- Aug 10, 2016
- 3,768
- 4,182
- Netherlands, eastern part
- C?ID=284912
Hi guys,
so my Passat B8 has a memory seat, soon it will have two memory seats. I figured it would be nice to have the car key linked to the seat position.
I saw this image a while ago, this is also a Passat B8 pre-facelift.
Would be nice to have the same menu in the mib with the functionality that comes with it.
I already saw some instructions on the VW Vortex for having personalisation.
I followed those instructions already, but still don't have the menu in the MIB.
These are the instructions: https://www.vwvortex.com/threads/ty...ost_id=112758863&nested_view=1#post-112758863
I'm guessing its a channel related to personalisation?
adapmap BCM:
Thursday,04,January,2024,16:01:48:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Workshop Code: 123 30389 056831
VIN: License Plate:
Mileage: 171917km-106824mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7
VIN: Mileage: 171917km-106824miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: B7DB7878
Coding: 091D003A2476050B3004
Shop #: WSC 30389 123 56831
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259J.rod
VCID: 313FE88591ABBF4290D-8065
VINID: 9E69EAAAA0D3A9A54008518520274044B7
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [00101111] - Signal too High
Mileage: 171440 km
Date: 2023.12.29
Time: 13:48:38
Engine RPM: 1616.75 /min
Normed load value: 5.5 %
Vehicle speed: 43 km/h
Coolant temperature: 88 ∞C
Intake air temperature: 20 ∞C
Voltage terminal 30: 12.832 V
Engine: operating status: PL
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 62 s
MAP_MES_SAE: 42 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.015625 %
FUP_H_SAE: 14000.0 kPa
15171 - Engine Oil Temp. Sensor (G8)
P0196 00 [00101111] - Implausible Signal
Mileage: 171334 km
Date: 2023.12.28
Time: 10:45:12
Engine RPM: 1278.25 /min
Normed load value: 7.5 %
Vehicle speed: 18 km/h
Coolant temperature: 14 ∞C
Intake air temperature: 11 ∞C
Voltage terminal 30: 12.812 V
T_AST_SAE: 33 s
MAP_MES_SAE: 47 kPa
FAC_TPS_1_SAE: 16.406250 %
FUP_H_SAE: 6240.0 kPa
Engine RPM: 0.00 /min
Coolant temperature: -40 ∞C
Intake air temperature: -40 ∞C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Part No SW: 0D9 300 018 C HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5297
Revision: 06454104 Serial number: TFK01706160335 CVN: 000099EF
Shop #: WSC 05311 115 00065
ROD: EV_TCMDQ250021.rod
VCID: 1C612931E629222AD3B-8049
P1734 00 [00000010] - -
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 FM HW: 5Q0 614 517 AH
Component: ESC H62 0755
Revision: 00000000 Serial number: 61907000000236
Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 015F7845618BEFC220D-8055
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0448732144 Dataset Number: V03935260TX 0001
Coding: 1F20200723
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E25C3B950F5503A1DF-806B
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8001216
Part No SW: 3G8 907 044 T HW: 3G8 907 044 T
Component: Climatronic H10 0221
Coding: 12020024104411011115500D0018592A
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
Air quality sensor:
Humidity sensor: exterior:
Subsystem 3 - Part No SW: 11A 907 049 A HW: 11A 907 049 A
Component: E265 KPH SH H02 0183
Serial number: G04S01.11.2100972191
Coding: FFFFFF
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865829061700DO Dataset Number: V03935260TT 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 06556B5948A5C8FA15F-8053
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170615 042 0607
Serial number: 170629234856
Coding: 0F4DFD
Component: RLHS 042 0105
Serial number: S4Y17M06D29H19M25S21
Coding: 06A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 14 04 2017 10001690
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1714382PB
Serial number: 00000000000070188699
Humidity sensor: interior:
Part No SW: 5QA 919 298 L HW: 5QA 919 298 A
Component: PLA 3.0 12K H07 0074
Serial number: 000308417617172 Dataset Number: V03935315EN 0001
Coding: 8A79267951
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA2CAU3700000 009055
VCID: 59EF7025A99B970208D-800D
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 S HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0780
Dataset Number: V12345678AA V315
Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
ASAM Dataset: EV_ACCBOSCHVW416 003015
ROD: EV_ACCBOSCHVW416_003_VW41.rod
VCID: 47CBA65D0F2F11F2AE9-8013
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 25061741350001 Dataset Number: V03935290WM 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 392FD0A549DB770228D-806D
Part No SW: 3Q0 959 655 CP HW: 3Q0 959 655 CP
Component: Airbag VW21 006 0721
Revision: -------- Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
Coding: 98FCC0C0008000005C5400CF000800000065
VCID: 0E45537920D580BAADF-805B
Left seat belt tensioner:
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705 0031T01500
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G1857706G0185R01460
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 606 17
Serial number: 357000000000507D3628
Subsystem 4 - Part No SW: ----------- HW: 454 001 806 17
Serial number: 358000000008D140C62J
Subsystem 5 - Part No SW: ----------- HW: 454 801 106 17
Serial number: 3510091305210000000U
Subsystem 6 - Part No SW: ----------- HW: 454 801 106 17
Serial number: 352002F2F52100000009
Subsystem 7 - Part No SW: ----------- HW: 454 801 406 17
Serial number: 3550040279610000000%
Part No SW: 5Q0 953 521 KT HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0265
Revision: FF035035 Serial number: 20170828500092 Dataset Number: V03935250KY 0001
Coding: 8410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
Part No SW: 3G0 920 791 D HW: 3G0 920 791 C
Component: KOMBI 406 4191
Coding: 07AD0898FE8C000C01887F0F3001000080000000
VCID: 2A0DFFE9BC7DCC9A517-807F
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 K HW: 5Q0 963 272 H
Component: STH-MQB 008 0080
Coding: 9309
Shop #: WSC 00015 115 00001
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000276932
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 C
Component: GW MQB High 518 5502
Serial number: 06071710802132 Dataset Number: V03935278KN 0001
Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
GVL: 01DE3C0008000600C0DC80000006CC0010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 7F5BFEBD177F9932569-802B
Generator:
Component: 4-00-03-00-04
