Scractching my head with this one. Ecm relay is clicking like crazy and fan would start too. Relay already replaced, tried disconnecting various engine components but didn't help. Any ideas?
Monday,12,February,2024,15:39:44:45700
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ1KZAW31**** License Plate: GOLFS
Mileage: 234710km-145842mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAW314629 Mileage: 234710km-145842miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 997 557 M HW: 03L 906 023 A
Component: R4 1.6l TDI H23 9983
Revision: --H23--- Serial number: 00000000000000 CVN: C9BED9C6
Coding: 00114014030500080000
Shop #: WSC 00653 210 61898
ASAM Dataset: EV_ECM16TDI02103L997557M 003003
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 46D55259782CC57A55F-8012
VINID: 9E69EAAAA05BA919C304418224239CA076
10 Faults Found:
7362 - Glow Plug Control Module (J179)
P0684 00 [01100101] - Implausible Signal
7345 - Particulate Filter; Differential Pressure Sensor
P2455 00 [10100101] - Short to Plus
10232 - Valve for Fuel Metering (N290)
P0091 00 [10100101] - Short to Ground
10231 - Valve for Fuel Metering (N290)
P0090 00 [10100101] - Open Circuit
10114 - Fuel Pressure Regulator Valve (N276)
P2295 00 [10100101] - Short to Ground
10113 - Fuel Pressure Regulator Valve (N276)
P2294 00 [10100101] - Open Circuit
9875 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0047 00 [10100101] - Short to GND
9874 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0045 00 [10100101] - Open Circuit
9871 - Exhaust Gas Recirculation Cooling Valve Control
P2425 00 [00100101] - Open Circuit
10125 - ECM Power Relay Control Circuit
P0687 00 [10100101] - Short to Plus
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 133B200D092300FEC81104E690220081300000
VCID: 78A9ECA142D8638A173-802C
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
ROD: EV_ClimaBasis_VW36.rod
VCID: 6D87CDF53D1AD622F45-8038
Part No SW: 1K0 937 085 D HW: 1K0 937 085 D
Component: BCM PQ35 B+ 103 0575
Revision: 00103 AG
Coding: 40180A3A9023189044000080100000E443010088524D8160648000200000
VCID: 30391481EA287BCA9F3-8064
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 01021 21 0512
Coding: 009795
010 - Open or Short to Plus
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA3JFZI Dataset Number: 5K0003v____ 0085
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B2333AD33EE88923A1-806E
Serial number: 3572MSME00791251ZZZI
Serial number: 3582MSME4B290250ZZZR
Serial number: 3512QSME0C414D6AZZZ+
Serial number: 3522QSME3C3A4C09ZZZ2
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 03538B4D071E3052321-8056
Part No SW: 5K0 920 960 N HW: 5K0 920 960 N
Component: KOMBI H04 0308
Coding: 770800
VCID: 38292CA102D8A38AD73-806C
9453842 - Oil Level Thermal Sensor
B1041 35 [00001001] - Signal High Time > Maximum
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 030210F2000726
Coding: E9801F06000202000003
VCID: 698FB9E50572CA0298D-803C
Component: IMMO H04 0308
VCID: 6A8DC6E90CF4C11A917-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2114
Coding: 0000564
VCID: 313F1185ED2272C290D-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
000 - - - MIL ON
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0000564
VCID: 323D1E89E82449DAE97-8066
Part No SW: 1K0 035 156 B HW: 1K0 035 156 B
Component: Radio 510 0521
Revision: R0510005 Serial number: VWZ5Z1K0263980
Coding: 0000020002
VCID: 221DEEC9B4C4D95A197-8076
00856 - Radio Antenna
End----------(Elapsed Time: 00:48, VBatt start/end: 12.3V/12.1V)-----------
