AFS retrofit problem
Deluxson24
C?ID=242930
Hi all,
I have just finished installing bi-xenons, and have managed to code the bi-xenons, getting rid of the bulb out symbol on the dash. I also fitted the AFS system too. I have managed to follow DIY's online, and fitted the sensor, and connected the can cable to the canbus pin 6 and 16, wired up to the fuse box and grounded it. The AFS system seems to be working only to level the headlights, because i can hear and see the headlight motors moving up and down. But when i use vagcom to code the afs module, it says "no response to the controller". I'm confused to why it keeps saying that message, and not letting me access the module and code it?
Autoscan from car in its current state, please?
Deluxson24
C?ID=242930
Hi Uwe,
This is an autoscan of my car in it's current state;
Sunday,28,June,2015,16:09:50:01483
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WVWZZZ1KZ9W511078   License Plate: DE09 HNJ
Mileage: 88480km-54978mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9W511078   Mileage: 88480km-54978miles
2E-Media Player 3 -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016     HW: 03C 906 016
   Component: MED17.5.5       G   3546
   Revision: L3H04---    Serial number:
   Coding: 0000072
   VCID: 5C9964F59F2E4CC1527-8009
Readiness: 0010 0001
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 163B400D092300FB680B02EB902100803000
   VCID: 74C92C55D7BEE4817A7-8021
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336     HW: 3C8 907 336
   Component: Climatic      120 0102
   Revision: 00004001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW32.rod
   VCID: 6AF5322D8D7A2271D0B-803F
   Part No SW: 1K0 937 087 E    HW: 1K0 937 087 E
   Component: BCM PQ35  H+  103 0575
   Revision: 00103 AG
   Coding: 46180A3A9025F1C044000080140008EC45550488536D8960E48408040000
   VCID: 334BEF499230A3B9A3D-8066
   Component: Wischer 13020  21  0501
   Coding: 009795
   Component: RLS 230209 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HO  H08 9001
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2D0960CE
   Coding: 00003136
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 77D31B59CEC88F995F5-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 33304044ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 22254145ZZZZZZZZZZZZ
   Serial number: 18471A3FZZZZZZZZZZZZ
   Serial number: 163E1827ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 032B7F894210D33973D-8056
   Part No SW: 5K0 920 960 F    HW: 5K0 920 960 F
   Component: KOMBI         H21 0029
   Coding: 470B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 3041E0456B2698A1DEF-8065
13639168 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 226
                    Mileage: 88486 km
                    Date: 2015.06.28
                    Time: 20:35:19
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 110209F2001148
   Coding: E9817F06000212000003
   VCID: 3753DB5946484F999F5-8062
                    Reset counter: 226
                    Mileage: 88486 km
                    Date: 2009.11.18
                    Time: 20:35:43
03272 - Control Module for Audio Interface
                    Reset counter: 226
                    Mileage: 88486 km
                    Date: 2009.11.18
                    Time: 20:35:47
   Component: IMMO          H21 0029
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
Address 2E: Media Player 3
   Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
   Component: Tuer-SG         008 2042
   Coding: 0000756
   VCID: 79D71D6130DC99E9291-802C
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 69     2501
   Revision: 00H15000
   VCID: 2C79F4358F0EFC41E27-8079
   Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
   Coding: 0000756
   VCID: 7AD5026D35DA92F120B-802F
Address 55: Headlight Range
Address 56: Radio
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
   VCID: 7BDB07693AE0ABF93BD-802E
End-------------------------(Elapsed Time: 01:31)--------------------------
Since neither your car's Gateway or VCDS can talk to your 55- Headlight Range control module, but the module sorta/kinda works (indicating it's getting power), you need to check your CAN bus wiring to that module.