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218123222100161
Coding: AF0B00
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Serial number: 5131394104
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0066181
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 3003201700010095
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
Coding: 0601
VCID: 4CC199711649F2AA83B-8019
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000160250002
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BF2885512BFF42D0D-8025
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 D HW: 3Q0 959 760 B
Component: Sitzmemory H05 0024
Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
Coding: 001000020000050081C280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3C21C9B146E9422A33B-8069
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 00000591782366 Dataset Number: V03935345YL 0001
Coding: 62954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 00000606636104
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
Coding: 00351A20D200028000011000
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 4ACD9F691C3DEC9AB17-801F
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5082
Dataset Number: 8V0909852AA 0001
Coding: 93070000
Shop #: WSC 00015 115 00319
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
Coding: 1284020001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
VCID: 6B833AED73071592EA1-803F
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 01071710801233 Dataset Number: V03935339UR 0001
Coding: 000000060100035207007F010A0000000000000000000000000000000000
VCID: 72BD2789542DC45A297-8027
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
Coding: 00351020DE00028000011000
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 49CFA065193BE782B8D-801D
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 022 B HW: 5NA 035 022
Component: MU-H-LND-EU H54 1367
Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
Coding: 02840201000000005111110200880A301F0106E4012004009F
VCID: 323DE78994AD845AE97-8067
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT1915518
Subsystem 2 - Part No SW: V03 959 809 PC HW: -----------
Component: ECE 2023 --- 0310
Compact disc data bank:
Component: Gracenote2 --- 1016
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3829D5A172D16E0AD73-806D
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0446947174 Dataset Number: V03935259HF 0001
Coding: 0100000202000000
VCID: 42DDB749240D34DA797-8017
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG069231 Dataset Number: ----------
Coding: 01840200E70F200004314817
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0265
Revision: -------- Serial number: 31344982200000 Dataset Number: V03935262CS 0001
Coding: 02A8
VCID: 46D5AB59082508FA55F-8013
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1421
Serial number: E80320003220200 Dataset Number: V03935411EY 0001
Coding: 0004019821FAC02488DF14001020004000218000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW38.rod
VCID: 3635DB9978C5987AC5F-8063
Part No SW: 5Q0 959 595 L HW: 8W1 959 595 D
Component: TSG HFS005 0350
Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
Coding: 000410200100028000001000
ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
Component: TSG HBFS005 0350
Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: V03935218DJ 0001
Coding: 208040748202
VCID: 372BD69D7FCF6172DE9-8063
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 16753B191805787AE5F-8043
Component: LED1R H09 0003
End----------(Elapsed Time: 02:40, VBatt start/end: 12.4V/12.3V)-----------
adapmap BCM:
SW:5Q0-937-086-BM HW:5Q0-937-086-BH --- Cent. Elect. --- SA: 31347
Component:BCM PQ37BOSCH 034 0242, Coding:
EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
Sunday,25,December,2022,15:09:59:11868
VCDS Version: Release 22.9.0 (x64) Data version: 20220830 DS341.0
VCID: 06556B5948A5C8FBDDF-8052
IDE01550-Service position,153.296551 ∞,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG112304-Rear wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.3 ∞,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 ∞C,16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 ∞C,16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,120 ∞,16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 ∞C,16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,80 ∞,16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.0 ∞C,11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.0 ∞C,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04928-MAS01577-Anti-theft protection-Parking heater,installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 00 9C 08 09 1C 12 00 9C 04 4C 00 4C 14 00 64 07 00 9C 08 0A 1C 13 00 9C 01 3A 00 49 14 00 7F 00 00 00 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 00 00 00 08 0A 7F 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 E2 28 49 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 ∞C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.50 ∞C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,17.50 ∞C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.50 ∞C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,17.50 ∞C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,27.50 ∞C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,26.50 ∞C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,27.50 ∞C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,26.50 ∞C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 ∞C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 ∞C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 ∞C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 ∞C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07356-Position during interval mode,24.890085 ∞,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,4 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,10 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,1 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,10 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,installed ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,8.296695 ∞,2
