- Apr 24, 2022
- 54
- 13
- Boston, MA, USA
- C?ID=516305
I have been working on retrofitting various driver assistance systems into my 2015 Golf MK7 TDI Variant. I have the lane assistance camera fitted, although the wiring harness has no arrived yet, so I am continuing this retrofit as if I do not have a lane assistance camera. I have fitted new steering wheel buttons on the left side to include ACC and driver assistance, as shown below.
I have finally got a chance to mount and wire the radar, although there are a few issues. I'm not even quite sure what the errors are, aside from calibration. I will post the scan below, any help is appreciated.
Thursday,15,September,2022,18:11:37:55940
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: 3VWCA7AU3FM515369 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU3FM515369 Mileage: 171466km-106544miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 N HW: 04L 907 309
Component: R4 2.0l TDI H23 9459
Revision: 85H23--- CVN: B5ADD45238D3FF82B866C2AD
Coding: 011D0012034410081000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ECM20TDI01104L997022N 004002
ROD: EV_ECM20TDI01104L997022N.rod
VCID: 3B23395723E80893F21-806E
VINID: 0E69D34474650D67450450C624EBB8C5E7
Readiness: 0 0 0 1 1
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 05853104 Serial number: TFK01503163011 CVN: 0000EF4F
Shop #: WSC 00066 790 00218
ROD: EV_TCMDQ250021.rod
VCID: 2313E137BB585053DA1-8076
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51085000000641
Coding: 04FA6AA124210971007A020681CC2520562490004081A4B200630050C002
Shop #: WSC 00046 000 00000
VCID: 47CB55A76F205C73669-8012
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
[FCAN: Coding of ESP and TSK does not fit together]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:10
Revision: 00021000 Serial number: 0365009729
Coding: 030C0C
Shop #: WSC 12345 123 61029
VCID: 3A2D3C532CD2319BE97-806E
Part No SW: 5GM 907 426 HW: 5GM 907 426
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104202100000000000010000000
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 05579FAF15AC8E63D45-8050
Part No SW: 5Q0 937 087 S HW: 5Q0 937 087 S
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 8658061116000M
Coding: 0001184240C182F969E44000000403001808000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 4BC369977348B813421-801E
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150327 043 0581
Serial number: 150518181529
Subsystem 2 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555
Component: RLHSS 052 0122
Serial number: S7Y20M10D30H19M14S05
Coding: 00A8DD
Humidity sensor: interior:
565764 - LED Light Bar
B1664 31 [009] - No Signal
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:08
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 14.4 V
Outside temperature: 19.5 ∞C
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 5Q0 907 572 J
Coding: 35000001CFEFCF28949F81A461400000000000000099400000
VCID: 44D142AB5E16776B83B-8010
10 Faults Found:
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_ALIGNMENT_NOT_OK]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
Control Module temperature: 53 ∞C
Voltage terminal 15: 14.3 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
201218 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FAULT_CODING2SWAP_GRP_ACC_EXTS]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
201217 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FAULT_CODING2SWAP_GRP_ACC_TYPE]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
201219 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FAULT_CODING2SWAP_GRP_AWV_TYPE]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
201225 - No Enable Identifications Active
B2032 00 [009] - -
[FAULT_SWAP_NO_FAS_FUNCTION]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
1233 - Databus
[FAULT_TIMEOUT_HCA_01]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
1127 - Databus
[FAULT_TIMEOUT_PSD_04]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 126
Mileage: 171466 km
Date: 2022.09.15
Time: 18:09:07
Component: AirbagVW20 009 0825
Serial number: 003GCR01MTC-
Shop #: WSC 01383 790 50316
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150002Q8BT0I
Coding: 303138
Subsystem 2 - Part No SW: ----------- HW: 480 002 403 15
Serial number: 3570000000053D41831A
Subsystem 3 - Part No SW: ----------- HW: 480 002 403 15
Serial number: 35800000000870718318
Subsystem 4 - Part No SW: ----------- HW: 480 403 103 15
Serial number: 3510002C71941315012E
Subsystem 5 - Part No SW: ----------- HW: 480 403 103 15
Serial number: 3520002A31A87850C1E5
Subsystem 6 - Part No SW: ----------- HW: 480 402 603 15
Serial number: 3550002C3194131211EO
Subsystem 7 - Part No SW: ----------- HW: 480 402 603 15
Serial number: 3560002C31941313D38Y
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150407400739
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 045182AB1E96B76BC3B-8050
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA5121A2580CF0502087E001000000000000000
VCID: 6597BF2FF5EC6E63745-8030
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 01101410803011
Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
GVL: 01503C0000000600400C80008000C80000000000000000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72BDD473342289DBE17-8026
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 33180001093480031439
Coding: 2C0000
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0056486
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000072186002
Coding: 5D00000000000000
Shop #: WSC 00066 790 07030
ROD: EV_ELVMarquMQB.rod
VCID: 3431126B0EB6C7EB33B-8060
Component: TSG FS 020 0041
Serial number: 01071506050371
Coding: 003113205000040000000000
VCID: 43D341B75B187053BA1-8016
Serial number: 00000000000001068099
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
Component: TSG BFS 020 0041
Serial number: 141016060509XD
Coding: 003113205C00040000000000
VCID: 42DD44B34402795BB17-8016
Serial number: 00000000000001127988
Coding: 091000
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 02730200FF00000051220001001808001F0100D40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6C81CA0B16065F2B2BB-8038
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 252 8130
Serial number: VWZ6ZMW0235535
Component: OCULowMQBUS 007 0564
Coding: 02730202C2821A017F1E06000000
Shop #: WSC 00066 790 00322
ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:31, VBatt start/end: 14.4V/14.4V)-----------
