic light assist, acc and traffic sign recognition, so the hardware as i understand is in place, its just a matter of enabling it
Thursday,15,October,2015,17:40:09:27988
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWZZZ3CZGE084984 License Plate:
Mileage: 544km-338mi Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
69 A5
VIN: WVWZZZ3CZGE084984 Mileage: 544km-338miles
Address 01: Engine (J623-CUAA) Labels: None
Part No SW: 03N 906 026 E HW: 03N 907 309
Component: R4 2,0L EDC H23 1754
Revision: A1H23---
Coding: 01250012047605083000
Shop #: WSC 05311 115 00308
ASAM Dataset: EV_ECM20BTD01103N906026E 001002
ROD: N/A
VCID: 2D5B04AF7C7C6A56C6-8078
No ASAM data for: "EV_ECM20BTD01103N906026E" (VW48)
25221 - ROD - Unknown Error Code
- 00 [096]
Mileage: 364 km
Date: 2015.10.15
Time: 19:22:31
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DL 300 011 H HW: 0BH 927 711 F
Component: GSG DQ500 H10 5201
Revision: 00H10V01
ROD: EV_TCMDQ500021_AU21.rod
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62625000000106
Coding: 0FEC6B8F54280B700780070841C769F0D62AD0E0E08296F5186250F8C209
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
VCID: 7AF1FFF3FDB20DEE13-802E
0156 - ASR and ESP Switch
C109C 29 [008] - Signal Implausible
Reset counter: 44
Mileage: 39 km
Date: 2015.10.13
Time: 19:42:30
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0380970998
Coding: 000F0F0703
ROD: EV_KessyHellaMQBAB_SK48.rod
VCID: 397320FFB834C6F65A-806C
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BG HW: 5G0 907 044 BG
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 1202010420210001111550000010180A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6DDBC4AFBCFCAA5686-8038
Slave 1:
263682 - Exterior Air Quality/Humidity Sensor
B137A 31 [008] - No Signal
Reset counter: 42
Mileage: 150 km
Date: 2015.10.14
Time: 12:17:40
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86580209151182
Coding: 00031E46C2C102FF0F844094B11C07281880000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 030F82178A784C2640-8056
Slave 1:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150826 042 0607
Serial number: 150902144310
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y15M09D22H05M43S21
Coding: 90A8DD
Slave 3:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 11 06 2015 10001547
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY152170MJC
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000033423006
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391526002413
Coding: 0071051911
Shop #: WSC 05311 115 00062
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 448D410BCFF68B1E39-8010
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Coding: 320067CA59FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346D11CB9F563B9E89-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 18091541350144
ROD: EV_DRCONTITEMIC.rod
VCID: 377726C78E20D086AC-8062
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSPH5X3T%
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X_VW48.rod
VCID: 7EF9F3E3E19A21CE2F-802A
Seat belt tensioner; left:
Serial number: 3G1857705G0261P00948
Coding: 80000D
Seat belt tensioner; right:
Serial number: 3G1857706G0261P00402
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 000 609 15
Serial number: 3576U000000D2A69661I
Subsystem 4 - Part No SW: ----------- HW: 454 000 609 15
Serial number: 3586U00000015A54E51B
Subsystem 5 - Part No SW: ----------- HW: 454 800 409 15
Serial number: 3516R62760E08000000%
Subsystem 6 - Part No SW: ----------- HW: 454 800 609 15
Serial number: 3526R5D9329080000006
Subsystem 7 - Part No SW: ----------- HW: 454 802 208 15
Serial number: 3556VE82812080000007
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150914401003
Coding: 0410
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D7B34EFAC1CFAD676-8068
Part No SW: 3G0 920 791 A HW: 3G0 920 791 A
Component: KOMBI 409 1340
Coding: 03A40818BF84000800886B011000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009048
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 2757F6875E8040063C-8072
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2224
Revision: -------- Serial number: 16091510800026
Coding: 0B0300345F017300FB00025E9C0F00010001070000000000000000000000
ROD: EV_GatewConti.rod
VCID: 75EBECCFD4AC62967E-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001583500105323
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 6384267303
Inverter power receptacle:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H56 0033
Serial number: 0131605
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Serial number: HA1-00024.07.15
Coding: 0301
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 4A916F33EDD25D6EC3-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000102553001
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E3D8DFA0C44EB6A2-8024
Component: TSG FS 020 0041
Serial number: 260815BHO51475
Coding: 003F0A20D000028000001000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 438F4217CAF88C2600-8016
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000382899
Coding: 01000010005001
Shop #: WSC 00015 115 00308
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_SK48.rod
VCID: 3B7F3AF7B208F4E648-806E
Component: TSG BFS 020 0041
Serial number: 100915BIA02299
Coding: 003F0020D000028000001000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42814713D5E2852E0B-8016
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 03A202004F210200
Shop #: WSC 05311 000 08193
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: 3F874EE7A610E8C664-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 3G0 035 043 B HW: 3G0 035 043
Component: MU-H-N-EU H42 0343
Serial number: A599I0FB015806
Coding: 028402010000000051110002000808001F0100E4012000009F
ROD: EV_MUHig4CGen2HBAS_VW48.rod
VCID: 1B3FDA7712C894E6A8-804E
Media Player Position 1:
Radio Tuner - Digital:
Subsystem 2 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU303858
Engine Control Module 2:
Subsystem 3 - Part No SW: ----------- HW: -----------
Component: ------------- --- ----
Seat Adjustment Driver Side:
Subsystem 4 - Part No SW: V03 959 800 QM HW: -----------
Component: ECE 2015/2016 --- 0123
Air Conditioning Compressor:
Diesel Pump Control Unit:
Door Electronics Driver Side:
Subsystem 7 - Part No SW: ----------- HW: -----------
Brake Assistance:
Subsystem 8 - Part No SW: ----------- HW: -----------
Interior Monitoring:
Subsystem 9 - Part No SW: ----------- HW: -----------
Sound System:
Door Electronics Rear Left:
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: ----------- HW: -----------
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1011
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0380087072
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_SE26.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 3Q0 980 654 HW: 3Q0 980 654
Component: MQB_B_MFK H04 0010
Serial number: 14091511P10783
Coding: 0004080200000401002223458050A10010000E200040
ROD: EV_MFKBoschMQBB_VW36.rod
VCID: 74EDD1CBDFD67B9E49-8020
End-------------------------(Elapsed Time: 05:37)--------------------------