IDE10299-Alternating park position 2,24.890085 ∞,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.40 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000101 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00111100 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000010 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00011100 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00011010 ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,127 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,127 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,127 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,2.0 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,255 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,138 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,255 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,255 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,255 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,1 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,1 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,255 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,1 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,1 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,255 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,43 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,1 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,20 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,1 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,128 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,255 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,215 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,255 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,1 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,255 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,226 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,1 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,47 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,255 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,1 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,1 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,1 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,255 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,255 ,30
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,255 ,30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin,138 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,255 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,255 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,255 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,1 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,1 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,255 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,1 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,1 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,255 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,138 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,1 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,40 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,1 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,128 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,255 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,215 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,1 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,255 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,10 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,1 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,143 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,255 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,1 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,1 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,1 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,255 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,255 ,30
MAS05055-lower turn position,26.296677 ∞,2
MAS05056-upper turn position,171.296533 ∞,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,I-panel ,30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,20 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,21 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,active ,13
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,not active ,13
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,1.00 ,13
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,1.00 ,13
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,0.78 ,13
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,0.18 ,13
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,1.00 ,13
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,1.00 ,13
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,1.00 ,13
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,1.00 ,13
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,1.00 ,13
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,0 ms,22
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,200 ms,22
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,2000 ms,22
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,400 ms,22
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,600 ms,22
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,800 ms,22
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,1000 ms,22
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,1200 ms,22
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,1400 ms,22
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,1600 ms,22
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,1800 ms,22
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,0.0 %,22
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,0.5 %,22
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,100.0 %,22
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,2.0 %,22
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,5.0 %,22
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,10.0 %,22
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,20.0 %,22
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,40.0 %,22
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,80.0 %,22
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,95.0 %,22
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,99.0 %,22
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122212-Auflenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG133379-Auflenlicht_Blinker-Abbruch Komfortblinken,active ,10
ENG141649-ENG116590-Auflenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger,separte ,10
ENG141649-ENG121966-Auflenlicht_Blinker-Crash flashing,not active ,10