maniken
Lithuania
C?ID=229989
i think problem is:you must connect afs module to external can,than active it in gateway
Deluxson24
C?ID=242930
Problem coding AFS control module
Hi guys, I cannot seem to be able to code my afs control module properly, I keep getting a few errors
Here is an autoscan of my car;
Monday,06,July,2015,14:58:10:01483
Mileage: 88680km-55103mi   Repair Order:
VIN: WVWZZZ1KZ9W511078   Mileage: 88680km-55103miles
55-Headlight Range -- Status: Malfunction 1010
   Coding: 0000072
   Revision: 00H35001
   Revision: 00004001
   Coding: 0000000000
   Revision: 00103 AG
   Coding: 009795
   Coding: 0330AD
   Coding: 00003136
   Coding: 0000034
   Coding: 470B00
          U1111 00 [008] - -
                    Fault Frequency: 98
                    Reset counter: 32
                    Mileage: 88486 km
                    Date: 2015.06.28
                    Time: 20:35:19
                    Fault Status: 00110100
                    Fault Frequency: 20
                    Reset counter: 31
                    Mileage: 88486 km
                    Date: 2009.11.18
                    Time: 20:35:43
                    Reset counter: 226
                    Mileage: 88486 km
                    Date: 2009.11.18
                    Time: 20:35:47
   Coding: 0000756
   Revision: 00H15000
   Coding: 0000756
   Coding: 1446940
   VCID: 3449EC55573EA481BA7-8061
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000020
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 247
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 247
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 247
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 01:33)--------------------------
Could you guys help me please, thanks a lot!
Deluxson24
C?ID=242930
Bump! Can someone please help
AIB Wolfgang
Hi
Coding 1446940 seems to be for US. Try 1442908. Then switch off ignition, lock the car, wait 15 minutes to let the CAN-BUS go to sleep ( please help me for the right term:) ),
then testing for right funktion and coding of subsystems AFS-Lst.-Modul r 00000020 > to each one > 00000022.
Hope this helps.
Deluxson24
C?ID=242930
Thanks for replying wolfgang! So i have to switch and lock the car before recoding the slave module? Also would i need to change the workshop number, importer number and equipment number? Because currently it's set to 0
AIB Wolfgang
change workshop number, importer number and equipment number? Because currently it's set to 0
Yes, better for further adaptions and codings. 12345 123 12345 as the manual suggested if you don't have a number of your own.
Deluxson24
C?ID=242930
Ohhh thanks, i shall give it a shot! I didn't get a manual with my afs kit, so i thought you would leave it as 0
Deluxson24
C?ID=242930
I have tried doing as you requested, but it still does not let me code the right hand side headlight, it keeps saying "request out of range" and if i remove a zero it says error 31. I don't know what's wrong, i have entered the security number and all, left the car to sleep for 20 minutes locked. What else could be wrong with the afs?
You can't code one headlight or the other. The output subsystems should be coded automatically by the AFS module when you code the main AFS module.
I wonder of the mismatch in software levels between the two output stages has anything to do with this?
Deluxson24
C?ID=242930
So would i need a new output stage for the right headlight? I got the output stages built on with headlight when i bought it from carsystems.
I don't know; at this point, I'm speculating.
AIB Wolfgang
Just one more try:)
I would disconnect the output stage > cycle ignition > read fault codes > ignition off >
connect output stage > ignition > one more coding > 55 with last code (overwrite it / save)
Ignition off > wait > test it :)
Yeah, we had a few examples of that in the mk6 xenon retrofit thread. I suspect the right side is the issue:
Coding: 00000022
Coding: 00000020
0004 would be a common SWL per the conversation nearby this post.
Deluxson24
C?ID=242930
I contacted my seller, and they are sending me a new slave module for the right headlight with sw 0004, so hopefully that should do the trick. I will let you guys know how it goes, hopefully by the end of the week!
Deluxson24
C?ID=242930
Hi guys i got my slave module for the right hand side headlight, and fitted in, it's the same software coding as the left handside headlight. I managed to code it, and also do basic settings. But i keep getting 3 faults; 01312 powertrain data bus - 004- no signal/communication- intermittent, 02233 - left headlight power stage output stage (j667) 004 - no signal/communication - intermittent and also 02234 - right headlight power stage output stage (j668) 004 - no signal/communication - intermittent. Due to these fault codes the headlight stays down, but when i clear the faults the headlights work perfectly fine, going up, down, left and right. But when i restart the car after 30 seconds, the fault codes come back up and the headlights do not work as it should be.
golfi_vend
Tartu, Estonia
C?ID=195131
You problably have terminal 15 and 30 mixed up in progress of install.
