Relay clicking and fan going with ignition. CAYC
vagcars69
C?ID=413796
Scractching my head with this one. Ecm relay is clicking like crazy and fan would start too. Relay already replaced, tried disconnecting various engine components but didn't help. Any ideas?
Monday,12,February,2024,15:39:44:45700
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
VIN: WVWZZZ1KZAW31****   License Plate: GOLFS
Mileage: 234710km-145842mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZAW314629   Mileage: 234710km-145842miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 997 557 M    HW: 03L 906 023 A
   Component: R4 1.6l TDI   H23 9983
   Revision: --H23---    Serial number: 00000000000000 CVN: C9BED9C6
   Coding: 00114014030500080000
   Shop #: WSC 00653 210 61898
   ASAM Dataset: EV_ECM16TDI02103L997557M 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 46D55259782CC57A55F-8012
   VINID: 9E69EAAAA05BA919C304418224239CA076
10 Faults Found:
7362 - Glow Plug Control Module (J179)
          P0684 00 [01100101] - Implausible Signal
7345 - Particulate Filter; Differential Pressure Sensor
          P2455 00 [10100101] - Short to Plus
10232 - Valve for Fuel Metering (N290)
          P0091 00 [10100101] - Short to Ground
10231 - Valve for Fuel Metering (N290)
          P0090 00 [10100101] - Open Circuit
10114 - Fuel Pressure Regulator Valve (N276)
          P2295 00 [10100101] - Short to Ground
10113 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [10100101] - Open Circuit
9875 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0047 00 [10100101] - Short to GND
9874 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [10100101] - Open Circuit
9871 - Exhaust Gas Recirculation Cooling Valve Control
          P2425 00 [00100101] - Open Circuit
10125 - ECM Power Relay Control Circuit
          P0687 00 [10100101] - Short to Plus
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 133B200D092300FEC81104E690220081300000
   VCID: 78A9ECA142D8638A173-802C
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D87CDF53D1AD622F45-8038
   Part No SW: 1K0 937 085 D    HW: 1K0 937 085 D
   Component: BCM PQ35  B+  103 0575
   Revision: 00103 AG
   Coding: 40180A3A9023189044000080100000E443010088524D8160648000200000
   VCID: 30391481EA287BCA9F3-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 01021  21  0512
   Coding: 009795
            010 - Open or Short to Plus
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA3JFZI   Dataset Number: 5K0003v____ 0085
   Coding: 00003133
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B2333AD33EE88923A1-806E
   Serial number: 3572MSME00791251ZZZI
   Serial number: 3582MSME4B290250ZZZR
   Serial number: 3512QSME0C414D6AZZZ+
   Serial number: 3522QSME3C3A4C09ZZZ2
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 03538B4D071E3052321-8056
   Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
   Component: KOMBI         H04 0308
   Coding: 770800
   VCID: 38292CA102D8A38AD73-806C
9453842 - Oil Level Thermal Sensor
          B1041 35 [00001001] - Signal High Time > Maximum
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 030210F2000726
   Coding: E9801F06000202000003
   VCID: 698FB9E50572CA0298D-803C
   Component: IMMO          H04 0308
   VCID: 6A8DC6E90CF4C11A917-803E
   Component: Tuer-SG         009 2114
   Coding: 0000564
   VCID: 313F1185ED2272C290D-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
            000 - - - MIL ON
   Coding: 0000564
   VCID: 323D1E89E82449DAE97-8066
   Part No SW: 1K0 035 156 B    HW: 1K0 035 156 B
   Component: Radio         510 0521
   Revision: R0510005    Serial number: VWZ5Z1K0263980
   Coding: 0000020002
   VCID: 221DEEC9B4C4D95A197-8076
00856 - Radio Antenna
End----------(Elapsed Time: 00:48, VBatt start/end: 12.3V/12.1V)-----------
Clearly an electrical problem, but I'm no sure how to diagnose that remotely.
I'd start with ECM relay. "Control Circuit - Short to Plus" might be a bad ground somewhere?
siLc
Tallinn, Estonia
C?ID=330192
N276, N290 and most of the other stuff is powered by a Terminal 30 relay J317 located in the engine bay fusebox. Fuse SB10 is intact and has a steady +12V present? That is the power supply for the switching side of this relay. This relay is actuated by the ECM with a ground. This ground is also steady and not flicking on/off?
vagcars69
C?ID=413796
Grounds are fine and steady. Fuse 10 is perfectly fine and has staedy 12v.
Something is causing
a- a fan to go off at random even with car locked.
b- when you can hear relay clicking voltage on terminal 30 and fuses 13/14/15 fluctuate in range 6-12v. Does it flicker because of voltage drop or relay causing voltage drop?
Would one of the components on terminal 30 cause a short somewhere?
siLc
Tallinn, Estonia
C?ID=330192
The consumers on the switched side of a relay cannot affect the switching side if the relay itself is internally good.
Those fuses are fed by this relay, thus it proves that the relay clicking on/off is affecting the voltage those consmers are receiving. If SB10 has good voltage, then it only leaves the ECM as the ground switcher as the culprit...or the fusebox itself and/or the wire connection from the ECM to the fusebox.
vagcars69
C?ID=413796
Makes sense.
Tried different ecu and it would do same thing. Fan would go off without ecu too. So stripped fuse box and found water ingress. That would indicate the issue. Will order another fuse box hopefully that will solve it.
Update:
New fuse box resolved the issue.
Thanks for your help!