ENG141649-ENG122207-Auflenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Auflenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG142194-Auflenlicht_Blinker-dynamisch_blinken_10,not active ,10
ENG141649-ENG142195-Auflenlicht_Blinker-Dynamische_Blink_Delay,50 ms,10
ENG141649-ENG126819-Auflenlicht_Blinker-Emergency_alert_blinken,not active ,10
ENG141649-ENG154601-Auflenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
ENG141649-ENG115774-Auflenlicht_Blinker-Komfortblinken,active ,10
ENG141649-ENG116587-Auflenlicht_Blinker-Komfortblinken Blinkzyklen,3 ,10
ENG141649-ENG122208-Auflenlicht_Blinker-Multi_kollisions_Blinken,not active ,10
ENG141649-ENG122209-Auflenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,not active ,10
ENG141649-ENG121967-Auflenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG154711-Auflenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Auflenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Auflenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122201-Auflenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Auflenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Auflenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG122202-Auflenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Auflenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG122214-Auflenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Auflenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141649-ENG122204-Auflenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Auflenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG141986-Auflenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG116705-Auflenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Auflenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG115833-Auflenlicht_Front-Fahrlicht bei Tag,Daytime running lamps ,9
ENG141647-ENG142193-Auflenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Auflenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG115832-Auflenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Auflenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Auflenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Auflenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Auflenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141647-ENG122184-Auflenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
ENG141647-ENG115734-Auflenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Auflenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115733-Auflenlicht_Front-Tagfahrlichtkontrollleuchte,not active ,9
ENG141647-ENG142192-Auflenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,9
ENG141647-ENG116591-Auflenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,9
ENG141647-ENG115860-Auflenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG142020-Auflenlicht_uebergreifend-All-weather light,not installed ,18
ENG141656-ENG133381-Auflenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar ¸ber Energiemanagement ,18
ENG141656-ENG133380-Auflenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar ¸ber Energiemanagement ,18
ENG141656-ENG142188-Auflenlicht_uebergreifend-bewusstes Standlicht,Aktive Begrenzung ,18
ENG141656-ENG115656-Auflenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Auflenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG116604-Auflenlicht_uebergreifend-Coming-home Einschaltereignis,Driver door ,18
ENG141656-ENG130581-Auflenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG126818-Auflenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG137034-Auflenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Auflenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Auflenlicht_uebergreifend-Fog lamp,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Auflenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Auflenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG142189-Auflenlicht_uebergreifend-HVLM_Ladezustandsanzeige,No ,18
ENG141656-ENG115858-Auflenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Auflenlicht_uebergreifend-LCM_blinker,false ,18
ENG141656-ENG141992-Auflenlicht_uebergreifend-LDS_mit_AFL,Yes ,18
ENG141656-ENG141991-Auflenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
ENG141656-ENG141990-Auflenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG141993-Auflenlicht_uebergreifend-LDS_mit_Standlichtstellung,Yes ,18
ENG141656-ENG115657-Auflenlicht_uebergreifend-Leaving-Home Verbausstatus,Enabled ,18
ENG141656-ENG141989-Auflenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG115862-Auflenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,18
ENG141656-ENG142034-Auflenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Auflenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115863-Auflenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Auflenlicht_uebergreifend-Menueeinstellung Cominghome,90 seconds ,18
ENG141656-ENG116607-Auflenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,90 seconds ,18
ENG141656-ENG116602-Auflenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung,active ,18
ENG141656-ENG116606-Auflenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP,active ,18
ENG141656-ENG115859-Auflenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
ENG141656-ENG126816-Auflenlicht_uebergreifend-Standlicht aus,active ,18
ENG141656-ENG115829-Auflenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
ENG141656-ENG133383-Auflenlicht_uebergreifend-Standlicht-Verf¸gbarkeit,24 s,18
ENG141656-ENG154174-Auflenlicht_uebergreifend-Turn signal lamp,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG126817-Auflenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte,not active ,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv,active ,8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung,installed ,8
ENG126651-ENG115658-Kennlinie Abdimmen-x0,0 ,22
ENG126651-ENG101574-Kennlinie Abdimmen-X1,200 ,22
ENG126651-ENG115664-Kennlinie Abdimmen-x10,2000 ,22
ENG126651-ENG99557-Kennlinie Abdimmen-X2,400 ,22
ENG126651-ENG102140-Kennlinie Abdimmen-X3,600 ,22
ENG126651-ENG102936-Kennlinie Abdimmen-X4,800 ,22
ENG126651-ENG103548-Kennlinie Abdimmen-X5,1000 ,22
ENG126651-ENG113992-Kennlinie Abdimmen-X6,1200 ,22
ENG126651-ENG115661-Kennlinie Abdimmen-x7,1400 ,22
ENG126651-ENG115662-Kennlinie Abdimmen-x8,1600 ,22
ENG126651-ENG115663-Kennlinie Abdimmen-x9,1800 ,22
ENG126651-ENG115659-Kennlinie Abdimmen-y0,100.0 ,22
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,99.0 ,22
