I just bought this car and did some work on it and found out the cluster is busted and has an internal problem. I'm trying to swap clusters in a Audi TT 8N 180 HP Quattro 8N0906018S. I sourced a cluster for a great price but found it was IMMO3 but my ECU is IMMO 2. I retrieved the login pin for the new cluster and can login but the VIN shows when I put it in not XXXXXXXXX. When I login then go to measuring block 50 it's not available I have the old cluster and I have the black tagged version of the clusters PIN 7 SKU. It appears to run but shows a low oil pressure light and the RPM and speedometer does not work. Was the ECU immo defeated or something messed with? What am I missing?
New cluster
Old Cluster
New Cluster
New cluster
Old Cluster
New Cluster
Tuesday,14,March,2023,16:35:56:26408
VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
VIN: License Plate:
Mileage: 296360km-184149mi Repair Order:
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Mileage: 296360km-184149miles
Address 01: Engine Labels: None
Part No: 8N0 906 018 S
Component: 1.8L R4/5VT G 0007
Coding: 06700
Shop #: WSC 01236
VCID: 41DF4903689FB88240D-513C
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.clb
Part No: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 01236
VCID: 3E2532FF1961C77A3DF-4AE0
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 2809F4A7EBE569CA673-2580
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
VCID: 77ABE7DB76DB36323E9-513C
00-10 - - - Intermittent
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 880 D
Component: KOMBI+WEGFAHRS. M73 D09
Coding: 07344
Shop #: WSC 93285
VCID: 36352ADF31510F3AE5F-4B00
00771 - Fuel Level Sensor (G)
29-00 - Short to Ground
00667 - Ambient Temperature Signal
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F1BEF7BBEABAE72169-4B00
Address 35: Centr. Locks Labels:. 8Nx-962-267.clb
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
VCID: 3FDB4FFB1E6BCE72369-4EEA
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 93285
VCID: 7CA1F8F74FFD156A53B-5118
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: 6597BD93DC77B4A29C5-5184
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8N0 035 186 A
Component: Radio D05
Coding: 00517
Shop #: WSC 01236
VCID: 2E0502BFC90137FAADF-4AA4
End----(Elapsed Time: 02:18, VBatt start/end: 11.9V/11.8V. VIgn 11.7V)-----
Tuesday,14,March,2023,16:07:54:26408
VIN: TRUZZZ8N421017095 License Plate:
Mileage: 174780km-108603mi Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
VIN: TRUZZZ8N421017095 Mileage: 174780km-108603miles
Coding: 06700
Shop #: WSC 01236
Coding: 18446
Shop #: WSC 01236
VCID: 3E2532FF1961C77A3DF-4B00
Coding: 00140
Shop #: WSC 01236
Coding: 10102
Shop #: WSC 01236
Part No: 8N2 920 980
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 07344
Shop #: WSC 00050
VCID: 74B1D0D767AD5D2A1BB-4B00
TRUZZZ8N421017095 AUZ5Z0AN220130
01128 - Immobilizer Pickup Coil (D2)
35-00 - -
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01176 - Key
07-00 - Signal too Low
49-00 - No Communications
01304 - Radio
37-00 - Faulty
Coding: 15884
Shop #: WSC 01236
Coding: 00001
Shop #: WSC 93285
Coding: 00010
Shop #: WSC 01236
Coding: 00517
Shop #: WSC 01236
End----------(Elapsed Time: 02:20, VBatt start/end: 12.3V/12.2V)-----------