ENG126651-ENG115668-Kennlinie Abdimmen-y10,0.0 ,22
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,95.0 ,22
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,80.0 ,22
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,40.0 ,22
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,20.0 ,22
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,10.0 ,22
ENG126651-ENG115665-Kennlinie Abdimmen-y7,5.0 ,22
ENG126651-ENG115666-Kennlinie Abdimmen-y8,2.0 ,22
ENG126651-ENG115667-Kennlinie Abdimmen-y9,0.5 ,22
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,56.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,56.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,56.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,56.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,51.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,47.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,33.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,26.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,3A ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,20 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake lamp ,16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,Daytime running lamps ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,39 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,10 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake lamp ,16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,Daytime running lamps ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Blinken links aktiv (beide Phasen) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Brake lamp ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Blinken rechts aktiv (beide Phasen) ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Brake lamp ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,90 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Brake lamp ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,37 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,09 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,34 - LED Bremsleuchten ,16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Brake lamp ,16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,28 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lamps ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Nebellicht links ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,28 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lamps ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Nebellicht rechts ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lamps ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lamps ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 64 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 64 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 64 06 18 80 00 00 00 00 00 00 20 1A 00 2A 08 0A 64 07 18 80 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 DA 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 64 18 00 80 1B 00 64 00 00 00 22 09 00 37 18 00 64 1B 00 80 00 00 00 00 00 00 25 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,25 20 00 3A 08 0A 64 18 14 64 00 00 00 00 00 00 25 10 00 39 08 09 64 18 14 64 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,CAN_Daempferregelung ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2550 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG141684-SFT271873-Slave_systems_identification-Wiper motor control module,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain/Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage door opener control head,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Anti-theft alarm system sensor,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sunroof control module,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Roof electronics control module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof shade control module,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Humidity sensor: interior,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Left head area heater,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Right head area heater,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Blower 1 for left front backrest,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Blower 1 for left front seat cushion,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Blower 1 for right front backrest,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Blower 1 for right front seat cushion,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_f¸r_P_plausibel,10.0 min,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe,active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,50 lx,10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,16.0 ,10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,25.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,30.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,Open ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schlieflen,active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schlieflen via Funkfernbedienung,active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schlieflen via Kessy,active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schlieflen via Schlieflzylinder,active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,active ,7
ENG141651-ENG115755-ZV allgemein-Notschlieflfunktion,active ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen,active ,8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art,Permanent ,8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV T¸rkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
ENG141652-ENG142043-ZV T¸rkonfiguration-HFT_Invertierung_Drehfallensignal,Inverted ,5
ENG141652-ENG142039-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite,not installed ,5
ENG141652-ENG142038-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite,not installed ,5
ENG141652-ENG142001-ZV T¸rkonfiguration-Schiebetuer_links,No ,5
ENG141652-ENG142002-ZV T¸rkonfiguration-Schiebetuer_rechts,No ,5
ENG141652-ENG142041-ZV T¸rkonfiguration-Schiebetueren_Crafter,not installed ,5
ENG141652-ENG142244-ZV T¸rkonfiguration-Schiebetuerschloss_direkt_BCM,Driver side ,5
ENG141652-ENG116631-ZV T¸rkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,5
ENG141652-ENG142000-ZV T¸rkonfiguration-Schlosstyp_NAR,No ,5
ENG141652-ENG141959-ZV T¸rkonfiguration-Viertuerer,Yes ,5
Elapsed Time: 01:47
